root/radiance/ray/src/px/macbethcal.c
Revision: 2.16
Committed: Fri Jul 16 16:12:20 1999 UTC (24 years, 11 months ago) by gwlarson
Changes since 2.15: +54 -3 lines
added -P option for direct display and picking of corners using ximage
1 /* Copyright (c) 1999 Regents of the University of California */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Calibrate a scanned MacBeth Color Checker Chart
9 *
10 * Produce a .cal file suitable for use with pcomb,
11 * or .cwp file suitable for use with pcwarp.
12 *
13 * Warping code depends on conformance of COLOR and W3VEC types.
14 */
15
16 #include <stdio.h>
17 #include <math.h>
18 #ifdef MSDOS
19 #include <fcntl.h>
20 #endif
21 #include "color.h"
22 #include "resolu.h"
23 #include "pmap.h"
24 #include "warp3d.h"
25
26 /* MacBeth colors */
27 #define DarkSkin 0
28 #define LightSkin 1
29 #define BlueSky 2
30 #define Foliage 3
31 #define BlueFlower 4
32 #define BluishGreen 5
33 #define Orange 6
34 #define PurplishBlue 7
35 #define ModerateRed 8
36 #define Purple 9
37 #define YellowGreen 10
38 #define OrangeYellow 11
39 #define Blue 12
40 #define Green 13
41 #define Red 14
42 #define Yellow 15
43 #define Magenta 16
44 #define Cyan 17
45 #define White 18
46 #define Neutral8 19
47 #define Neutral65 20
48 #define Neutral5 21
49 #define Neutral35 22
50 #define Black 23
51 /* computed from 5nm spectral measurements */
52 /* CIE 1931 2 degree obs, equal-energy white */
53 float mbxyY[24][3] = {
54 {0.462, 0.3769, 0.0932961}, /* DarkSkin */
55 {0.4108, 0.3542, 0.410348}, /* LightSkin */
56 {0.2626, 0.267, 0.181554}, /* BlueSky */
57 {0.36, 0.4689, 0.108447}, /* Foliage */
58 {0.2977, 0.2602, 0.248407}, /* BlueFlower */
59 {0.2719, 0.3485, 0.401156}, /* BluishGreen */
60 {0.52, 0.4197, 0.357899}, /* Orange */
61 {0.229, 0.1866, 0.103911}, /* PurplishBlue */
62 {0.4909, 0.3262, 0.242615}, /* ModerateRed */
63 {0.3361, 0.2249, 0.0600102}, /* Purple */
64 {0.3855, 0.4874, 0.42963}, /* YellowGreen */
65 {0.4853, 0.4457, 0.476343}, /* OrangeYellow */
66 {0.2026, 0.1369, 0.0529249}, /* Blue */
67 {0.3007, 0.4822, 0.221226}, /* Green */
68 {0.5805, 0.3238, 0.162167}, /* Red */
69 {0.4617, 0.472, 0.64909}, /* Yellow */
70 {0.4178, 0.2625, 0.233662}, /* Magenta */
71 {0.2038, 0.2508, 0.167275}, /* Cyan */
72 {0.3358, 0.337, 0.916877}, /* White */
73 {0.3338, 0.3348, 0.604678}, /* Neutral.8 */
74 {0.3333, 0.3349, 0.364566}, /* Neutral.65 */
75 {0.3353, 0.3359, 0.200238}, /* Neutral.5 */
76 {0.3363, 0.336, 0.0878721}, /* Neutral.35 */
77 {0.3346, 0.3349, 0.0308383} /* Black */
78 };
79
80 COLOR mbRGB[24]; /* MacBeth RGB values */
81
82 #define NMBNEU 6 /* Number of MacBeth neutral colors */
83 short mbneu[NMBNEU] = {Black,Neutral35,Neutral5,Neutral65,Neutral8,White};
84
85 #define NEUFLGS (1L<<White|1L<<Neutral8|1L<<Neutral65| \
86 1L<<Neutral5|1L<<Neutral35|1L<<Black)
87
88 #define SATFLGS (1L<<Red|1L<<Green|1L<<Blue|1L<<Magenta|1L<<Yellow| \
89 1L<<Cyan|1L<<Orange|1L<<Purple|1L<<PurplishBlue| \
90 1L<<YellowGreen|1<<OrangeYellow|1L<<BlueFlower)
91
92 #define UNSFLGS (1L<<DarkSkin|1L<<LightSkin|1L<<BlueSky|1L<<Foliage| \
93 1L<<BluishGreen|1L<<ModerateRed)
94
95 #define REQFLGS NEUFLGS /* need these colors */
