root/radiance/ray/src/px/macbethcal.c
Revision: 2.13
Committed: Fri Jan 31 15:56:17 1997 UTC (28 years, 5 months ago) by greg
Changes since 2.12: +50 -42 lines
added gamut mapping for display devices (doesn't work w/ pcomb)
1 /* Copyright (c) 1997 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Calibrate a scanned MacBeth Color Checker Chart
9 *
10 * Produce a .cal file suitable for use with pcomb.
11 */
12
13 #include <stdio.h>
14 #ifdef MSDOS
15 #include <fcntl.h>
16 #endif
17 #include "color.h"
18 #include "resolu.h"
19 #include "pmap.h"
20
21 /* MacBeth colors */
22 #define DarkSkin 0
23 #define LightSkin 1
24 #define BlueSky 2
25 #define Foliage 3
26 #define BlueFlower 4
27 #define BluishGreen 5
28 #define Orange 6
29 #define PurplishBlue 7
30 #define ModerateRed 8
31 #define Purple 9
32 #define YellowGreen 10
33 #define OrangeYellow 11
34 #define Blue 12
35 #define Green 13
36 #define Red 14
37 #define Yellow 15
38 #define Magenta 16
39 #define Cyan 17
40 #define White 18
41 #define Neutral8 19
42 #define Neutral65 20
43 #define Neutral5 21
44 #define Neutral35 22
45 #define Black 23
46 /* computed from 5nm spectral measurements */
47 /* CIE 1931 2 degree obs, equal-energy white */
48 float mbxyY[24][3] = {
49 {0.462, 0.3769, 0.0932961}, /* DarkSkin */
50 {0.4108, 0.3542, 0.410348}, /* LightSkin */
51 {0.2626, 0.267, 0.181554}, /* BlueSky */
52 {0.36, 0.4689, 0.108447}, /* Foliage */
53 {0.2977, 0.2602, 0.248407}, /* BlueFlower */
54 {0.2719, 0.3485, 0.401156}, /* BluishGreen */
55 {0.52, 0.4197, 0.357899}, /* Orange */
56 {0.229, 0.1866, 0.103911}, /* PurplishBlue */
57 {0.4909, 0.3262, 0.242615}, /* ModerateRed */
58 {0.3361, 0.2249, 0.0600102}, /* Purple */
59 {0.3855, 0.4874, 0.42963}, /* YellowGreen */
60 {0.4853, 0.4457, 0.476343}, /* OrangeYellow */
61 {0.2026, 0.1369, 0.0529249}, /* Blue */
62 {0.3007, 0.4822, 0.221226}, /* Green */
63 {0.5805, 0.3238, 0.162167}, /* Red */
64 {0.4617, 0.472, 0.64909}, /* Yellow */
65 {0.4178, 0.2625, 0.233662}, /* Magenta */
66 {0.2038, 0.2508, 0.167275}, /* Cyan */
67 {0.3358, 0.337, 0.916877}, /* White */
68 {0.3338, 0.3348, 0.604678}, /* Neutral.8 */
69 {0.3333, 0.3349, 0.364566}, /* Neutral.65 */
70 {0.3353, 0.3359, 0.200238}, /* Neutral.5 */
71 {0.3363, 0.336, 0.0878721}, /* Neutral.35 */
72 {0.3346, 0.3349, 0.0308383} /* Black */
73 };
74
75 COLOR mbRGB[24]; /* MacBeth RGB values */
76
77 #define NMBNEU 6 /* Number of MacBeth neutral colors */
78 short mbneu[NMBNEU] = {Black,Neutral35,Neutral5,Neutral65,Neutral8,White};
79
80 #define NEUFLGS (1L<<White|1L<<Neutral8|1L<<Neutral65| \
81 1L<<Neutral5|1L<<Neutral35|1L<<Black)
82
83 #define SATFLGS (1L<<Red|1L<<Green|1L<<Blue|1L<<Magenta|1L<<Yellow| \
84 1L<<Cyan|1L<<Orange|1L<<Purple|1L<<PurplishBlue| \
85 1L<<YellowGreen|1<<OrangeYellow|1L<<BlueFlower)
86
87 #define UNSFLGS (1L<<DarkSkin|1L<<LightSkin|1L<<BlueSky|1L<<Foliage| \
