root/radiance/ray/src/px/macbethcal.c
Revision: 2.8
Committed: Mon Oct 23 10:19:40 1995 UTC (29 years, 7 months ago) by greg
Changes since 2.7: +77 -43 lines
added automatic detection of out-of-gamut colors
1 /* Copyright (c) 1995 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Calibrate a scanned MacBeth Color Checker Chart
9 *
10 * Produce a .cal file suitable for use with pcomb.
11 */
12
13 #include <stdio.h>
14 #ifdef MSDOS
15 #include <fcntl.h>
16 #endif
17 #include "color.h"
18 #include "resolu.h"
19 #include "pmap.h"
20
21 /* MacBeth colors */
22 #define DarkSkin 0
23 #define LightSkin 1
24 #define BlueSky 2
25 #define Foliage 3
26 #define BlueFlower 4
27 #define BluishGreen 5
28 #define Orange 6
29 #define PurplishBlue 7
30 #define ModerateRed 8
31 #define Purple 9
32 #define YellowGreen 10
33 #define OrangeYellow 11
34 #define Blue 12
35 #define Green 13
36 #define Red 14
37 #define Yellow 15
38 #define Magenta 16
39 #define Cyan 17
40 #define White 18
41 #define Neutral8 19
42 #define Neutral65 20
43 #define Neutral5 21
44 #define Neutral35 22
45 #define Black 23
46 /* computed from 5nm spectral measurements */
47 /* CIE 1931 2 degree obs, equal-energy white */
48 float mbxyY[24][3] = {
49 {0.462, 0.3769, 0.0932961}, /* DarkSkin */
50 {0.4108, 0.3542, 0.410348}, /* LightSkin */
51 {0.2626, 0.267, 0.181554}, /* BlueSky */
52 {0.36, 0.4689, 0.108447}, /* Foliage */
53 {0.2977, 0.2602, 0.248407}, /* BlueFlower */
54 {0.2719, 0.3485, 0.401156}, /* BluishGreen */
55 {0.52, 0.4197, 0.357899}, /* Orange */
56 {0.229, 0.1866, 0.103911}, /* PurplishBlue */
57 {0.4909, 0.3262, 0.242615}, /* ModerateRed */
58 {0.3361, 0.2249, 0.0600102}, /* Purple */
59 {0.3855, 0.4874, 0.42963}, /* YellowGreen */
60 {0.4853, 0.4457, 0.476343}, /* OrangeYellow */
61 {0.2026, 0.1369, 0.0529249}, /* Blue */
62 {0.3007, 0.4822, 0.221226}, /* Green */
63 {0.5805, 0.3238, 0.162167}, /* Red */
64 {0.4617, 0.472, 0.64909}, /* Yellow */
65 {0.4178, 0.2625, 0.233662}, /* Magenta */
66 {0.2038, 0.2508, 0.167275}, /* Cyan */
67 {0.3358, 0.337, 0.916877}, /* White */
68 {0.3338, 0.3348, 0.604678}, /* Neutral.8 */
69 {0.3333, 0.3349, 0.364566}, /* Neutral.65 */
70 {0.3353, 0.3359, 0.200238}, /* Neutral.5 */
71 {0.3363, 0.336, 0.0878721}, /* Neutral.35 */
72 {0.3346, 0.3349, 0.0308383} /* Black */
73 };
74
75 COLOR mbRGB[24]; /* MacBeth RGB values */
76
77 #define NMBNEU 6 /* Number of MacBeth neutral colors */
78 short mbneu[NMBNEU] = {Black,Neutral35,Neutral5,Neutral65,Neutral8,White};
79
80 #define NEUFLGS (1L<<White|1L<<Neutral8|1L<<Neutral65| \
81 1L<<Neutral5|1L<<Neutral35|1L<<Black)
82
83 #define SATFLGS (1L<<Red|1L<<Green|1L<<Blue|1L<<Magenta|1L<<Yellow| \
84 1L<<Cyan|1L<<Orange|1L<<Purple|1L<<PurplishBlue| \
85 1L<<YellowGreen|1<<OrangeYellow|1L<<BlueFlower)
86
87 #define UNSFLGS (1L<<DarkSkin|1L<<LightSkin|1L<<BlueSky|1L<<Foliage| \
88 1L<<BluishGreen|1L<<ModerateRed)
89
90 #define REQFLGS NEUFLGS /* need these colors */
