root/radiance/ray/src/px/falsecolor.pl
Revision: 2.4
Committed: Wed Mar 23 21:57:11 2011 UTC (13 years, 2 months ago) by greg
Changes since 2.3: +13 -10 lines
Fixed problems with legend text placement
1 #!/usr/bin/perl -w
2 # RCSid $Id: falsecolor.pl,v 2.3 2011/03/23 19:33:29 greg Exp $
3
4 use strict;
5 use File::Temp qw/ tempdir /;
6 use POSIX qw/ floor /;
7
8 my $mult = 179.0; # Multiplier. Default W/sr/m2 -> cd/m2
9 my $label = 'cd/m2'; # Units shown in legend
10 my $scale = 1000; # Top of the scale
11 my $decades = 0; # Default is linear mapping
12 my $redv = 'def_red(v)'; # Mapping function for R,G,B
13 my $grnv = 'def_grn(v)';
14 my $bluv = 'def_blu(v)';
15 my $ndivs = 8; # Number of lines in legend
16 my $picture = '-';
17 my $cpict = '';
18 my $legwidth = 100; # Legend width and height
19 my $legheight = 200;
20 my $docont = ''; # Contours
21 my $loff = 0; # Offset to align with values
22 my $doextrem = 0; # Don't mark extrema
23 my $needfile = 0;
24
25 while ($#ARGV >= 0) {
26 # Options with qualifiers
27 if ("$ARGV[0]" eq '-lw') { # Legend width
28 $legwidth = $ARGV[1];
29 shift @ARGV;
30 } elsif ("$ARGV[0]" eq '-lh') { # Legend height
31 $legheight = $ARGV[1];
32 shift @ARGV;
33 } elsif ("$ARGV[0]" eq '-m') { # Multiplier
34 $mult = $ARGV[1];
35 shift @ARGV;
36 } elsif ("$ARGV[0]" eq '-s') { # Scale
37 $scale = $ARGV[1];
38 shift @ARGV;
39 if ($scale =~ m/[aA].*/) {
40 $needfile = 1;
41 }
42 } elsif ("$ARGV[0]" eq '-l') { # Label
43 $label = $ARGV[1];
44 shift @ARGV;
45 } elsif ("$ARGV[0]" eq '-log') { # Logarithmic mapping
46 $decades = $ARGV[1];
47 shift @ARGV;
48 } elsif ("$ARGV[0]" eq '-r') {
49 $redv = $ARGV[1];
50 shift @ARGV;
51 } elsif ("$ARGV[0]" eq '-g') {
52 $grnv = $ARGV[1];
53 shift @ARGV;
54 } elsif ("$ARGV[0]" eq '-b') {
55 $bluv = $ARGV[1];
56 shift @ARGV;
57 } elsif ("$ARGV[0]" eq '-pal') {
58 $redv = "$ARGV[1]_red(v)";
59 $grnv = "$ARGV[1]_grn(v)";
60 $bluv = "$ARGV[1]_blu(v)";
61 shift @ARGV;
62 } elsif ("$ARGV[0]" eq '-i') { # Image for intensity mapping
63 $picture = $ARGV[1];
64 shift @ARGV;
65 } elsif ("$ARGV[0]" eq '-p') { # Image for background
66 $cpict = $ARGV[1];
67 shift @ARGV;
68 } elsif ("$ARGV[0]" eq '-ip' || "$ARGV[0]" eq '-pi') {
69 $picture = $ARGV[1];
70 $cpict = $ARGV[1];
71 shift @ARGV;
72 } elsif ("$ARGV[0]" eq '-n') { # Number of contour lines
73 $ndivs = $ARGV[1];
74 shift @ARGV;
75
76 # Switches
77 } elsif ("$ARGV[0]" eq '-cl') { # Contour lines
78 $docont = 'a';
79 $loff = 0.48;
80 } elsif ("$ARGV[0]" eq '-cb') { # Contour bands
81 $docont = 'b';
82 $loff = 0.52;
83 } elsif ("$ARGV[0]" eq '-e') {
84 $doextrem = 1;
85 $needfile = 1;
86
87 # Oops! Illegal option
88 } else {
89 die("bad option \"$ARGV[0]\"\n");
90 }
91 shift @ARGV;
92 }
93
94 # Temporary directory. Will be removed upon successful program exit.
95 my $td = tempdir( CLEANUP => 1 );
96
97 if ($needfile == 1 && $picture eq '-') {
98 # Pretend that $td/stdin.rad is the actual filename.
99 $picture = "$td/stdin.hdr";
100 open(FHpic, ">$picture") or
101 die("Unable to write to file $picture\n");
102 # Input is from STDIN: Capture to file.
103 while (<>) {
104 print FHpic;
105 }
106 close(FHpic);
107
108 if ($cpict eq '-') {
109 $cpict = "$td/stdin.hdr";
110 }
111 }
112
113 # Find a good scale for auto mode.