96 #define MODFLGS (NEUFLGS|UNSFLGS) /* should be in gamut */
97
98 #define RG_BORD 0 /* patch border */
99 #define RG_CENT 01 /* central region of patch */
100 #define RG_ORIG 02 /* original color region */
101 #define RG_CORR 04 /* corrected color region */
102
103 #ifndef DISPCOM
104 #define DISPCOM "ximage -op %s"
105 #endif
106
107 int scanning = 1; /* scanned input (or recorded output)? */
108 double irrad = 1.0; /* irradiance multiplication factor */
109 int rawmap = 0; /* put out raw color mapping? */
110
111 int xmax, ymax; /* input image dimensions */
112 int bounds[4][2]; /* image coordinates of chart corners */
113 double imgxfm[3][3]; /* coordinate transformation matrix */
114
115 COLOR inpRGB[24]; /* measured or scanned input colors */
116 long inpflags = 0; /* flags of which colors were input */
117 long gmtflags = 0; /* flags of out-of-gamut colors */
118
119 COLOR bramp[NMBNEU][2]; /* brightness ramp (per primary) */
120 COLORMAT solmat; /* color mapping matrix */
121 COLOR colmin, colmax; /* gamut limits */
122
123 WARP3D *wcor = NULL; /* color space warp */
124
125 FILE *debugfp = NULL; /* debug output picture */
126 char *progname;
127
128 extern char *malloc();
129
130
131 main(argc, argv)
132 int argc;
133 char **argv;
134 {
135 int i;
136
137 progname = argv[0];
138 for (i = 1; i < argc && argv[i][0] == '-'; i++)
139 switch (argv[i][1]) {
140 case 'd': /* debug output */
141 i++;
142 if (badarg(argc-i, argv+i, "s"))
143 goto userr;
144 if ((debugfp = fopen(argv[i], "w")) == NULL) {
145 perror(argv[i]);
146 exit(1);
147 }
148 #ifdef MSDOS
149 setmode(fileno(debugfp), O_BINARY);
150 #endif
151 newheader("RADIANCE", debugfp); /* start */
152 printargs(argc, argv, debugfp); /* header */
153 break;
154 case 'p': /* picture position */
155 if (badarg(argc-i-1, argv+i+1, "iiiiiiii"))
156 goto userr;
157 bounds[0][0] = atoi(argv[++i]);
158 bounds[0][1] = atoi(argv[++i]);
159 bounds[1][0] = atoi(argv[++i]);
160 bounds[1][1] = atoi(argv[++i]);
161 bounds[2][0] = atoi(argv[++i]);
162 bounds[2][1] = atoi(argv[++i]);
163 bounds[3][0] = atoi(argv[++i]);
164 bounds[3][1] = atoi(argv[++i]);
165 scanning = 2;
166 break;
167 case 'P': /* pick position */
168 scanning = 3;
169 break;
170 case 'i': /* irradiance factor */
171 i++;
172 if (badarg(argc-i, argv+i, "f"))
173 goto userr;
174 irrad = atof(argv[i]);
175 break;
176 case 'm': /* raw map output */
177 rawmap = 1;
178 break;
179 case 'c': /* color input */
180 scanning = 0;
181 break;
182 default:
183 goto userr;
184 }
185 /* open files */
186 if (i < argc && freopen(argv[i], "r", stdin) == NULL) {
187 perror(argv[i]);
188 exit(1);
189 }
190 if (i+1 < argc && freopen(argv[i+1], "w", stdout) == NULL) {
191 perror(argv[i+1]);
192 exit(1);
193 }
194 if (scanning) { /* load input picture header */
195 #ifdef MSDOS
196 setmode(fileno(stdin), O_BINARY);
197 #endif
198 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
199 fgetresolu(&xmax, &ymax, stdin) < 0) {
200 fprintf(stderr, "%s: bad input picture\n", progname);
201 exit(1);
202 }
203 if (scanning == 3) {
204 if (i >= argc)
205 goto userr;
206 pickchartpos(argv[i]);
207 scanning = 2;
