root/Development/ray/src/px/macbethcal.c
Revision: 2.17
Committed: Sat Feb 22 02:07:27 2003 UTC (22 years, 10 months ago) by greg
Changes since 2.16: +5 -9 lines
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.17 static const char RCSid[] = "$Id$";
3 greg 2.1 #endif
4     /*
5     * Calibrate a scanned MacBeth Color Checker Chart
6     *
7 greg 2.14 * Produce a .cal file suitable for use with pcomb,
8     * or .cwp file suitable for use with pcwarp.
9     *
10     * Warping code depends on conformance of COLOR and W3VEC types.
11 greg 2.1 */
12
13     #include <stdio.h>
14 greg 2.14 #include <math.h>
15 greg 2.1 #ifdef MSDOS
16     #include <fcntl.h>
17     #endif
18 greg 2.17 #include <time.h>
19 greg 2.1 #include "color.h"
20     #include "resolu.h"
21     #include "pmap.h"
22 greg 2.14 #include "warp3d.h"
23 greg 2.1
24 greg 2.4 /* MacBeth colors */
25     #define DarkSkin 0
26     #define LightSkin 1
27     #define BlueSky 2
28     #define Foliage 3
29     #define BlueFlower 4
30     #define BluishGreen 5
31     #define Orange 6
32     #define PurplishBlue 7
33     #define ModerateRed 8
34     #define Purple 9
35     #define YellowGreen 10
36     #define OrangeYellow 11
37     #define Blue 12
38     #define Green 13
39     #define Red 14
40     #define Yellow 15
41     #define Magenta 16
42     #define Cyan 17
43     #define White 18
44     #define Neutral8 19
45     #define Neutral65 20
46     #define Neutral5 21
47     #define Neutral35 22
48     #define Black 23
49     /* computed from 5nm spectral measurements */
50     /* CIE 1931 2 degree obs, equal-energy white */
51 greg 2.1 float mbxyY[24][3] = {
52     {0.462, 0.3769, 0.0932961}, /* DarkSkin */
53     {0.4108, 0.3542, 0.410348}, /* LightSkin */
54     {0.2626, 0.267, 0.181554}, /* BlueSky */
55     {0.36, 0.4689, 0.108447}, /* Foliage */
56     {0.2977, 0.2602, 0.248407}, /* BlueFlower */
57     {0.2719, 0.3485, 0.401156}, /* BluishGreen */
58     {0.52, 0.4197, 0.357899}, /* Orange */
59     {0.229, 0.1866, 0.103911}, /* PurplishBlue */
60     {0.4909, 0.3262, 0.242615}, /* ModerateRed */
61     {0.3361, 0.2249, 0.0600102}, /* Purple */
62     {0.3855, 0.4874, 0.42963}, /* YellowGreen */
63     {0.4853, 0.4457, 0.476343}, /* OrangeYellow */
64     {0.2026, 0.1369, 0.0529249}, /* Blue */
65     {0.3007, 0.4822, 0.221226}, /* Green */
66     {0.5805, 0.3238, 0.162167}, /* Red */
67     {0.4617, 0.472, 0.64909}, /* Yellow */
68     {0.4178, 0.2625, 0.233662}, /* Magenta */
69     {0.2038, 0.2508, 0.167275}, /* Cyan */
70     {0.3358, 0.337, 0.916877}, /* White */
71     {0.3338, 0.3348, 0.604678}, /* Neutral.8 */
72     {0.3333, 0.3349, 0.364566}, /* Neutral.65 */
73     {0.3353, 0.3359, 0.200238}, /* Neutral.5 */
74     {0.3363, 0.336, 0.0878721}, /* Neutral.35 */
75     {0.3346, 0.3349, 0.0308383} /* Black */
76     };
77
78     COLOR mbRGB[24]; /* MacBeth RGB values */
79
80     #define NMBNEU 6 /* Number of MacBeth neutral colors */
81 greg 2.4 short mbneu[NMBNEU] = {Black,Neutral35,Neutral5,Neutral65,Neutral8,White};
82 greg 2.1
83 greg 2.8 #define NEUFLGS (1L<<White|1L<<Neutral8|1L<<Neutral65| \
84     1L<<Neutral5|1L<<Neutral35|1L<<Black)
85 greg 2.4
86 greg 2.8 #define SATFLGS (1L<<Red|1L<<Green|1L<<Blue|1L<<Magenta|1L<<Yellow| \
87     1L<<Cyan|1L<<Orange|1L<<Purple|1L<<PurplishBlue| \
88     1L<<YellowGreen|1<<OrangeYellow|1L<<BlueFlower)
89 greg 2.4
90 greg 2.8 #define UNSFLGS (1L<<DarkSkin|1L<<LightSkin|1L<<BlueSky|1L<<Foliage| \
91     1L<<BluishGreen|1L<<ModerateRed)
92 greg 2.7
93 greg 2.8 #define REQFLGS NEUFLGS /* need these colors */
94     #define MODFLGS (NEUFLGS|UNSFLGS) /* should be in gamut */
95
96 greg 2.9 #define RG_BORD 0 /* patch border */