88 1L<<BluishGreen|1L<<ModerateRed)
89
90 #define REQFLGS NEUFLGS /* need these colors */
91 #define MODFLGS (NEUFLGS|UNSFLGS) /* should be in gamut */
92
93 #define RG_BORD 0 /* patch border */
94 #define RG_CENT 01 /* central region of patch */
95 #define RG_ORIG 02 /* original color region */
96 #define RG_CORR 04 /* corrected color region */
97
98 int scanning = 1; /* scanned input (or recorded output)? */
99
100 int xmax, ymax; /* input image dimensions */
101 int bounds[4][2]; /* image coordinates of chart corners */
102 double imgxfm[3][3]; /* coordinate transformation matrix */
103
104 COLOR inpRGB[24]; /* measured or scanned input colors */
105 long inpflags = 0; /* flags of which colors were input */
106 long gmtflags = 0; /* flags of out-of-gamut colors */
107
108 COLOR bramp[NMBNEU][2]; /* brightness ramp (per primary) */
109 COLORMAT solmat; /* color mapping matrix */
110 COLOR colmin, colmax; /* gamut limits */
111
112 FILE *debugfp = NULL; /* debug output picture */
113 char *progname;
114
115 extern char *malloc();
116
117
118 main(argc, argv)
119 int argc;
120 char **argv;
121 {
122 int i;
123
124 progname = argv[0];
125 for (i = 1; i < argc && argv[i][0] == '-'; i++)
126 switch (argv[i][1]) {
127 case 'd': /* debug output */
128 i++;
129 if (badarg(argc-i, argv+i, "s"))
130 goto userr;
131 if ((debugfp = fopen(argv[i], "w")) == NULL) {
132 perror(argv[i]);
133 exit(1);
134 }
135 #ifdef MSDOS
136 setmode(fileno(debugfp), O_BINARY);
137 #endif
138 newheader("RADIANCE", debugfp); /* start */
139 printargs(argc, argv, debugfp); /* header */
140 break;
141 case 'p': /* picture position */
142 if (badarg(argc-i-1, argv+i+1, "iiiiiiii"))
143 goto userr;
144 bounds[0][0] = atoi(argv[++i]);
145 bounds[0][1] = atoi(argv[++i]);
146 bounds[1][0] = atoi(argv[++i]);
147 bounds[1][1] = atoi(argv[++i]);
148 bounds[2][0] = atoi(argv[++i]);
149 bounds[2][1] = atoi(argv[++i]);
150 bounds[3][0] = atoi(argv[++i]);
151 bounds[3][1] = atoi(argv[++i]);
152 scanning = 2;
153 break;
154 case 'c': /* color input */
155 scanning = 0;
156 break;
157 default:
158 goto userr;
159 }
160 /* open files */
161 if (i < argc && freopen(argv[i], "r", stdin) == NULL) {
162 perror(argv[i]);
163 exit(1);
164 }
165 if (i+1 < argc && freopen(argv[i+1], "w", stdout) == NULL) {
166 perror(argv[i+1]);
167 exit(1);
168 }
169 if (scanning) { /* load input picture header */
170 #ifdef MSDOS
171 setmode(fileno(stdin), O_BINARY);
172 #endif
173 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
174 fgetresolu(&xmax, &ymax, stdin) < 0) {
175 fprintf(stderr, "%s: bad input picture\n", progname);
176 exit(1);
177 }
178 } else { /* else set default xmax and ymax */
179 xmax = 512;
180 ymax = 2*512/3;
181 }
182 if (scanning != 2) { /* use default boundaries */
183 bounds[0][0] = bounds[2][0] = .029*xmax + .5;
184 bounds[0][1] = bounds[1][1] = .956*ymax + .5;
