root/radiance/ray/src/px/macbethcal.c
Revision: 2.10
Committed: Wed Nov 1 09:04:16 1995 UTC (29 years, 7 months ago) by greg
Changes since 2.9: +3 -1 lines
added comment on pcomb usage to output file
1 /* Copyright (c) 1995 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Calibrate a scanned MacBeth Color Checker Chart
9 *
10 * Produce a .cal file suitable for use with pcomb.
11 */
12
13 #include <stdio.h>
14 #ifdef MSDOS
15 #include <fcntl.h>
16 #endif
17 #include "color.h"
18 #include "resolu.h"
19 #include "pmap.h"
20
21 /* MacBeth colors */
22 #define DarkSkin 0
23 #define LightSkin 1
24 #define BlueSky 2
25 #define Foliage 3
26 #define BlueFlower 4
27 #define BluishGreen 5
28 #define Orange 6
29 #define PurplishBlue 7
30 #define ModerateRed 8
31 #define Purple 9
32 #define YellowGreen 10
33 #define OrangeYellow 11
34 #define Blue 12
35 #define Green 13
36 #define Red 14
37 #define Yellow 15
38 #define Magenta 16
39 #define Cyan 17
40 #define White 18
41 #define Neutral8 19
42 #define Neutral65 20
43 #define Neutral5 21
44 #define Neutral35 22
45 #define Black 23
46 /* computed from 5nm spectral measurements */
47 /* CIE 1931 2 degree obs, equal-energy white */
48 float mbxyY[24][3] = {
49 {0.462, 0.3769, 0.0932961}, /* DarkSkin */
50 {0.4108, 0.3542, 0.410348}, /* LightSkin */
51 {0.2626, 0.267, 0.181554}, /* BlueSky */
52 {0.36, 0.4689, 0.108447}, /* Foliage */
53 {0.2977, 0.2602, 0.248407}, /* BlueFlower */
54 {0.2719, 0.3485, 0.401156}, /* BluishGreen */
55 {0.52, 0.4197, 0.357899}, /* Orange */
56 {0.229, 0.1866, 0.103911}, /* PurplishBlue */
57 {0.4909, 0.3262, 0.242615}, /* ModerateRed */
58 {0.3361, 0.2249, 0.0600102}, /* Purple */
59 {0.3855, 0.4874, 0.42963}, /* YellowGreen */
60 {0.4853, 0.4457, 0.476343}, /* OrangeYellow */
61 {0.2026, 0.1369, 0.0529249}, /* Blue */
62 {0.3007, 0.4822, 0.221226}, /* Green */
63 {0.5805, 0.3238, 0.162167}, /* Red */
64 {0.4617, 0.472, 0.64909}, /* Yellow */
65 {0.4178, 0.2625, 0.233662}, /* Magenta */
66 {0.2038, 0.2508, 0.167275}, /* Cyan */
67 {0.3358, 0.337, 0.916877}, /* White */
68 {0.3338, 0.3348, 0.604678}, /* Neutral.8 */
69 {0.3333, 0.3349, 0.364566}, /* Neutral.65 */
70 {0.3353, 0.3359, 0.200238}, /* Neutral.5 */
71 {0.3363, 0.336, 0.0878721}, /* Neutral.35 */
72 {0.3346, 0.3349, 0.0308383} /* Black */
73 };
74
75 COLOR mbRGB[24]; /* MacBeth RGB values */
76
77 #define NMBNEU 6 /* Number of MacBeth neutral colors */
78 short mbneu[NMBNEU] = {Black,Neutral35,Neutral5,Neutral65,Neutral8,White};
79
80 #define NEUFLGS (1L<<White|1L<<Neutral8|1L<<Neutral65| \