97     #define RG_CENT 01 /* central region of patch */
98     #define RG_ORIG 02 /* original color region */
99     #define RG_CORR 04 /* corrected color region */
100 greg 2.7
101 gwlarson 2.16 #ifndef DISPCOM
102     #define DISPCOM "ximage -op %s"
103     #endif
104
105 greg 2.11 int scanning = 1; /* scanned input (or recorded output)? */
106 greg 2.14 double irrad = 1.0; /* irradiance multiplication factor */
107     int rawmap = 0; /* put out raw color mapping? */
108 greg 2.11
109 greg 2.1 int xmax, ymax; /* input image dimensions */
110     int bounds[4][2]; /* image coordinates of chart corners */
111     double imgxfm[3][3]; /* coordinate transformation matrix */
112
113 greg 2.7 COLOR inpRGB[24]; /* measured or scanned input colors */
114     long inpflags = 0; /* flags of which colors were input */
115 greg 2.8 long gmtflags = 0; /* flags of out-of-gamut colors */
116 greg 2.1
117 greg 2.2 COLOR bramp[NMBNEU][2]; /* brightness ramp (per primary) */
118 greg 2.13 COLORMAT solmat; /* color mapping matrix */
119     COLOR colmin, colmax; /* gamut limits */
120 greg 2.1
121 greg 2.14 WARP3D *wcor = NULL; /* color space warp */
122
123 greg 2.4 FILE *debugfp = NULL; /* debug output picture */
124 greg 2.1 char *progname;
125
126
127     main(argc, argv)
128     int argc;
129     char **argv;
130     {
131     int i;
132
133     progname = argv[0];
134 greg 2.7 for (i = 1; i < argc && argv[i][0] == '-'; i++)
135     switch (argv[i][1]) {
136     case 'd': /* debug output */
137     i++;
138     if (badarg(argc-i, argv+i, "s"))
139     goto userr;
140     if ((debugfp = fopen(argv[i], "w")) == NULL) {
141     perror(argv[i]);
142     exit(1);
143     }
144 greg 2.1 #ifdef MSDOS
145 greg 2.7 setmode(fileno(debugfp), O_BINARY);
146 greg 2.1 #endif
147 greg 2.7 newheader("RADIANCE", debugfp); /* start */
148     printargs(argc, argv, debugfp); /* header */
149     break;
150     case 'p': /* picture position */
151     if (badarg(argc-i-1, argv+i+1, "iiiiiiii"))
152     goto userr;
153     bounds[0][0] = atoi(argv[++i]);
154     bounds[0][1] = atoi(argv[++i]);
155     bounds[1][0] = atoi(argv[++i]);
156     bounds[1][1] = atoi(argv[++i]);
157     bounds[2][0] = atoi(argv[++i]);
158     bounds[2][1] = atoi(argv[++i]);
159     bounds[3][0] = atoi(argv[++i]);
160     bounds[3][1] = atoi(argv[++i]);
161 greg 2.11 scanning = 2;
162 greg 2.7 break;
163 gwlarson 2.16 case 'P': /* pick position */
164     scanning = 3;
165     break;
166 greg 2.14 case 'i': /* irradiance factor */
167     i++;
168     if (badarg(argc-i, argv+i, "f"))
169     goto userr;
170     irrad = atof(argv[i]);
171     break;
172     case 'm': /* raw map output */
173     rawmap = 1;
174     break;
175 greg 2.7 case 'c': /* color input */
176 greg 2.11 scanning = 0;
177 greg 2.7 break;
178     default:
179     goto userr;
180     }
181     /* open files */
182     if (i < argc && freopen(argv[i], "r", stdin) == NULL) {
183 greg 2.13 perror(argv[i]);
184 greg 2.1 exit(1);
185     }
186 greg 2.7 if (i+1 < argc && freopen(argv[i+1], "w", stdout) == NULL) {
187 greg 2.13 perror(argv[i+1]);
188 greg 2.1 exit(1);
189     }
190 greg 2.11 if (scanning) { /* load input picture header */
191 greg 2.1 #ifdef MSDOS
192 greg 2.7 setmode(fileno(stdin), O_BINARY);
193 greg 2.1 #endif
194 greg 2.7 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
195     fgetresolu(&xmax, &ymax, stdin) < 0) {
196     fprintf(stderr, "%s: bad input picture\n", progname);
197     exit(1);
198     }
199 gwlarson 2.16 if (scanning == 3) {
200     if (i >= argc)
201     goto userr;
202     pickchartpos(argv[i]);
203     scanning = 2;
204     }
