root/radiance/ray/src/px/macbethcal.c
Revision: 2.29
Committed: Thu Feb 22 02:07:40 2024 UTC (14 months, 1 week ago) by greg
Changes since 2.28: +21 -22 lines
fix(macbethcal): Fixed bug in checking color mapping (erroneous out-of-gamut report)
2 static const char RCSid[] = "$Id: macbethcal.c,v 2.28 2019/12/28 18:05:14 greg Exp $";
5 * Calibrate a scanned MacBeth Color Checker Chart
6 *
7 * Produce a .cal file suitable for use with pcomb,
8 * or .cwp file suitable for use with pcwarp.
9 *
10 * Warping code depends on conformance of COLOR and W3VEC types.
11 */
12
13 #include <math.h>
14
15 #include "platform.h"
16 #include "paths.h"
17 #include "rtio.h"
18 #include "color.h"
19 #include "resolu.h"
20 #include "pmap.h"
21 #include "warp3d.h"
22 #include "mx3.h"
23
24 /* MacBeth colors */
25 #define DarkSkin 0
26 #define LightSkin 1
27 #define BlueSky 2
28 #define Foliage 3
29 #define BlueFlower 4
30 #define BluishGreen 5
31 #define Orange 6
32 #define PurplishBlue 7
33 #define ModerateRed 8
34 #define Purple 9
35 #define YellowGreen 10
36 #define OrangeYellow 11
37 #define Blue 12
38 #define Green 13
39 #define Red 14
40 #define Yellow 15
41 #define Magenta 16
42 #define Cyan 17
43 #define White 18
44 #define Neutral8 19
45 #define Neutral65 20
46 #define Neutral5 21
47 #define Neutral35 22
48 #define Black 23
49 /* computed from 10nm spectral measurements */
50 /* CIE 1931 2 degree obs, equal-energy white */
51 float mbxyY[24][3] = {
52 {0.421236, 0.361196, 0.103392}, /* DarkSkin */
53 {0.40868, 0.358157, 0.352867}, /* LightSkin */
54 {0.265063, 0.271424, 0.185124}, /* BlueSky */
55 {0.362851, 0.43055, 0.132625}, /* Foliage */
56 {0.28888, 0.260851, 0.233138}, /* BlueFlower */
57 {0.277642, 0.365326, 0.416443}, /* BluishGreen */
58 {0.524965, 0.40068, 0.312039}, /* Orange */
59 {0.225018, 0.190392, 0.114999}, /* PurplishBlue */
60 {0.487199, 0.315372, 0.198616}, /* ModerateRed */
61 {0.314245, 0.227231, 0.0646047}, /* Purple */
62 {0.396202, 0.489732, 0.440724}, /* YellowGreen */
63 {0.493297, 0.435299, 0.43444}, /* OrangeYellow */
64 {0.198191, 0.149265, 0.0588122}, /* Blue */
65 {0.322838, 0.487601, 0.229258}, /* Green */
66 {0.561833, 0.321165, 0.126978}, /* Red */
67 {0.468113, 0.467021, 0.605289}, /* Yellow */
68 {0.397128, 0.248535, 0.201761}, /* Magenta */
69 {0.209552, 0.276256, 0.190917}, /* Cyan */
70 {0.337219, 0.339042, 0.912482}, /* White */
71 {0.333283, 0.335077, 0.588297}, /* Neutral.8 */
72 {0.332747, 0.334371, 0.3594}, /* Neutral.65 */
73 {0.331925, 0.334202, 0.19114}, /* Neutral.5 */
74 {0.330408, 0.332615, 0.0892964}, /* Neutral.35 */
75 {0.331841, 0.331405, 0.0319541}, /* Black */
76 };
77
78 COLOR mbRGB[24]; /* MacBeth RGB values */
79
80 #define NMBNEU 6 /* Number of MacBeth neutral colors */
81 short mbneu[NMBNEU] = {Black,Neutral35,Neutral5,Neutral65,Neutral8,White};
82
83 #define NEUFLGS (1L<<White|1L<<Neutral8|1L<<Neutral65| \
84 1L<<Neutral5|1L<<Neutral35|1L<<Black)
85
86 #define SATFLGS (1L<<Red|1L<<Green|1L<<Blue|1L<<Magenta|1L<<Yellow| \
87 1L<<Cyan|1L<<Orange|1L<<Purple|1L<<PurplishBlue| \
88 1L<<YellowGreen|1<<OrangeYellow|1L<<BlueFlower)
89
90 #define UNSFLGS (1L<<DarkSkin|1L<<LightSkin|1L<<BlueSky|1L<<Foliage| \
91 1L<<BluishGreen|1L<<ModerateRed)
92
93 #define REQFLGS NEUFLGS /* need these colors */
94 #define MODFLGS (NEUFLGS|UNSFLGS) /* should be in gamut */
95
96 #define RG_BORD 0 /* patch border */