81 1L<<Neutral5|1L<<Neutral35|1L<<Black)
82
83 #define SATFLGS (1L<<Red|1L<<Green|1L<<Blue|1L<<Magenta|1L<<Yellow| \
84 1L<<Cyan|1L<<Orange|1L<<Purple|1L<<PurplishBlue| \
85 1L<<YellowGreen|1<<OrangeYellow|1L<<BlueFlower)
86
87 #define UNSFLGS (1L<<DarkSkin|1L<<LightSkin|1L<<BlueSky|1L<<Foliage| \
88 1L<<BluishGreen|1L<<ModerateRed)
89
90 #define REQFLGS NEUFLGS /* need these colors */
91 #define MODFLGS (NEUFLGS|UNSFLGS) /* should be in gamut */
92
93 #define RG_BORD 0 /* patch border */
94 #define RG_CENT 01 /* central region of patch */
95 #define RG_ORIG 02 /* original color region */
96 #define RG_CORR 04 /* corrected color region */
97
98 int xmax, ymax; /* input image dimensions */
99 int bounds[4][2]; /* image coordinates of chart corners */
100 double imgxfm[3][3]; /* coordinate transformation matrix */
101
102 COLOR inpRGB[24]; /* measured or scanned input colors */
103 long inpflags = 0; /* flags of which colors were input */
104 long gmtflags = 0; /* flags of out-of-gamut colors */
105
106 COLOR bramp[NMBNEU][2]; /* brightness ramp (per primary) */
107 double solmat[3][3]; /* color mapping matrix */
108
109 FILE *debugfp = NULL; /* debug output picture */
110 char *progname;
111
112 extern char *malloc();
113
114
115 main(argc, argv)
116 int argc;
117 char **argv;
118 {
119 int inpispic = 1;
120 int i;
121
122 progname = argv[0];
123 for (i = 1; i < argc && argv[i][0] == '-'; i++)
124 switch (argv[i][1]) {
125 case 'd': /* debug output */
126 i++;
127 if (badarg(argc-i, argv+i, "s"))
128 goto userr;
129 if ((debugfp = fopen(argv[i], "w")) == NULL) {
130 perror(argv[i]);
131 exit(1);
132 }
133 #ifdef MSDOS
134 setmode(fileno(debugfp), O_BINARY);
135 #endif
136 newheader("RADIANCE", debugfp); /* start */
137 printargs(argc, argv, debugfp); /* header */
138 break;
139 case 'p': /* picture position */
140 if (badarg(argc-i-1, argv+i+1, "iiiiiiii"))
141 goto userr;
142 bounds[0][0] = atoi(argv[++i]);
143 bounds[0][1] = atoi(argv[++i]);
144 bounds[1][0] = atoi(argv[++i]);
145 bounds[1][1] = atoi(argv[++i]);
146 bounds[2][0] = atoi(argv[++i]);
147 bounds[2][1] = atoi(argv[++i]);
148 bounds[3][0] = atoi(argv[++i]);
149 bounds[3][1] = atoi(argv[++i]);
150 inpispic = 2;
151 break;
152 case 'c': /* color input */
153 inpispic = 0;
154 break;
155 default:
156 goto userr;
157 }
158 /* open files */
159 if (i < argc && freopen(argv[i], "r", stdin) == NULL) {
160 perror(argv[1]);
161 exit(1);
162 }
163 if (i+1 < argc && freopen(argv[i+1], "w", stdout) == NULL) {