205 greg 2.7 } else { /* else set default xmax and ymax */
206     xmax = 512;
207     ymax = 2*512/3;
208 greg 2.1 }
209 greg 2.11 if (scanning != 2) { /* use default boundaries */
210 greg 2.1 bounds[0][0] = bounds[2][0] = .029*xmax + .5;
211     bounds[0][1] = bounds[1][1] = .956*ymax + .5;
212     bounds[1][0] = bounds[3][0] = .971*xmax + .5;
213     bounds[2][1] = bounds[3][1] = .056*ymax + .5;
214     }
215     init(); /* initialize */
216 greg 2.11 if (scanning) /* get picture colors */
217 greg 2.7 getpicture();
218     else
219     getcolors();
220 greg 2.2 compute(); /* compute color mapping */
221 greg 2.14 if (rawmap) { /* print out raw correspondence */
222     register int j;
223
224     printf("# Color correspondence produced by:\n#\t\t");
225     printargs(argc, argv, stdout);
226 greg 2.15 printf("#\tUsage: pcwarp %s uncorrected.pic > corrected.pic\n",
227 greg 2.11 i+1 < argc ? argv[i+1] : "{this_file}");
228 greg 2.14 printf("#\t Or: pcond [options] -m %s orig.pic > output.pic\n",
229     i+1 < argc ? argv[i+1] : "{this_file}");
230     for (j = 0; j < 24; j++)
231     printf("%f %f %f %f %f %f\n",
232     colval(inpRGB[j],RED), colval(inpRGB[j],GRN),
233     colval(inpRGB[j],BLU), colval(mbRGB[j],RED),
234     colval(mbRGB[j],GRN), colval(mbRGB[j],BLU));
235     if (scanning && debugfp != NULL)
236     cwarp(); /* color warp for debugging */
237     } else { /* print color mapping */
238     /* print header */
239     printf("{\n\tColor correction file computed by:\n\t\t");
240     printargs(argc, argv, stdout);
241     printf("\n\tUsage: pcomb -f %s uncorrected.pic > corrected.pic\n",
242     i+1 < argc ? argv[i+1] : "{this_file}");
243     if (!scanning)
244     printf("\t Or: pcond [options] -f %s orig.pic > output.pic\n",
245     i+1 < argc ? argv[i+1] : "{this_file}");
246     printf("}\n");
247     putmapping(); /* put out color mapping */
248     }
249 greg 2.7 if (debugfp != NULL) /* put out debug picture */
250 greg 2.11 if (scanning)
251 greg 2.7 picdebug();
252     else
253     clrdebug();
254 greg 2.1 exit(0);
255     userr:
256 greg 2.7 fprintf(stderr,
257 gwlarson 2.16 "Usage: %s [-d dbg.pic][-P | -p xul yul xur yur xll yll xlr ylr][-i irrad][-m] input.pic [output.{cal|cwp}]\n",
258 greg 2.1 progname);
259 greg 2.14 fprintf(stderr, " or: %s [-d dbg.pic][-i irrad][-m] -c [xyY.dat [output.{cal|cwp}]]\n",
260 greg 2.7 progname);
261 greg 2.1 exit(1);
262     }
263
264
265     init() /* initialize */
266     {
267     double quad[4][2];
268 greg 2.7 register int i;
269 greg 2.1 /* make coordinate transformation */
270     quad[0][0] = bounds[0][0];
271     quad[0][1] = bounds[0][1];
272     quad[1][0] = bounds[1][0];
273     quad[1][1] = bounds[1][1];
274     quad[2][0] = bounds[3][0];
275     quad[2][1] = bounds[3][1];
276     quad[3][0] = bounds[2][0];
277     quad[3][1] = bounds[2][1];
278
279     if (pmap_quad_rect(0., 0., 6., 4., quad, imgxfm) == PMAP_BAD) {
280     fprintf(stderr, "%s: bad chart boundaries\n", progname);
281     exit(1);
282     }
283 greg 2.7 /* map MacBeth colors to RGB space */
284 greg 2.14 for (i = 0; i < 24; i++) {
285 greg 2.7 xyY2RGB(mbRGB[i], mbxyY[i]);
286 greg 2.14 scalecolor(mbRGB[i], irrad);
287     }
288 greg 2.1 }
289
290
291     int
292 greg 2.9 chartndx(x, y, np) /* find color number for position */
293 greg 2.1 int x, y;
294 greg 2.9 int *np;
295 greg 2.1 {
296     double ipos[3], cpos[3];
297     int ix, iy;
298     double fx, fy;
299
300     ipos[0] = x;
301     ipos[1] = y;
302     ipos[2] = 1;
303     mx3d_transform(ipos, imgxfm, cpos);
304     cpos[0] /= cpos[2];
305     cpos[1] /= cpos[2];
306     if (cpos[0] < 0. || cpos[0] >= 6. || cpos[1] < 0. || cpos[1] >= 4.)