208 }
209 } else { /* else set default xmax and ymax */
210 xmax = 512;
211 ymax = 2*512/3;
212 }
213 if (scanning != 2) { /* use default boundaries */
214 bounds[0][0] = bounds[2][0] = .029*xmax + .5;
215 bounds[0][1] = bounds[1][1] = .956*ymax + .5;
216 bounds[1][0] = bounds[3][0] = .971*xmax + .5;
217 bounds[2][1] = bounds[3][1] = .056*ymax + .5;
218 }
219 init(); /* initialize */
220 if (scanning) /* get picture colors */
221 getpicture();
222 else
223 getcolors();
224 compute(); /* compute color mapping */
225 if (rawmap) { /* print out raw correspondence */
226 register int j;
227
228 printf("# Color correspondence produced by:\n#\t\t");
229 printargs(argc, argv, stdout);
230 printf("#\tUsage: pcwarp %s uncorrected.pic > corrected.pic\n",
231 i+1 < argc ? argv[i+1] : "{this_file}");
232 printf("#\t Or: pcond [options] -m %s orig.pic > output.pic\n",
233 i+1 < argc ? argv[i+1] : "{this_file}");
234 for (j = 0; j < 24; j++)
235 printf("%f %f %f %f %f %f\n",
236 colval(inpRGB[j],RED), colval(inpRGB[j],GRN),
237 colval(inpRGB[j],BLU), colval(mbRGB[j],RED),
238 colval(mbRGB[j],GRN), colval(mbRGB[j],BLU));
239 if (scanning && debugfp != NULL)
240 cwarp(); /* color warp for debugging */
241 } else { /* print color mapping */
242 /* print header */
243 printf("{\n\tColor correction file computed by:\n\t\t");
244 printargs(argc, argv, stdout);
245 printf("\n\tUsage: pcomb -f %s uncorrected.pic > corrected.pic\n",
246 i+1 < argc ? argv[i+1] : "{this_file}");
247 if (!scanning)
248 printf("\t Or: pcond [options] -f %s orig.pic > output.pic\n",
249 i+1 < argc ? argv[i+1] : "{this_file}");
250 printf("}\n");
251 putmapping(); /* put out color mapping */
252 }
253 if (debugfp != NULL) /* put out debug picture */
254 if (scanning)
255 picdebug();
256 else
257 clrdebug();
258 exit(0);
259 userr:
260 fprintf(stderr,
261 "Usage: %s [-d dbg.pic][-P | -p xul yul xur yur xll yll xlr ylr][-i irrad][-m] input.pic [output.{cal|cwp}]\n",
262 progname);
263 fprintf(stderr, " or: %s [-d dbg.pic][-i irrad][-m] -c [xyY.dat [output.{cal|cwp}]]\n",
264 progname);
265 exit(1);
266 }
267
268
269 init() /* initialize */
270 {
271 double quad[4][2];
272 register int i;
273 /* make coordinate transformation */
274 quad[0][0] = bounds[0][0];
275 quad[0][1] = bounds[0][1];
276 quad[1][0] = bounds[1][0];
277 quad[1][1] = bounds[1][1];
278 quad[2][0] = bounds[3][0];
279 quad[2][1] = bounds[3][1];
280 quad[3][0] = bounds[2][0];
281 quad[3][1] = bounds[2][1];
282
283 if (pmap_quad_rect(0., 0., 6., 4., quad, imgxfm) == PMAP_BAD) {
284 fprintf(stderr, "%s: bad chart boundaries\n", progname);
285 exit(1);
286 }
287 /* map MacBeth colors to RGB space */
288 for (i = 0; i < 24; i++) {
289 xyY2RGB(mbRGB[i], mbxyY[i]);
290 scalecolor(mbRGB[i], irrad);
291 }
292 }
293
294
295 int
296 chartndx(x, y, np) /* find color number for position */
297 int x, y;
298 int *np;
299 {
300 double ipos[3], cpos[3];
301 int ix, iy;
302 double fx, fy;
303
304 ipos[0] = x;
305 ipos[1] = y;
306 ipos[2] = 1;
307 mx3d_transform(ipos, imgxfm, cpos);
308 cpos[0] /= cpos[2];
309 cpos[1] /= cpos[2];
310 if (cpos[0] < 0. || cpos[0] >= 6. || cpos[1] < 0. || cpos[1] >= 4.)