164 perror(argv[2]);
165 exit(1);
166 }
167 if (inpispic) { /* load input picture header */
168 #ifdef MSDOS
169 setmode(fileno(stdin), O_BINARY);
170 #endif
171 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
172 fgetresolu(&xmax, &ymax, stdin) < 0) {
173 fprintf(stderr, "%s: bad input picture\n", progname);
174 exit(1);
175 }
176 } else { /* else set default xmax and ymax */
177 xmax = 512;
178 ymax = 2*512/3;
179 }
180 if (inpispic != 2) { /* use default boundaries */
181 bounds[0][0] = bounds[2][0] = .029*xmax + .5;
182 bounds[0][1] = bounds[1][1] = .956*ymax + .5;
183 bounds[1][0] = bounds[3][0] = .971*xmax + .5;
184 bounds[2][1] = bounds[3][1] = .056*ymax + .5;
185 }
186 init(); /* initialize */
187 if (inpispic) /* get picture colors */
188 getpicture();
189 else
190 getcolors();
191 compute(); /* compute color mapping */
192 /* print comment */
193 printf("{\n\tColor correction file computed by:\n\t\t");
194 printargs(argc, argv, stdout);
195 printf("\n\tUsage: pcomb -f %s uncorrected.pic > corrected.pic\n",
196 i+1 < argc ? argv[i+1] : "{this_file}");
197 printf("}\n");
198 putmapping(); /* put out color mapping */
199 if (debugfp != NULL) /* put out debug picture */
200 if (inpispic)
201 picdebug();
202 else
203 clrdebug();
204 exit(0);
205 userr:
206 fprintf(stderr,
207 "Usage: %s [-d dbg.pic][-p xul yul xur yur xll yll xlr ylr] input.pic [output.cal]\n",
208 progname);
209 fprintf(stderr, " or: %s [-d dbg.pic] -c [xyY.dat [output.cal]]\n",
210 progname);
211 exit(1);
212 }
213
214
215 init() /* initialize */
216 {
217 double quad[4][2];
218 register int i;
219 /* make coordinate transformation */
220 quad[0][0] = bounds[0][0];
221 quad[0][1] = bounds[0][1];
222 quad[1][0] = bounds[1][0];
223 quad[1][1] = bounds[1][1];
224 quad[2][0] = bounds[3][0];
225 quad[2][1] = bounds[3][1];
226 quad[3][0] = bounds[2][0];
227 quad[3][1] = bounds[2][1];
228
229 if (pmap_quad_rect(0., 0., 6., 4., quad, imgxfm) == PMAP_BAD) {
230 fprintf(stderr, "%s: bad chart boundaries\n", progname);
231 exit(1);
232 }
233 /* map MacBeth colors to RGB space */
234 for (i = 0; i < 24; i++)
235 xyY2RGB(mbRGB[i], mbxyY[i]);
236 }
237
238
239 int
240 chartndx(x, y, np) /* find color number for position */
241 int x, y;
242 int *np;
243 {
244 double ipos[3], cpos[3];
245 int ix, iy;
246 double fx, fy;
247
248 ipos[0] = x;
249 ipos[1] = y;
250 ipos[2] = 1;
251 mx3d_transform(ipos, imgxfm, cpos);
252 cpos[0] /= cpos[2];
253 cpos[1] /= cpos[2];
254 if (cpos[0] < 0. || cpos[0] >= 6. || cpos[1] < 0. || cpos[1] >= 4.)