307 greg 2.9 return(RG_BORD);
308 greg 2.1 ix = cpos[0];
309     iy = cpos[1];
310     fx = cpos[0] - ix;
311     fy = cpos[1] - iy;
312 greg 2.9 *np = iy*6 + ix;
313     if (fx >= 0.35 && fx < 0.65 && fy >= 0.35 && fy < 0.65)
314     return(RG_CENT);
315     if (fx < 0.05 || fx >= 0.95 || fy < 0.05 || fy >= 0.95)
316     return(RG_BORD);
317     if (fx >= 0.5) /* right side is corrected */
318     return(RG_CORR);
319     return(RG_ORIG); /* left side is original */
320 greg 2.1 }
321
322
323 greg 2.7 getpicture() /* load in picture colors */
324 greg 2.1 {
325     COLR *scanln;
326     COLOR pval;
327     int ccount[24];
328     double d;
329 greg 2.9 int y, i;
330     register int x;
331 greg 2.1
332     scanln = (COLR *)malloc(xmax*sizeof(COLR));
333     if (scanln == NULL) {
334     perror(progname);
335     exit(1);
336     }
337     for (i = 0; i < 24; i++) {
338 greg 2.7 setcolor(inpRGB[i], 0., 0., 0.);
339 greg 2.1 ccount[i] = 0;
340     }
341     for (y = ymax-1; y >= 0; y--) {
342     if (freadcolrs(scanln, xmax, stdin) < 0) {
343     fprintf(stderr, "%s: error reading input picture\n",
344     progname);
345     exit(1);
346     }
347 greg 2.9 for (x = 0; x < xmax; x++)
348     if (chartndx(x, y, &i) == RG_CENT) {
349 greg 2.1 colr_color(pval, scanln[x]);
350 greg 2.7 addcolor(inpRGB[i], pval);
351 greg 2.1 ccount[i]++;
352     }
353     }
354 greg 2.7 for (i = 0; i < 24; i++) { /* compute averages */
355     if (ccount[i] == 0)
356     continue;
357     d = 1./ccount[i];
358     scalecolor(inpRGB[i], d);
359     inpflags |= 1L<<i;
360     }
361 greg 2.17 free((void *)scanln);
362 greg 2.7 }
363
364
365     getcolors() /* get xyY colors from standard input */
366     {
367     int gotwhite = 0;
368     COLOR whiteclr;
369     int n;
370     float xyYin[3];
371
372     while (fgetval(stdin, 'i', &n) == 1) { /* read colors */
373     if (n < 0 | n > 24 ||
374     fgetval(stdin, 'f', &xyYin[0]) != 1 ||
375     fgetval(stdin, 'f', &xyYin[1]) != 1 ||
376     fgetval(stdin, 'f', &xyYin[2]) != 1 ||
377 greg 2.12 xyYin[0] < 0. | xyYin[1] < 0. ||
378     xyYin[0] + xyYin[1] > 1.) {
379 greg 2.7 fprintf(stderr, "%s: bad color input data\n",
380 greg 2.1 progname);
381     exit(1);
382     }
383 greg 2.7 if (n == 0) { /* calibration white */
384     xyY2RGB(whiteclr, xyYin);
385     gotwhite++;
386     } else { /* standard color */
387     n--;
388     xyY2RGB(inpRGB[n], xyYin);
389     inpflags |= 1L<<n;
390     }
391 greg 2.1 }
392 greg 2.7 /* normalize colors */
393     if (!gotwhite) {
394     if (!(inpflags & 1L<<White)) {
395     fprintf(stderr, "%s: missing input for White\n",
396     progname);
397     exit(1);
398     }
399     setcolor(whiteclr,
400     colval(inpRGB[White],RED)/colval(mbRGB[White],RED),
401     colval(inpRGB[White],GRN)/colval(mbRGB[White],GRN),
402     colval(inpRGB[White],BLU)/colval(mbRGB[White],BLU));
403     }
404     for (n = 0; n < 24; n++)
405     if (inpflags & 1L<<n)
406     setcolor(inpRGB[n],
407     colval(inpRGB[n],RED)/colval(whiteclr,RED),
408     colval(inpRGB[n],GRN)/colval(whiteclr,GRN),
409     colval(inpRGB[n],BLU)/colval(whiteclr,BLU));
410 greg 2.1 }
411
412
413 greg 2.2 bresp(y, x) /* piecewise linear interpolation of primaries */
414     COLOR y, x;
415 greg 2.1 {
416 greg 2.2 register int i, n;