311 return(RG_BORD);
312 ix = cpos[0];
313 iy = cpos[1];
314 fx = cpos[0] - ix;
315 fy = cpos[1] - iy;
316 *np = iy*6 + ix;
317 if (fx >= 0.35 && fx < 0.65 && fy >= 0.35 && fy < 0.65)
318 return(RG_CENT);
319 if (fx < 0.05 || fx >= 0.95 || fy < 0.05 || fy >= 0.95)
320 return(RG_BORD);
321 if (fx >= 0.5) /* right side is corrected */
322 return(RG_CORR);
323 return(RG_ORIG); /* left side is original */
324 }
325
326
327 getpicture() /* load in picture colors */
328 {
329 COLR *scanln;
330 COLOR pval;
331 int ccount[24];
332 double d;
333 int y, i;
334 register int x;
335
336 scanln = (COLR *)malloc(xmax*sizeof(COLR));
337 if (scanln == NULL) {
338 perror(progname);
339 exit(1);
340 }
341 for (i = 0; i < 24; i++) {
342 setcolor(inpRGB[i], 0., 0., 0.);
343 ccount[i] = 0;
344 }
345 for (y = ymax-1; y >= 0; y--) {
346 if (freadcolrs(scanln, xmax, stdin) < 0) {
347 fprintf(stderr, "%s: error reading input picture\n",
348 progname);
349 exit(1);
350 }
351 for (x = 0; x < xmax; x++)
352 if (chartndx(x, y, &i) == RG_CENT) {
353 colr_color(pval, scanln[x]);
354 addcolor(inpRGB[i], pval);
355 ccount[i]++;
356 }
357 }
358 for (i = 0; i < 24; i++) { /* compute averages */
359 if (ccount[i] == 0)
360 continue;
361 d = 1./ccount[i];
362 scalecolor(inpRGB[i], d);
363 inpflags |= 1L<<i;
364 }
365 free((char *)scanln);
366 }
367
368
369 getcolors() /* get xyY colors from standard input */
370 {
371 int gotwhite = 0;
372 COLOR whiteclr;
373 int n;
374 float xyYin[3];
375
376 while (fgetval(stdin, 'i', &n) == 1) { /* read colors */
377 if (n < 0 | n > 24 ||
378 fgetval(stdin, 'f', &xyYin[0]) != 1 ||
379 fgetval(stdin, 'f', &xyYin[1]) != 1 ||
380 fgetval(stdin, 'f', &xyYin[2]) != 1 ||
381 xyYin[0] < 0. | xyYin[1] < 0. ||
382 xyYin[0] + xyYin[1] > 1.) {
383 fprintf(stderr, "%s: bad color input data\n",
384 progname);
385 exit(1);
386 }
387 if (n == 0) { /* calibration white */
388 xyY2RGB(whiteclr, xyYin);
389 gotwhite++;
390 } else { /* standard color */
391 n--;
392 xyY2RGB(inpRGB[n], xyYin);
393 inpflags |= 1L<<n;
394 }
395 }
396 /* normalize colors */
397 if (!gotwhite) {
398 if (!(inpflags & 1L<<White)) {
399 fprintf(stderr, "%s: missing input for White\n",
400 progname);
401 exit(1);
402 }
403 setcolor(whiteclr,
404 colval(inpRGB[White],RED)/colval(mbRGB[White],RED),
405 colval(inpRGB[White],GRN)/colval(mbRGB[White],GRN),
406 colval(inpRGB[White],BLU)/colval(mbRGB[White],BLU));
407 }
408 for (n = 0; n < 24; n++)
409 if (inpflags & 1L<<n)
410 setcolor(inpRGB[n],
411 colval(inpRGB[n],RED)/colval(whiteclr,RED),
412 colval(inpRGB[n],GRN)/colval(whiteclr,GRN),
413 colval(inpRGB[n],BLU)/colval(whiteclr,BLU));
414 }
415
416
417 bresp(y, x) /* piecewise linear interpolation of primaries */
418 COLOR y, x;
419 {
420 register int i, n;
421