255 return(RG_BORD);
256 ix = cpos[0];
257 iy = cpos[1];
258 fx = cpos[0] - ix;
259 fy = cpos[1] - iy;
260 *np = iy*6 + ix;
261 if (fx >= 0.35 && fx < 0.65 && fy >= 0.35 && fy < 0.65)
262 return(RG_CENT);
263 if (fx < 0.05 || fx >= 0.95 || fy < 0.05 || fy >= 0.95)
264 return(RG_BORD);
265 if (fx >= 0.5) /* right side is corrected */
266 return(RG_CORR);
267 return(RG_ORIG); /* left side is original */
268 }
269
270
271 getpicture() /* load in picture colors */
272 {
273 COLR *scanln;
274 COLOR pval;
275 int ccount[24];
276 double d;
277 int y, i;
278 register int x;
279
280 scanln = (COLR *)malloc(xmax*sizeof(COLR));
281 if (scanln == NULL) {
282 perror(progname);
283 exit(1);
284 }
285 for (i = 0; i < 24; i++) {
286 setcolor(inpRGB[i], 0., 0., 0.);
287 ccount[i] = 0;
288 }
289 for (y = ymax-1; y >= 0; y--) {
290 if (freadcolrs(scanln, xmax, stdin) < 0) {
291 fprintf(stderr, "%s: error reading input picture\n",
292 progname);
293 exit(1);
294 }
295 for (x = 0; x < xmax; x++)
296 if (chartndx(x, y, &i) == RG_CENT) {
297 colr_color(pval, scanln[x]);
298 addcolor(inpRGB[i], pval);
299 ccount[i]++;
300 }
301 }
302 for (i = 0; i < 24; i++) { /* compute averages */
303 if (ccount[i] == 0)
304 continue;
305 d = 1./ccount[i];
306 scalecolor(inpRGB[i], d);
307 inpflags |= 1L<<i;
308 }
309 free((char *)scanln);
310 }
311
312
313 getcolors() /* get xyY colors from standard input */
314 {
315 int gotwhite = 0;
316 COLOR whiteclr;
317 int n;
318 float xyYin[3];
319
320 while (fgetval(stdin, 'i', &n) == 1) { /* read colors */
321 if (n < 0 | n > 24 ||
322 fgetval(stdin, 'f', &xyYin[0]) != 1 ||
323 fgetval(stdin, 'f', &xyYin[1]) != 1 ||
324 fgetval(stdin, 'f', &xyYin[2]) != 1 ||
325 xyYin[0] < 0. | xyYin[0] > 1. |
326 xyYin[1] < 0. | xyYin[1] > 1.) {
327 fprintf(stderr, "%s: bad color input data\n",
328 progname);
329 exit(1);
330 }
331 if (n == 0) { /* calibration white */
332 xyY2RGB(whiteclr, xyYin);
333 gotwhite++;
334 } else { /* standard color */
335 n--;
336 xyY2RGB(inpRGB[n], xyYin);
337 inpflags |= 1L<<n;
338 }
339 }
340 /* normalize colors */
341 if (!gotwhite) {
342 if (!(inpflags & 1L<<White)) {
343 fprintf(stderr, "%s: missing input for White\n",
344 progname);
345 exit(1);
346 }
347 setcolor(whiteclr,
348 colval(inpRGB[White],RED)/colval(mbRGB[White],RED),
349 colval(inpRGB[White],GRN)/colval(mbRGB[White],GRN),
350 colval(inpRGB[White],BLU)/colval(mbRGB[White],BLU));
351 }
352 for (n = 0; n < 24; n++)
353 if (inpflags & 1L<<n)
354 setcolor(inpRGB[n],
355 colval(inpRGB[n],RED)/colval(whiteclr,RED),
356 colval(inpRGB[n],GRN)/colval(whiteclr,GRN),
357 colval(inpRGB[n],BLU)/colval(whiteclr,BLU));
358 }
359
360
361 bresp(y, x) /* piecewise linear interpolation of primaries */
362 COLOR y, x;
363 {
364 register int i, n;
365
366 for (i = 0; i < 3; i++) {
367 for (n = 0; n < NMBNEU-2; n++)