91 #define MODFLGS (NEUFLGS|UNSFLGS) /* should be in gamut */
92
93 #define CENTCVG 0.3 /* measured coverage of square sample */
94 #define FULLCVG 0.9 /* coverage of entire square */
95
96 int xmax, ymax; /* input image dimensions */
97 int bounds[4][2]; /* image coordinates of chart corners */
98 double imgxfm[3][3]; /* coordinate transformation matrix */
99
100 COLOR inpRGB[24]; /* measured or scanned input colors */
101 long inpflags = 0; /* flags of which colors were input */
102 long gmtflags = 0; /* flags of out-of-gamut colors */
103
104 COLOR bramp[NMBNEU][2]; /* brightness ramp (per primary) */
105 double solmat[3][3]; /* color mapping matrix */
106
107 FILE *debugfp = NULL; /* debug output picture */
108 char *progname;
109
110 extern char *malloc();
111
112
113 main(argc, argv)
114 int argc;
115 char **argv;
116 {
117 int inpispic = 1;
118 int i;
119
120 progname = argv[0];
121 for (i = 1; i < argc && argv[i][0] == '-'; i++)
122 switch (argv[i][1]) {
123 case 'd': /* debug output */
124 i++;
125 if (badarg(argc-i, argv+i, "s"))
126 goto userr;
127 if ((debugfp = fopen(argv[i], "w")) == NULL) {
128 perror(argv[i]);
129 exit(1);
130 }
131 #ifdef MSDOS
132 setmode(fileno(debugfp), O_BINARY);
133 #endif
134 newheader("RADIANCE", debugfp); /* start */
135 printargs(argc, argv, debugfp); /* header */
136 break;
137 case 'p': /* picture position */
138 if (badarg(argc-i-1, argv+i+1, "iiiiiiii"))
139 goto userr;
140 bounds[0][0] = atoi(argv[++i]);
141 bounds[0][1] = atoi(argv[++i]);
142 bounds[1][0] = atoi(argv[++i]);
143 bounds[1][1] = atoi(argv[++i]);
144 bounds[2][0] = atoi(argv[++i]);
145 bounds[2][1] = atoi(argv[++i]);
146 bounds[3][0] = atoi(argv[++i]);
147 bounds[3][1] = atoi(argv[++i]);
148 inpispic = 2;
149 break;
150 case 'c': /* color input */
151 inpispic = 0;
152 break;
153 default:
154 goto userr;
155 }
156 /* open files */
157 if (i < argc && freopen(argv[i], "r", stdin) == NULL) {
158 perror(argv[1]);
159 exit(1);
160 }
161 if (i+1 < argc && freopen(argv[i+1], "w", stdout) == NULL) {
162 perror(argv[2]);
163 exit(1);
164 }
165 if (inpispic) { /* load input picture header */
166 #ifdef MSDOS
167 setmode(fileno(stdin), O_BINARY);
168 #endif
169 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
170 fgetresolu(&xmax, &ymax, stdin) < 0) {
171 fprintf(stderr, "%s: bad input picture\n", progname);
172 exit(1);
173 }
174 } else { /* else set default xmax and ymax */
175 xmax = 512;
176 ymax = 2*512/3;
177 }
178 if (inpispic != 2) { /* use default boundaries */
179 bounds[0][0] = bounds[2][0] = .029*xmax + .5;
180 bounds[0][1] = bounds[1][1] = .956*ymax + .5;
181 bounds[1][0] = bounds[3][0] = .971*xmax + .5;
182 bounds[2][1] = bounds[3][1] = .056*ymax + .5;
183 }
184 init(); /* initialize */
185 if (inpispic) /* get picture colors */
186 getpicture();
187 else
188 getcolors();
189 compute(); /* compute color mapping */
190 /* print comment */
191 printf("{ Color correction file computed by:\n\t");
192 printargs(argc, argv, stdout);