422 for (i = 0; i < 3; i++) {
423 for (n = 0; n < NMBNEU-2; n++)
424 if (colval(x,i) < colval(bramp[n+1][0],i))
425 break;
426 colval(y,i) = ((colval(bramp[n+1][0],i) - colval(x,i)) *
427 colval(bramp[n][1],i) +
428 (colval(x,i) - colval(bramp[n][0],i)) *
429 colval(bramp[n+1][1],i)) /
430 (colval(bramp[n+1][0],i) - colval(bramp[n][0],i));
431 }
432 }
433
434
435 compute() /* compute color mapping */
436 {
437 COLOR clrin[24], clrout[24];
438 long cflags;
439 COLOR ctmp;
440 register int i, n;
441 /* did we get what we need? */
442 if ((inpflags & REQFLGS) != REQFLGS) {
443 fprintf(stderr, "%s: missing required input colors\n",
444 progname);
445 exit(1);
446 }
447 /* compute piecewise luminance curve */
448 for (i = 0; i < NMBNEU; i++) {
449 copycolor(bramp[i][0], inpRGB[mbneu[i]]);
450 copycolor(bramp[i][1], mbRGB[mbneu[i]]);
451 }
452 /* compute color space gamut */
453 if (scanning) {
454 copycolor(colmin, cblack);
455 copycolor(colmax, cwhite);
456 scalecolor(colmax, irrad);
457 } else
458 for (i = 0; i < 3; i++) {
459 colval(colmin,i) = colval(bramp[0][0],i) -
460 colval(bramp[0][1],i) *
461 (colval(bramp[1][0],i)-colval(bramp[0][0],i)) /
462 (colval(bramp[1][1],i)-colval(bramp[1][0],i));
463 colval(colmax,i) = colval(bramp[NMBNEU-2][0],i) +
464 (1.-colval(bramp[NMBNEU-2][1],i)) *
465 (colval(bramp[NMBNEU-1][0],i) -
466 colval(bramp[NMBNEU-2][0],i)) /
467 (colval(bramp[NMBNEU-1][1],i) -
468 colval(bramp[NMBNEU-2][1],i));
469 }
470 /* compute color mapping */
471 do {
472 cflags = inpflags & ~gmtflags;
473 n = 0; /* compute transform matrix */
474 for (i = 0; i < 24; i++)
475 if (cflags & 1L<<i) {
476 bresp(clrin[n], inpRGB[i]);
477 copycolor(clrout[n], mbRGB[i]);
478 n++;
479 }
480 compsoln(clrin, clrout, n);
481 if (irrad > 0.99 && irrad < 1.01) /* check gamut */
482 for (i = 0; i < 24; i++)
483 if (cflags & 1L<<i && cvtcolor(ctmp, mbRGB[i]))
484 gmtflags |= 1L<<i;
485 } while (cflags & gmtflags);
486 if (gmtflags & MODFLGS)
487 fprintf(stderr,
488 "%s: warning - some moderate colors are out of gamut\n",
489 progname);
490 }
491
492
493 putmapping() /* put out color mapping */
494 {
495 static char cchar[3] = {'r', 'g', 'b'};
496 register int i, j;
497 /* print brightness mapping */
498 for (j = 0; j < 3; j++) {
499 printf("%cxa(i) : select(i", cchar[j]);
500 for (i = 0; i < NMBNEU; i++)
501 printf(",%g", colval(bramp[i][0],j));
502 printf(");\n");
503 printf("%cya(i) : select(i", cchar[j]);
504 for (i = 0; i < NMBNEU; i++)
505 printf(",%g", colval(bramp[i][1],j));
506 printf(");\n");
507 printf("%cfi(n) = if(n-%g, %d, if(%cxa(n+1)-%c, n, %cfi(n+1)));\n",
508 cchar[j], NMBNEU-1.5, NMBNEU-1, cchar[j],
509 cchar[j], cchar[j]);
510 printf("%cndx = %cfi(1);\n", cchar[j], cchar[j]);
511 printf("%c%c = ((%cxa(%cndx+1)-%c)*%cya(%cndx) + ",