97 #define RG_CENT 01 /* central region of patch */
98 #define RG_ORIG 02 /* original color region */
99 #define RG_CORR 04 /* corrected color region */
100
101 #ifndef DISPCOM
102 #define DISPCOM "ximage -e auto -op \"%s\""
103 #endif
104
105 int scanning = 1; /* scanned input (or recorded output)? */
106 double irrad = 1.0; /* irradiance multiplication factor */
107 int rawmap = 0; /* put out raw color mapping? */
108
109 int xmax, ymax; /* input image dimensions */
110 int bounds[4][2]; /* image coordinates of chart corners */
111 double imgxfm[3][3]; /* coordinate transformation matrix */
112
113 COLOR inpRGB[24]; /* measured or scanned input colors */
114 long inpflags = 0; /* flags of which colors were input */
115 long gmtflags = 0; /* flags of out-of-gamut colors */
116
117 COLOR bramp[NMBNEU][2]; /* brightness ramp (per primary) */
118 COLORMAT solmat; /* color mapping matrix */
119 COLOR colmin, colmax; /* gamut limits */
120
121 WARP3D *wcor = NULL; /* color space warp */
122
123 FILE *debugfp = NULL; /* debug output picture */
124 char *progname;
125
126 static void init(void);
127 static int chartndx(int x, int y, int *np);
128 static void getpicture(void);
129 static void getcolors(void);
130 static void bresp(COLOR y, COLOR x);
131 static void compute(void);
132 static void putmapping(void);
133 static void compsoln(COLOR cin[], COLOR cout[], int n);
134 static void cwarp(void);
135 static int cvtcolor(COLOR cout, COLOR cin);
136 static int cresp(COLOR cout, COLOR cin);
137 static void xyY2RGB(COLOR rgbout, float xyYin[3]);
138 static void picdebug(void);
139 static void clrdebug(void);
140 static void getpos(char *name, int bnds[2], FILE *fp);
141 static void pickchartpos(char *pfn);
142
143
144 int
145 main(
146 int argc,
147 char **argv
148 )
149 {
150 int i;
151
152 progname = argv[0];
153 for (i = 1; i < argc && argv[i][0] == '-'; i++)
154 switch (argv[i][1]) {
155 case 'd': /* debug output */
156 i++;
157 if (badarg(argc-i, argv+i, "s"))
158 goto userr;
159 if ((debugfp = fopen(argv[i], "w")) == NULL) {
160 perror(argv[i]);
161 exit(1);
162 }
163 SET_FILE_BINARY(debugfp);
164 newheader("RADIANCE", debugfp); /* start */
165 printargs(argc, argv, debugfp); /* header */
166 break;
167 case 'p': /* picture position */
168 if (badarg(argc-i-1, argv+i+1, "iiiiiiii"))
169 goto userr;
170 bounds[0][0] = atoi(argv[++i]);
171 bounds[0][1] = atoi(argv[++i]);
172 bounds[1][0] = atoi(argv[++i]);
173 bounds[1][1] = atoi(argv[++i]);
174 bounds[2][0] = atoi(argv[++i]);
175 bounds[2][1] = atoi(argv[++i]);
176 bounds[3][0] = atoi(argv[++i]);
177 bounds[3][1] = atoi(argv[++i]);
178 scanning = 2;
179 break;
180 case 'P': /* pick position */
181 scanning = 3;
182 break;
183 case 'i': /* irradiance factor */
184 i++;
185 if (badarg(argc-i, argv+i, "f"))
186 goto userr;
187 irrad = atof(argv[i]);
188 break;
189 case 'm': /* raw map output */
190 rawmap = 1;
191 break;
192 case 'c': /* color input */
193 scanning = 0;
194 break;
195 default:
196 goto userr;
197 }
198 /* open files */
199 if (i < argc && freopen(argv[i], "r", stdin) == NULL) {
200 perror(argv[i]);
201 exit(1);
202 }
203 if (i+1 < argc && freopen(argv[i+1], "w", stdout) == NULL) {
204 perror(argv[i+1]);
205 exit(1);
206 }
207 if (scanning) { /* load input picture header */
208 SET_FILE_BINARY(stdin);
209 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
210 fgetresolu(&xmax, &ymax, stdin) < 0) {