417 greg 2.1
418 greg 2.2 for (i = 0; i < 3; i++) {
419 greg 2.5 for (n = 0; n < NMBNEU-2; n++)
420     if (colval(x,i) < colval(bramp[n+1][0],i))
421     break;
422 greg 2.8 colval(y,i) = ((colval(bramp[n+1][0],i) - colval(x,i)) *
423 greg 2.2 colval(bramp[n][1],i) +
424     (colval(x,i) - colval(bramp[n][0],i)) *
425     colval(bramp[n+1][1],i)) /
426     (colval(bramp[n+1][0],i) - colval(bramp[n][0],i));
427     }
428 greg 2.1 }
429
430
431 greg 2.2 compute() /* compute color mapping */
432 greg 2.1 {
433 greg 2.8 COLOR clrin[24], clrout[24];
434     long cflags;
435     COLOR ctmp;
436 greg 2.13 register int i, n;
437 greg 2.7 /* did we get what we need? */
438     if ((inpflags & REQFLGS) != REQFLGS) {
439     fprintf(stderr, "%s: missing required input colors\n",
440     progname);
441     exit(1);
442 greg 2.2 }
443 greg 2.1 /* compute piecewise luminance curve */
444     for (i = 0; i < NMBNEU; i++) {
445 greg 2.7 copycolor(bramp[i][0], inpRGB[mbneu[i]]);
446 greg 2.2 copycolor(bramp[i][1], mbRGB[mbneu[i]]);
447 greg 2.1 }
448 greg 2.13 /* compute color space gamut */
449     if (scanning) {
450     copycolor(colmin, cblack);
451     copycolor(colmax, cwhite);
452 greg 2.14 scalecolor(colmax, irrad);
453 greg 2.13 } else
454     for (i = 0; i < 3; i++) {
455     colval(colmin,i) = colval(bramp[0][0],i) -
456     colval(bramp[0][1],i) *
457     (colval(bramp[1][0],i)-colval(bramp[0][0],i)) /
458     (colval(bramp[1][1],i)-colval(bramp[1][0],i));
459     colval(colmax,i) = colval(bramp[NMBNEU-2][0],i) +
460     (1.-colval(bramp[NMBNEU-2][1],i)) *
461     (colval(bramp[NMBNEU-1][0],i) -
462     colval(bramp[NMBNEU-2][0],i)) /
463     (colval(bramp[NMBNEU-1][1],i) -
464     colval(bramp[NMBNEU-2][1],i));
465     }
466 greg 2.8 /* compute color mapping */
467     do {
468     cflags = inpflags & ~gmtflags;
469     n = 0; /* compute transform matrix */
470     for (i = 0; i < 24; i++)
471     if (cflags & 1L<<i) {
472     bresp(clrin[n], inpRGB[i]);
473     copycolor(clrout[n], mbRGB[i]);
474     n++;
475     }
476     compsoln(clrin, clrout, n);
477 greg 2.14 if (irrad > 0.99 && irrad < 1.01) /* check gamut */
478     for (i = 0; i < 24; i++)
479     if (cflags & 1L<<i && cvtcolor(ctmp, mbRGB[i]))
480     gmtflags |= 1L<<i;
481 greg 2.8 } while (cflags & gmtflags);
482     if (gmtflags & MODFLGS)
483     fprintf(stderr,
484     "%s: warning - some moderate colors are out of gamut\n",
485     progname);
486 greg 2.2 }
487
488
489 greg 2.14 putmapping() /* put out color mapping */
490 greg 2.2 {
491     static char cchar[3] = {'r', 'g', 'b'};
492     register int i, j;
493 greg 2.1 /* print brightness mapping */
494 greg 2.2 for (j = 0; j < 3; j++) {
495     printf("%cxa(i) : select(i", cchar[j]);
496     for (i = 0; i < NMBNEU; i++)
497     printf(",%g", colval(bramp[i][0],j));
498     printf(");\n");
499     printf("%cya(i) : select(i", cchar[j]);
500     for (i = 0; i < NMBNEU; i++)
501     printf(",%g", colval(bramp[i][1],j));
502     printf(");\n");
503     printf("%cfi(n) = if(n-%g, %d, if(%cxa(n+1)-%c, n, %cfi(n+1)));\n",
504     cchar[j], NMBNEU-1.5, NMBNEU-1, cchar[j],
505     cchar[j], cchar[j]);
506     printf("%cndx = %cfi(1);\n", cchar[j], cchar[j]);
507 greg 2.11 printf("%c%c = ((%cxa(%cndx+1)-%c)*%cya(%cndx) + ",
