--- ray/src/px/macbethcal.c 1995/10/17 11:05:17 2.6 +++ ray/src/px/macbethcal.c 2024/02/22 02:07:40 2.29 @@ -1,22 +1,25 @@ -/* Copyright (c) 1995 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: macbethcal.c,v 2.29 2024/02/22 02:07:40 greg Exp $"; #endif - /* * Calibrate a scanned MacBeth Color Checker Chart * - * Produce a .cal file suitable for use with pcomb. + * Produce a .cal file suitable for use with pcomb, + * or .cwp file suitable for use with pcwarp. + * + * Warping code depends on conformance of COLOR and W3VEC types. */ -#include -#ifdef MSDOS -#include -#endif +#include + +#include "platform.h" +#include "paths.h" +#include "rtio.h" #include "color.h" #include "resolu.h" #include "pmap.h" +#include "warp3d.h" +#include "mx3.h" /* MacBeth colors */ #define DarkSkin 0 @@ -43,33 +46,33 @@ static char SCCSid[] = "$SunId$ LBL"; #define Neutral5 21 #define Neutral35 22 #define Black 23 - /* computed from 5nm spectral measurements */ + /* computed from 10nm spectral measurements */ /* CIE 1931 2 degree obs, equal-energy white */ float mbxyY[24][3] = { - {0.462, 0.3769, 0.0932961}, /* DarkSkin */ - {0.4108, 0.3542, 0.410348}, /* LightSkin */ - {0.2626, 0.267, 0.181554}, /* BlueSky */ - {0.36, 0.4689, 0.108447}, /* Foliage */ - {0.2977, 0.2602, 0.248407}, /* BlueFlower */ - {0.2719, 0.3485, 0.401156}, /* BluishGreen */ - {0.52, 0.4197, 0.357899}, /* Orange */ - {0.229, 0.1866, 0.103911}, /* PurplishBlue */ - {0.4909, 0.3262, 0.242615}, /* ModerateRed */ - {0.3361, 0.2249, 0.0600102}, /* Purple */ - {0.3855, 0.4874, 0.42963}, /* YellowGreen */ - {0.4853, 0.4457, 0.476343}, /* OrangeYellow */ - {0.2026, 0.1369, 0.0529249}, /* Blue */ - {0.3007, 0.4822, 0.221226}, /* Green */ - {0.5805, 0.3238, 0.162167}, /* Red */ - {0.4617, 0.472, 0.64909}, /* Yellow */ - {0.4178, 0.2625, 0.233662}, /* Magenta */ - {0.2038, 0.2508, 0.167275}, /* Cyan */ - {0.3358, 0.337, 0.916877}, /* White */ - {0.3338, 0.3348, 0.604678}, /* Neutral.8 */ - {0.3333, 0.3349, 0.364566}, /* Neutral.65 */ - {0.3353, 0.3359, 0.200238}, /* Neutral.5 */ - {0.3363, 0.336, 0.0878721}, /* Neutral.35 */ - {0.3346, 0.3349, 0.0308383} /* Black */ + {0.421236, 0.361196, 0.103392}, /* DarkSkin */ + {0.40868, 0.358157, 0.352867}, /* LightSkin */ + {0.265063, 0.271424, 0.185124}, /* BlueSky */ + {0.362851, 0.43055, 0.132625}, /* Foliage */ + {0.28888, 0.260851, 0.233138}, /* BlueFlower */ + {0.277642, 0.365326, 0.416443}, /* BluishGreen */ + {0.524965, 0.40068, 0.312039}, /* Orange */ + {0.225018, 0.190392, 0.114999}, /* PurplishBlue */ + {0.487199, 0.315372, 0.198616}, /* ModerateRed */ + {0.314245, 0.227231, 0.0646047}, /* Purple */ + {0.396202, 0.489732, 0.440724}, /* YellowGreen */ + {0.493297, 0.435299, 0.43444}, /* OrangeYellow */ + {0.198191, 0.149265, 0.0588122}, /* Blue */ + {0.322838, 0.487601, 0.229258}, /* Green */ + {0.561833, 0.321165, 0.126978}, /* Red */ + {0.468113, 0.467021, 0.605289}, /* Yellow */ + {0.397128, 0.248535, 0.201761}, /* Magenta */ + {0.209552, 0.276256, 0.190917}, /* Cyan */ + {0.337219, 0.339042, 0.912482}, /* White */ + {0.333283, 0.335077, 