211 fprintf(stderr, "%s: bad input picture\n", progname);
212 exit(1);
213 }
214 if (scanning == 3) {
215 if (i >= argc)
216 goto userr;
217 pickchartpos(argv[i]);
218 scanning = 2;
219 }
220 } else { /* else set default xmax and ymax */
221 xmax = 512;
222 ymax = 2*512/3;
223 }
224 if (scanning != 2) { /* use default boundaries */
225 bounds[0][0] = bounds[2][0] = .029*xmax + .5;
226 bounds[0][1] = bounds[1][1] = .956*ymax + .5;
227 bounds[1][0] = bounds[3][0] = .971*xmax + .5;
228 bounds[2][1] = bounds[3][1] = .056*ymax + .5;
229 }
230 init(); /* initialize */
231 if (scanning) /* get picture colors */
232 getpicture();
233 else
234 getcolors();
235 compute(); /* compute color mapping */
236 if (rawmap) { /* print out raw correspondence */
237 int j;
238
239 printf("# Color correspondence produced by:\n#\t\t");
240 printargs(argc, argv, stdout);
241 printf("#\tUsage: pcwarp %s uncorrected.hdr > corrected.hdr\n",
242 i+1 < argc ? argv[i+1] : "{this_file}");
243 printf("#\t Or: pcond [options] -m %s orig.hdr > output.hdr\n",
244 i+1 < argc ? argv[i+1] : "{this_file}");
245 for (j = 0; j < 24; j++)
246 printf("%f %f %f %f %f %f\n",
247 colval(inpRGB[j],RED), colval(inpRGB[j],GRN),
248 colval(inpRGB[j],BLU), colval(mbRGB[j],RED),
249 colval(mbRGB[j],GRN), colval(mbRGB[j],BLU));
250 if (scanning && debugfp != NULL)
251 cwarp(); /* color warp for debugging */
252 } else { /* print color mapping */
253 /* print header */
254 printf("{\n\tColor correction file computed by:\n\t\t");
255 printargs(argc, argv, stdout);
256 printf("\n\tUsage: pcomb -f %s uncorrected.hdr > corrected.hdr\n",
257 i+1 < argc ? argv[i+1] : "{this_file}");
258 if (!scanning)
259 printf("\t Or: pcond [options] -f %s orig.hdr > output.hdr\n",
260 i+1 < argc ? argv[i+1] : "{this_file}");
261 printf("}\n");
262 putmapping(); /* put out color mapping */
263 }
264 if (debugfp != NULL) { /* put out debug picture */
265 if (scanning)
266 picdebug();
267 else
268 clrdebug();
269 }
270 exit(0);
271 userr:
272 fprintf(stderr,
273 "Usage: %s [-d dbg.hdr][-P | -p xul yul xur yur xll yll xlr ylr][-i irrad][-m] input.hdr [output.{cal|cwp}]\n",
274 progname);
275 fprintf(stderr, " or: %s [-d dbg.hdr][-i irrad][-m] -c [xyY.dat [output.{cal|cwp}]]\n",
276 progname);
277 exit(1);
278 return 1; /* pro forma return */
279 }
280
281
282 static void
283 init(void) /* initialize */
284 {
285 double quad[4][2];
286 int i;
287 /* make coordinate transformation */
288 quad[0][0] = bounds[0][0];
289 quad[0][1] = bounds[0][1];
290 quad[1][0] = bounds[1][0];
291 quad[1][1] = bounds[1][1];
292 quad[2][0] = bounds[3][0];
293 quad[2][1] = bounds[3][1];
294 quad[3][0] = bounds[2][0];
295 quad[3][1] = bounds[2][1];
296
297 if (pmap_quad_rect(0., 0., 6., 4., quad, imgxfm) == PMAP_BAD) {
298 fprintf(stderr, "%s: bad chart boundaries\n", progname);
299 exit(1);
300 }
301 /* map MacBeth colors to RGB space */
302 for (i = 0; i < 24; i++) {
303 xyY2RGB(mbRGB[i], mbxyY[i]);
304 scalecolor(mbRGB[i], irrad);
305 }
306 }
307
308
309 static int
310 chartndx( /* find color number for position */
311 int x,
312 int y,
313 int *np
314 )
315 {
316 double ipos[3], cpos[3];
317 int ix, iy;
318 double fx, fy;
319
320 ipos[0] = x;
321 ipos[1] = y;
322 ipos[2] = 1;
323 mx3d_transform(ipos, imgxfm, cpos);
324 cpos[0] /= cpos[2];
325 cpos[1] /= cpos[2];
326 if ((cpos[0] < 0.) | (cpos[0] >= 6.) | (cpos[1] < 0.) | (cpos[1] >= 4.))