185 bounds[1][0] = bounds[3][0] = .971*xmax + .5;
186 bounds[2][1] = bounds[3][1] = .056*ymax + .5;
187 }
188 init(); /* initialize */
189 if (scanning) /* get picture colors */
190 getpicture();
191 else
192 getcolors();
193 compute(); /* compute color mapping */
194 /* print comment */
195 printf("{\n\tColor correction file computed by:\n\t\t");
196 printargs(argc, argv, stdout);
197 printf("\n\tUsage: pcomb -f %s uncorrected.pic > corrected.pic\n",
198 i+1 < argc ? argv[i+1] : "{this_file}");
199 if (!scanning)
200 printf("\t Or: pcond [options] -f %s orig.pic > output.pic\n",
201 i+1 < argc ? argv[i+1] : "{this_file}");
202 printf("}\n");
203 putmapping(); /* put out color mapping */
204 if (debugfp != NULL) /* put out debug picture */
205 if (scanning)
206 picdebug();
207 else
208 clrdebug();
209 exit(0);
210 userr:
211 fprintf(stderr,
212 "Usage: %s [-d dbg.pic][-p xul yul xur yur xll yll xlr ylr] input.pic [output.cal]\n",
213 progname);
214 fprintf(stderr, " or: %s [-d dbg.pic] -c [xyY.dat [output.cal]]\n",
215 progname);
216 exit(1);
217 }
218
219
220 init() /* initialize */
221 {
222 double quad[4][2];
223 register int i;
224 /* make coordinate transformation */
225 quad[0][0] = bounds[0][0];
226 quad[0][1] = bounds[0][1];
227 quad[1][0] = bounds[1][0];
228 quad[1][1] = bounds[1][1];
229 quad[2][0] = bounds[3][0];
230 quad[2][1] = bounds[3][1];
231 quad[3][0] = bounds[2][0];
232 quad[3][1] = bounds[2][1];
233
234 if (pmap_quad_rect(0., 0., 6., 4., quad, imgxfm) == PMAP_BAD) {
235 fprintf(stderr, "%s: bad chart boundaries\n", progname);
236 exit(1);
237 }
238 /* map MacBeth colors to RGB space */
239 for (i = 0; i < 24; i++)
240 xyY2RGB(mbRGB[i], mbxyY[i]);
241 }
242
243
244 int
245 chartndx(x, y, np) /* find color number for position */
246 int x, y;
247 int *np;
248 {
249 double ipos[3], cpos[3];
250 int ix, iy;
251 double fx, fy;
252
253 ipos[0] = x;
254 ipos[1] = y;
255 ipos[2] = 1;
256 mx3d_transform(ipos, imgxfm, cpos);
257 cpos[0] /= cpos[2];
258 cpos[1] /= cpos[2];
259 if (cpos[0] < 0. || cpos[0] >= 6. || cpos[1] < 0. || cpos[1] >= 4.)
260 return(RG_BORD);
261 ix = cpos[0];
262 iy = cpos[1];
263 fx = cpos[0] - ix;
264 fy = cpos[1] - iy;
265 *np = iy*6 + ix;
266 if (fx >= 0.35 && fx < 0.65 && fy >= 0.35 && fy < 0.65)
267 return(RG_CENT);
268 if (fx < 0.05 || fx >= 0.95 || fy < 0.05 || fy >= 0.95)
269 return(RG_BORD);
270 if (fx >= 0.5) /* right side is corrected */
271 return(RG_CORR);
272 return(RG_ORIG); /* left side is original */
273 }
274
275
276 getpicture() /* load in picture colors */
277 {
278 COLR *scanln;
279 COLOR pval;
280 int ccount[24];
281 double d;
282 int y, i;
283 register int x;
284
285 scanln = (COLR *)malloc(xmax*sizeof(COLR));
286 if (scanln == NULL) {
287 perror(progname);
288 exit(1);
289 }
290 for (i = 0; i < 24; i++) {
291 setcolor(inpRGB[i], 0., 0., 0.);
292 ccount[i] = 0;