193 printf("}\n");
194 putmapping(); /* put out color mapping */
195 if (debugfp != NULL) /* put out debug picture */
196 if (inpispic)
197 picdebug();
198 else
199 clrdebug();
200 exit(0);
201 userr:
202 fprintf(stderr,
203 "Usage: %s [-d dbg.pic][-p xul yul xur yur xll yll xlr ylr] input.pic [output.cal]\n",
204 progname);
205 fprintf(stderr, " or: %s [-d dbg.pic] -c [xyY.dat [output.cal]]\n",
206 progname);
207 exit(1);
208 }
209
210
211 init() /* initialize */
212 {
213 double quad[4][2];
214 register int i;
215 /* make coordinate transformation */
216 quad[0][0] = bounds[0][0];
217 quad[0][1] = bounds[0][1];
218 quad[1][0] = bounds[1][0];
219 quad[1][1] = bounds[1][1];
220 quad[2][0] = bounds[3][0];
221 quad[2][1] = bounds[3][1];
222 quad[3][0] = bounds[2][0];
223 quad[3][1] = bounds[2][1];
224
225 if (pmap_quad_rect(0., 0., 6., 4., quad, imgxfm) == PMAP_BAD) {
226 fprintf(stderr, "%s: bad chart boundaries\n", progname);
227 exit(1);
228 }
229 /* map MacBeth colors to RGB space */
230 for (i = 0; i < 24; i++)
231 xyY2RGB(mbRGB[i], mbxyY[i]);
232 }
233
234
235 int
236 chartndx(x, y, cvg) /* find color number for position */
237 int x, y;
238 double cvg;
239 {
240 double ipos[3], cpos[3];
241 int ix, iy;
242 double fx, fy;
243 double cmin, cmax;
244
245 ipos[0] = x;
246 ipos[1] = y;
247 ipos[2] = 1;
248 mx3d_transform(ipos, imgxfm, cpos);
249 cpos[0] /= cpos[2];
250 cpos[1] /= cpos[2];
251 if (cpos[0] < 0. || cpos[0] >= 6. || cpos[1] < 0. || cpos[1] >= 4.)
252 return(-1);
253 ix = cpos[0];
254 iy = cpos[1];
255 fx = cpos[0] - ix;
256 fy = cpos[1] - iy;
257 cmin = .5*(1.-cvg);
258 cmax = 1. - cmin;
259 if (fx < cmin || fx >= cmax || fy < cmin || fy >= cmax)
260 return(-1);
261 return(iy*6 + ix);
262 }
263
264
265 getpicture() /* load in picture colors */
266 {
267 COLR *scanln;
268 COLOR pval;
269 int ccount[24];
270 double d;
271 int y;
272 register int x, i;
273
274 scanln = (COLR *)malloc(xmax*sizeof(COLR));
275 if (scanln == NULL) {
276 perror(progname);
277 exit(1);
278 }
279 for (i = 0; i < 24; i++) {
280 setcolor(inpRGB[i], 0., 0., 0.);
281 ccount[i] = 0;
282 }
283 for (y = ymax-1; y >= 0; y--) {
284 if (freadcolrs(scanln, xmax, stdin) < 0) {
285 fprintf(stderr, "%s: error reading input picture\n",
286 progname);
287 exit(1);
288 }
289 for (x = 0; x < xmax; x++) {
290 i = chartndx(x, y, CENTCVG);
291 if (i >= 0) {
292 colr_color(pval, scanln[x]);
293 addcolor(inpRGB[i], pval);
294 ccount[i]++;
295 }
296 }
297 }
298 for (i = 0; i < 24; i++) { /* compute averages */
299 if (ccount[i] == 0)
300 continue;
301 d = 1./ccount[i];
302 scalecolor(inpRGB[i], d);
303 inpflags |= 1L<<i;
304 }
305 free((char *)scanln);
306 }
307
308
309 getcolors() /* get xyY colors from standard input */
310 {
311 int gotwhite = 0;
312 COLOR whiteclr;
313 int n;
314 float xyYin[3];
315
316 while (fgetval(stdin, 'i', &n) == 1) { /* read colors */
317 if (n < 0 | n > 24 ||
318 fgetval(stdin, 'f', &xyYin[0]) != 1 ||