327 return(RG_BORD);
328 ix = cpos[0];
329 iy = cpos[1];
330 fx = cpos[0] - ix;
331 fy = cpos[1] - iy;
332 *np = iy*6 + ix;
333 if ((fx >= 0.35) & (fx < 0.65) & (fy >= 0.35) & (fy < 0.65))
334 return(RG_CENT);
335 if ((fx < 0.05) | (fx >= 0.95) | (fy < 0.05) | (fy >= 0.95))
336 return(RG_BORD);
337 if (fx >= 0.5) /* right side is corrected */
338 return(RG_CORR);
339 return(RG_ORIG); /* left side is original */
340 }
341
342
343 static void
344 getpicture(void) /* load in picture colors */
345 {
346 COLR *scanln;
347 COLOR pval;
348 int ccount[24];
349 double d;
350 int y, i;
351 int x;
352
353 scanln = (COLR *)malloc(xmax*sizeof(COLR));
354 if (scanln == NULL) {
355 perror(progname);
356 exit(1);
357 }
358 for (i = 0; i < 24; i++) {
359 setcolor(inpRGB[i], 0., 0., 0.);
360 ccount[i] = 0;
361 }
362 for (y = ymax-1; y >= 0; y--) {
363 if (freadcolrs(scanln, xmax, stdin) < 0) {
364 fprintf(stderr, "%s: error reading input picture\n",
365 progname);
366 exit(1);
367 }
368 for (x = 0; x < xmax; x++)
369 if (chartndx(x, y, &i) == RG_CENT) {
370 colr_color(pval, scanln[x]);
371 addcolor(inpRGB[i], pval);
372 ccount[i]++;
373 }
374 }
375 for (i = 0; i < 24; i++) { /* compute averages */
376 if (ccount[i] == 0)
377 continue;
378 d = 1./ccount[i];
379 scalecolor(inpRGB[i], d);
380 inpflags |= 1L<<i;
381 }
382 free((void *)scanln);
383 }
384
385
386 static void
387 getcolors(void) /* get xyY colors from standard input */
388 {
389 int gotwhite = 0;
390 COLOR whiteclr;
391 int n;
392 float xyYin[3];
393
394 while (fgetval(stdin, 'i', &n) == 1) { /* read colors */
395 if ((n < 0) | (n > 24) ||
396 fgetval(stdin, 'f', &xyYin[0]) != 1 ||
397 fgetval(stdin, 'f', &xyYin[1]) != 1 ||
398 fgetval(stdin, 'f', &xyYin[2]) != 1 ||
399 (xyYin[0] < 0.) | (xyYin[1] < 0.) ||
400 xyYin[0] + xyYin[1] > 1.) {
401 fprintf(stderr, "%s: bad color input data\n",
402 progname);
403 exit(1);
404 }
405 if (n == 0) { /* calibration white */
406 xyY2RGB(whiteclr, xyYin);
407 gotwhite++;
408 } else { /* standard color */
409 n--;
410 xyY2RGB(inpRGB[n], xyYin);
411 inpflags |= 1L<<n;
412 }
413 }
414 /* normalize colors */
415 if (!gotwhite) {
416 if (!(inpflags & 1L<<White)) {
417 fprintf(stderr, "%s: missing input for White\n",
418 progname);
419 exit(1);
420 }
421 setcolor(whiteclr,
422 colval(inpRGB[White],RED)/colval(mbRGB[White],RED),
423 colval(inpRGB[White],GRN)/colval(mbRGB[White],GRN),
424 colval(inpRGB[White],BLU)/colval(mbRGB[White],BLU));
425 }
426 for (n = 0; n < 24; n++)
427 if (inpflags & 1L<<n)
428 setcolor(inpRGB[n],
429 colval(inpRGB[n],RED)/colval(whiteclr,RED),
430 colval(inpRGB[n],GRN)/colval(whiteclr,GRN),
431 colval(inpRGB[n],BLU)/colval(whiteclr,BLU));
432 }
433
434
435 static void
436 bresp( /* piecewise linear interpolation of primaries */
437 COLOR y,
438 COLOR x
439 )
440 {
441 int i, n;
442
