root/radiance/ray/src/px/macbethcal.c
Revision: 2.30
Committed: Thu Feb 22 17:45:54 2024 UTC (14 months, 1 week ago) by greg
Changes since 2.29: +42 -23 lines
perf(macbethcal): Untested performance improvement for measured printer values
2 static const char RCSid[] = "$Id: macbethcal.c,v 2.29 2024/02/22 02:07:40 greg Exp $";
5 * Calibrate a scanned MacBeth Color Checker Chart
6 *
7 * Produce a .cal file suitable for use with pcomb,
8 * or .cwp file suitable for use with pcwarp.
9 *
10 * Warping code depends on conformance of COLOR and W3VEC types.
11 */
12
13 #include <math.h>
14
15 #include "platform.h"
16 #include "paths.h"
17 #include "rtio.h"
18 #include "color.h"
19 #include "resolu.h"
20 #include "pmap.h"
21 #include "warp3d.h"
22 #include "mx3.h"
23
24 /* MacBeth colors */
25 #define DarkSkin 0
26 #define LightSkin 1
27 #define BlueSky 2
28 #define Foliage 3
29 #define BlueFlower 4
30 #define BluishGreen 5
31 #define Orange 6
32 #define PurplishBlue 7
33 #define ModerateRed 8
34 #define Purple 9
35 #define YellowGreen 10
36 #define OrangeYellow 11
37 #define Blue 12
38 #define Green 13
39 #define Red 14
40 #define Yellow 15
41 #define Magenta 16
42 #define Cyan 17
43 #define White 18
44 #define Neutral8 19
45 #define Neutral65 20
46 #define Neutral5 21
47 #define Neutral35 22
48 #define Black 23
49 /* computed from 10nm spectral measurements */
50 /* CIE 1931 2 degree obs, equal-energy white */
51 float mbxyY[24][3] = {
52 {0.421236, 0.361196, 0.103392}, /* DarkSkin */
53 {0.40868, 0.358157, 0.352867}, /* LightSkin */
54 {0.265063, 0.271424, 0.185124}, /* BlueSky */
55 {0.362851, 0.43055, 0.132625}, /* Foliage */
56 {0.28888, 0.260851, 0.233138}, /* BlueFlower */
57 {0.277642, 0.365326, 0.416443}, /* BluishGreen */
58 {0.524965, 0.40068, 0.312039}, /* Orange */
59 {0.225018, 0.190392, 0.114999}, /* PurplishBlue */
60 {0.487199, 0.315372, 0.198616}, /* ModerateRed */
61 {0.314245, 0.227231, 0.0646047}, /* Purple */
62 {0.396202, 0.489732, 0.440724}, /* YellowGreen */
63 {0.493297, 0.435299, 0.43444}, /* OrangeYellow */
64 {0.198191, 0.149265, 0.0588122}, /* Blue */
65 {0.322838, 0.487601, 0.229258}, /* Green */
66 {0.561833, 0.321165, 0.126978}, /* Red */
67 {0.468113, 0.467021, 0.605289}, /* Yellow */
68 {0.397128, 0.248535, 0.201761}, /* Magenta */
69 {0.209552, 0.276256, 0.190917}, /* Cyan */
70 {0.337219, 0.339042, 0.912482}, /* White */
71 {0.333283, 0.335077, 0.588297}, /* Neutral.8 */
72 {0.332747, 0.334371, 0.3594}, /* Neutral.65 */
73 {0.331925, 0.334202, 0.19114}, /* Neutral.5 */
74 {0.330408, 0.332615, 0.0892964}, /* Neutral.35 */
75 {0.331841, 0.331405, 0.0319541}, /* Black */
76 };
77
78 COLOR mbRGB[24]; /* MacBeth RGB values */
79
80 #define NMBNEU 6 /* Number of MacBeth neutral colors */
81 short mbneu[NMBNEU] = {Black,Neutral35,Neutral5,Neutral65,Neutral8,White};
82
83 #define NEUFLGS (1L<<White|1L<<Neutral8|1L<<Neutral65| \
84 1L<<Neutral5|1L<<Neutral35|1L<<Black)
85
86 #define SATFLGS (1L<<Red|1L<<Green|1L<<Blue|1L<<Magenta|1L<<Yellow| \
87 1L<<Cyan|1L<<Orange|1L<<Purple|1L<<PurplishBlue| \
88 1L<<YellowGreen|1<<OrangeYellow|1L<<BlueFlower)
89
90 #define UNSFLGS (1L<<DarkSkin|1L<<LightSkin|1L<<BlueSky|1L<<Foliage| \
91 1L<<BluishGreen|1L<<ModerateRed)
92
93 #define REQFLGS NEUFLGS /* need these colors */
94 #define MODFLGS (NEUFLGS|UNSFLGS) /* should be in gamut */
95
96 #define RG_BORD 0 /* patch border */
97 #define RG_CENT 01 /* central region of patch */