368 if (colval(x,i) < colval(bramp[n+1][0],i))
369 break;
370 colval(y,i) = ((colval(bramp[n+1][0],i) - colval(x,i)) *
371 colval(bramp[n][1],i) +
372 (colval(x,i) - colval(bramp[n][0],i)) *
373 colval(bramp[n+1][1],i)) /
374 (colval(bramp[n+1][0],i) - colval(bramp[n][0],i));
375 }
376 }
377
378
379 compute() /* compute color mapping */
380 {
381 COLOR clrin[24], clrout[24];
382 long cflags;
383 COLOR ctmp;
384 register int i, j, n;
385 /* did we get what we need? */
386 if ((inpflags & REQFLGS) != REQFLGS) {
387 fprintf(stderr, "%s: missing required input colors\n",
388 progname);
389 exit(1);
390 }
391 /* compute piecewise luminance curve */
392 for (i = 0; i < NMBNEU; i++) {
393 copycolor(bramp[i][0], inpRGB[mbneu[i]]);
394 copycolor(bramp[i][1], mbRGB[mbneu[i]]);
395 }
396 /* compute color mapping */
397 do {
398 cflags = inpflags & ~gmtflags;
399 n = 0; /* compute transform matrix */
400 for (i = 0; i < 24; i++)
401 if (cflags & 1L<<i) {
402 bresp(clrin[n], inpRGB[i]);
403 copycolor(clrout[n], mbRGB[i]);
404 n++;
405 }
406 compsoln(clrin, clrout, n);
407 /* check out-of-gamut colors */
408 for (i = 0; i < 24; i++)
409 if (cflags & 1L<<i) {
410 cresp(ctmp, mbRGB[i]);
411 for (j = 0; j < 3; j++)
412 if (colval(ctmp,j) <= 0. ||
413 colval(ctmp,j) >= 1.) {
414 gmtflags |= 1L<<i;
415 break;
416 }
417 }
418 } while (cflags & gmtflags);
419 if (gmtflags & MODFLGS)
420 fprintf(stderr,
421 "%s: warning - some moderate colors are out of gamut\n",
422 progname);
423 }
424
425
426 putmapping() /* put out color mapping for pcomb -f */
427 {
428 static char cchar[3] = {'r', 'g', 'b'};
429 register int i, j;
430 /* print brightness mapping */
431 for (j = 0; j < 3; j++) {
432 printf("%cxa(i) : select(i", cchar[j]);
433 for (i = 0; i < NMBNEU; i++)
434 printf(",%g", colval(bramp[i][0],j));
435 printf(");\n");
436 printf("%cya(i) : select(i", cchar[j]);
437 for (i = 0; i < NMBNEU; i++)
438 printf(",%g", colval(bramp[i][1],j));
439 printf(");\n");
440 printf("%c = %ci(1);\n", cchar[j], cchar[j]);
441 printf("%cfi(n) = if(n-%g, %d, if(%cxa(n+1)-%c, n, %cfi(n+1)));\n",
442 cchar[j], NMBNEU-1.5, NMBNEU-1, cchar[j],
443 cchar[j], cchar[j]);
444 printf("%cndx = %cfi(1);\n", cchar[j], cchar[j]);
445 printf("%cn = ((%cxa(%cndx+1)-%c)*%cya(%cndx) + ",
446 cchar[j], cchar[j], cchar[j],
447 cchar[j], cchar[j], cchar[j]);
448 printf("(%c-%cxa(%cndx))*%cya(%cndx+1)) /\n",
449 cchar[j], cchar[j], cchar[j],
450 cchar[j], cchar[j]);
451 printf("\t\t(%cxa(%cndx+1) - %cxa(%cndx)) ;\n",
452 cchar[j], cchar[j], cchar[j], cchar[j]);
453 }
454 /* print color mapping */
455 printf("ro = %g*rn + %g*gn + %g*bn ;\n",
456 solmat[0][0], solmat[0][1], solmat[0][2]);
457 printf("go = %g*rn + %g*gn + %g*bn ;\n",
458 solmat[1][0], solmat[1][1], solmat[1][2]);
459 printf("bo = %g*rn + %g*gn + %g*bn ;\n",