443 for (i = 0; i < 3; i++) {
444 for (n = 0; n < NMBNEU-2; n++)
445 if (colval(x,i) < colval(bramp[n+1][0],i))
446 break;
447 colval(y,i) = ((colval(bramp[n+1][0],i) - colval(x,i)) *
448 colval(bramp[n][1],i) +
449 (colval(x,i) - colval(bramp[n][0],i)) *
450 colval(bramp[n+1][1],i)) /
451 (colval(bramp[n+1][0],i) - colval(bramp[n][0],i));
452 }
453 }
454
455
456 static void
457 compute(void) /* compute color mapping */
458 {
459 COLOR clrin[24], clrout[24];
460 long cflags;
461 COLOR ctmp;
462 int i, n;
463 /* did we get what we need? */
464 if ((inpflags & REQFLGS) != REQFLGS) {
465 fprintf(stderr, "%s: missing required input colors\n",
466 progname);
467 exit(1);
468 }
469 /* compute piecewise luminance curve */
470 for (i = 0; i < NMBNEU; i++) {
471 copycolor(bramp[i][0], inpRGB[mbneu[i]]);
472 for (n = 3*(i>0); n--; )
473 if (colval(bramp[i][0],n) <=
474 colval(bramp[i-1][0],n)+1e-7) {
475 fprintf(stderr,
476 "%s: non-increasing neutral patch\n", progname);
477 exit(1);
478 }
479 copycolor(bramp[i][1], mbRGB[mbneu[i]]);
480 }
481 /* compute color space gamut */
482 if (scanning) {
483 copycolor(colmin, cblack);
484 copycolor(colmax, cwhite);
485 scalecolor(colmax, irrad);
486 } else
487 for (i = 0; i < 3; i++) {
488 colval(colmin,i) = colval(bramp[0][0],i) -
489 colval(bramp[0][1],i) *
490 (colval(bramp[1][0],i)-colval(bramp[0][0],i)) /
491 (colval(bramp[1][1],i)-colval(bramp[0][1],i));
492 colval(colmax,i) = colval(bramp[NMBNEU-2][0],i) +
493 (1.-colval(bramp[NMBNEU-2][1],i)) *
494 (colval(bramp[NMBNEU-1][0],i) -
495 colval(bramp[NMBNEU-2][0],i)) /
496 (colval(bramp[NMBNEU-1][1],i) -
497 colval(bramp[NMBNEU-2][1],i));
498 }
499 /* compute color mapping */
500 do {
501 cflags = inpflags & ~gmtflags;
502 n = 0; /* compute transform matrix */
503 for (i = 0; i < 24; i++)
504 if (cflags & 1L<<i) {
505 bresp(clrin[n], inpRGB[i]);
506 copycolor(clrout[n], mbRGB[i]);
507 n++;
508 }
509 compsoln(clrin, clrout, n);
510 for (i = 0; i < 24; i++) /* check gamut */
511 if (cflags & 1L<<i && cvtcolor(ctmp, inpRGB[i]))
512 gmtflags |= 1L<<i;
513 } while (cflags & gmtflags);
514 if (gmtflags & MODFLGS)
515 fprintf(stderr,
516 "%s: warning - some moderate colors are out of gamut\n",
517 progname);
518 }
519
520
521 static void
522 putmapping(void) /* put out color mapping */
523 {
524 static char cchar[3] = {'r', 'g', 'b'};
525 int i, j;
526 /* print brightness mapping */
527 for (j = 0; j < 3; j++) {
528 printf("%cxa(i) : select(i", cchar[j]);
529 for (i = 0; i < NMBNEU; i++)
530 printf(",%g", colval(bramp[i][0],j));
531 printf(");\n");
532 printf("%cya(i) : select(i", cchar[j]);
533 for (i = 0; i < NMBNEU; i++)
534 printf(",%g", colval(bramp[i][1],j));
535 printf(");\n");
536 printf("%cfi(n) = if(n-%g, %d, if(%cxa(n+1)-%c, n, %cfi(n+1)));\n",
537 cchar[j], NMBNEU-1.5, NMBNEU-1, cchar[j],