512 cchar[j], scanning?'n':'o', cchar[j],
513 cchar[j], cchar[j], cchar[j], cchar[j]);
514 printf("(%c-%cxa(%cndx))*%cya(%cndx+1)) /\n",
515 cchar[j], cchar[j], cchar[j],
516 cchar[j], cchar[j]);
517 printf("\t\t(%cxa(%cndx+1) - %cxa(%cndx)) ;\n",
518 cchar[j], cchar[j], cchar[j], cchar[j]);
519 }
520 /* print color mapping */
521 if (scanning) {
522 printf("r = ri(1); g = gi(1); b = bi(1);\n");
523 printf("ro = %g*rn + %g*gn + %g*bn ;\n",
524 solmat[0][0], solmat[0][1], solmat[0][2]);
525 printf("go = %g*rn + %g*gn + %g*bn ;\n",
526 solmat[1][0], solmat[1][1], solmat[1][2]);
527 printf("bo = %g*rn + %g*gn + %g*bn ;\n",
528 solmat[2][0], solmat[2][1], solmat[2][2]);
529 } else {
530 printf("r1 = ri(1); g1 = gi(1); b1 = bi(1);\n");
531 printf("r = %g*r1 + %g*g1 + %g*b1 ;\n",
532 solmat[0][0], solmat[0][1], solmat[0][2]);
533 printf("g = %g*r1 + %g*g1 + %g*b1 ;\n",
534 solmat[1][0], solmat[1][1], solmat[1][2]);
535 printf("b = %g*r1 + %g*g1 + %g*b1 ;\n",
536 solmat[2][0], solmat[2][1], solmat[2][2]);
537 }
538 }
539
540
541 compsoln(cin, cout, n) /* solve 3xN system using least-squares */
542 COLOR cin[], cout[];
543 int n;
544 {
545 extern double mx3d_adjoint(), fabs();
546 double mat[3][3], invmat[3][3];
547 double det;
548 double colv[3], rowv[3];
549 register int i, j, k;
550
551 if (n < 3) {
552 fprintf(stderr, "%s: too few colors to match!\n", progname);
553 exit(1);
554 }
555 if (n == 3)
556 for (i = 0; i < 3; i++)
557 for (j = 0; j < 3; j++)
558 mat[i][j] = colval(cin[j],i);
559 else { /* compute A^t A */
560 for (i = 0; i < 3; i++)
561 for (j = i; j < 3; j++) {
562 mat[i][j] = 0.;
563 for (k = 0; k < n; k++)
564 mat[i][j] += colval(cin[k],i) *
565 colval(cin[k],j);
566 }
567 for (i = 1; i < 3; i++) /* using symmetry */
568 for (j = 0; j < i; j++)
569 mat[i][j] = mat[j][i];
570 }
571 det = mx3d_adjoint(mat, invmat);
572 if (fabs(det) < 1e-4) {
573 fprintf(stderr, "%s: cannot compute color mapping\n",
574 progname);
575 solmat[0][0] = solmat[1][1] = solmat[2][2] = 1.;
576 solmat[0][1] = solmat[0][2] = solmat[1][0] =
577 solmat[1][2] = solmat[2][0] = solmat[2][1] = 0.;
578 return;
579 }
580 for (i = 0; i < 3; i++)
581 for (j = 0; j < 3; j++)
582 invmat[i][j] /= det;
583 for (i = 0; i < 3; i++) {
584 if (n == 3)
585 for (j = 0; j < 3; j++)
586 colv[j] = colval(cout[j],i);
587 else
588 for (j = 0; j < 3; j++) {
589 colv[j] = 0.;
590 for (k = 0; k < n; k++)
591 colv[j] += colval(cout[k],i) *
592 colval(cin[k],j);
593 }
594 mx3d_transform(colv, invmat, rowv);
595 for (j = 0; j < 3; j++)
596 solmat[i][j] = rowv[j];
597 }
598 }
599
600
601 cwarp() /* compute color warp map */
602 {
603 register int i;
604
605 if ((wcor = new3dw(W3EXACT)) == NULL)
606 goto memerr;
607 for (i = 0; i < 24; i++)