460 solmat[2][0], solmat[2][1], solmat[2][2]);
461 }
462
463
464 compsoln(cin, cout, n) /* solve 3xN system using least-squares */
465 COLOR cin[], cout[];
466 int n;
467 {
468 extern double mx3d_adjoint(), fabs();
469 double mat[3][3], invmat[3][3];
470 double det;
471 double colv[3], rowv[3];
472 register int i, j, k;
473
474 if (n < 3) {
475 fprintf(stderr, "%s: too few colors to match!\n", progname);
476 exit(1);
477 }
478 if (n == 3)
479 for (i = 0; i < 3; i++)
480 for (j = 0; j < 3; j++)
481 mat[i][j] = colval(cin[j],i);
482 else { /* compute A^t A */
483 for (i = 0; i < 3; i++)
484 for (j = i; j < 3; j++) {
485 mat[i][j] = 0.;
486 for (k = 0; k < n; k++)
487 mat[i][j] += colval(cin[k],i) *
488 colval(cin[k],j);
489 }
490 for (i = 1; i < 3; i++) /* using symmetry */
491 for (j = 0; j < i; j++)
492 mat[i][j] = mat[j][i];
493 }
494 det = mx3d_adjoint(mat, invmat);
495 if (fabs(det) < 1e-4) {
496 fprintf(stderr, "%s: cannot compute color mapping\n",
497 progname);
498 solmat[0][0] = solmat[1][1] = solmat[2][2] = 1.;
499 solmat[0][1] = solmat[0][2] = solmat[1][0] =
500 solmat[1][2] = solmat[2][0] = solmat[2][1] = 0.;
501 return;
502 }
503 for (i = 0; i < 3; i++)
504 for (j = 0; j < 3; j++)
505 invmat[i][j] /= det;
506 for (i = 0; i < 3; i++) {
507 if (n == 3)
508 for (j = 0; j < 3; j++)
509 colv[j] = colval(cout[j],i);
510 else
511 for (j = 0; j < 3; j++) {
512 colv[j] = 0.;
513 for (k = 0; k < n; k++)
514 colv[j] += colval(cout[k],i) *
515 colval(cin[k],j);
516 }
517 mx3d_transform(colv, invmat, rowv);
518 for (j = 0; j < 3; j++)
519 solmat[i][j] = rowv[j];
520 }
521 }
522
523
524 cvtcolor(cout, cin) /* convert color according to our mapping */
525 COLOR cout, cin;
526 {
527 COLOR ctmp;
528
529 bresp(ctmp, cin);
530 cresp(cout, ctmp);
531 if (colval(cout,RED) < 0.)
532 colval(cout,RED) = 0.;
533 if (colval(cout,GRN) < 0.)
534 colval(cout,GRN) = 0.;
535 if (colval(cout,BLU) < 0.)
536 colval(cout,BLU) = 0.;
537 }
538
539
540 cresp(cout, cin) /* transform color according to matrix */
541 COLOR cout, cin;
542 {
543 double r, g, b;
544
545 r = colval(cin,0)*solmat[0][0] + colval(cin,1)*solmat[0][1]
546 + colval(cin,2)*solmat[0][2];
547 g = colval(cin,0)*solmat[1][0] + colval(cin,1)*solmat[1][1]
548 + colval(cin,2)*solmat[1][2];
549 b = colval(cin,0)*solmat[2][0] + colval(cin,1)*solmat[2][1]
550 + colval(cin,2)*solmat[2][2];
551 setcolor(cout, r, g, b);
552 }
553
554
555 xyY2RGB(rgbout, xyYin) /* convert xyY to RGB */
556 COLOR rgbout;
557 register float xyYin[3];
558 {
559 COLOR ctmp;
560 double d;
561
562 d = xyYin[2] / xyYin[1];
563 ctmp[0] = xyYin[0] * d;
564 ctmp[1] = xyYin[2];
565 ctmp[2] = (1. - xyYin[0] - xyYin[1]) * d;
566 cie_rgb(rgbout, ctmp);
567 }
568
569
570 picdebug() /* put out debugging picture */
571 {
572 static COLOR blkcol = BLKCOLOR;
573 COLOR *scan;
574 int y, i;
575 register int x, rg;