319 fgetval(stdin, 'f', &xyYin[1]) != 1 ||
320 fgetval(stdin, 'f', &xyYin[2]) != 1 ||
321 xyYin[0] < 0. | xyYin[0] > 1. |
322 xyYin[1] < 0. | xyYin[1] > 1.) {
323 fprintf(stderr, "%s: bad color input data\n",
324 progname);
325 exit(1);
326 }
327 if (n == 0) { /* calibration white */
328 xyY2RGB(whiteclr, xyYin);
329 gotwhite++;
330 } else { /* standard color */
331 n--;
332 xyY2RGB(inpRGB[n], xyYin);
333 inpflags |= 1L<<n;
334 }
335 }
336 /* normalize colors */
337 if (!gotwhite) {
338 if (!(inpflags & 1L<<White)) {
339 fprintf(stderr, "%s: missing input for White\n",
340 progname);
341 exit(1);
342 }
343 setcolor(whiteclr,
344 colval(inpRGB[White],RED)/colval(mbRGB[White],RED),
345 colval(inpRGB[White],GRN)/colval(mbRGB[White],GRN),
346 colval(inpRGB[White],BLU)/colval(mbRGB[White],BLU));
347 }
348 for (n = 0; n < 24; n++)
349 if (inpflags & 1L<<n)
350 setcolor(inpRGB[n],
351 colval(inpRGB[n],RED)/colval(whiteclr,RED),
352 colval(inpRGB[n],GRN)/colval(whiteclr,GRN),
353 colval(inpRGB[n],BLU)/colval(whiteclr,BLU));
354 }
355
356
357 bresp(y, x) /* piecewise linear interpolation of primaries */
358 COLOR y, x;
359 {
360 register int i, n;
361
362 for (i = 0; i < 3; i++) {
363 for (n = 0; n < NMBNEU-2; n++)
364 if (colval(x,i) < colval(bramp[n+1][0],i))
365 break;
366 colval(y,i) = ((colval(bramp[n+1][0],i) - colval(x,i)) *
367 colval(bramp[n][1],i) +
368 (colval(x,i) - colval(bramp[n][0],i)) *
369 colval(bramp[n+1][1],i)) /
370 (colval(bramp[n+1][0],i) - colval(bramp[n][0],i));
371 }
372 }
373
374
375 compute() /* compute color mapping */
376 {
377 COLOR clrin[24], clrout[24];
378 long cflags;
379 COLOR ctmp;
380 register int i, j, n;
381 /* did we get what we need? */
382 if ((inpflags & REQFLGS) != REQFLGS) {
383 fprintf(stderr, "%s: missing required input colors\n",
384 progname);
385 exit(1);
386 }
387 /* compute piecewise luminance curve */
388 for (i = 0; i < NMBNEU; i++) {
389 copycolor(bramp[i][0], inpRGB[mbneu[i]]);
390 copycolor(bramp[i][1], mbRGB[mbneu[i]]);
391 }
392 /* compute color mapping */
393 do {
394 cflags = inpflags & ~gmtflags;
395 n = 0; /* compute transform matrix */
396 for (i = 0; i < 24; i++)
397 if (cflags & 1L<<i) {
398 bresp(clrin[n], inpRGB[i]);
399 copycolor(clrout[n], mbRGB[i]);
400 n++;
401 }
402 compsoln(clrin, clrout, n);
403 /* check out-of-gamut colors */
404 for (i = 0; i < 24; i++)
405 if (cflags & 1L<<i) {
406 cresp(ctmp, mbRGB[i]);
407 for (j = 0; j < 3; j++)
408 if (colval(ctmp,j) <= 0. ||
409 colval(ctmp,j) >= 1.) {
410 gmtflags |= 1L<<i;
411 break;
412 }
413 }
414 } while (cflags & gmtflags);
415 if (gmtflags & MODFLGS)
416 fprintf(stderr,
417 "%s: warning - some moderate colors are out of gamut\n",
418 progname);
419 }
420
421
422 putmapping() /* put out color mapping for pcomb -f */
423 {
424 static char cchar[3] = {'r', 'g', 'b'};
425 register int i, j;
426 /* print brightness mapping */
427 for (j = 0; j < 3; j++) {
428 printf("%cxa(i) : select(i", cchar[j]);
429 for (i = 0; i < NMBNEU; i++)