538 cchar[j], cchar[j]);
539 printf("%cndx = %cfi(1);\n", cchar[j], cchar[j]);
540 printf("%c%c = ((%cxa(%cndx+1)-%c)*%cya(%cndx) + ",
541 cchar[j], scanning?'n':'o', cchar[j],
542 cchar[j], cchar[j], cchar[j], cchar[j]);
543 printf("(%c-%cxa(%cndx))*%cya(%cndx+1)) /\n",
544 cchar[j], cchar[j], cchar[j],
545 cchar[j], cchar[j]);
546 printf("\t\t(%cxa(%cndx+1) - %cxa(%cndx)) ;\n",
547 cchar[j], cchar[j], cchar[j], cchar[j]);
548 }
549 /* print color mapping */
550 if (scanning) {
551 printf("r = ri(1); g = gi(1); b = bi(1);\n");
552 printf("ro = %g*rn + %g*gn + %g*bn ;\n",
553 solmat[0][0], solmat[0][1], solmat[0][2]);
554 printf("go = %g*rn + %g*gn + %g*bn ;\n",
555 solmat[1][0], solmat[1][1], solmat[1][2]);
556 printf("bo = %g*rn + %g*gn + %g*bn ;\n",
557 solmat[2][0], solmat[2][1], solmat[2][2]);
558 } else {
559 printf("r1 = ri(1); g1 = gi(1); b1 = bi(1);\n");
560 printf("r = %g*r1 + %g*g1 + %g*b1 ;\n",
561 solmat[0][0], solmat[0][1], solmat[0][2]);
562 printf("g = %g*r1 + %g*g1 + %g*b1 ;\n",
563 solmat[1][0], solmat[1][1], solmat[1][2]);
564 printf("b = %g*r1 + %g*g1 + %g*b1 ;\n",
565 solmat[2][0], solmat[2][1], solmat[2][2]);
566 }
567 }
568
569
570 static void
571 compsoln( /* solve 3xN system using least-squares */
572 COLOR cin[],
573 COLOR cout[],
574 int n
575 )
576 {
577 extern double mx3d_adjoint(), fabs();
578 double mat[3][3], invmat[3][3];
579 double det;
580 double colv[3], rowv[3];
581 int i, j, k;
582
583 if (n < 3) {
584 fprintf(stderr, "%s: too few colors to match!\n", progname);
585 exit(1);
586 }
587 if (n == 3)
588 for (i = 0; i < 3; i++)
589 for (j = 0; j < 3; j++)
590 mat[i][j] = colval(cin[j],i);
591 else { /* compute A^t A */
592 for (i = 0; i < 3; i++)
593 for (j = i; j < 3; j++) {
594 mat[i][j] = 0.;
595 for (k = 0; k < n; k++)
596 mat[i][j] += colval(cin[k],i) *
597 colval(cin[k],j);
598 }
599 for (i = 1; i < 3; i++) /* using symmetry */
600 for (j = 0; j < i; j++)
601 mat[i][j] = mat[j][i];
602 }
603 det = mx3d_adjoint(mat, invmat);
604 if (fabs(det) < 1e-4) {
605 fprintf(stderr, "%s: cannot compute color mapping\n",
606 progname);
607 solmat[0][0] = solmat[1][1] = solmat[2][2] = 1.;
608 solmat[0][1] = solmat[0][2] = solmat[1][0] =
609 solmat[1][2] = solmat[2][0] = solmat[2][1] = 0.;
610 return;
611 }
612 for (i = 0; i < 3; i++)
613 for (j = 0; j < 3; j++)
614 invmat[i][j] /= det;
615 for (i = 0; i < 3; i++) {
616 if (n == 3)
617 for (j = 0; j < 3; j++)
618 colv[j] = colval(cout[j],i);
619 else
620 for (j = 0; j < 3; j++) {
621 colv[j] = 0.;
622 for (k = 0; k < n; k++)
623 colv[j] += colval(cout[k],i) *
624 colval(cin[k],j);
625 }
626 mx3d_transform(colv, invmat, rowv);
627 for (j = 0; j < 3; j++)
628 solmat[i][j] = rowv[j];
629 }
630 }
631
632
633 static void
634 cwarp(void) /* compute color warp map */
635 {
636 int i;
637
638 if ((wcor = new3dw(W3EXACT)) == NULL)