508     cchar[j], scanning?'n':'o', cchar[j],
509     cchar[j], cchar[j], cchar[j], cchar[j]);
510 greg 2.2 printf("(%c-%cxa(%cndx))*%cya(%cndx+1)) /\n",
511     cchar[j], cchar[j], cchar[j],
512     cchar[j], cchar[j]);
513     printf("\t\t(%cxa(%cndx+1) - %cxa(%cndx)) ;\n",
514     cchar[j], cchar[j], cchar[j], cchar[j]);
515     }
516 greg 2.1 /* print color mapping */
517 greg 2.11 if (scanning) {
518     printf("r = ri(1); g = gi(1); b = bi(1);\n");
519     printf("ro = %g*rn + %g*gn + %g*bn ;\n",
520     solmat[0][0], solmat[0][1], solmat[0][2]);
521     printf("go = %g*rn + %g*gn + %g*bn ;\n",
522     solmat[1][0], solmat[1][1], solmat[1][2]);
523     printf("bo = %g*rn + %g*gn + %g*bn ;\n",
524     solmat[2][0], solmat[2][1], solmat[2][2]);
525     } else {
526     printf("r1 = ri(1); g1 = gi(1); b1 = bi(1);\n");
527     printf("r = %g*r1 + %g*g1 + %g*b1 ;\n",
528     solmat[0][0], solmat[0][1], solmat[0][2]);
529     printf("g = %g*r1 + %g*g1 + %g*b1 ;\n",
530     solmat[1][0], solmat[1][1], solmat[1][2]);
531     printf("b = %g*r1 + %g*g1 + %g*b1 ;\n",
532     solmat[2][0], solmat[2][1], solmat[2][2]);
533     }
534 greg 2.1 }
535
536
537 greg 2.4 compsoln(cin, cout, n) /* solve 3xN system using least-squares */
538 greg 2.2 COLOR cin[], cout[];
539 greg 2.1 int n;
540     {
541     extern double mx3d_adjoint(), fabs();
542     double mat[3][3], invmat[3][3];
543     double det;
544     double colv[3], rowv[3];
545 greg 2.4 register int i, j, k;
546 greg 2.1
547 greg 2.8 if (n < 3) {
548     fprintf(stderr, "%s: too few colors to match!\n", progname);
549 greg 2.1 exit(1);
550     }
551 greg 2.4 if (n == 3)
552     for (i = 0; i < 3; i++)
553     for (j = 0; j < 3; j++)
554     mat[i][j] = colval(cin[j],i);
555     else { /* compute A^t A */
556     for (i = 0; i < 3; i++)
557     for (j = i; j < 3; j++) {
558     mat[i][j] = 0.;
559     for (k = 0; k < n; k++)
560     mat[i][j] += colval(cin[k],i) *
561     colval(cin[k],j);
562     }
563     for (i = 1; i < 3; i++) /* using symmetry */
564     for (j = 0; j < i; j++)
565     mat[i][j] = mat[j][i];
566     }
567 greg 2.1 det = mx3d_adjoint(mat, invmat);
568     if (fabs(det) < 1e-4) {
569     fprintf(stderr, "%s: cannot compute color mapping\n",
570     progname);
571     solmat[0][0] = solmat[1][1] = solmat[2][2] = 1.;
572     solmat[0][1] = solmat[0][2] = solmat[1][0] =
573     solmat[1][2] = solmat[2][0] = solmat[2][1] = 0.;
574     return;
575     }
576     for (i = 0; i < 3; i++)
577     for (j = 0; j < 3; j++)
578     invmat[i][j] /= det;
579     for (i = 0; i < 3; i++) {
580 greg 2.4 if (n == 3)
581     for (j = 0; j < 3; j++)
582     colv[j] = colval(cout[j],i);
583     else
584     for (j = 0; j < 3; j++) {
585     colv[j] = 0.;
586     for (k = 0; k < n; k++)
587     colv[j] += colval(cout[k],i) *
588     colval(cin[k],j);
589     }
590 greg 2.3 mx3d_transform(colv, invmat, rowv);
591 greg 2.1 for (j = 0; j < 3; j++)
592 greg 2.3 solmat[i][j] = rowv[j];
593 greg 2.1 }
594     }
595
596 greg 2.3
597 greg 2.14 cwarp() /* compute color warp map */
598     {
599     register int i;
600
601     if ((wcor = new3dw(W3EXACT)) == NULL)
602     goto memerr;
603     for (i = 0; i < 24; i++)
604     if (!add3dpt(wcor, inpRGB[i], mbRGB[i]))
605     goto memerr;
606     return;