98 #define RG_ORIG 02 /* original color region */
99 #define RG_CORR 04 /* corrected color region */
100
101 #ifndef DISPCOM
102 #define DISPCOM "ximage -e auto -op \"%s\""
103 #endif
104
105 int scanning = 1; /* scanned input (or recorded output)? */
106 double irrad = 1.0; /* irradiance multiplication factor */
107 int rawmap = 0; /* put out raw color mapping? */
108
109 int xmax, ymax; /* input image dimensions */
110 int bounds[4][2]; /* image coordinates of chart corners */
111 double imgxfm[3][3]; /* coordinate transformation matrix */
112
113 COLOR inpRGB[24]; /* measured or scanned input colors */
114 long inpflags = 0; /* flags of which colors were input */
115 long gmtflags = 0; /* flags of out-of-gamut colors */
116
117 COLOR bramp[NMBNEU][2]; /* brightness ramp (per primary) */
118 COLORMAT solmat; /* color mapping matrix */
119 COLOR colmin, colmax; /* gamut limits */
120
121 WARP3D *wcor = NULL; /* color space warp */
122
123 FILE *debugfp = NULL; /* debug output picture */
124 char *progname;
125
126 static void init(void);
127 static int chartndx(int x, int y, int *np);
128 static void getpicture(void);
129 static void getcolors(void);
130 static void bresp(COLOR y, COLOR x);
131 static void ibresp(COLOR y, COLOR x);
132 static void compute(void);
133 static void putmapping(void);
134 static void compsoln(COLOR cin[], COLOR cout[], int n);
135 static void cwarp(void);
136 static int cvtcolor(COLOR cout, COLOR cin);
137 static int cresp(COLOR cout, COLOR cin);
138 static void xyY2RGB(COLOR rgbout, float xyYin[3]);
139 static void picdebug(void);
140 static void clrdebug(void);
141 static void getpos(char *name, int bnds[2], FILE *fp);
142 static void pickchartpos(char *pfn);
143
144
145 int
146 main(
147 int argc,
148 char **argv
149 )
150 {
151 int i;
152
153 progname = argv[0];
154 for (i = 1; i < argc && argv[i][0] == '-'; i++)
155 switch (argv[i][1]) {
156 case 'd': /* debug output */
157 i++;
158 if (badarg(argc-i, argv+i, "s"))
159 goto userr;
160 if ((debugfp = fopen(argv[i], "w")) == NULL) {
161 perror(argv[i]);
162 exit(1);
163 }
164 SET_FILE_BINARY(debugfp);
165 newheader("RADIANCE", debugfp); /* start */
166 printargs(argc, argv, debugfp); /* header */
167 break;
168 case 'p': /* picture position */
169 if (badarg(argc-i-1, argv+i+1, "iiiiiiii"))
170 goto userr;
171 bounds[0][0] = atoi(argv[++i]);
172 bounds[0][1] = atoi(argv[++i]);
173 bounds[1][0] = atoi(argv[++i]);
174 bounds[1][1] = atoi(argv[++i]);
175 bounds[2][0] = atoi(argv[++i]);
176 bounds[2][1] = atoi(argv[++i]);
177 bounds[3][0] = atoi(argv[++i]);
178 bounds[3][1] = atoi(argv[++i]);
179 scanning = 2;
180 break;
181 case 'P': /* pick position */
182 scanning = 3;
183 break;
184 case 'i': /* irradiance factor */
185 i++;
186 if (badarg(argc-i, argv+i, "f"))
187 goto userr;
188 irrad = atof(argv[i]);
189 break;
190 case 'm': /* raw map output */
191 rawmap = 1;
192 break;
193 case 'c': /* color input */
194 scanning = 0;
195 break;
196 default:
197 goto userr;
198 }
199 /* open files */
200 if (i < argc && freopen(argv[i], "r", stdin) == NULL) {
201 perror(argv[i]);
202 exit(1);
203 }
204 if (i+1 < argc && freopen(argv[i+1], "w", stdout) == NULL) {
205 perror(argv[i+1]);
206 exit(1);
207 }
208 if (scanning) { /* load input picture header */
209 SET_FILE_BINARY(stdin);
210 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
211 fgetresolu(&xmax, &ymax, stdin) < 0) {
