root/Development/ray/src/px/macbethcal.c
Revision: 2.32
Committed: Sat Jun 7 05:09:46 2025 UTC (5 months, 1 week ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.31: +1 -2 lines
2 static const char RCSid[] = "$Id: macbethcal.c,v 2.31 2025/06/03 21:31:51 greg Exp $";
5 * Calibrate a scanned MacBeth Color Checker Chart
6 *
7 * Produce a .cal file suitable for use with pcomb,
8 * or .cwp file suitable for use with pcwarp.
9 *
10 * Warping code depends on conformance of COLOR and W3VEC types.
11 */
12
13 #include <math.h>
14
15 #include "platform.h"
16 #include "rtio.h"
17 #include "color.h"
18 #include "resolu.h"
19 #include "pmap.h"
20 #include "warp3d.h"
21 #include "mx3.h"
22
23 /* MacBeth colors */
24 #define DarkSkin 0
25 #define LightSkin 1
26 #define BlueSky 2
27 #define Foliage 3
28 #define BlueFlower 4
29 #define BluishGreen 5
30 #define Orange 6
31 #define PurplishBlue 7
32 #define ModerateRed 8
33 #define Purple 9
34 #define YellowGreen 10
35 #define OrangeYellow 11
36 #define Blue 12
37 #define Green 13
38 #define Red 14
39 #define Yellow 15
40 #define Magenta 16
41 #define Cyan 17
42 #define White 18
43 #define Neutral8 19
44 #define Neutral65 20
45 #define Neutral5 21
46 #define Neutral35 22
47 #define Black 23
48 /* computed from 10nm spectral measurements */
49 /* CIE 1931 2 degree obs, equal-energy white */
50 float mbxyY[24][3] = {
51 {0.421236, 0.361196, 0.103392}, /* DarkSkin */
52 {0.40868, 0.358157, 0.352867}, /* LightSkin */
53 {0.265063, 0.271424, 0.185124}, /* BlueSky */
54 {0.362851, 0.43055, 0.132625}, /* Foliage */
55 {0.28888, 0.260851, 0.233138}, /* BlueFlower */
56 {0.277642, 0.365326, 0.416443}, /* BluishGreen */
57 {0.524965, 0.40068, 0.312039}, /* Orange */
58 {0.225018, 0.190392, 0.114999}, /* PurplishBlue */
59 {0.487199, 0.315372, 0.198616}, /* ModerateRed */
60 {0.314245, 0.227231, 0.0646047}, /* Purple */
61 {0.396202, 0.489732, 0.440724}, /* YellowGreen */
62 {0.493297, 0.435299, 0.43444}, /* OrangeYellow */
63 {0.198191, 0.149265, 0.0588122}, /* Blue */
64 {0.322838, 0.487601, 0.229258}, /* Green */
65 {0.561833, 0.321165, 0.126978}, /* Red */
66 {0.468113, 0.467021, 0.605289}, /* Yellow */
67 {0.397128, 0.248535, 0.201761}, /* Magenta */
68 {0.209552, 0.276256, 0.190917}, /* Cyan */
69 {0.337219, 0.339042, 0.912482}, /* White */
70 {0.333283, 0.335077, 0.588297}, /* Neutral.8 */
71 {0.332747, 0.334371, 0.3594}, /* Neutral.65 */
72 {0.331925, 0.334202, 0.19114}, /* Neutral.5 */
73 {0.330408, 0.332615, 0.0892964}, /* Neutral.35 */
74 {0.331841, 0.331405, 0.0319541}, /* Black */
75 };
76
77 COLOR mbRGB[24]; /* MacBeth RGB values */
78
79 #define NMBNEU 6 /* Number of MacBeth neutral colors */
80 short mbneu[NMBNEU] = {Black,Neutral35,Neutral5,Neutral65,Neutral8,White};
81
82 #define NEUFLGS (1L<<White|1L<<Neutral8|1L<<Neutral65| \
83 1L<<Neutral5|1L<<Neutral35|1L<<Black)
84
85 #define SATFLGS (1L<<Red|1L<<Green|1L<<Blue|1L<<Magenta|1L<<Yellow| \
86 1L<<Cyan|1L<<Orange|1L<<Purple|1L<<PurplishBlue| \
87 1L<<YellowGreen|1<<OrangeYellow|1L<<BlueFlower)
88
89 #define UNSFLGS (1L<<DarkSkin|1L<<LightSkin|1L<<BlueSky|1L<<Foliage| \
90 1L<<BluishGreen|1L<<ModerateRed)
91
92 #define REQFLGS NEUFLGS /* need these colors */
93 #define MODFLGS (NEUFLGS|UNSFLGS) /* should be in gamut */
94
95 #define RG_BORD 0 /* patch border */
96 #define RG_CENT 01 /* central region of patch */
97 #define RG_ORIG 02 /* original color region */