576
577 if (fseek(stdin, 0L, 0) == EOF) {
578 fprintf(stderr, "%s: cannot seek on input picture\n", progname);
579 exit(1);
580 }
581 getheader(stdin, NULL, NULL); /* skip input header */
582 fgetresolu(&xmax, &ymax, stdin);
583 /* allocate scanline */
584 scan = (COLOR *)malloc(xmax*sizeof(COLOR));
585 if (scan == NULL) {
586 perror(progname);
587 exit(1);
588 }
589 /* finish debug header */
590 fputformat(COLRFMT, debugfp);
591 putc('\n', debugfp);
592 fprtresolu(xmax, ymax, debugfp);
593 /* write debug picture */
594 for (y = ymax-1; y >= 0; y--) {
595 if (freadscan(scan, xmax, stdin) < 0) {
596 fprintf(stderr, "%s: error rereading input picture\n",
597 progname);
598 exit(1);
599 }
600 for (x = 0; x < xmax; x++) {
601 rg = chartndx(x, y, &i);
602 if (rg == RG_CENT) {
603 if (!(1L<<i & gmtflags) || (x+y)&07)
604 copycolor(scan[x], mbRGB[i]);
605 else
606 copycolor(scan[x], blkcol);
607 } else if (rg == RG_CORR)
608 cvtcolor(scan[x], scan[x]);
609 else if (rg != RG_ORIG)
610 copycolor(scan[x], blkcol);
611 }
612 if (fwritescan(scan, xmax, debugfp) < 0) {
613 fprintf(stderr, "%s: error writing debugging picture\n",
614 progname);
615 exit(1);
616 }
617 }
618 /* clean up */
619 fclose(debugfp);
620 free((char *)scan);
621 }
622
623
624 clrdebug() /* put out debug picture from color input */
625 {
626 static COLR blkclr = BLKCOLR;
627 COLR mbclr[24], cvclr[24], orclr[24];
628 COLR *scan;
629 COLOR ctmp;
630 int y, i;
631 register int x, rg;
632 /* convert colors */
633 for (i = 0; i < 24; i++) {
634 setcolr(mbclr[i], colval(mbRGB[i],RED),
635 colval(mbRGB[i],GRN), colval(mbRGB[i],BLU));
636 if (inpflags & 1L<<i) {
637 setcolr(orclr[i], colval(inpRGB[i],RED),
638 colval(inpRGB[i],GRN),
639 colval(inpRGB[i],BLU));
640 cvtcolor(ctmp, inpRGB[i]);
641 setcolr(cvclr[i], colval(ctmp,RED),
642 colval(ctmp,GRN), colval(ctmp,BLU));
643 }
644 }
645 /* allocate scanline */
646 scan = (COLR *)malloc(xmax*sizeof(COLR));
647 if (scan == NULL) {
648 perror(progname);
649 exit(1);
650 }
651 /* finish debug header */
652 fputformat(COLRFMT, debugfp);
653 putc('\n', debugfp);
654 fprtresolu(xmax, ymax, debugfp);
655 /* write debug picture */
656 for (y = ymax-1; y >= 0; y--) {
657 for (x = 0; x < xmax; x++) {
658 rg = chartndx(x, y, &i);
659 if (rg == RG_CENT) {
660 if (!(1L<<i & gmtflags) || (x+y)&07)
661 copycolr(scan[x], mbclr[i]);
662 else
663 copycolr(scan[x], blkclr);
664 } else if (rg == RG_BORD || !(1L<<i & inpflags))
665 copycolr(scan[x], blkclr);
666 else if (rg == RG_ORIG)
667 copycolr(scan[x], orclr[i]);
668 else /* rg == RG_CORR */
669 copycolr(scan[x], cvclr[i]);
670 }
671 if (fwritecolrs(scan, xmax, debugfp) < 0) {
672 fprintf(stderr, "%s: error writing debugging picture\n",
673 progname);
674 exit(1);
675 }
676 }
677 /* clean up */
678 fclose(debugfp);
679 free((char *)scan);
680 }