293 }
294 for (y = ymax-1; y >= 0; y--) {
295 if (freadcolrs(scanln, xmax, stdin) < 0) {
296 fprintf(stderr, "%s: error reading input picture\n",
297 progname);
298 exit(1);
299 }
300 for (x = 0; x < xmax; x++)
301 if (chartndx(x, y, &i) == RG_CENT) {
302 colr_color(pval, scanln[x]);
303 addcolor(inpRGB[i], pval);
304 ccount[i]++;
305 }
306 }
307 for (i = 0; i < 24; i++) { /* compute averages */
308 if (ccount[i] == 0)
309 continue;
310 d = 1./ccount[i];
311 scalecolor(inpRGB[i], d);
312 inpflags |= 1L<<i;
313 }
314 free((char *)scanln);
315 }
316
317
318 getcolors() /* get xyY colors from standard input */
319 {
320 int gotwhite = 0;
321 COLOR whiteclr;
322 int n;
323 float xyYin[3];
324
325 while (fgetval(stdin, 'i', &n) == 1) { /* read colors */
326 if (n < 0 | n > 24 ||
327 fgetval(stdin, 'f', &xyYin[0]) != 1 ||
328 fgetval(stdin, 'f', &xyYin[1]) != 1 ||
329 fgetval(stdin, 'f', &xyYin[2]) != 1 ||
330 xyYin[0] < 0. | xyYin[1] < 0. ||
331 xyYin[0] + xyYin[1] > 1.) {
332 fprintf(stderr, "%s: bad color input data\n",
333 progname);
334 exit(1);
335 }
336 if (n == 0) { /* calibration white */
337 xyY2RGB(whiteclr, xyYin);
338 gotwhite++;
339 } else { /* standard color */
340 n--;
341 xyY2RGB(inpRGB[n], xyYin);
342 inpflags |= 1L<<n;
343 }
344 }
345 /* normalize colors */
346 if (!gotwhite) {
347 if (!(inpflags & 1L<<White)) {
348 fprintf(stderr, "%s: missing input for White\n",
349 progname);
350 exit(1);
351 }
352 setcolor(whiteclr,
353 colval(inpRGB[White],RED)/colval(mbRGB[White],RED),
354 colval(inpRGB[White],GRN)/colval(mbRGB[White],GRN),
355 colval(inpRGB[White],BLU)/colval(mbRGB[White],BLU));
356 }
357 for (n = 0; n < 24; n++)
358 if (inpflags & 1L<<n)
359 setcolor(inpRGB[n],
360 colval(inpRGB[n],RED)/colval(whiteclr,RED),
361 colval(inpRGB[n],GRN)/colval(whiteclr,GRN),
362 colval(inpRGB[n],BLU)/colval(whiteclr,BLU));
363 }
364
365
366 bresp(y, x) /* piecewise linear interpolation of primaries */
367 COLOR y, x;
368 {
369 register int i, n;
370
371 for (i = 0; i < 3; i++) {
372 for (n = 0; n < NMBNEU-2; n++)
373 if (colval(x,i) < colval(bramp[n+1][0],i))
374 break;
375 colval(y,i) = ((colval(bramp[n+1][0],i) - colval(x,i)) *
376 colval(bramp[n][1],i) +
377 (colval(x,i) - colval(bramp[n][0],i)) *
378 colval(bramp[n+1][1],i)) /
379 (colval(bramp[n+1][0],i) - colval(bramp[n][0],i));
380 }
381 }
382
383
384 compute() /* compute color mapping */
385 {
386 COLOR clrin[24], clrout[24];
387 long cflags;
388 COLOR ctmp;
389 register int i, n;
390 /* did we get what we need? */
391 if ((inpflags & REQFLGS) != REQFLGS) {
392 fprintf(stderr, "%s: missing required input colors\n",
393 progname);
394 exit(1);
395 }
396 /* compute piecewise luminance curve */
397 for (i = 0; i < NMBNEU; i++) {
398 copycolor(bramp[i][0], inpRGB[mbneu[i]]);
399 copycolor(bramp[i][1], mbRGB[mbneu[i]]);
400 }
401 /* compute color space gamut */