0.588297}, /* Neutral.8 */ + {0.332747, 0.334371, 0.3594}, /* Neutral.65 */ + {0.331925, 0.334202, 0.19114}, /* Neutral.5 */ + {0.330408, 0.332615, 0.0892964}, /* Neutral.35 */ + {0.331841, 0.331405, 0.0319541}, /* Black */ }; COLOR mbRGB[24]; /* MacBeth RGB values */ @@ -77,105 +80,210 @@ COLOR mbRGB[24]; /* MacBeth RGB values */ #define NMBNEU 6 /* Number of MacBeth neutral colors */ short mbneu[NMBNEU] = {Black,Neutral35,Neutral5,Neutral65,Neutral8,White}; -#define NMBMOD 16 /* Number of MacBeth unsaturated colors */ -short mbmod[NMBMOD] = { - DarkSkin,LightSkin,BlueSky,Foliage,BlueFlower,BluishGreen, - PurplishBlue,ModerateRed,YellowGreen,OrangeYellow, - Black,Neutral35,Neutral5,Neutral65,Neutral8,White - }; +#define NEUFLGS (1L< 2 && !strcmp(argv[1], "-d")) { /* debug output */ - if ((debugfp = fopen(argv[2], "w")) == NULL) { - perror(argv[2]); - exit(1); + for (i = 1; i < argc && argv[i][0] == '-'; i++) + switch (argv[i][1]) { + case 'd': /* debug output */ + i++; + if (badarg(argc-i, argv+i, "s")) + goto userr; + if ((debugfp = fopen(argv[i], "w")) == NULL) { + perror(argv[i]); + exit(1); + } + SET_FILE_BINARY(debugfp); + newheader("RADIANCE", debugfp); /* start */ + printargs(argc, argv, debugfp); /* header */ + break; + case 'p': /* picture position */ + if (badarg(argc-i-1, argv+i+1, "iiiiiiii")) + goto userr; + bounds[0][0] = atoi(argv[++i]); + bounds[0][1] = atoi(argv[++i]); + bounds[1][0] = atoi(argv[++i]); + bounds[1][1] = atoi(argv[++i]); + bounds[2][0] = atoi(argv[++i]); + bounds[2][1] = atoi(argv[++i]); + bounds[3][0] = atoi(argv[++i]); + bounds[3][1] = atoi(argv[++i]); + scanning = 2; + break; + case 'P': /* pick position */ + scanning = 3; + break; + case 'i': /* irradiance factor */ + i++; + if (badarg(argc-i, argv+i, "f")) + goto userr; + irrad = atof(argv[i]); + break; + case 'm': /* raw map output */ + rawmap = 1; + break; + case 'c': /* color input */ + scanning = 0; + break; + default: + goto userr; } -#ifdef MSDOS - setmode(fileno(debugfp), O_BINARY); -#endif - newheader("RADIANCE", debugfp); - printargs(argc, argv, debugfp); - argv += 2; - argc -= 2; - } - if (argc != 3 && argc != 11) - goto userr; - if (strcmp(argv[1], "-") && freopen(argv[1], "r", stdin) == NULL) { - perror(argv[1]); + /* open files */ + if (i < argc && freopen(argv[i], "r", stdin) == NULL) { + perror(argv[i]); exit(1); } - if (strcmp(argv[2], "-") && freopen(argv[2], "w", stdout) == NULL) { - perror(argv[2]); + if (i+1 < argc && freopen(argv[i+1], "w", stdout) == NULL) { + perror(argv[i+1]); exit(1); } -#ifdef MSDOS - setmode(fileno(stdin), O_BINARY); -#endif - if (checkheader(stdin, COLRFMT, NULL) < 0 || - fgetresolu(&xmax, &ymax, stdin) < 0) { - fprintf(stderr, "%s: bad input picture\n", progname); - exit(1); - } - /* get chart boundaries */ - if (argc == 11) { - for (i = 0; i < 4; i++) { - if (!isint(argv[2*i+3]) | !isint(argv[2*i+4])) + if (scanning) { /* load input picture header */ + SET_FILE_BINARY(stdin); + if (checkheader(stdin, COLRFMT, NULL) < 0 || + fgetresolu(&xmax, &ymax, stdin) < 0) { + fprintf(stderr, "%s: bad input picture\n", progname); + exit(1); + } + if (scanning == 3) { + if (i >= argc) goto userr; - bounds[i][0] = atoi(argv[2*i+3]); - bounds[i][1] = atoi(argv[2*i+4]); + pickchartpos(argv[i]); + scanning = 2; } - } else { + } else { /* else set default xmax and ymax */ + xmax = 512; + ymax = 2*512/3; + } + if (scanning != 2) { /* use default boundaries */ bounds[0][0] = bounds[2][0] = .029*xmax + .5; bounds[0][1] = bounds[1][1] = .956*ymax + .5; bounds[1][0] = bounds[3][0] = .971*xmax + .5; bounds[2][1] = bounds[3][1] = .056*ymax + .5; } init(); /* initialize */ - getcolors(); /* get picture colors */ + if (scanning) /* get picture colors */ + getpicture(); + else + getcolors(); compute(); /* compute color mapping */ - /* print comment */ - printf("{ Color correction file computed by %s }\n", progname); - printf("{ from scanned MacBetch color chart %s }\n", argv[1]); - putmapping(); /* put out color mapping */ - putdebug(); /* put out debug picture */ + if (rawmap) { /* print out raw correspondence */ + int j; + + printf("# Color correspondence produced by:\n#\t\t"); + printargs(argc, argv, stdout); + printf("#\tUsage: pcwarp %s uncorrected.hdr > corrected.hdr\n", + i+1 < argc ? argv[i+1] : "{this_file}"); + printf("#\t Or: pcond [options] -m %s orig.hdr > output.hdr\n", + i+1 < argc ? argv[i+1] : "{this_file}"); + for (j = 0; j < 24; j++) + printf("%f %f %f %f %f %f\n", + colval(inpRGB[j],RED), colval(inpRGB[j],GRN), + colval(inpRGB[j],BLU), colval(mbRGB[j],RED), + colval(mbRGB[j],GRN), colval(mbRGB[j],BLU)); + if (scanning && debugfp != NULL) + cwarp(); /* color warp for debugging */ + } else { /* print color mapping */ + /* print header */ + printf("{\n\tColor correction file computed by:\n\t\t"); + printargs(argc, argv, stdout); + printf("\n\tUsage: pcomb -f %s uncorrected.hdr > corrected.hdr\n", + i+1 < argc ? argv[i+1] : "{this_file}"); + if (!scanning) + printf("\t Or: pcond [options] -f %s orig.hdr > output.hdr\n", + i+1 < argc ? argv[i+1] : "{this_file}"); + printf("}\n"); + putmapping(); /* put out color mapping */ + } + if (debugfp != NULL) { /* put out debug picture */ + if (scanning) + picdebug(); + else + clrdebug(); + } exit(0); userr: - fprintf(stderr, "Usage: %s [-d dbg.pic] input.pic output.cal [xul yul xur yur xll yll xlr ylr]\n", + fprintf(stderr, +"Usage: %s [-d dbg.hdr][-P | -p xul yul xur yur xll yll xlr ylr][-i irrad][-m] input.hdr [output.{cal|cwp}]\n", progname); + fprintf(stderr, " or: %s [-d dbg.hdr][-i irrad][-m] -c [xyY.dat [output.{cal|cwp}]]\n", + progname); exit(1); + return 1; /* pro forma return */ } -init() /* initialize */ +static void +init(void) /* initialize */ { double quad[4][2]; + int i; /* make coordinate transformation */ quad[0][0] = bounds[0][0]; quad[0][1] = bounds[0][1]; @@ -190,12 +298,20 @@ init() /* initialize */ fprintf(stderr, "%s: bad chart boundaries\n", progname); exit(1); } + /* map MacBeth colors to RGB space */ + for (i = 0; i < 24; i++) { + xyY2RGB(mbRGB[i], mbxyY[i]); + scalecolor(mbRGB[i], irrad); + } } -int -chartndx(x, y) /* find color number for position */ -int x, y; +static int +chartndx( /* find color number