98 #define RG_CORR 04 /* corrected color region */
99
100 #ifndef DISPCOM
101 #define DISPCOM "ximage -e auto -op \"%s\""
102 #endif
103
104 int scanning = 1; /* scanned input (or recorded output)? */
105 double irrad = 1.0; /* irradiance multiplication factor */
106 int rawmap = 0; /* put out raw color mapping? */
107
108 int xmax, ymax; /* input image dimensions */
109 int bounds[4][2]; /* image coordinates of chart corners */
110 double imgxfm[3][3]; /* coordinate transformation matrix */
111
112 COLOR inpRGB[24]; /* measured or scanned input colors */
113 long inpflags = 0; /* flags of which colors were input */
114 long gmtflags = 0; /* flags of out-of-gamut colors */
115
116 COLOR bramp[NMBNEU][2]; /* brightness ramp (per primary) */
117 COLORMAT solmat; /* color mapping matrix */
118 COLOR colmin, colmax; /* gamut limits */
119
120 WARP3D *wcor = NULL; /* color space warp */
121
122 FILE *debugfp = NULL; /* debug output picture */
123
124 static void init(void);
125 static int chartndx(int x, int y, int *np);
126 static void getpicture(void);
127 static void getcolors(void);
128 static void bresp(COLOR y, COLOR x);
129 static void ibresp(COLOR y, COLOR x);
130 static void compute(void);
131 static void putmapping(void);
132 static void compsoln(COLOR cin[], COLOR cout[], int n);
133 static void cwarp(void);
134 static int cvtcolor(COLOR cout, COLOR cin);
135 static int cresp(COLOR cout, COLOR cin);
136 static void xyY2RGB(COLOR rgbout, float xyYin[3]);
137 static void picdebug(void);
138 static void clrdebug(void);
139 static void getpos(char *name, int bnds[2], FILE *fp);
140 static void pickchartpos(char *pfn);
141
142
143 int
144 main(
145 int argc,
146 char **argv
147 )
148 {
149 int i;
150
151 fixargv0(argv[0]); /* sets global progname */
152 for (i = 1; i < argc && argv[i][0] == '-'; i++)
153 switch (argv[i][1]) {
154 case 'd': /* debug output */
155 i++;
156 if (badarg(argc-i, argv+i, "s"))
157 goto userr;
158 if ((debugfp = fopen(argv[i], "w")) == NULL) {
159 perror(argv[i]);
160 exit(1);
161 }
162 SET_FILE_BINARY(debugfp);
163 newheader("RADIANCE", debugfp); /* start */
164 printargs(argc, argv, debugfp); /* header */
165 break;
166 case 'p': /* picture position */
167 if (badarg(argc-i-1, argv+i+1, "iiiiiiii"))
168 goto userr;
169 bounds[0][0] = atoi(argv[++i]);
170 bounds[0][1] = atoi(argv[++i]);
171 bounds[1][0] = atoi(argv[++i]);
172 bounds[1][1] = atoi(argv[++i]);
173 bounds[2][0] = atoi(argv[++i]);
174 bounds[2][1] = atoi(argv[++i]);
175 bounds[3][0] = atoi(argv[++i]);
176 bounds[3][1] = atoi(argv[++i]);
177 scanning = 2;
178 break;
179 case 'P': /* pick position */
180 scanning = 3;
181 break;
182 case 'i': /* irradiance factor */
183 i++;
184 if (badarg(argc-i, argv+i, "f"))
185 goto userr;
186 irrad = atof(argv[i]);
187 break;
188 case 'm': /* raw map output */
189 rawmap = 1;
190 break;
191 case 'c': /* color input */
192 scanning = 0;
193 break;
194 default:
195 goto userr;
196 }
197 /* open files */
198 if (i < argc && freopen(argv[i], "r", stdin) == NULL) {
199 perror(argv[i]);
200 exit(1);
201 }
202 if (i+1 < argc && freopen(argv[i+1], "w", stdout) == NULL) {
203 perror(argv[i+1]);
204 exit(1);
205 }
206 if (scanning) { /* load input picture header */
207 SET_FILE_BINARY(stdin);
208 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
209 fgetresolu(&xmax, &ymax, stdin) < 0) {