607     memerr:
608     perror(progname);
609     exit(1);
610     }
611
612
613 greg 2.13 int
614 greg 2.1 cvtcolor(cout, cin) /* convert color according to our mapping */
615     COLOR cout, cin;
616     {
617 greg 2.8 COLOR ctmp;
618 greg 2.13 int clipped;
619 greg 2.8
620 greg 2.14 if (wcor != NULL) {
621     clipped = warp3d(cout, cin, wcor);
622     clipped |= clipgamut(cout,bright(cout),CGAMUT,colmin,colmax);
623     } else if (scanning) {
624 greg 2.11 bresp(ctmp, cin);
625 greg 2.13 clipped = cresp(cout, ctmp);
626 greg 2.11 } else {
627 greg 2.13 clipped = cresp(ctmp, cin);
628 greg 2.11 bresp(cout, ctmp);
629     }
630 greg 2.13 return(clipped);
631 greg 2.8 }
632
633
634 greg 2.13 int
635 greg 2.8 cresp(cout, cin) /* transform color according to matrix */
636     COLOR cout, cin;
637     {
638 greg 2.13 colortrans(cout, solmat, cin);
639     return(clipgamut(cout, bright(cout), CGAMUT, colmin, colmax));
640 greg 2.1 }
641
642
643 greg 2.7 xyY2RGB(rgbout, xyYin) /* convert xyY to RGB */
644     COLOR rgbout;
645     register float xyYin[3];
646 greg 2.1 {
647 greg 2.7 COLOR ctmp;
648     double d;
649
650     d = xyYin[2] / xyYin[1];
651     ctmp[0] = xyYin[0] * d;
652     ctmp[1] = xyYin[2];
653     ctmp[2] = (1. - xyYin[0] - xyYin[1]) * d;
654 greg 2.12 /* allow negative values */
655 greg 2.13 colortrans(rgbout, xyz2rgbmat, ctmp);
656 greg 2.7 }
657
658
659     picdebug() /* put out debugging picture */
660     {
661 greg 2.8 static COLOR blkcol = BLKCOLOR;
662 greg 2.1 COLOR *scan;
663 greg 2.9 int y, i;
664     register int x, rg;
665 greg 2.1
666     if (fseek(stdin, 0L, 0) == EOF) {
667     fprintf(stderr, "%s: cannot seek on input picture\n", progname);
668     exit(1);
669     }
670     getheader(stdin, NULL, NULL); /* skip input header */
671     fgetresolu(&xmax, &ymax, stdin);
672     /* allocate scanline */
673     scan = (COLOR *)malloc(xmax*sizeof(COLOR));
674     if (scan == NULL) {
675     perror(progname);
676     exit(1);
677     }
678     /* finish debug header */
679 greg 2.5 fputformat(COLRFMT, debugfp);
680 greg 2.1 putc('\n', debugfp);
681     fprtresolu(xmax, ymax, debugfp);
682 greg 2.7 /* write debug picture */
683 greg 2.1 for (y = ymax-1; y >= 0; y--) {
684     if (freadscan(scan, xmax, stdin) < 0) {
685     fprintf(stderr, "%s: error rereading input picture\n",
686     progname);
687     exit(1);
688     }
689     for (x = 0; x < xmax; x++) {
690 greg 2.9 rg = chartndx(x, y, &i);
691     if (rg == RG_CENT) {
692 greg 2.13 if (!(1L<<i & gmtflags) || (x+y)&07) {
693 greg 2.9 copycolor(scan[x], mbRGB[i]);
694 greg 2.13 clipgamut(scan[x], bright(scan[x]),
695 greg 2.14 CGAMUT, colmin, colmax);
696 greg 2.13 } else
697 greg 2.9 copycolor(scan[x], blkcol);
698     } else if (rg == RG_CORR)
699 greg 2.1 cvtcolor(scan[x], scan[x]);
700 greg 2.9 else if (rg != RG_ORIG)
701 greg 2.8 copycolor(scan[x], blkcol);
702 greg 2.1 }
703     if (fwritescan(scan, xmax, debugfp) < 0) {
704     fprintf(stderr, "%s: error writing debugging picture\n",
705     progname);
706     exit(1);
707     }
708     }
709 greg 2.7 /* clean up */
710     fclose(debugfp);
711 greg 2.17 free((void *)scan);
712 greg 2.7 }
713
714
715     clrdebug() /* put out debug picture from color input */
716     {
717     static COLR blkclr = BLKCOLR;