for position */ + int x, + int y, + int *np +) { double ipos[3], cpos[3]; int ix, iy; @@ -207,26 +323,32 @@ int x, y; mx3d_transform(ipos, imgxfm, cpos); cpos[0] /= cpos[2]; cpos[1] /= cpos[2]; - if (cpos[0] < 0. || cpos[0] >= 6. || cpos[1] < 0. || cpos[1] >= 4.) - return(-1); + if ((cpos[0] < 0.) | (cpos[0] >= 6.) | (cpos[1] < 0.) | (cpos[1] >= 4.)) + return(RG_BORD); ix = cpos[0]; iy = cpos[1]; fx = cpos[0] - ix; fy = cpos[1] - iy; - if (fx < .35 || fx >= .65 || fy < .35 || fy >= .65) - return(-1); - return(iy*6 + ix); + *np = iy*6 + ix; + if ((fx >= 0.35) & (fx < 0.65) & (fy >= 0.35) & (fy < 0.65)) + return(RG_CENT); + if ((fx < 0.05) | (fx >= 0.95) | (fy < 0.05) | (fy >= 0.95)) + return(RG_BORD); + if (fx >= 0.5) /* right side is corrected */ + return(RG_CORR); + return(RG_ORIG); /* left side is original */ } -getcolors() /* load in picture colors */ +static void +getpicture(void) /* load in picture colors */ { COLR *scanln; COLOR pval; int ccount[24]; double d; - int y; - register int x, i; + int y, i; + int x; scanln = (COLR *)malloc(xmax*sizeof(COLR)); if (scanln == NULL) { @@ -234,7 +356,7 @@ getcolors() /* load in picture colors */ exit(1); } for (i = 0; i < 24; i++) { - setcolor(picRGB[i], 0., 0., 0.); + setcolor(inpRGB[i], 0., 0., 0.); ccount[i] = 0; } for (y = ymax-1; y >= 0; y--) { @@ -243,81 +365,164 @@ getcolors() /* load in picture colors */ progname); exit(1); } - for (x = 0; x < xmax; x++) { - i = chartndx(x, y); - if (i >= 0) { + for (x = 0; x < xmax; x++) + if (chartndx(x, y, &i) == RG_CENT) { colr_color(pval, scanln[x]); - addcolor(picRGB[i], pval); + addcolor(inpRGB[i], pval); ccount[i]++; } + } + for (i = 0; i < 24; i++) { /* compute averages */ + if (ccount[i] == 0) + continue; + d = 1./ccount[i]; + scalecolor(inpRGB[i], d); + inpflags |= 1L< 24) || + fgetval(stdin, 'f', &xyYin[0]) != 1 || + fgetval(stdin, 'f', &xyYin[1]) != 1 || + fgetval(stdin, 'f', &xyYin[2]) != 1 || + (xyYin[0] < 0.) | (xyYin[1] < 0.) || + xyYin[0] + xyYin[1] > 1.) { + fprintf(stderr, "%s: bad color input data\n", + progname); + exit(1); } + if (n == 0) { /* calibration white */ + xyY2RGB(whiteclr, xyYin); + gotwhite++; + } else { /* standard color */ + n--; + xyY2RGB(inpRGB[n], xyYin); + inpflags |= 1L<0); n--; ) + if (colval(bramp[i][0],n) <= + colval(bramp[i-1][0],n)+1e-7) { + fprintf(stderr, + "%s: non-increasing neutral patch\n", progname); + exit(1); + } copycolor(bramp[i][1], mbRGB[mbneu[i]]); } - /* compute color matrix */ - for (i = 0; i < NMBMOD; i++) { - bresp(clrin[i], picRGB[mbmod[i]]); - copycolor(clrout[i], mbRGB[mbmod[i]]); - } - compsoln(clrin, clrout, NMBMOD); + /* compute color space gamut */ + if (scanning) { + copycolor(colmin, cblack); + copycolor(colmax, cwhite); + scalecolor(colmax, irrad); + } else + for (i = 0; i < 3; i++) { + colval(colmin,i) = colval(bramp[0][0],i) - + colval(bramp[0][1],i) * + (colval(bramp[1][0],i)-colval(bramp[0][0],i)) / + (colval(bramp[1][1],i)-colval(bramp[0][1],i)); + colval(colmax,i) = colval(bramp[NMBNEU-2][0],i) + + (1.