210 fprintf(stderr, "%s: bad input picture\n", progname);
211 exit(1);
212 }
213 if (scanning == 3) {
214 if (i >= argc)
215 goto userr;
216 pickchartpos(argv[i]);
217 scanning = 2;
218 }
219 } else { /* else set default xmax and ymax */
220 xmax = 512;
221 ymax = 2*512/3;
222 }
223 if (scanning != 2) { /* use default boundaries */
224 bounds[0][0] = bounds[2][0] = .029*xmax + .5;
225 bounds[0][1] = bounds[1][1] = .956*ymax + .5;
226 bounds[1][0] = bounds[3][0] = .971*xmax + .5;
227 bounds[2][1] = bounds[3][1] = .056*ymax + .5;
228 }
229 init(); /* initialize */
230 if (scanning) /* get picture colors */
231 getpicture();
232 else
233 getcolors();
234 compute(); /* compute color mapping */
235 if (rawmap) { /* print out raw correspondence */
236 int j;
237
238 printf("# Color correspondence produced by:\n#\t\t");
239 printargs(argc, argv, stdout);
240 printf("#\tUsage: pcwarp %s uncorrected.hdr > corrected.hdr\n",
241 i+1 < argc ? argv[i+1] : "{this_file}");
242 printf("#\t Or: pcond [options] -m %s orig.hdr > output.hdr\n",
243 i+1 < argc ? argv[i+1] : "{this_file}");
244 for (j = 0; j < 24; j++)
245 printf("%f %f %f %f %f %f\n",
246 colval(inpRGB[j],RED), colval(inpRGB[j],GRN),
247 colval(inpRGB[j],BLU), colval(mbRGB[j],RED),
248 colval(mbRGB[j],GRN), colval(mbRGB[j],BLU));
249 if (scanning && debugfp != NULL)
250 cwarp(); /* color warp for debugging */
251 } else { /* print color mapping */
252 /* print header */
253 printf("{\n\tColor correction file computed by:\n\t\t");
254 printargs(argc, argv, stdout);
255 printf("\n\tUsage: pcomb -f %s uncorrected.hdr > corrected.hdr\n",
256 i+1 < argc ? argv[i+1] : "{this_file}");
257 if (!scanning)
258 printf("\t Or: pcond [options] -f %s orig.hdr > output.hdr\n",
259 i+1 < argc ? argv[i+1] : "{this_file}");
260 printf("}\n");
261 putmapping(); /* put out color mapping */
262 }
263 if (debugfp != NULL) { /* put out debug picture */
264 if (scanning)
265 picdebug();
266 else
267 clrdebug();
268 }
269 exit(0);
270 userr:
271 fprintf(stderr,
272 "Usage: %s [-d dbg.hdr][-P | -p xul yul xur yur xll yll xlr ylr][-i irrad][-m] input.hdr [output.{cal|cwp}]\n",
273 progname);
274 fprintf(stderr, " or: %s [-d dbg.hdr][-i irrad][-m] -c [xyY.dat [output.{cal|cwp}]]\n",
275 progname);
276 exit(1);
277 return 1; /* pro forma return */
278 }
279
280
281 static void
282 init(void) /* initialize */
283 {
284 double quad[4][2];
285 int i;
286 /* make coordinate transformation */
287 quad[0][0] = bounds[0][0];
288 quad[0][1] = bounds[0][1];
289 quad[1][0] = bounds[1][0];
290 quad[1][1] = bounds[1][1];
291 quad[2][0] = bounds[3][0];
292 quad[2][1] = bounds[3][1];
293 quad[3][0] = bounds[2][0];
294 quad[3][1] = bounds[2][1];
295
296 if (pmap_quad_rect(0., 0., 6., 4., quad, imgxfm) == PMAP_BAD) {
297 fprintf(stderr, "%s: bad chart boundaries\n", progname);
298 exit(1);
299 }
300 /* map MacBeth colors to RGB space */
301 for (i = 0; i < 24; i++) {
302 xyY2RGB(mbRGB[i], mbxyY[i]);
303 scalecolor(mbRGB[i], irrad);
304 }
305 }
306
307
308 static int
309 chartndx( /* find color number for position */
310 int x,
311 int y,
312 int *np
313 )
314 {
315 double ipos[3], cpos[3];
316 int ix, iy;
317 double fx, fy;
318
319 ipos[0] = x;
320 ipos[1] = y;
321 ipos[2] = 1;
322 mx3d_transform(ipos, imgxfm, cpos);
323 cpos[0] /= cpos[2];
324 cpos[1] /= cpos[2];
325 if ((cpos[0] < 0.) | (cpos[0] >= 6.) | (cpos[1] < 0.) | (cpos[1] >= 4.))