430 printf(",%g", colval(bramp[i][0],j));
431 printf(");\n");
432 printf("%cya(i) : select(i", cchar[j]);
433 for (i = 0; i < NMBNEU; i++)
434 printf(",%g", colval(bramp[i][1],j));
435 printf(");\n");
436 printf("%c = %ci(1);\n", cchar[j], cchar[j]);
437 printf("%cfi(n) = if(n-%g, %d, if(%cxa(n+1)-%c, n, %cfi(n+1)));\n",
438 cchar[j], NMBNEU-1.5, NMBNEU-1, cchar[j],
439 cchar[j], cchar[j]);
440 printf("%cndx = %cfi(1);\n", cchar[j], cchar[j]);
441 printf("%cn = ((%cxa(%cndx+1)-%c)*%cya(%cndx) + ",
442 cchar[j], cchar[j], cchar[j],
443 cchar[j], cchar[j], cchar[j]);
444 printf("(%c-%cxa(%cndx))*%cya(%cndx+1)) /\n",
445 cchar[j], cchar[j], cchar[j],
446 cchar[j], cchar[j]);
447 printf("\t\t(%cxa(%cndx+1) - %cxa(%cndx)) ;\n",
448 cchar[j], cchar[j], cchar[j], cchar[j]);
449 }
450 /* print color mapping */
451 printf("ro = %g*rn + %g*gn + %g*bn ;\n",
452 solmat[0][0], solmat[0][1], solmat[0][2]);
453 printf("go = %g*rn + %g*gn + %g*bn ;\n",
454 solmat[1][0], solmat[1][1], solmat[1][2]);
455 printf("bo = %g*rn + %g*gn + %g*bn ;\n",
456 solmat[2][0], solmat[2][1], solmat[2][2]);
457 }
458
459
460 compsoln(cin, cout, n) /* solve 3xN system using least-squares */
461 COLOR cin[], cout[];
462 int n;
463 {
464 extern double mx3d_adjoint(), fabs();
465 double mat[3][3], invmat[3][3];
466 double det;
467 double colv[3], rowv[3];
468 register int i, j, k;
469
470 if (n < 3) {
471 fprintf(stderr, "%s: too few colors to match!\n", progname);
472 exit(1);
473 }
474 if (n == 3)
475 for (i = 0; i < 3; i++)
476 for (j = 0; j < 3; j++)
477 mat[i][j] = colval(cin[j],i);
478 else { /* compute A^t A */
479 for (i = 0; i < 3; i++)
480 for (j = i; j < 3; j++) {
481 mat[i][j] = 0.;
482 for (k = 0; k < n; k++)
483 mat[i][j] += colval(cin[k],i) *
484 colval(cin[k],j);
485 }
486 for (i = 1; i < 3; i++) /* using symmetry */
487 for (j = 0; j < i; j++)
488 mat[i][j] = mat[j][i];
489 }
490 det = mx3d_adjoint(mat, invmat);
491 if (fabs(det) < 1e-4) {
492 fprintf(stderr, "%s: cannot compute color mapping\n",
493 progname);
494 solmat[0][0] = solmat[1][1] = solmat[2][2] = 1.;
495 solmat[0][1] = solmat[0][2] = solmat[1][0] =
496 solmat[1][2] = solmat[2][0] = solmat[2][1] = 0.;
497 return;
498 }
499 for (i = 0; i < 3; i++)
500 for (j = 0; j < 3; j++)
501 invmat[i][j] /= det;
502 for (i = 0; i < 3; i++) {
503 if (n == 3)
504 for (j = 0; j < 3; j++)
505 colv[j] = colval(cout[j],i);
506 else
507 for (j = 0; j < 3; j++) {
508 colv[j] = 0.;
509 for (k = 0; k < n; k++)
510 colv[j] += colval(cout[k],i) *
511 colval(cin[k],j);
512 }
513 mx3d_transform(colv, invmat, rowv);
514 for (j = 0; j < 3; j++)
515 solmat[i][j] = rowv[j];
516 }
517 }
518
519
520 cvtcolor(cout, cin) /* convert color according to our mapping */
521 COLOR cout, cin;
522 {
523 COLOR ctmp;
524
525 bresp(ctmp, cin);
526 cresp(cout, ctmp);
527 if (colval(cout,RED) < 0.)
528 colval(cout,RED) = 0.;
529 if (colval(cout,GRN) < 0.)
530 colval(cout,GRN) = 0.;
531 if (colval(cout,BLU) < 0.)