718 greg 2.9 COLR mbclr[24], cvclr[24], orclr[24];
719 greg 2.7 COLR *scan;
720 greg 2.13 COLOR ctmp, ct2;
721 greg 2.9 int y, i;
722     register int x, rg;
723 greg 2.7 /* convert colors */
724     for (i = 0; i < 24; i++) {
725 greg 2.13 copycolor(ctmp, mbRGB[i]);
726     clipgamut(ctmp, bright(ctmp), CGAMUT, cblack, cwhite);
727     setcolr(mbclr[i], colval(ctmp,RED),
728     colval(ctmp,GRN), colval(ctmp,BLU));
729 greg 2.7 if (inpflags & 1L<<i) {
730 greg 2.13 copycolor(ctmp, inpRGB[i]);
731     clipgamut(ctmp, bright(ctmp), CGAMUT, cblack, cwhite);
732     setcolr(orclr[i], colval(ctmp,RED),
733 greg 2.7 colval(ctmp,GRN), colval(ctmp,BLU));
734 greg 2.14 if (rawmap)
735     copycolr(cvclr[i], mbclr[i]);
736     else {
737     bresp(ctmp, inpRGB[i]);
738     colortrans(ct2, solmat, ctmp);
739     clipgamut(ct2, bright(ct2), CGAMUT,
740     cblack, cwhite);
741     setcolr(cvclr[i], colval(ct2,RED),
742     colval(ct2,GRN),
743     colval(ct2,BLU));
744     }
745 greg 2.7 }
746     }
747     /* allocate scanline */
748     scan = (COLR *)malloc(xmax*sizeof(COLR));
749     if (scan == NULL) {
750     perror(progname);
751     exit(1);
752     }
753     /* finish debug header */
754     fputformat(COLRFMT, debugfp);
755     putc('\n', debugfp);
756     fprtresolu(xmax, ymax, debugfp);
757     /* write debug picture */
758     for (y = ymax-1; y >= 0; y--) {
759 greg 2.9 for (x = 0; x < xmax; x++) {
760     rg = chartndx(x, y, &i);
761     if (rg == RG_CENT) {
762 greg 2.8 if (!(1L<<i & gmtflags) || (x+y)&07)
763     copycolr(scan[x], mbclr[i]);
764     else
765     copycolr(scan[x], blkclr);
766 greg 2.9 } else if (rg == RG_BORD || !(1L<<i & inpflags))
767     copycolr(scan[x], blkclr);
768     else if (rg == RG_ORIG)
769     copycolr(scan[x], orclr[i]);
770     else /* rg == RG_CORR */
771 greg 2.7 copycolr(scan[x], cvclr[i]);
772 greg 2.9 }
773 greg 2.7 if (fwritecolrs(scan, xmax, debugfp) < 0) {
774     fprintf(stderr, "%s: error writing debugging picture\n",
775     progname);
776     exit(1);
777     }
778     }
779     /* clean up */
780     fclose(debugfp);
781 greg 2.17 free((void *)scan);
782 gwlarson 2.16 }
783
784
785     getpos(name, bnds, fp) /* get boundary position */
786     char *name;
787     int bnds[2];
788     FILE *fp;
789     {
790     char buf[64];
791
792     fprintf(stderr, "\tSelect corner: %s\n", name);
793     if (fgets(buf, sizeof(buf), fp) == NULL ||
794     sscanf(buf, "%d %d", &bnds[0], &bnds[1]) != 2) {
795     fprintf(stderr, "%s: read error from display process\n",
796     progname);
797     exit(1);
798     }
799     }
800
801
802     pickchartpos(pfn) /* display picture and pick chart location */
803     char *pfn;
804     {
805     char combuf[512];
806     FILE *pfp;
807
808     sprintf(combuf, DISPCOM, pfn);
809     if ((pfp = popen(combuf, "r")) == NULL) {
810     perror(combuf);
811     exit(1);
812     }
813     fputs("Use middle mouse button to select chart corners:\n", stderr);
814     getpos("upper left (dark skin)", bounds[0], pfp);
815     getpos("upper right (bluish green)", bounds[1], pfp);
816     getpos("lower left (white)", bounds[2], pfp);
817     getpos("lower right (black)", bounds[3], pfp);
818     fputs("Got it -- quit display program.\n", stderr);
819     pclose(pfp);
820 greg 2.1 }