326 return(RG_BORD);
327 ix = cpos[0];
328 iy = cpos[1];
329 fx = cpos[0] - ix;
330 fy = cpos[1] - iy;
331 *np = iy*6 + ix;
332 if ((fx >= 0.35) & (fx < 0.65) & (fy >= 0.35) & (fy < 0.65))
333 return(RG_CENT);
334 if ((fx < 0.05) | (fx >= 0.95) | (fy < 0.05) | (fy >= 0.95))
335 return(RG_BORD);
336 if (fx >= 0.5) /* right side is corrected */
337 return(RG_CORR);
338 return(RG_ORIG); /* left side is original */
339 }
340
341
342 static void
343 getpicture(void) /* load in picture colors */
344 {
345 COLR *scanln;
346 COLOR pval;
347 int ccount[24];
348 double d;
349 int y, i;
350 int x;
351
352 scanln = (COLR *)malloc(xmax*sizeof(COLR));
353 if (scanln == NULL) {
354 perror(progname);
355 exit(1);
356 }
357 for (i = 0; i < 24; i++) {
358 setcolor(inpRGB[i], 0., 0., 0.);
359 ccount[i] = 0;
360 }
361 for (y = ymax-1; y >= 0; y--) {
362 if (freadcolrs(scanln, xmax, stdin) < 0) {
363 fprintf(stderr, "%s: error reading input picture\n",
364 progname);
365 exit(1);
366 }
367 for (x = 0; x < xmax; x++)
368 if (chartndx(x, y, &i) == RG_CENT) {
369 colr_color(pval, scanln[x]);
370 addcolor(inpRGB[i], pval);
371 ccount[i]++;
372 }
373 }
374 for (i = 0; i < 24; i++) { /* compute averages */
375 if (ccount[i] == 0)
376 continue;
377 d = 1./ccount[i];
378 scalecolor(inpRGB[i], d);
379 inpflags |= 1L<<i;
380 }
381 free((void *)scanln);
382 }
383
384
385 static void
386 getcolors(void) /* get xyY colors from standard input */
387 {
388 int gotwhite = 0;
389 COLOR whiteclr;
390 int n;
391 float xyYin[3];
392
393 while (fgetval(stdin, 'i', &n) == 1) { /* read colors */
394 if ((n < 0) | (n > 24) ||
395 fgetval(stdin, 'f', &xyYin[0]) != 1 ||
396 fgetval(stdin, 'f', &xyYin[1]) != 1 ||
397 fgetval(stdin, 'f', &xyYin[2]) != 1 ||
398 (xyYin[0] < 0.) | (xyYin[1] < 0.) ||
399 xyYin[0] + xyYin[1] > 1.) {
400 fprintf(stderr, "%s: bad color input data\n",
401 progname);
402 exit(1);
403 }
404 if (n == 0) { /* calibration white */
405 xyY2RGB(whiteclr, xyYin);
406 gotwhite++;
407 } else { /* standard color */
408 n--;
409 xyY2RGB(inpRGB[n], xyYin);
410 inpflags |= 1L<<n;
411 }
412 }
413 /* normalize colors */
414 if (!gotwhite) {
415 if (!(inpflags & 1L<<White)) {
416 fprintf(stderr, "%s: missing input for White\n",
417 progname);
418 exit(1);
419 }
420 setcolor(whiteclr,
421 colval(inpRGB[White],RED)/colval(mbRGB[White],RED),
422 colval(inpRGB[White],GRN)/colval(mbRGB[White],GRN),
423 colval(inpRGB[White],BLU)/colval(mbRGB[White],BLU));
424 }
425 for (n = 0; n < 24; n++)
426 if (inpflags & 1L<<n)
427 setcolor(inpRGB[n],
428 colval(inpRGB[n],RED)/colval(whiteclr,RED),
429 colval(inpRGB[n],GRN)/colval(whiteclr,GRN),
430 colval(inpRGB[n],BLU)/colval(whiteclr,BLU));
431 }
432
433
434 static void
435 bresp( /* piecewise linear interpolation of primaries */
436 COLOR y, /* y is linear output */
437 COLOR x /* x is non-linear input */
438 )
439 {
440 int i, n;
441
