root/radiance/ray/src/px/macbethcal.c
Sat Jun 7 05:09:46 2025 UTC (6 weeks, 4 days ago) by greg
Changes since 2.31: +1 -2 lines
Diff to previous 2.31 , to selected 2.21
Tue Jun 3 21:31:51 2025 UTC (7 weeks ago) by greg
Changes since 2.30: +2 -3 lines
Diff to previous 2.30 , to selected 2.21
Thu Feb 22 17:45:54 2024 UTC (16 months, 4 weeks ago) by greg
Changes since 2.29: +42 -23 lines
Diff to previous 2.29 , to selected 2.21
perf(macbethcal): Untested performance improvement for measured printer values
Thu Feb 22 02:07:40 2024 UTC (17 months ago) by greg
Changes since 2.28: +21 -22 lines
Diff to previous 2.28 , to selected 2.21
fix(macbethcal): Fixed bug in checking color mapping (erroneous out-of-gamut report)
Sat Dec 28 18:05:14 2019 UTC (5 years, 6 months ago) by greg
CVS Tags: rad5R3, rad5R4
Changes since 2.27: +1 -3 lines
Diff to previous 2.27 , to selected 2.21
Tue Feb 2 18:02:32 2016 UTC (9 years, 5 months ago) by greg
CVS Tags: rad5R1, rad5R2
Diff to previous 2.26 , to selected 2.21
Tue May 14 22:45:38 2013 UTC (12 years, 2 months ago) by greg
Changes since 2.25: +26 -26 lines
Diff to previous 2.25 , to selected 2.21
Update MacBeth chart values to average of 30 charts
Mon Nov 10 19:08:19 2008 UTC (16 years, 8 months ago) by greg
CVS Tags: rad4R0, rad4R1
Changes since 2.24: +7 -7 lines
Diff to previous 2.24 , to selected 2.21
Wed Dec 15 06:30:36 2004 UTC (20 years, 7 months ago) by greg
Changes since 2.23: +8 -1 lines
Diff to previous 2.23 , to selected 2.21
Added check for problem neutral patches
Sun Mar 28 20:33:13 2004 UTC (21 years, 3 months ago) by schorsch
Changes since 2.22: +84 -36 lines
Diff to previous 2.22 , to selected 2.21
Mon Nov 10 12:28:56 2003 UTC (21 years, 8 months ago) by schorsch
Changes since 2.21: +3 -3 lines
Diff to previous 2.21
Fixed size of command line buffers, and allow spaces in input file paths.
Revision 2.21 - (view) (download) (annotate) - [selected]
Mon Oct 27 10:24:51 2003 UTC (21 years, 9 months ago) by schorsch
Diff to previous 2.20
Various compatibility fixes.
Sun Jul 27 22:12:03 2003 UTC (22 years ago) by schorsch
Diff to previous 2.19 , to selected 2.21
Mon Jul 21 22:30:18 2003 UTC (22 years ago) by schorsch
Diff to previous 2.18 , to selected 2.21
Thu Jun 5 19:29:34 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 2.17: +6 -11 lines
Diff to previous 2.17 , to selected 2.21
Sat Feb 22 02:07:27 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.16: +5 -9 lines
Diff to previous 2.16 , to selected 2.21
Fri Jul 16 16:12:20 1999 UTC (26 years ago) by gwlarson
Changes since 2.15: +54 -3 lines
Diff to previous 2.15 , to selected 2.21
added -P option for direct display and picking of corners using ximage
Thu Feb 6 11:36:53 1997 UTC (28 years, 5 months ago) by greg
Diff to previous 2.14 , to selected 2.21
minor correction in usage message
Tue Feb 4 16:04:23 1997 UTC (28 years, 5 months ago) by greg
Changes since 2.13: +89 -25 lines
Diff to previous 2.13 , to selected 2.21
added -m option to print out raw correspondence map for pcwarp
Fri Jan 31 15:56:17 1997 UTC (28 years, 5 months ago) by greg
Changes since 2.12: +50 -42 lines
Diff to previous 2.12 , to selected 2.21
added gamut mapping for display devices (doesn't work w/ pcomb)
Thu Jan 30 19:14:11 1997 UTC (28 years, 5 months ago) by greg
Changes since 2.11: +5 -3 lines
Diff to previous 2.11 , to selected 2.21
changed colortrans() to optionally allow negative results
Thu Jan 30 17:07:42 1997 UTC (28 years, 5 months ago) by greg
Changes since 2.10: +41 -22 lines
Diff to previous 2.10 , to selected 2.21
changed ordering so color trans. before non-lin. corr. for output
Wed Nov 1 09:04:16 1995 UTC (29 years, 8 months ago) by greg
Changes since 2.9: +3 -1 lines
Diff to previous 2.9 , to selected 2.21
added comment on pcomb usage to output file
Mon Oct 23 12:20:03 1995 UTC (29 years, 9 months ago) by greg
Changes since 2.8: +44 -33 lines
Diff to previous 2.8 , to selected 2.21
changed debug output to show original and corrected colors both
Mon Oct 23 10:19:40 1995 UTC (29 years, 9 months ago) by greg
Changes since 2.7: +77 -43 lines
Diff to previous 2.7 , to selected 2.21
added automatic detection of out-of-gamut colors
Fri Oct 20 15:26:11 1995 UTC (29 years, 9 months ago) by greg
Changes since 2.6: +223 -68 lines
Diff to previous 2.6 , to selected 2.21
added -c option for color input and changed option ordering
Tue Oct 17 11:05:17 1995 UTC (29 years, 9 months ago) by greg
Diff to previous 2.5 , to selected 2.21
took Purple out of unsaturated color list, for incandescent lighting
Tue Oct 17 10:24:21 1995 UTC (29 years, 9 months ago) by greg
Diff to previous 2.4 , to selected 2.21
fixed a couple of bugs in the debug ouput picture
Wed Oct 11 20:48:17 1995 UTC (29 years, 9 months ago) by greg
Changes since 2.3: +74 -62 lines
Diff to previous 2.3 , to selected 2.21
working version using least-squares matrix computation
Wed Oct 11 18:52:00 1995 UTC (29 years, 9 months ago) by greg
Changes since 2.2: +63 -14 lines
Diff to previous 2.2 , to selected 2.21
non-working version using buggy svdcmp() routine
Wed Oct 11 11:57:41 1995 UTC (29 years, 9 months ago) by greg
Changes since 2.1: +82 -64 lines
Diff to previous 2.1 , to selected 2.21
numerous changes and improvements
Wed Oct 11 10:40:13 1995 UTC (29 years, 9 months ago) by greg
Diff to selected 2.21