212 fprintf(stderr, "%s: bad input picture\n", progname);
213 exit(1);
214 }
215 if (scanning == 3) {
216 if (i >= argc)
217 goto userr;
218 pickchartpos(argv[i]);
219 scanning = 2;
220 }
221 } else { /* else set default xmax and ymax */
222 xmax = 512;
223 ymax = 2*512/3;
224 }
225 if (scanning != 2) { /* use default boundaries */
226 bounds[0][0] = bounds[2][0] = .029*xmax + .5;
227 bounds[0][1] = bounds[1][1] = .956*ymax + .5;
228 bounds[1][0] = bounds[3][0] = .971*xmax + .5;
229 bounds[2][1] = bounds[3][1] = .056*ymax + .5;
230 }
231 init(); /* initialize */
232 if (scanning) /* get picture colors */
233 getpicture();
234 else
235 getcolors();
236 compute(); /* compute color mapping */
237 if (rawmap) { /* print out raw correspondence */
238 int j;
239
240 printf("# Color correspondence produced by:\n#\t\t");
241 printargs(argc, argv, stdout);
242 printf("#\tUsage: pcwarp %s uncorrected.hdr > corrected.hdr\n",
243 i+1 < argc ? argv[i+1] : "{this_file}");
244 printf("#\t Or: pcond [options] -m %s orig.hdr > output.hdr\n",
245 i+1 < argc ? argv[i+1] : "{this_file}");
246 for (j = 0; j < 24; j++)
247 printf("%f %f %f %f %f %f\n",
248 colval(inpRGB[j],RED), colval(inpRGB[j],GRN),
249 colval(inpRGB[j],BLU), colval(mbRGB[j],RED),
250 colval(mbRGB[j],GRN), colval(mbRGB[j],BLU));
251 if (scanning && debugfp != NULL)
252 cwarp(); /* color warp for debugging */
253 } else { /* print color mapping */
254 /* print header */
255 printf("{\n\tColor correction file computed by:\n\t\t");
256 printargs(argc, argv, stdout);
257 printf("\n\tUsage: pcomb -f %s uncorrected.hdr > corrected.hdr\n",
258 i+1 < argc ? argv[i+1] : "{this_file}");
259 if (!scanning)
260 printf("\t Or: pcond [options] -f %s orig.hdr > output.hdr\n",
261 i+1 < argc ? argv[i+1] : "{this_file}");
262 printf("}\n");
263 putmapping(); /* put out color mapping */
264 }
265 if (debugfp != NULL) { /* put out debug picture */
266 if (scanning)
267 picdebug();
268 else
269 clrdebug();
270 }
271 exit(0);
272 userr:
273 fprintf(stderr,
274 "Usage: %s [-d dbg.hdr][-P | -p xul yul xur yur xll yll xlr ylr][-i irrad][-m] input.hdr [output.{cal|cwp}]\n",
275 progname);
276 fprintf(stderr, " or: %s [-d dbg.hdr][-i irrad][-m] -c [xyY.dat [output.{cal|cwp}]]\n",
277 progname);
278 exit(1);
279 return 1; /* pro forma return */
280 }
281
282
283 static void
284 init(void) /* initialize */
285 {
286 double quad[4][2];
287 int i;
288 /* make coordinate transformation */
289 quad[0][0] = bounds[0][0];
290 quad[0][1] = bounds[0][1];
291 quad[1][0] = bounds[1][0];
292 quad[1][1] = bounds[1][1];
293 quad[2][0] = bounds[3][0];
294 quad[2][1] = bounds[3][1];
295 quad[3][0] = bounds[2][0];
296 quad[3][1] = bounds[2][1];
297
298 if (pmap_quad_rect(0., 0., 6., 4., quad, imgxfm) == PMAP_BAD) {
299 fprintf(stderr, "%s: bad chart boundaries\n", progname);
300 exit(1);
301 }
302 /* map MacBeth colors to RGB space */
303 for (i = 0; i < 24; i++) {
304 xyY2RGB(mbRGB[i], mbxyY[i]);
305 scalecolor(mbRGB[i], irrad);
306 }
307 }
308
309
310 static int
311 chartndx( /* find color number for position */
312 int x,
313 int y,
314 int *np
315 )
316 {
317 double ipos[3], cpos[3];
318 int ix, iy;
319 double fx, fy;
320
321 ipos[0] = x;
322 ipos[1] = y;
323 ipos[2] = 1;
324 mx3d_transform(ipos, imgxfm, cpos);
325 cpos[0] /= cpos[2];
326 cpos[1] /= cpos[2];
327 if ((cpos[0] < 0.) | (cpos[0] >= 6.) | (cpos[1] < 0.) | (cpos[1] >= 4.))