442 for (i = 0; i < 3; i++) {
443 for (n = 0; n < NMBNEU-2; n++)
444 if (colval(x,i) < colval(bramp[n+1][0],i))
445 break;
446 colval(y,i) = ((colval(bramp[n+1][0],i) - colval(x,i)) *
447 colval(bramp[n][1],i) +
448 (colval(x,i) - colval(bramp[n][0],i)) *
449 colval(bramp[n+1][1],i)) /
450 (colval(bramp[n+1][0],i) - colval(bramp[n][0],i));
451 }
452 }
453
454
455 static void
456 ibresp( /* inverse mapping (delinearization) */
457 COLOR x, /* x is non-linear output */
458 COLOR y /* y is linear input */
459 )
460 {
461 int i, n;
462
463 for (i = 0; i < 3; i++) {
464 for (n = 0; n < NMBNEU-2; n++)
465 if (colval(y,i) < colval(bramp[n+1][1],i))
466 break;
467 colval(x,i) = ((colval(bramp[n+1][1],i) - colval(y,i)) *
468 colval(bramp[n][0],i) +
469 (colval(y,i) - colval(bramp[n][1],i)) *
470 colval(bramp[n+1][0],i)) /
471 (colval(bramp[n+1][1],i) - colval(bramp[n][1],i));
472 }
473 }
474
475
476 static void
477 compute(void) /* compute color mapping */
478 {
479 COLOR clrin[24], clrout[24];
480 long cflags;
481 COLOR ctmp;
482 int i, n;
483 /* did we get what we need? */
484 if ((inpflags & REQFLGS) != REQFLGS) {
485 fprintf(stderr, "%s: missing required input colors\n",
486 progname);
487 exit(1);
488 }
489 /* compute piecewise luminance curve */
490 for (i = 0; i < NMBNEU; i++) {
491 copycolor(bramp[i][0], inpRGB[mbneu[i]]);
492 for (n = 3*(i>0); n--; )
493 if (colval(bramp[i][0],n) <=
494 colval(bramp[i-1][0],n)+1e-7) {
495 fprintf(stderr,
496 "%s: non-increasing neutral patch\n", progname);
497 exit(1);
498 }
499 copycolor(bramp[i][1], mbRGB[mbneu[i]]);
500 }
501 /* compute color space gamut */
502 copycolor(colmin, cblack);
503 copycolor(colmax, cwhite);
504 scalecolor(colmax, irrad);
505 if (!scanning) {
506 ibresp(colmin, colmin);
507 ibresp(colmax, colmax);
508 }
509 /* compute color mapping */
510 do {
511 cflags = inpflags & ~gmtflags;
512 n = 0; /* compute transform matrix */
513 for (i = 0; i < 24; i++) {
514 if (!(cflags & 1L<<i))
515 continue;
516 if (scanning) {
517 bresp(clrin[n], inpRGB[i]);
518 copycolor(clrout[n], mbRGB[i]);
519 } else {
520 copycolor(clrin[n], inpRGB[i]);
521 ibresp(clrout[n], mbRGB[i]);
522 }
523 n++;
524 }
525 compsoln(clrin, clrout, n);
526 for (i = 0; i < 24; i++) /* check gamut */
527 if (cflags & 1L<<i && cvtcolor(ctmp, inpRGB[i]))
528 gmtflags |= 1L<<i;
529 } while (cflags & gmtflags);
530
531 if (gmtflags & MODFLGS)
532 fprintf(stderr,
533 "%s: warning - some moderate colors are out of gamut\n",
534 progname);
535 }
536
537
538 static void
539 putmapping(void) /* put out color mapping */
540 {
541 static char cchar[3] = {'r', 'g', 'b'};
542 int i, j;
543 /* print brightness mapping */
544 for (j = 0; j < 3; j++) {
545 printf("%cxa(i) : select(i", cchar[j]);
546 for (i = 0; i < NMBNEU; i++)
547 printf(",%g", colval(bramp[i][0],j));
548 printf(");\n");
549 printf("%cya(i) : select(i", cchar[j]);
550 for (i = 0; i < NMBNEU; i++)