639 goto memerr;
640 for (i = 0; i < 24; i++)
641 if (!add3dpt(wcor, inpRGB[i], mbRGB[i]))
642 goto memerr;
643 return;
644 memerr:
645 perror(progname);
646 exit(1);
647 }
648
649
650 static int
651 cvtcolor( /* convert color according to our mapping */
652 COLOR cout,
653 COLOR cin
654 )
655 {
656 COLOR ctmp;
657 int clipped;
658
659 if (wcor != NULL) {
660 clipped = warp3d(cout, cin, wcor);
661 clipped |= clipgamut(cout,bright(cout),CGAMUT,colmin,colmax);
662 } else if (scanning) {
663 bresp(ctmp, cin);
664 clipped = cresp(cout, ctmp);
665 } else {
666 clipped = cresp(ctmp, cin);
667 bresp(cout, ctmp);
668 }
669 return(clipped);
670 }
671
672
673 static int
674 cresp( /* transform color according to matrix */
675 COLOR cout,
676 COLOR cin
677 )
678 {
679 colortrans(cout, solmat, cin);
680 return(clipgamut(cout, bright(cout), CGAMUT, colmin, colmax));
681 }
682
683
684 static void
685 xyY2RGB( /* convert xyY to RGB */
686 COLOR rgbout,
687 float xyYin[3]
688 )
689 {
690 COLOR ctmp;
691 double d;
692
693 d = xyYin[2] / xyYin[1];
694 ctmp[0] = xyYin[0] * d;
695 ctmp[1] = xyYin[2];
696 ctmp[2] = (1. - xyYin[0] - xyYin[1]) * d;
697 /* allow negative values */
698 colortrans(rgbout, xyz2rgbmat, ctmp);
699 }
700
701
702 static void
703 picdebug(void) /* put out debugging picture */
704 {
705 static COLOR blkcol = BLKCOLOR;
706 COLOR *scan;
707 int y, i;
708 int x, rg;
709
710 if (fseek(stdin, 0L, 0) == EOF) {
711 fprintf(stderr, "%s: cannot seek on input picture\n", progname);
712 exit(1);
713 }
714 getheader(stdin, NULL, NULL); /* skip input header */
715 fgetresolu(&xmax, &ymax, stdin);
716 /* allocate scanline */
717 scan = (COLOR *)malloc(xmax*sizeof(COLOR));
718 if (scan == NULL) {
719 perror(progname);
720 exit(1);
721 }
722 /* finish debug header */
723 fputformat(COLRFMT, debugfp);
724 putc('\n', debugfp);
725 fprtresolu(xmax, ymax, debugfp);
726 /* write debug picture */
727 for (y = ymax-1; y >= 0; y--) {
728 if (freadscan(scan, xmax, stdin) < 0) {
729 fprintf(stderr, "%s: error rereading input picture\n",
730 progname);
731 exit(1);
732 }
733 for (x = 0; x < xmax; x++) {
734 rg = chartndx(x, y, &i);
735 if (rg == RG_CENT) {
736 if (!(1L<<i & gmtflags) || (x+y)&07) {
737 copycolor(scan[x], mbRGB[i]);
738 clipgamut(scan[x], bright(scan[x]),
739 CGAMUT, colmin, colmax);
740 } else
741 copycolor(scan[x], blkcol);
742 } else if (rg == RG_CORR)
743 cvtcolor(scan[x], scan[x]);
744 else if (rg != RG_ORIG)
745 copycolor(scan[x], blkcol);
746 }
747 if (fwritescan(scan, xmax, debugfp) < 0) {
748 fprintf(stderr, "%s: error writing debugging picture\n",
749 progname);
750 exit(1);
751 }
752 }
753 /* clean up */
754 fclose(debugfp);
755 free((void *)scan);
756 }
757
758
759 static void
760 clrdebug(void) /* put out debug picture from color input */
761 {
762 static COLR blkclr = BLKCOLR;