608 if (!add3dpt(wcor, inpRGB[i], mbRGB[i]))
609 goto memerr;
610 return;
611 memerr:
612 perror(progname);
613 exit(1);
614 }
615
616
617 int
618 cvtcolor(cout, cin) /* convert color according to our mapping */
619 COLOR cout, cin;
620 {
621 COLOR ctmp;
622 int clipped;
623
624 if (wcor != NULL) {
625 clipped = warp3d(cout, cin, wcor);
626 clipped |= clipgamut(cout,bright(cout),CGAMUT,colmin,colmax);
627 } else if (scanning) {
628 bresp(ctmp, cin);
629 clipped = cresp(cout, ctmp);
630 } else {
631 clipped = cresp(ctmp, cin);
632 bresp(cout, ctmp);
633 }
634 return(clipped);
635 }
636
637
638 int
639 cresp(cout, cin) /* transform color according to matrix */
640 COLOR cout, cin;
641 {
642 colortrans(cout, solmat, cin);
643 return(clipgamut(cout, bright(cout), CGAMUT, colmin, colmax));
644 }
645
646
647 xyY2RGB(rgbout, xyYin) /* convert xyY to RGB */
648 COLOR rgbout;
649 register float xyYin[3];
650 {
651 COLOR ctmp;
652 double d;
653
654 d = xyYin[2] / xyYin[1];
655 ctmp[0] = xyYin[0] * d;
656 ctmp[1] = xyYin[2];
657 ctmp[2] = (1. - xyYin[0] - xyYin[1]) * d;
658 /* allow negative values */
659 colortrans(rgbout, xyz2rgbmat, ctmp);
660 }
661
662
663 picdebug() /* put out debugging picture */
664 {
665 static COLOR blkcol = BLKCOLOR;
666 COLOR *scan;
667 int y, i;
668 register int x, rg;
669
670 if (fseek(stdin, 0L, 0) == EOF) {
671 fprintf(stderr, "%s: cannot seek on input picture\n", progname);
672 exit(1);
673 }
674 getheader(stdin, NULL, NULL); /* skip input header */
675 fgetresolu(&xmax, &ymax, stdin);
676 /* allocate scanline */
677 scan = (COLOR *)malloc(xmax*sizeof(COLOR));
678 if (scan == NULL) {
679 perror(progname);
680 exit(1);
681 }
682 /* finish debug header */
683 fputformat(COLRFMT, debugfp);
684 putc('\n', debugfp);
685 fprtresolu(xmax, ymax, debugfp);
686 /* write debug picture */
687 for (y = ymax-1; y >= 0; y--) {
688 if (freadscan(scan, xmax, stdin) < 0) {
689 fprintf(stderr, "%s: error rereading input picture\n",
690 progname);
691 exit(1);
692 }
693 for (x = 0; x < xmax; x++) {
694 rg = chartndx(x, y, &i);
695 if (rg == RG_CENT) {
696 if (!(1L<<i & gmtflags) || (x+y)&07) {
697 copycolor(scan[x], mbRGB[i]);
698 clipgamut(scan[x], bright(scan[x]),
699 CGAMUT, colmin, colmax);
700 } else
701 copycolor(scan[x], blkcol);
702 } else if (rg == RG_CORR)
703 cvtcolor(scan[x], scan[x]);
704 else if (rg != RG_ORIG)
705 copycolor(scan[x], blkcol);
706 }
707 if (fwritescan(scan, xmax, debugfp) < 0) {
708 fprintf(stderr, "%s: error writing debugging picture\n",
709 progname);
710 exit(1);
711 }
712 }
713 /* clean up */
714 fclose(debugfp);
715 free((char *)scan);
716 }
717
718
719 clrdebug() /* put out debug picture from color input */
720 {
721 static COLR blkclr = BLKCOLR;
722 COLR mbclr[24], cvclr[24], orclr[24];