551 printf(",%g", colval(bramp[i][1],j));
552 printf(");\n");
553 printf("%cfi(n) = if(n-%g, %d, if(%cxa(n+1)-%c, n, %cfi(n+1)));\n",
554 cchar[j], NMBNEU-1.5, NMBNEU-1, cchar[j],
555 cchar[j], cchar[j]);
556 printf("%cndx = %cfi(1);\n", cchar[j], cchar[j]);
557 printf("%c%c = ((%cxa(%cndx+1)-%c)*%cya(%cndx) + ",
558 cchar[j], scanning?'n':'o', cchar[j],
559 cchar[j], cchar[j], cchar[j], cchar[j]);
560 printf("(%c-%cxa(%cndx))*%cya(%cndx+1)) /\n",
561 cchar[j], cchar[j], cchar[j],
562 cchar[j], cchar[j]);
563 printf("\t\t(%cxa(%cndx+1) - %cxa(%cndx)) ;\n",
564 cchar[j], cchar[j], cchar[j], cchar[j]);
565 }
566 /* print color mapping */
567 if (scanning) {
568 printf("r = ri(1); g = gi(1); b = bi(1);\n");
569 printf("ro = %g*rn + %g*gn + %g*bn ;\n",
570 solmat[0][0], solmat[0][1], solmat[0][2]);
571 printf("go = %g*rn + %g*gn + %g*bn ;\n",
572 solmat[1][0], solmat[1][1], solmat[1][2]);
573 printf("bo = %g*rn + %g*gn + %g*bn ;\n",
574 solmat[2][0], solmat[2][1], solmat[2][2]);
575 } else {
576 printf("r1 = ri(1); g1 = gi(1); b1 = bi(1);\n");
577 printf("r = %g*r1 + %g*g1 + %g*b1 ;\n",
578 solmat[0][0], solmat[0][1], solmat[0][2]);
579 printf("g = %g*r1 + %g*g1 + %g*b1 ;\n",
580 solmat[1][0], solmat[1][1], solmat[1][2]);
581 printf("b = %g*r1 + %g*g1 + %g*b1 ;\n",
582 solmat[2][0], solmat[2][1], solmat[2][2]);
583 }
584 }
585
586
587 static void
588 compsoln( /* solve 3xN system using least-squares */
589 COLOR cin[],
590 COLOR cout[],
591 int n
592 )
593 {
594 extern double mx3d_adjoint(), fabs();
595 double mat[3][3], invmat[3][3];
596 double det;
597 double colv[3], rowv[3];
598 int i, j, k;
599
600 if (n < 3) {
601 fprintf(stderr, "%s: too few colors to match!\n", progname);
602 exit(1);
603 }
604 if (n == 3)
605 for (i = 0; i < 3; i++)
606 for (j = 0; j < 3; j++)
607 mat[i][j] = colval(cin[j],i);
608 else { /* compute A^t A */
609 for (i = 0; i < 3; i++)
610 for (j = i; j < 3; j++) {
611 mat[i][j] = 0.;
612 for (k = 0; k < n; k++)
613 mat[i][j] += colval(cin[k],i) *
614 colval(cin[k],j);
615 }
616 for (i = 1; i < 3; i++) /* using symmetry */
617 for (j = 0; j < i; j++)
618 mat[i][j] = mat[j][i];
619 }
620 det = mx3d_adjoint(mat, invmat);
621 if (fabs(det) < 1e-4) {
622 fprintf(stderr, "%s: cannot compute color mapping\n",
623 progname);
624 solmat[0][0] = solmat[1][1] = solmat[2][2] = 1.;
625 solmat[0][1] = solmat[0][2] = solmat[1][0] =
626 solmat[1][2] = solmat[2][0] = solmat[2][1] = 0.;
627 return;
628 }
629 for (i = 0; i < 3; i++)
630 for (j = 0; j < 3; j++)
631 invmat[i][j] /= det;
632 for (i = 0; i < 3; i++) {
633 if (n == 3)
634 for (j = 0; j < 3; j++)
635 colv[j] = colval(cout[j],i);
636 else
637 for (j = 0; j < 3; j++) {
638 colv[j] = 0.;
639 for (k = 0; k < n; k++)
640 colv[j] += colval(cout[k],i) *
641 colval(cin[k],j);
642 }
643 mx3d_transform(colv, invmat, rowv);
644 for (j = 0; j < 3; j++)
645 solmat[i][j] = rowv[j];
646 }