328 return(RG_BORD);
329 ix = cpos[0];
330 iy = cpos[1];
331 fx = cpos[0] - ix;
332 fy = cpos[1] - iy;
333 *np = iy*6 + ix;
334 if ((fx >= 0.35) & (fx < 0.65) & (fy >= 0.35) & (fy < 0.65))
335 return(RG_CENT);
336 if ((fx < 0.05) | (fx >= 0.95) | (fy < 0.05) | (fy >= 0.95))
337 return(RG_BORD);
338 if (fx >= 0.5) /* right side is corrected */
339 return(RG_CORR);
340 return(RG_ORIG); /* left side is original */
341 }
342
343
344 static void
345 getpicture(void) /* load in picture colors */
346 {
347 COLR *scanln;
348 COLOR pval;
349 int ccount[24];
350 double d;
351 int y, i;
352 int x;
353
354 scanln = (COLR *)malloc(xmax*sizeof(COLR));
355 if (scanln == NULL) {
356 perror(progname);
357 exit(1);
358 }
359 for (i = 0; i < 24; i++) {
360 setcolor(inpRGB[i], 0., 0., 0.);
361 ccount[i] = 0;
362 }
363 for (y = ymax-1; y >= 0; y--) {
364 if (freadcolrs(scanln, xmax, stdin) < 0) {
365 fprintf(stderr, "%s: error reading input picture\n",
366 progname);
367 exit(1);
368 }
369 for (x = 0; x < xmax; x++)
370 if (chartndx(x, y, &i) == RG_CENT) {
371 colr_color(pval, scanln[x]);
372 addcolor(inpRGB[i], pval);
373 ccount[i]++;
374 }
375 }
376 for (i = 0; i < 24; i++) { /* compute averages */
377 if (ccount[i] == 0)
378 continue;
379 d = 1./ccount[i];
380 scalecolor(inpRGB[i], d);
381 inpflags |= 1L<<i;
382 }
383 free((void *)scanln);
384 }
385
386
387 static void
388 getcolors(void) /* get xyY colors from standard input */
389 {
390 int gotwhite = 0;
391 COLOR whiteclr;
392 int n;
393 float xyYin[3];
394
395 while (fgetval(stdin, 'i', &n) == 1) { /* read colors */
396 if ((n < 0) | (n > 24) ||
397 fgetval(stdin, 'f', &xyYin[0]) != 1 ||
398 fgetval(stdin, 'f', &xyYin[1]) != 1 ||
399 fgetval(stdin, 'f', &xyYin[2]) != 1 ||
400 (xyYin[0] < 0.) | (xyYin[1] < 0.) ||
401 xyYin[0] + xyYin[1] > 1.) {
402 fprintf(stderr, "%s: bad color input data\n",
403 progname);
404 exit(1);
405 }
406 if (n == 0) { /* calibration white */
407 xyY2RGB(whiteclr, xyYin);
408 gotwhite++;
409 } else { /* standard color */
410 n--;
411 xyY2RGB(inpRGB[n], xyYin);
412 inpflags |= 1L<<n;
413 }
414 }
415 /* normalize colors */
416 if (!gotwhite) {
417 if (!(inpflags & 1L<<White)) {
418 fprintf(stderr, "%s: missing input for White\n",
419 progname);
420 exit(1);
421 }
422 setcolor(whiteclr,
423 colval(inpRGB[White],RED)/colval(mbRGB[White],RED),
424 colval(inpRGB[White],GRN)/colval(mbRGB[White],GRN),
425 colval(inpRGB[White],BLU)/colval(mbRGB[White],BLU));
426 }
427 for (n = 0; n < 24; n++)
428 if (inpflags & 1L<<n)
429 setcolor(inpRGB[n],
430 colval(inpRGB[n],RED)/colval(whiteclr,RED),
431 colval(inpRGB[n],GRN)/colval(whiteclr,GRN),
432 colval(inpRGB[n],BLU)/colval(whiteclr,BLU));
433 }
434
435
436 static void
437 bresp( /* piecewise linear interpolation of primaries */
438 COLOR y, /* y is linear output */
439 COLOR x /* x is non-linear input */
440 )
441 {
442 int i, n;
443