114 if ($scale =~ m/[aA].*/) {
115 my @histo = split(/\s/, `phisto $picture| tail -2`);
116 # e.g. $ phisto tests/richmond.hdr| tail -2
117 # 3.91267 14
118 # 3.94282 6
119 my $LogLmax = $histo[0];
120 $scale = $mult / 179 * 10**$LogLmax;
121 }
122
123 my $pc0 = "$td/pc0.cal";
124 open(FHpc0, ">$pc0");
125 print FHpc0 <<EndOfPC0;
126 PI : 3.14159265358979323846 ;
127 scale : $scale ;
128 mult : $mult ;
129 ndivs : $ndivs ;
130 gamma : 2.2;
131
132 or(a,b) : if(a,a,b);
133 EPS : 1e-7;
134 neq(a,b) : if(a-b-EPS,1,b-a-EPS);
135 btwn(a,x,b) : if(a-x,-1,b-x);
136 clip(x) : if(x-1,1,if(x,x,0));
137 frac(x) : x - floor(x);
138 boundary(a,b) : neq(floor(ndivs*a+.5),floor(ndivs*b+.5));
139
140 spec_red(x) = 1.6*x - .6;
141 spec_grn(x) = if(x-.375, 1.6-1.6*x, 8/3*x);
142 spec_blu(x) = 1 - 8/3*x;
143
144 pm3d_red(x) = sqrt(x) ^ gamma;
145 pm3d_grn(x) = x*x*x ^ gamma;
146 pm3d_blu(x) = clip(sin(2*PI*x)) ^ gamma;
147
148 hot_red(x) = clip(3*x) ^ gamma;
149 hot_grn(x) = clip(3*x - 1) ^ gamma;
150 hot_blu(x) = clip(3*x - 2) ^ gamma;
151
152 interp_arr2(i,x,f):(i+1-x)*f(i)+(x-i)*f(i+1);
153 interp_arr(x,f):if(x-1,if(f(0)-x,interp_arr2(floor(x),x,f),f(f(0))),f(1));
154
155 def_redp(i):select(i,0.18848,0.05468174,
156 0.00103547,8.311144e-08,7.449763e-06,0.0004390987,0.001367254,
157 0.003076,0.01376382,0.06170773,0.1739422,0.2881156,0.3299725,
158 0.3552663,0.372552,0.3921184,0.4363976,0.6102754,0.7757267,
159 0.9087369,1,1,0.9863);
160 def_red(x):interp_arr(x/0.0454545+1,def_redp);
161
162 def_grnp(i):select(i,0.0009766,2.35501e-05,
163 0.0008966244,0.0264977,0.1256843,0.2865799,0.4247083,0.4739468,
164 0.4402732,0.3671876,0.2629843,0.1725325,0.1206819,0.07316644,
165 0.03761026,0.01612362,0.004773749,6.830967e-06,0.00803605,
166 0.1008085,0.3106831,0.6447838,0.9707);
167 def_grn(x):interp_arr(x/0.0454545+1,def_grnp);
168
169 def_blup(i):select(i,0.2666,0.3638662,0.4770437,
170 0.5131397,0.5363797,0.5193677,0.4085123,0.1702815,0.05314236,
171 0.05194055,0.08564082,0.09881395,0.08324373,0.06072902,
172 0.0391076,0.02315354,0.01284458,0.005184709,0.001691774,
173 2.432735e-05,1.212949e-05,0.006659406,0.02539);
174 def_blu(x):interp_arr(x/0.0454545+1,def_blup);
175
176 isconta = if(btwn(0,v,1),or(boundary(vleft,vright),boundary(vabove,vbelow)),-1);
177 iscontb = if(btwn(0,v,1),btwn(.4,frac(ndivs*v),.6),-1);
178
179 ra = 0;
180 ga = 0;
181 ba = 0;
182
183 in = 1;
184
185 ro = if(in,clip($redv),ra);
186 go = if(in,clip($grnv),ga);
187 bo = if(in,clip($bluv),ba);
188 EndOfPC0
189
190 my $pc1 = "$td/pc1.cal";
191 open(FHpc1, ">$pc1");
192 print FHpc1 <<EndOfPC1;
193 norm : mult/scale/le(1);
194
195 v = map(li(1)*norm);
196
197 vleft = map(li(1,-1,0)*norm);
198 vright = map(li(1,1,0)*norm);
199 vabove = map(li(1,0,1)*norm);
200 vbelow = map(li(1,0,-1)*norm);
201
202 map(x) = x;
203
204 ra = ri(nfiles);
205 ga = gi(nfiles);
206 ba = bi(nfiles);
207 EndOfPC1
208
209 my $pc0args = "-f $pc0";
210 my $pc1args = "-f $pc1";
211
212 # Contour lines or bands
213 if ($docont ne '') {
214 $pc0args .= " -e 'in=iscont$docont'";
215 }
216
217 if ($cpict eq '') {
218 $pc1args .= " -e 'ra=0;ga=0;ba=0'";
219 } elsif ($cpict eq $picture) {
220 $cpict = '';
221 }
222
223 # Logarithmic mapping
224 if ($decades > 0) {