647 }
648
649
650 static void
651 cwarp(void) /* compute color warp map */
652 {
653 int i;
654
655 if ((wcor = new3dw(W3EXACT)) == NULL)
656 goto memerr;
657 for (i = 0; i < 24; i++)
658 if (!add3dpt(wcor, inpRGB[i], mbRGB[i]))
659 goto memerr;
660 return;
661 memerr:
662 perror(progname);
663 exit(1);
664 }
665
666
667 static int
668 cvtcolor( /* convert color according to our mapping */
669 COLOR cout,
670 COLOR cin
671 )
672 {
673 COLOR ctmp;
674 int clipped;
675
676 if (wcor != NULL) {
677 clipped = warp3d(cout, cin, wcor);
678 clipped |= clipgamut(cout,bright(cout),CGAMUT,colmin,colmax);
679 } else if (scanning) {
680 bresp(ctmp, cin);
681 clipped = cresp(cout, ctmp);
682 } else {
683 clipped = cresp(ctmp, cin);
684 bresp(cout, ctmp);
685 }
686 return(clipped);
687 }
688
689
690 static int
691 cresp( /* transform color according to matrix */
692 COLOR cout,
693 COLOR cin
694 )
695 {
696 colortrans(cout, solmat, cin);
697 return(clipgamut(cout, bright(cout), CGAMUT, colmin, colmax));
698 }
699
700
701 static void
702 xyY2RGB( /* convert xyY to RGB */
703 COLOR rgbout,
704 float xyYin[3]
705 )
706 {
707 COLOR ctmp;
708 double d;
709
710 d = xyYin[2] / xyYin[1];
711 ctmp[0] = xyYin[0] * d;
712 ctmp[1] = xyYin[2];
713 ctmp[2] = (1. - xyYin[0] - xyYin[1]) * d;
714 /* allow negative values */
715 colortrans(rgbout, xyz2rgbmat, ctmp);
716 }
717
718
719 static void
720 picdebug(void) /* put out debugging picture */
721 {
722 static COLOR blkcol = BLKCOLOR;
723 COLOR *scan;
724 int y, i;
725 int x, rg;
726
727 if (fseek(stdin, 0L, 0) == EOF) {
728 fprintf(stderr, "%s: cannot seek on input picture\n", progname);
729 exit(1);
730 }
731 getheader(stdin, NULL, NULL); /* skip input header */
732 fgetresolu(&xmax, &ymax, stdin);
733 /* allocate scanline */
734 scan = (COLOR *)malloc(xmax*sizeof(COLOR));
735 if (scan == NULL) {
736 perror(progname);
737 exit(1);
738 }
739 /* finish debug header */
740 fputformat(COLRFMT, debugfp);
741 putc('\n', debugfp);
742 fprtresolu(xmax, ymax, debugfp);
743 /* write debug picture */
744 for (y = ymax-1; y >= 0; y--) {
745 if (freadscan(scan, xmax, stdin) < 0) {
746 fprintf(stderr, "%s: error rereading input picture\n",
747 progname);
748 exit(1);
749 }
750 for (x = 0; x < xmax; x++) {
751 rg = chartndx(x, y, &i);
752 if (rg == RG_CENT) {
753 if (!(1L<<i & gmtflags) || (x+y)&07) {
754 copycolor(scan[x], mbRGB[i]);
755 clipgamut(scan[x], bright(scan[x]),
756 CGAMUT, colmin, colmax);
757 } else
758 copycolor(scan[x], blkcol);
759 } else if (rg == RG_CORR)
760 cvtcolor(scan[x], scan[x]);
761 else if (rg != RG_ORIG)
762 copycolor(scan[x], blkcol);
763 }
764 if (fwritescan(scan, xmax, debugfp) < 0) {
765 fprintf(stderr, "%s: error writing debugging picture\n",
766 progname);
767 exit(1);
768 }
769 }
770 /* clean up */
771 fclose(debugfp);
772 free((void *)scan);
773 }
774
775
776 static void
777 clrdebug(void) /* put out debug picture from color input */