444 for (i = 0; i < 3; i++) {
445 for (n = 0; n < NMBNEU-2; n++)
446 if (colval(x,i) < colval(bramp[n+1][0],i))
447 break;
448 colval(y,i) = ((colval(bramp[n+1][0],i) - colval(x,i)) *
449 colval(bramp[n][1],i) +
450 (colval(x,i) - colval(bramp[n][0],i)) *
451 colval(bramp[n+1][1],i)) /
452 (colval(bramp[n+1][0],i) - colval(bramp[n][0],i));
453 }
454 }
455
456
457 static void
458 ibresp( /* inverse mapping (delinearization) */
459 COLOR x, /* x is non-linear output */
460 COLOR y /* y is linear input */
461 )
462 {
463 int i, n;
464
465 for (i = 0; i < 3; i++) {
466 for (n = 0; n < NMBNEU-2; n++)
467 if (colval(y,i) < colval(bramp[n+1][1],i))
468 break;
469 colval(x,i) = ((colval(bramp[n+1][1],i) - colval(y,i)) *
470 colval(bramp[n][0],i) +
471 (colval(y,i) - colval(bramp[n][1],i)) *
472 colval(bramp[n+1][0],i)) /
473 (colval(bramp[n+1][1],i) - colval(bramp[n][1],i));
474 }
475 }
476
477
478 static void
479 compute(void) /* compute color mapping */
480 {
481 COLOR clrin[24], clrout[24];
482 long cflags;
483 COLOR ctmp;
484 int i, n;
485 /* did we get what we need? */
486 if ((inpflags & REQFLGS) != REQFLGS) {
487 fprintf(stderr, "%s: missing required input colors\n",
488 progname);
489 exit(1);
490 }
491 /* compute piecewise luminance curve */
492 for (i = 0; i < NMBNEU; i++) {
493 copycolor(bramp[i][0], inpRGB[mbneu[i]]);
494 for (n = 3*(i>0); n--; )
495 if (colval(bramp[i][0],n) <=
496 colval(bramp[i-1][0],n)+1e-7) {
497 fprintf(stderr,
498 "%s: non-increasing neutral patch\n", progname);
499 exit(1);
500 }
501 copycolor(bramp[i][1], mbRGB[mbneu[i]]);
502 }
503 /* compute color space gamut */
504 copycolor(colmin, cblack);
505 copycolor(colmax, cwhite);
506 scalecolor(colmax, irrad);
507 if (!scanning) {
508 ibresp(colmin, colmin);
509 ibresp(colmax, colmax);
510 }
511 /* compute color mapping */
512 do {
513 cflags = inpflags & ~gmtflags;
514 n = 0; /* compute transform matrix */
515 for (i = 0; i < 24; i++) {
516 if (!(cflags & 1L<<i))
517 continue;
518 if (scanning) {
519 bresp(clrin[n], inpRGB[i]);
520 copycolor(clrout[n], mbRGB[i]);
521 } else {
522 copycolor(clrin[n], inpRGB[i]);
523 ibresp(clrout[n], mbRGB[i]);
524 }
525 n++;
526 }
527 compsoln(clrin, clrout, n);
528 for (i = 0; i < 24; i++) /* check gamut */
529 if (cflags & 1L<<i && cvtcolor(ctmp, inpRGB[i]))
530 gmtflags |= 1L<<i;
531 } while (cflags & gmtflags);
532
533 if (gmtflags & MODFLGS)
534 fprintf(stderr,
535 "%s: warning - some moderate colors are out of gamut\n",
536 progname);
537 }
538
539
540 static void
541 putmapping(void) /* put out color mapping */
542 {
543 static char cchar[3] = {'r', 'g', 'b'};
544 int i, j;
545 /* print brightness mapping */
546 for (j = 0; j < 3; j++) {
547 printf("%cxa(i) : select(i", cchar[j]);
548 for (i = 0; i < NMBNEU; i++)
549 printf(",%g", colval(bramp[i][0],j));
550 printf(");\n");
551 printf("%cya(i) : select(i", cchar[j]);
552 for (i = 0; i < NMBNEU; i++)