763 COLR mbclr[24], cvclr[24], orclr[24];
764 COLR *scan;
765 COLOR ctmp, ct2;
766 int y, i;
767 int x, rg;
768 /* convert colors */
769 for (i = 0; i < 24; i++) {
770 copycolor(ctmp, mbRGB[i]);
771 clipgamut(ctmp, bright(ctmp), CGAMUT, cblack, cwhite);
772 setcolr(mbclr[i], colval(ctmp,RED),
773 colval(ctmp,GRN), colval(ctmp,BLU));
774 if (inpflags & 1L<<i) {
775 copycolor(ctmp, inpRGB[i]);
776 clipgamut(ctmp, bright(ctmp), CGAMUT, cblack, cwhite);
777 setcolr(orclr[i], colval(ctmp,RED),
778 colval(ctmp,GRN), colval(ctmp,BLU));
779 if (rawmap)
780 copycolr(cvclr[i], mbclr[i]);
781 else {
782 bresp(ctmp, inpRGB[i]);
783 colortrans(ct2, solmat, ctmp);
784 clipgamut(ct2, bright(ct2), CGAMUT,
785 cblack, cwhite);
786 setcolr(cvclr[i], colval(ct2,RED),
787 colval(ct2,GRN),
788 colval(ct2,BLU));
789 }
790 }
791 }
792 /* allocate scanline */
793 scan = (COLR *)malloc(xmax*sizeof(COLR));
794 if (scan == NULL) {
795 perror(progname);
796 exit(1);
797 }
798 /* finish debug header */
799 fputformat(COLRFMT, debugfp);
800 putc('\n', debugfp);
801 fprtresolu(xmax, ymax, debugfp);
802 /* write debug picture */
803 for (y = ymax-1; y >= 0; y--) {
804 for (x = 0; x < xmax; x++) {
805 rg = chartndx(x, y, &i);
806 if (rg == RG_CENT) {
807 if (!(1L<<i & gmtflags) || (x+y)&07)
808 copycolr(scan[x], mbclr[i]);
809 else
810 copycolr(scan[x], blkclr);
811 } else if (rg == RG_BORD || !(1L<<i & inpflags))
812 copycolr(scan[x], blkclr);
813 else if (rg == RG_ORIG)
814 copycolr(scan[x], orclr[i]);
815 else /* rg == RG_CORR */
816 copycolr(scan[x], cvclr[i]);
817 }
818 if (fwritecolrs(scan, xmax, debugfp) < 0) {
819 fprintf(stderr, "%s: error writing debugging picture\n",
820 progname);
821 exit(1);
822 }
823 }
824 /* clean up */
825 fclose(debugfp);
826 free((void *)scan);
827 }
828
829
830 static void
831 getpos( /* get boundary position */
832 char *name,
833 int bnds[2],
834 FILE *fp
835 )
836 {
837 char buf[64];
838
839 fprintf(stderr, "\tSelect corner: %s\n", name);
840 if (fgets(buf, sizeof(buf), fp) == NULL ||
841 sscanf(buf, "%d %d", &bnds[0], &bnds[1]) != 2) {
842 fprintf(stderr, "%s: read error from display process\n",
843 progname);
844 exit(1);
845 }
846 }
847
848
849 static void
850 pickchartpos( /* display picture and pick chart location */
851 char *pfn
852 )
853 {
854 char combuf[PATH_MAX];
855 FILE *pfp;
856
857 sprintf(combuf, DISPCOM, pfn);
858 if ((pfp = popen(combuf, "r")) == NULL) {
859 perror(combuf);
860 exit(1);
861 }
862 fputs("Use middle mouse button to select chart corners:\n", stderr);
863 getpos("upper left (dark skin)", bounds[0], pfp);
864 getpos("upper right (bluish green)", bounds[1], pfp);
865 getpos("lower left (white)", bounds[2], pfp);
866 getpos("lower right (black)", bounds[3], pfp);
867 fputs("Got it -- quit display program.\n", stderr);
868 pclose(pfp);
869 }