778 {
779 static COLR blkclr = BLKCOLR;
780 COLR mbclr[24], cvclr[24], orclr[24];
781 COLR *scan;
782 COLOR ctmp, ct2;
783 int y, i;
784 int x, rg;
785 /* convert colors */
786 for (i = 0; i < 24; i++) {
787 copycolor(ctmp, mbRGB[i]);
788 clipgamut(ctmp, bright(ctmp), CGAMUT, cblack, cwhite);
789 setcolr(mbclr[i], colval(ctmp,RED),
790 colval(ctmp,GRN), colval(ctmp,BLU));
791 if (inpflags & 1L<<i) {
792 copycolor(ctmp, inpRGB[i]);
793 clipgamut(ctmp, bright(ctmp), CGAMUT, cblack, cwhite);
794 setcolr(orclr[i], colval(ctmp,RED),
795 colval(ctmp,GRN), colval(ctmp,BLU));
796 if (rawmap)
797 copycolr(cvclr[i], mbclr[i]);
798 else {
799 bresp(ctmp, inpRGB[i]);
800 colortrans(ct2, solmat, ctmp);
801 clipgamut(ct2, bright(ct2), CGAMUT,
802 cblack, cwhite);
803 setcolr(cvclr[i], colval(ct2,RED),
804 colval(ct2,GRN),
805 colval(ct2,BLU));
806 }
807 }
808 }
809 /* allocate scanline */
810 scan = (COLR *)malloc(xmax*sizeof(COLR));
811 if (scan == NULL) {
812 perror(progname);
813 exit(1);
814 }
815 /* finish debug header */
816 fputformat(COLRFMT, debugfp);
817 putc('\n', debugfp);
818 fprtresolu(xmax, ymax, debugfp);
819 /* write debug picture */
820 for (y = ymax-1; y >= 0; y--) {
821 for (x = 0; x < xmax; x++) {
822 rg = chartndx(x, y, &i);
823 if (rg == RG_CENT) {
824 if (!(1L<<i & gmtflags) || (x+y)&07)
825 copycolr(scan[x], mbclr[i]);
826 else
827 copycolr(scan[x], blkclr);
828 } else if (rg == RG_BORD || !(1L<<i & inpflags))
829 copycolr(scan[x], blkclr);
830 else if (rg == RG_ORIG)
831 copycolr(scan[x], orclr[i]);
832 else /* rg == RG_CORR */
833 copycolr(scan[x], cvclr[i]);
834 }
835 if (fwritecolrs(scan, xmax, debugfp) < 0) {
836 fprintf(stderr, "%s: error writing debugging picture\n",
837 progname);
838 exit(1);
839 }
840 }
841 /* clean up */
842 fclose(debugfp);
843 free((void *)scan);
844 }
845
846
847 static void
848 getpos( /* get boundary position */
849 char *name,
850 int bnds[2],
851 FILE *fp
852 )
853 {
854 char buf[64];
855
856 fprintf(stderr, "\tSelect corner: %s\n", name);
857 if (fgets(buf, sizeof(buf), fp) == NULL ||
858 sscanf(buf, "%d %d", &bnds[0], &bnds[1]) != 2) {
859 fprintf(stderr, "%s: read error from display process\n",
860 progname);
861 exit(1);
862 }
863 }
864
865
866 static void
867 pickchartpos( /* display picture and pick chart location */
868 char *pfn
869 )
870 {
871 char combuf[PATH_MAX];
872 FILE *pfp;
873
874 sprintf(combuf, DISPCOM, pfn);
875 if ((pfp = popen(combuf, "r")) == NULL) {
876 perror(combuf);
877 exit(1);
878 }
879 fputs("Use middle mouse button to select chart corners:\n", stderr);
880 getpos("upper left (dark skin)", bounds[0], pfp);
881 getpos("upper right (bluish green)", bounds[1], pfp);
882 getpos("lower left (white)", bounds[2], pfp);
883 getpos("lower right (black)", bounds[3], pfp);
884 fputs("Got it -- quit display program.\n", stderr);
885 pclose(pfp);
886 }