402 if (scanning) {
403 copycolor(colmin, cblack);
404 copycolor(colmax, cwhite);
405 } else
406 for (i = 0; i < 3; i++) {
407 colval(colmin,i) = colval(bramp[0][0],i) -
408 colval(bramp[0][1],i) *
409 (colval(bramp[1][0],i)-colval(bramp[0][0],i)) /
410 (colval(bramp[1][1],i)-colval(bramp[1][0],i));
411 colval(colmax,i) = colval(bramp[NMBNEU-2][0],i) +
412 (1.-colval(bramp[NMBNEU-2][1],i)) *
413 (colval(bramp[NMBNEU-1][0],i) -
414 colval(bramp[NMBNEU-2][0],i)) /
415 (colval(bramp[NMBNEU-1][1],i) -
416 colval(bramp[NMBNEU-2][1],i));
417 }
418 /* compute color mapping */
419 do {
420 cflags = inpflags & ~gmtflags;
421 n = 0; /* compute transform matrix */
422 for (i = 0; i < 24; i++)
423 if (cflags & 1L<<i) {
424 bresp(clrin[n], inpRGB[i]);
425 copycolor(clrout[n], mbRGB[i]);
426 n++;
427 }
428 compsoln(clrin, clrout, n);
429 /* check out-of-gamut colors */
430 for (i = 0; i < 24; i++)
431 if (cflags & 1L<<i && cvtcolor(ctmp, mbRGB[i]))
432 gmtflags |= 1L<<i;
433 } while (cflags & gmtflags);
434 if (gmtflags & MODFLGS)
435 fprintf(stderr,
436 "%s: warning - some moderate colors are out of gamut\n",
437 progname);
438 }
439
440
441 putmapping() /* put out color mapping for pcomb -f */
442 {
443 static char cchar[3] = {'r', 'g', 'b'};
444 register int i, j;
445 /* print brightness mapping */
446 for (j = 0; j < 3; j++) {
447 printf("%cxa(i) : select(i", cchar[j]);
448 for (i = 0; i < NMBNEU; i++)
449 printf(",%g", colval(bramp[i][0],j));
450 printf(");\n");
451 printf("%cya(i) : select(i", cchar[j]);
452 for (i = 0; i < NMBNEU; i++)
453 printf(",%g", colval(bramp[i][1],j));
454 printf(");\n");
455 printf("%cfi(n) = if(n-%g, %d, if(%cxa(n+1)-%c, n, %cfi(n+1)));\n",
456 cchar[j], NMBNEU-1.5, NMBNEU-1, cchar[j],
457 cchar[j], cchar[j]);
458 printf("%cndx = %cfi(1);\n", cchar[j], cchar[j]);
459 printf("%c%c = ((%cxa(%cndx+1)-%c)*%cya(%cndx) + ",
460 cchar[j], scanning?'n':'o', cchar[j],
461 cchar[j], cchar[j], cchar[j], cchar[j]);
462 printf("(%c-%cxa(%cndx))*%cya(%cndx+1)) /\n",
463 cchar[j], cchar[j], cchar[j],
464 cchar[j], cchar[j]);
465 printf("\t\t(%cxa(%cndx+1) - %cxa(%cndx)) ;\n",
466 cchar[j], cchar[j], cchar[j], cchar[j]);
467 }
468 /* print color mapping */
469 if (scanning) {
470 printf("r = ri(1); g = gi(1); b = bi(1);\n");
471 printf("ro = %g*rn + %g*gn + %g*bn ;\n",
472 solmat[0][0], solmat[0][1], solmat[0][2]);
473 printf("go = %g*rn + %g*gn + %g*bn ;\n",
474 solmat[1][0], solmat[1][1], solmat[1][2]);
475 printf("bo = %g*rn + %g*gn + %g*bn ;\n",
476 solmat[2][0], solmat[2][1], solmat[2][2]);
477 } else {
478 printf("r1 = ri(1); g1 = gi(1); b1 = bi(1);\n");
479 printf("r = %g*r1 + %g*g1 + %g*b1 ;\n",
480 solmat[0][0], solmat[0][1], solmat[0][2]);
481 printf("g = %g*r1 + %g*g1 + %g*b1 ;\n",
482 solmat[1][0], solmat[1][1], solmat[1][2]);
483 printf("b = %g*r1 + %g*g1 + %g*b1 ;\n",
484 solmat[2][0], solmat[2][1], solmat[2][2]);