723 COLR *scan;
724 COLOR ctmp, ct2;
725 int y, i;
726 register int x, rg;
727 /* convert colors */
728 for (i = 0; i < 24; i++) {
729 copycolor(ctmp, mbRGB[i]);
730 clipgamut(ctmp, bright(ctmp), CGAMUT, cblack, cwhite);
731 setcolr(mbclr[i], colval(ctmp,RED),
732 colval(ctmp,GRN), colval(ctmp,BLU));
733 if (inpflags & 1L<<i) {
734 copycolor(ctmp, inpRGB[i]);
735 clipgamut(ctmp, bright(ctmp), CGAMUT, cblack, cwhite);
736 setcolr(orclr[i], colval(ctmp,RED),
737 colval(ctmp,GRN), colval(ctmp,BLU));
738 if (rawmap)
739 copycolr(cvclr[i], mbclr[i]);
740 else {
741 bresp(ctmp, inpRGB[i]);
742 colortrans(ct2, solmat, ctmp);
743 clipgamut(ct2, bright(ct2), CGAMUT,
744 cblack, cwhite);
745 setcolr(cvclr[i], colval(ct2,RED),
746 colval(ct2,GRN),
747 colval(ct2,BLU));
748 }
749 }
750 }
751 /* allocate scanline */
752 scan = (COLR *)malloc(xmax*sizeof(COLR));
753 if (scan == NULL) {
754 perror(progname);
755 exit(1);
756 }
757 /* finish debug header */
758 fputformat(COLRFMT, debugfp);
759 putc('\n', debugfp);
760 fprtresolu(xmax, ymax, debugfp);
761 /* write debug picture */
762 for (y = ymax-1; y >= 0; y--) {
763 for (x = 0; x < xmax; x++) {
764 rg = chartndx(x, y, &i);
765 if (rg == RG_CENT) {
766 if (!(1L<<i & gmtflags) || (x+y)&07)
767 copycolr(scan[x], mbclr[i]);
768 else
769 copycolr(scan[x], blkclr);
770 } else if (rg == RG_BORD || !(1L<<i & inpflags))
771 copycolr(scan[x], blkclr);
772 else if (rg == RG_ORIG)
773 copycolr(scan[x], orclr[i]);
774 else /* rg == RG_CORR */
775 copycolr(scan[x], cvclr[i]);
776 }
777 if (fwritecolrs(scan, xmax, debugfp) < 0) {
778 fprintf(stderr, "%s: error writing debugging picture\n",
779 progname);
780 exit(1);
781 }
782 }
783 /* clean up */
784 fclose(debugfp);
785 free((char *)scan);
786 }
787
788
789 getpos(name, bnds, fp) /* get boundary position */
790 char *name;
791 int bnds[2];
792 FILE *fp;
793 {
794 char buf[64];
795
796 fprintf(stderr, "\tSelect corner: %s\n", name);
797 if (fgets(buf, sizeof(buf), fp) == NULL ||
798 sscanf(buf, "%d %d", &bnds[0], &bnds[1]) != 2) {
799 fprintf(stderr, "%s: read error from display process\n",
800 progname);
801 exit(1);
802 }
803 }
804
805
806 pickchartpos(pfn) /* display picture and pick chart location */
807 char *pfn;
808 {
809 char combuf[512];
810 FILE *pfp;
811
812 sprintf(combuf, DISPCOM, pfn);
813 if ((pfp = popen(combuf, "r")) == NULL) {
814 perror(combuf);
815 exit(1);
816 }
817 fputs("Use middle mouse button to select chart corners:\n", stderr);
818 getpos("upper left (dark skin)", bounds[0], pfp);
819 getpos("upper right (bluish green)", bounds[1], pfp);
820 getpos("lower left (white)", bounds[2], pfp);
821 getpos("lower right (black)", bounds[3], pfp);
822 fputs("Got it -- quit display program.\n", stderr);
823 pclose(pfp);
824 }