553 printf(",%g", colval(bramp[i][1],j));
554 printf(");\n");
555 printf("%cfi(n) = if(n-%g, %d, if(%cxa(n+1)-%c, n, %cfi(n+1)));\n",
556 cchar[j], NMBNEU-1.5, NMBNEU-1, cchar[j],
557 cchar[j], cchar[j]);
558 printf("%cndx = %cfi(1);\n", cchar[j], cchar[j]);
559 printf("%c%c = ((%cxa(%cndx+1)-%c)*%cya(%cndx) + ",
560 cchar[j], scanning?'n':'o', cchar[j],
561 cchar[j], cchar[j], cchar[j], cchar[j]);
562 printf("(%c-%cxa(%cndx))*%cya(%cndx+1)) /\n",
563 cchar[j], cchar[j], cchar[j],
564 cchar[j], cchar[j]);
565 printf("\t\t(%cxa(%cndx+1) - %cxa(%cndx)) ;\n",
566 cchar[j], cchar[j], cchar[j], cchar[j]);
567 }
568 /* print color mapping */
569 if (scanning) {
570 printf("r = ri(1); g = gi(1); b = bi(1);\n");
571 printf("ro = %g*rn + %g*gn + %g*bn ;\n",
572 solmat[0][0], solmat[0][1], solmat[0][2]);
573 printf("go = %g*rn + %g*gn + %g*bn ;\n",
574 solmat[1][0], solmat[1][1], solmat[1][2]);
575 printf("bo = %g*rn + %g*gn + %g*bn ;\n",
576 solmat[2][0], solmat[2][1], solmat[2][2]);
577 } else {
578 printf("r1 = ri(1); g1 = gi(1); b1 = bi(1);\n");
579 printf("r = %g*r1 + %g*g1 + %g*b1 ;\n",
580 solmat[0][0], solmat[0][1], solmat[0][2]);
581 printf("g = %g*r1 + %g*g1 + %g*b1 ;\n",
582 solmat[1][0], solmat[1][1], solmat[1][2]);
583 printf("b = %g*r1 + %g*g1 + %g*b1 ;\n",
584 solmat[2][0], solmat[2][1], solmat[2][2]);
585 }
586 }
587
588
589 static void
590 compsoln( /* solve 3xN system using least-squares */
591 COLOR cin[],
592 COLOR cout[],
593 int n
594 )
595 {
596 extern double mx3d_adjoint(), fabs();
597 double mat[3][3], invmat[3][3];
598 double det;
599 double colv[3], rowv[3];
600 int i, j, k;
601
602 if (n < 3) {
603 fprintf(stderr, "%s: too few colors to match!\n", progname);
604 exit(1);
605 }
606 if (n == 3)
607 for (i = 0; i < 3; i++)
608 for (j = 0; j < 3; j++)
609 mat[i][j] = colval(cin[j],i);
610 else { /* compute A^t A */
611 for (i = 0; i < 3; i++)
612 for (j = i; j < 3; j++) {
613 mat[i][j] = 0.;
614 for (k = 0; k < n; k++)
615 mat[i][j] += colval(cin[k],i) *
616 colval(cin[k],j);
617 }
618 for (i = 1; i < 3; i++) /* using symmetry */
619 for (j = 0; j < i; j++)
620 mat[i][j] = mat[j][i];
621 }
622 det = mx3d_adjoint(mat, invmat);
623 if (fabs(det) < 1e-4) {
624 fprintf(stderr, "%s: cannot compute color mapping\n",
625 progname);
626 solmat[0][0] = solmat[1][1] = solmat[2][2] = 1.;
627 solmat[0][1] = solmat[0][2] = solmat[1][0] =
628 solmat[1][2] = solmat[2][0] = solmat[2][1] = 0.;
629 return;
630 }
631 for (i = 0; i < 3; i++)
632 for (j = 0; j < 3; j++)
633 invmat[i][j] /= det;
634 for (i = 0; i < 3; i++) {
635 if (n == 3)
636 for (j = 0; j < 3; j++)
637 colv[j] = colval(cout[j],i);
638 else
639 for (j = 0; j < 3; j++) {
640 colv[j] = 0.;
641 for (k = 0; k < n; k++)
642 colv[j] += colval(cout[k],i) *
643 colval(cin[k],j);
644 }
645 mx3d_transform(colv, invmat, rowv);
646 for (j = 0; j < 3; j++)
647 solmat[i][j] = rowv[j];
648 }