-colval(bramp[NMBNEU-2][1],i)) * + (colval(bramp[NMBNEU-1][0],i) - + colval(bramp[NMBNEU-2][0],i)) / + (colval(bramp[NMBNEU-1][1],i) - + colval(bramp[NMBNEU-2][1],i)); + } + /* compute color mapping */ + do { + cflags = inpflags & ~gmtflags; + n = 0; /* compute transform matrix */ + for (i = 0; i < 24; i++) + if (cflags & 1L< NMBMOD) { - fprintf(stderr, "%s: inconsistent code!\n", progname); + if (n < 3) { + fprintf(stderr, "%s: too few colors to match!\n", progname); exit(1); } if (n == 3) @@ -412,33 +630,83 @@ int n; } -cvtcolor(cout, cin) /* convert color according to our mapping */ -COLOR cout, cin; +static void +cwarp(void) /* compute color warp map */ { - double r, g, b; + int i; - bresp(cout, cin); - r = colval(cout,0)*solmat[0][0] + colval(cout,1)*solmat[0][1] - + colval(cout,2)*solmat[0][2]; - if (r < 0) r = 0; - g = colval(cout,0)*solmat[1][0] + colval(cout,1)*solmat[1][1] - + colval(cout,2)*solmat[1][2]; - if (g < 0) g = 0; - b = colval(cout,0)*solmat[2][0] + colval(cout,1)*solmat[2][1] - + colval(cout,2)*solmat[2][2]; - if (b < 0) b = 0; - setcolor(cout, r, g, b); + if ((wcor = new3dw(W3EXACT)) == NULL) + goto memerr; + for (i = 0; i < 24; i++) + if (!add3dpt(wcor, inpRGB[i], mbRGB[i])) + goto memerr; + return; +memerr: + perror(progname); + exit(1); } -putdebug() /* put out debugging picture */ +static int +cvtcolor( /* convert color according to our mapping */ + COLOR cout, + COLOR cin +) { + COLOR ctmp; + int clipped; + + if (wcor != NULL) { + clipped = warp3d(cout, cin, wcor); + clipped |= clipgamut(cout,bright(cout),CGAMUT,colmin,colmax); + } else if (scanning) { + bresp(ctmp, cin); + clipped = cresp(cout, ctmp); + } else { + clipped = cresp(ctmp, cin); + bresp(cout, ctmp); + } + return(clipped); +} + + +static int +cresp( /* transform color according to matrix */ + COLOR cout, + COLOR cin +) +{ + colortrans(cout, solmat, cin); + return(clipgamut(cout, bright(cout), CGAMUT, colmin, colmax)); +} + + +static void +xyY2RGB( /* convert xyY to RGB */ + COLOR rgbout, + float xyYin[3] +) +{ + COLOR ctmp; + double d; + + d = xyYin[2] / xyYin[1]; + ctmp[0] = xyYin[0] * d; + ctmp[1] = xyYin[2]; + ctmp[2] = (1. - xyYin[0] - xyYin[1]) * d; + /* allow negative values */ + colortrans(rgbout, xyz2rgbmat, ctmp); +} + + +static void +picdebug(void) /* put out debugging picture */ +{ + static COLOR blkcol = BLKCOLOR; COLOR *scan; - int y; - register int x, i; + int y, i; + int x, rg; - if (debugfp == NULL) - return; if (fseek(stdin, 0L, 0) == EOF) { fprintf(stderr, "%s: cannot seek on input picture\n", progname); exit(1); @@ -455,6 +723,7 @@ putdebug() /* put out debugging picture */ fputformat(COLRFMT, debugfp); putc('\n', debugfp); fprtresolu(xmax, ymax, debugfp); + /* write debug picture */ for (y = ymax-1; y >= 0; y--) { if (freadscan(scan, xmax, stdin) < 0) { fprintf(stderr, "%s: error rereading input picture\n", @@ -462,11 +731,18 @@ putdebug() /* put out debugging picture */ exit(1); } for (x = 0; x < xmax; x++) { - i = chartndx(x, y); - if (i < 0) + rg = chartndx(x, y, &i); + if (rg == RG_CENT) { + if (!(1L<= 0; y--) { + for (x = 0; x < xmax; x++) { + rg = chartndx(x, y, &i); + if (rg == RG_CENT) { + if (!(1L<