485 }
486 }
487
488
489 compsoln(cin, cout, n) /* solve 3xN system using least-squares */
490 COLOR cin[], cout[];
491 int n;
492 {
493 extern double mx3d_adjoint(), fabs();
494 double mat[3][3], invmat[3][3];
495 double det;
496 double colv[3], rowv[3];
497 register int i, j, k;
498
499 if (n < 3) {
500 fprintf(stderr, "%s: too few colors to match!\n", progname);
501 exit(1);
502 }
503 if (n == 3)
504 for (i = 0; i < 3; i++)
505 for (j = 0; j < 3; j++)
506 mat[i][j] = colval(cin[j],i);
507 else { /* compute A^t A */
508 for (i = 0; i < 3; i++)
509 for (j = i; j < 3; j++) {
510 mat[i][j] = 0.;
511 for (k = 0; k < n; k++)
512 mat[i][j] += colval(cin[k],i) *
513 colval(cin[k],j);
514 }
515 for (i = 1; i < 3; i++) /* using symmetry */
516 for (j = 0; j < i; j++)
517 mat[i][j] = mat[j][i];
518 }
519 det = mx3d_adjoint(mat, invmat);
520 if (fabs(det) < 1e-4) {
521 fprintf(stderr, "%s: cannot compute color mapping\n",
522 progname);
523 solmat[0][0] = solmat[1][1] = solmat[2][2] = 1.;
524 solmat[0][1] = solmat[0][2] = solmat[1][0] =
525 solmat[1][2] = solmat[2][0] = solmat[2][1] = 0.;
526 return;
527 }
528 for (i = 0; i < 3; i++)
529 for (j = 0; j < 3; j++)
530 invmat[i][j] /= det;
531 for (i = 0; i < 3; i++) {
532 if (n == 3)
533 for (j = 0; j < 3; j++)
534 colv[j] = colval(cout[j],i);
535 else
536 for (j = 0; j < 3; j++) {
537 colv[j] = 0.;
538 for (k = 0; k < n; k++)
539 colv[j] += colval(cout[k],i) *
540 colval(cin[k],j);
541 }
542 mx3d_transform(colv, invmat, rowv);
543 for (j = 0; j < 3; j++)
544 solmat[i][j] = rowv[j];
545 }
546 }
547
548
549 int
550 cvtcolor(cout, cin) /* convert color according to our mapping */
551 COLOR cout, cin;
552 {
553 COLOR ctmp;
554 int clipped;
555
556 if (scanning) {
557 bresp(ctmp, cin);
558 clipped = cresp(cout, ctmp);
559 } else {
560 clipped = cresp(ctmp, cin);
561 bresp(cout, ctmp);
562 }
563 return(clipped);
564 }
565
566
567 int
568 cresp(cout, cin) /* transform color according to matrix */
569 COLOR cout, cin;
570 {
571 colortrans(cout, solmat, cin);
572 return(clipgamut(cout, bright(cout), CGAMUT, colmin, colmax));
573 }
574
575
576 xyY2RGB(rgbout, xyYin) /* convert xyY to RGB */
577 COLOR rgbout;
578 register float xyYin[3];
579 {
580 COLOR ctmp;
581 double d;
582
583 d = xyYin[2] / xyYin[1];
584 ctmp[0] = xyYin[0] * d;
585 ctmp[1] = xyYin[2];
586 ctmp[2] = (1. - xyYin[0] - xyYin[1]) * d;
587 /* allow negative values */
588 colortrans(rgbout, xyz2rgbmat, ctmp);
589 }
590
591
592 picdebug() /* put out debugging picture */
593 {
594 static COLOR blkcol = BLKCOLOR;
595 COLOR *scan;
596 int y, i;
597 register int x, rg;
598
599 if (fseek(stdin, 0L, 0) == EOF) {
600 fprintf(stderr, "%s: cannot seek on input picture\n", progname);
601 exit(1);
602 }
603 getheader(stdin, NULL, NULL); /* skip input header */
604 fgetresolu(&xmax, &ymax, stdin);
605 /* allocate scanline */