649 }
650
651
652 static void
653 cwarp(void) /* compute color warp map */
654 {
655 int i;
656
657 if ((wcor = new3dw(W3EXACT)) == NULL)
658 goto memerr;
659 for (i = 0; i < 24; i++)
660 if (!add3dpt(wcor, inpRGB[i], mbRGB[i]))
661 goto memerr;
662 return;
663 memerr:
664 perror(progname);
665 exit(1);
666 }
667
668
669 static int
670 cvtcolor( /* convert color according to our mapping */
671 COLOR cout,
672 COLOR cin
673 )
674 {
675 COLOR ctmp;
676 int clipped;
677
678 if (wcor != NULL) {
679 clipped = warp3d(cout, cin, wcor);
680 clipped |= clipgamut(cout,bright(cout),CGAMUT,colmin,colmax);
681 } else if (scanning) {
682 bresp(ctmp, cin);
683 clipped = cresp(cout, ctmp);
684 } else {
685 clipped = cresp(ctmp, cin);
686 bresp(cout, ctmp);
687 }
688 return(clipped);
689 }
690
691
692 static int
693 cresp( /* transform color according to matrix */
694 COLOR cout,
695 COLOR cin
696 )
697 {
698 colortrans(cout, solmat, cin);
699 return(clipgamut(cout, bright(cout), CGAMUT, colmin, colmax));
700 }
701
702
703 static void
704 xyY2RGB( /* convert xyY to RGB */
705 COLOR rgbout,
706 float xyYin[3]
707 )
708 {
709 COLOR ctmp;
710 double d;
711
712 d = xyYin[2] / xyYin[1];
713 ctmp[0] = xyYin[0] * d;
714 ctmp[1] = xyYin[2];
715 ctmp[2] = (1. - xyYin[0] - xyYin[1]) * d;
716 /* allow negative values */
717 colortrans(rgbout, xyz2rgbmat, ctmp);
718 }
719
720
721 static void
722 picdebug(void) /* put out debugging picture */
723 {
724 static COLOR blkcol = BLKCOLOR;
725 COLOR *scan;
726 int y, i;
727 int x, rg;
728
729 if (fseek(stdin, 0L, 0) == EOF) {
730 fprintf(stderr, "%s: cannot seek on input picture\n", progname);
731 exit(1);
732 }
733 getheader(stdin, NULL, NULL); /* skip input header */
734 fgetresolu(&xmax, &ymax, stdin);
735 /* allocate scanline */
736 scan = (COLOR *)malloc(xmax*sizeof(COLOR));
737 if (scan == NULL) {
738 perror(progname);
739 exit(1);
740 }
741 /* finish debug header */
742 fputformat(COLRFMT, debugfp);
743 putc('\n', debugfp);
744 fprtresolu(xmax, ymax, debugfp);
745 /* write debug picture */
746 for (y = ymax-1; y >= 0; y--) {
747 if (freadscan(scan, xmax, stdin) < 0) {
748 fprintf(stderr, "%s: error rereading input picture\n",
749 progname);
750 exit(1);
751 }
752 for (x = 0; x < xmax; x++) {
753 rg = chartndx(x, y, &i);
754 if (rg == RG_CENT) {
755 if (!(1L<<i & gmtflags) || (x+y)&07) {
756 copycolor(scan[x], mbRGB[i]);
757 clipgamut(scan[x], bright(scan[x]),
758 CGAMUT, colmin, colmax);
759 } else
760 copycolor(scan[x], blkcol);
761 } else if (rg == RG_CORR)
762 cvtcolor(scan[x], scan[x]);
763 else if (rg != RG_ORIG)
764 copycolor(scan[x], blkcol);
765 }
766 if (fwritescan(scan, xmax, debugfp) < 0) {
767 fprintf(stderr, "%s: error writing debugging picture\n",
768 progname);
769 exit(1);
770 }
771 }
772 /* clean up */
773 fclose(debugfp);
774 free((void *)scan);
775 }
776
777
778 static void
779 clrdebug(void) /* put out debug picture from color input */