225 $pc1args .= " -e 'map(x)=if(x-10^-$decades,log10(x)/$decades+1,0)'";
226 }
227
228 # Colours in the legend
229 my $scolpic = "$td/scol.hdr";
230 # Labels in the legend
231 my $slabpic = "$td/slab.hdr";
232 my $cmd;
233
234 if (($legwidth > 20) && ($legheight > 40)) {
235 # Legend: Create the text labels
236 my $sheight = floor($legheight / $ndivs + 0.5);
237 $legheight = $sheight * $ndivs;
238 $loff = floor($loff * $sheight + 0.5);
239 my $text = "$label";
240 for (my $i=0; $i<$ndivs; $i++) {
241 my $imap = ($ndivs - 0.5 - $i) / $ndivs;
242 my $value = $scale;
243 if ($decades > 0) {
244 $value *= 10**(($imap - 1) * $decades);
245 } else {
246 $value *= $imap;
247 }
248 # Have no more than 3 decimal places
249 $value =~ s/(\.[0-9]{3})[0-9]*/$1/;
250 $text .= "\n$value";
251 }
252 $cmd = "echo '$text' | psign -s -.15 -cf 1 1 1 -cb 0 0 0";
253 $cmd .= " -h $sheight > $slabpic";
254 system $cmd;
255
256 # Legend: Create the background colours
257 $cmd = "pcomb $pc0args -e 'v=(y+.5)/yres;vleft=v;vright=v'";
258 $cmd .= " -e 'vbelow=(y-.5)/yres;vabove=(y+1.5)/yres'";
259 $cmd .= " -x $legwidth -y $legheight > $scolpic";
260 system $cmd;
261 } else {
262 # Legend is too small to be legible. Don't bother doing one.
263 $legwidth = 0;
264 $legheight = 0;
265 $loff = 0;
266 # Create dummy colour scale and legend labels so we don't
267 # need to change the final command line.
268 open(FHscolpic, ">$scolpic");
269 print FHscolpic "\n-Y 1 +X 1\naaa\n";
270 close(FHscolpic);
271 open(FHslabpic, ">$slabpic");
272 print FHslabpic "\n-Y 1 +X 1\naaa\n";
273 close(FHslabpic);
274 }
275
276 # Legend: Invert the text labels (for dropshadow)
277 my $slabinvpic = "$td/slabinv.hdr";
278 $cmd = "pcomb -e 'lo=1-gi(1)' $slabpic > $slabinvpic";
279 system $cmd;
280
281 my $loff1 = $loff - 1;
282 # Command line without extrema
283 $cmd = "pcomb $pc0args $pc1args $picture $cpict";
284 $cmd .= "| pcompos $scolpic 0 0 +t .1 $slabinvpic 2 $loff1";
285 $cmd .= " -t .5 $slabpic 0 $loff - $legwidth 0";
286
287 if ($doextrem == 1) {
288 # Get min/max image luminance
289 my $cmd1 = 'pextrem -o ' . $picture;
290 my $retval = `$cmd1`;
291 # e.g.
292 # x y r g b
293 # 193 207 3.070068e-02 3.118896e-02 1.995850e-02
294 # 211 202 1.292969e+00 1.308594e+00 1.300781e+00
295
296 my @extrema = split(/\s/, $retval);
297 my ($lxmin, $ymin, $rmin, $gmin, $bmin, $lxmax, $ymax, $rmax, $gmax, $bmax) = @extrema;
298 $lxmin += $legwidth;
299 $lxmax += $legwidth;
300
301 # Weighted average of R,G,B
302 my $minpos = "$lxmin $ymin";
303 my $minval = ($rmin * .27 + $gmin * .67 + $bmin * .06) * $mult;
304 $minval =~ s/(\.[0-9]{3})[0-9]*/$1/;
305 my $maxpos = "$lxmax $ymax";
306 my $maxval = ($rmax * .27 + $gmax * .67 + $bmax * .06) * $mult;
307 $maxval =~ s/(\.[0-9]{3})[0-9]*/$1/;
308
309 # Create the labels for min/max intensity
310 my $minvpic = "$td/minv.hdr";
311 $cmd1 = "psign -s -.15 -a 2 -h 16 $minval > $minvpic";
312 system $cmd1;
313 my $maxvpic = "$td/maxv.hdr";
314 $cmd1 = "psign -s -.15 -a 2 -h 16 $maxval > $maxvpic";
315 system $cmd1;
316
317 # Add extrema labels to command line
318 $cmd .= " $minvpic $minpos $maxvpic $maxpos";
319 }
320
321 # Process image and combine with legend
322 system "$cmd";
323
324 #EOF