606 scan = (COLOR *)malloc(xmax*sizeof(COLOR));
607 if (scan == NULL) {
608 perror(progname);
609 exit(1);
610 }
611 /* finish debug header */
612 fputformat(COLRFMT, debugfp);
613 putc('\n', debugfp);
614 fprtresolu(xmax, ymax, debugfp);
615 /* write debug picture */
616 for (y = ymax-1; y >= 0; y--) {
617 if (freadscan(scan, xmax, stdin) < 0) {
618 fprintf(stderr, "%s: error rereading input picture\n",
619 progname);
620 exit(1);
621 }
622 for (x = 0; x < xmax; x++) {
623 rg = chartndx(x, y, &i);
624 if (rg == RG_CENT) {
625 if (!(1L<<i & gmtflags) || (x+y)&07) {
626 copycolor(scan[x], mbRGB[i]);
627 clipgamut(scan[x], bright(scan[x]),
628 CGAMUT, cblack, cwhite);
629 } else
630 copycolor(scan[x], blkcol);
631 } else if (rg == RG_CORR)
632 cvtcolor(scan[x], scan[x]);
633 else if (rg != RG_ORIG)
634 copycolor(scan[x], blkcol);
635 }
636 if (fwritescan(scan, xmax, debugfp) < 0) {
637 fprintf(stderr, "%s: error writing debugging picture\n",
638 progname);
639 exit(1);
640 }
641 }
642 /* clean up */
643 fclose(debugfp);
644 free((char *)scan);
645 }
646
647
648 clrdebug() /* put out debug picture from color input */
649 {
650 static COLR blkclr = BLKCOLR;
651 COLR mbclr[24], cvclr[24], orclr[24];
652 COLR *scan;
653 COLOR ctmp, ct2;
654 int y, i;
655 register int x, rg;
656 /* convert colors */
657 for (i = 0; i < 24; i++) {
658 copycolor(ctmp, mbRGB[i]);
659 clipgamut(ctmp, bright(ctmp), CGAMUT, cblack, cwhite);
660 setcolr(mbclr[i], colval(ctmp,RED),
661 colval(ctmp,GRN), colval(ctmp,BLU));
662 if (inpflags & 1L<<i) {
663 copycolor(ctmp, inpRGB[i]);
664 clipgamut(ctmp, bright(ctmp), CGAMUT, cblack, cwhite);
665 setcolr(orclr[i], colval(ctmp,RED),
666 colval(ctmp,GRN), colval(ctmp,BLU));
667 bresp(ctmp, inpRGB[i]);
668 colortrans(ct2, solmat, ctmp);
669 clipgamut(ct2, bright(ct2), CGAMUT, cblack, cwhite);
670 setcolr(cvclr[i], colval(ct2,RED),
671 colval(ct2,GRN), colval(ct2,BLU));
672 }
673 }
674 /* allocate scanline */
675 scan = (COLR *)malloc(xmax*sizeof(COLR));
676 if (scan == NULL) {
677 perror(progname);
678 exit(1);
679 }
680 /* finish debug header */
681 fputformat(COLRFMT, debugfp);
682 putc('\n', debugfp);
683 fprtresolu(xmax, ymax, debugfp);
684 /* write debug picture */
685 for (y = ymax-1; y >= 0; y--) {
686 for (x = 0; x < xmax; x++) {
687 rg = chartndx(x, y, &i);
688 if (rg == RG_CENT) {
689 if (!(1L<<i & gmtflags) || (x+y)&07)
690 copycolr(scan[x], mbclr[i]);
691 else
692 copycolr(scan[x], blkclr);
693 } else if (rg == RG_BORD || !(1L<<i & inpflags))
694 copycolr(scan[x], blkclr);
695 else if (rg == RG_ORIG)
696 copycolr(scan[x], orclr[i]);
697 else /* rg == RG_CORR */
698 copycolr(scan[x], cvclr[i]);
699 }
700 if (fwritecolrs(scan, xmax, debugfp) < 0) {
701 fprintf(stderr, "%s: error writing debugging picture\n",
702 progname);
703 exit(1);
704 }
705 }
706 /* clean up */
707 fclose(debugfp);
708 free((char *)scan);
709 }