780 {
781 static COLR blkclr = BLKCOLR;
782 COLR mbclr[24], cvclr[24], orclr[24];
783 COLR *scan;
784 COLOR ctmp, ct2;
785 int y, i;
786 int x, rg;
787 /* convert colors */
788 for (i = 0; i < 24; i++) {
789 copycolor(ctmp, mbRGB[i]);
790 clipgamut(ctmp, bright(ctmp), CGAMUT, cblack, cwhite);
791 setcolr(mbclr[i], colval(ctmp,RED),
792 colval(ctmp,GRN), colval(ctmp,BLU));
793 if (inpflags & 1L<<i) {
794 copycolor(ctmp, inpRGB[i]);
795 clipgamut(ctmp, bright(ctmp), CGAMUT, cblack, cwhite);
796 setcolr(orclr[i], colval(ctmp,RED),
797 colval(ctmp,GRN), colval(ctmp,BLU));
798 if (rawmap)
799 copycolr(cvclr[i], mbclr[i]);
800 else {
801 bresp(ctmp, inpRGB[i]);
802 colortrans(ct2, solmat, ctmp);
803 clipgamut(ct2, bright(ct2), CGAMUT,
804 cblack, cwhite);
805 setcolr(cvclr[i], colval(ct2,RED),
806 colval(ct2,GRN),
807 colval(ct2,BLU));
808 }
809 }
810 }
811 /* allocate scanline */
812 scan = (COLR *)malloc(xmax*sizeof(COLR));
813 if (scan == NULL) {
814 perror(progname);
815 exit(1);
816 }
817 /* finish debug header */
818 fputformat(COLRFMT, debugfp);
819 putc('\n', debugfp);
820 fprtresolu(xmax, ymax, debugfp);
821 /* write debug picture */
822 for (y = ymax-1; y >= 0; y--) {
823 for (x = 0; x < xmax; x++) {
824 rg = chartndx(x, y, &i);
825 if (rg == RG_CENT) {
826 if (!(1L<<i & gmtflags) || (x+y)&07)
827 copycolr(scan[x], mbclr[i]);
828 else
829 copycolr(scan[x], blkclr);
830 } else if (rg == RG_BORD || !(1L<<i & inpflags))
831 copycolr(scan[x], blkclr);
832 else if (rg == RG_ORIG)
833 copycolr(scan[x], orclr[i]);
834 else /* rg == RG_CORR */
835 copycolr(scan[x], cvclr[i]);
836 }
837 if (fwritecolrs(scan, xmax, debugfp) < 0) {
838 fprintf(stderr, "%s: error writing debugging picture\n",
839 progname);
840 exit(1);
841 }
842 }
843 /* clean up */
844 fclose(debugfp);
845 free((void *)scan);
846 }
847
848
849 static void
850 getpos( /* get boundary position */
851 char *name,
852 int bnds[2],
853 FILE *fp
854 )
855 {
856 char buf[64];
857
858 fprintf(stderr, "\tSelect corner: %s\n", name);
859 if (fgets(buf, sizeof(buf), fp) == NULL ||
860 sscanf(buf, "%d %d", &bnds[0], &bnds[1]) != 2) {
861 fprintf(stderr, "%s: read error from display process\n",
862 progname);
863 exit(1);
864 }
865 }
866
867
868 static void
869 pickchartpos( /* display picture and pick chart location */
870 char *pfn
871 )
872 {
873 char combuf[PATH_MAX];
874 FILE *pfp;
875
876 sprintf(combuf, DISPCOM, pfn);
877 if ((pfp = popen(combuf, "r")) == NULL) {
878 perror(combuf);
879 exit(1);
880 }
881 fputs("Use middle mouse button to select chart corners:\n", stderr);
882 getpos("upper left (dark skin)", bounds[0], pfp);
883 getpos("upper right (bluish green)", bounds[1], pfp);
884 getpos("lower left (white)", bounds[2], pfp);
885 getpos("lower right (black)", bounds[3], pfp);
886 fputs("Got it -- quit display program.\n", stderr);
887 pclose(pfp);
888 }