532 colval(cout,BLU) = 0.;
533 }
534
535
536 cresp(cout, cin) /* transform color according to matrix */
537 COLOR cout, cin;
538 {
539 double r, g, b;
540
541 r = colval(cin,0)*solmat[0][0] + colval(cin,1)*solmat[0][1]
542 + colval(cin,2)*solmat[0][2];
543 g = colval(cin,0)*solmat[1][0] + colval(cin,1)*solmat[1][1]
544 + colval(cin,2)*solmat[1][2];
545 b = colval(cin,0)*solmat[2][0] + colval(cin,1)*solmat[2][1]
546 + colval(cin,2)*solmat[2][2];
547 setcolor(cout, r, g, b);
548 }
549
550
551 xyY2RGB(rgbout, xyYin) /* convert xyY to RGB */
552 COLOR rgbout;
553 register float xyYin[3];
554 {
555 COLOR ctmp;
556 double d;
557
558 d = xyYin[2] / xyYin[1];
559 ctmp[0] = xyYin[0] * d;
560 ctmp[1] = xyYin[2];
561 ctmp[2] = (1. - xyYin[0] - xyYin[1]) * d;
562 cie_rgb(rgbout, ctmp);
563 }
564
565
566 picdebug() /* put out debugging picture */
567 {
568 static COLOR blkcol = BLKCOLOR;
569 COLOR *scan;
570 int y;
571 register int x, i;
572
573 if (fseek(stdin, 0L, 0) == EOF) {
574 fprintf(stderr, "%s: cannot seek on input picture\n", progname);
575 exit(1);
576 }
577 getheader(stdin, NULL, NULL); /* skip input header */
578 fgetresolu(&xmax, &ymax, stdin);
579 /* allocate scanline */
580 scan = (COLOR *)malloc(xmax*sizeof(COLOR));
581 if (scan == NULL) {
582 perror(progname);
583 exit(1);
584 }
585 /* finish debug header */
586 fputformat(COLRFMT, debugfp);
587 putc('\n', debugfp);
588 fprtresolu(xmax, ymax, debugfp);
589 /* write debug picture */
590 for (y = ymax-1; y >= 0; y--) {
591 if (freadscan(scan, xmax, stdin) < 0) {
592 fprintf(stderr, "%s: error rereading input picture\n",
593 progname);
594 exit(1);
595 }
596 for (x = 0; x < xmax; x++) {
597 i = chartndx(x, y, CENTCVG);
598 if (i < 0)
599 cvtcolor(scan[x], scan[x]);
600 else if (!(1L<<i & gmtflags) || (x+y)&07)
601 copycolor(scan[x], mbRGB[i]);
602 else
603 copycolor(scan[x], blkcol);
604 }
605 if (fwritescan(scan, xmax, debugfp) < 0) {
606 fprintf(stderr, "%s: error writing debugging picture\n",
607 progname);
608 exit(1);
609 }
610 }
611 /* clean up */
612 fclose(debugfp);
613 free((char *)scan);
614 }
615
616
617 clrdebug() /* put out debug picture from color input */
618 {
619 static COLR blkclr = BLKCOLR;
620 COLR mbclr[24], cvclr[24];
621 COLR *scan;
622 COLOR ctmp;
623 int y;
624 register int i, x;
625 /* convert colors */
626 for (i = 0; i < 24; i++) {
627 setcolr(mbclr[i], colval(mbRGB[i],RED),
628 colval(mbRGB[i],GRN), colval(mbRGB[i],BLU));
629 if (inpflags & 1L<<i) {
630 cvtcolor(ctmp, inpRGB[i]);
631 setcolr(cvclr[i], colval(ctmp,RED),
632 colval(ctmp,GRN), colval(ctmp,BLU));
633 }
634 }
635 /* allocate scanline */
636 scan = (COLR *)malloc(xmax*sizeof(COLR));
637 if (scan == NULL) {
638 perror(progname);
639 exit(1);
640 }
641 /* finish debug header */
642 fputformat(COLRFMT, debugfp);
643 putc('\n', debugfp);
644 fprtresolu(xmax, ymax, debugfp);
645 /* write debug picture */
646 for (y = ymax-1; y >= 0; y--) {
647 for (x = 0; x < xmax; x++)
648 if ((i = chartndx(x, y, CENTCVG)) >= 0) {
649 if (!(1L<<i & gmtflags) || (x+y)&07)
650 copycolr(scan[x], mbclr[i]);
651 else
652 copycolr(scan[x], blkclr);
653 } else if ((i = chartndx(x, y, FULLCVG)) >= 0 &&
654 inpflags & 1L<<i)
655 copycolr(scan[x], cvclr[i]);
656 else
657 copycolr(scan[x], blkclr);
658 if (fwritecolrs(scan, xmax, debugfp) < 0) {
659 fprintf(stderr, "%s: error writing debugging picture\n",
660 progname);
661 exit(1);
662 }
663 }
664 /* clean up */
665 fclose(debugfp);
666 free((char *)scan);
667 }
