root/radiance/ray/src/px/falsecolor.pl
Revision: 2.23
Committed: Mon Nov 21 20:21:36 2022 UTC (18 months, 1 week ago) by greg
Changes since 2.22: +10 -11 lines
fix(falsecolor): Eliminated fractional pixel offsets to pcompos, etc.
1 #!/usr/bin/perl -w
2 # RCSid $Id: falsecolor.pl,v 2.22 2022/11/14 18:45:38 greg Exp $
3
4 use warnings;
5 use strict;
6 use File::Temp qw/ tempdir /;
7
8 my @palettes = ('def', 'spec', 'pm3d', 'hot', 'eco', 'tbo');
9
10 my $mult = 179.0; # Multiplier. Default W/sr/m2 -> cd/m2
11 my $label = 'cd/m2'; # Units shown in legend
12 my $scale = 1000; # Top of the scale
13 my $scaledigits = 3; # Number of maximum digits for numbers in legend
14 my $decades = 0; # Default is linear mapping
15 my $pal = 'def'; # Palette
16 my $redv = "${pal}_red(v)"; # Mapping functions for R,G,B
17 my $grnv = "${pal}_grn(v)";
18 my $bluv = "${pal}_blu(v)";
19 my $ndivs = 8; # Number of lines in legend
20 my $picture = '-';
21 my $cpict = '';
22 my $legwidth = 100; # Legend width and height
23 my $legheight = 200;
24 my @overlayWH = (0,0); # Overlay matrix width and height (default = none)
25 my @overlayRect; # Overlay rectangle (left, lower, right, upper)
26 my $haszero = 1; # print 0 in scale for falsecolor images only
27 my $docont = ''; # Contours: -cl, -cb, and -c0
28 my $doposter = 0; # Posterization: -cp
29 my $doextrem = 0; # Don't mark extrema
30 my $needfile = 0;
31 my $showpal = 0; # Show available colour palettes
32
33 my @savedARGV = @ARGV; # Save for final header
34
35 while ($#ARGV >= 0) {
36 $_ = shift;
37 # Options with qualifiers
38 if (m/-lw/) { # Legend width
39 $legwidth = shift;
40 } elsif (m/-lh/) { # Legend height
41 $legheight = shift;
42 } elsif (m/-m/) { # Multiplier
43 $mult = shift;
44 } elsif (m/-spec/) {
45 die("depricated option '-spec'. Please use '-pal spec' instead.\n");
46 } elsif (m/-s/) { # Scale
47 $scale = shift;
48 if ($scale =~ m/[aA].*/) {
49 $needfile = 1;
50 }
51 } elsif (m/-d/) { # Number of maximum digits for numbers in legend
52 $scaledigits = shift;
53 } elsif (m/-l$/) { # Label
54 $label = shift;
55 } elsif (m/-log/) { # Logarithmic mapping
56 $decades = shift;
57 } elsif (m/-r/) { # Custom palette functions for R,G,B
58 $redv = shift;
59 } elsif (m/-g/) {
60 $grnv = shift;
61 } elsif (m/-b/) {
62 $bluv = shift;
63 } elsif (m/-pal$/) { # Color palette
64 $pal = shift;
65 if (! grep $_ eq $pal, @palettes) {
66 die("invalid palette '$pal'.\n");
67 }
68 $redv = "${pal}_red(v)";
69 $grnv = "${pal}_grn(v)";
70 $bluv = "${pal}_blu(v)";
71 } elsif (m/-i$/) { # Image for intensity mapping
72 $picture = shift;
73 } elsif (m/-p$/) { # Image for background
74 $cpict = shift;
75 } elsif (m/-ip/ || m/-pi/) {
76 $picture = shift;
77 $cpict = $picture;
78 } elsif (m/-n/) { # Number of contour lines
79 $ndivs = shift;
80 } elsif (m/-odim$/) { # Overlay width and height
81 $overlayWH[0] = shift;
82 $overlayWH[1] = shift;
83 $needfile ||= $overlayWH[0] && $overlayWH[1];
84 } elsif (m/-orct/) { # Overlay rectangle
85 $overlayRect[0] = shift;
86 $overlayRect[1] = shift;
87 $overlayRect[2] = shift;
88 $overlayRect[3] = shift;
89
90 # Switches
91 } elsif (m/-cl/) { # Contour lines
92 $docont = 'a';
93 $haszero = 0;
94 } elsif (m/-cb/) { # Contour bands
95 $docont = 'b';
96 $haszero = 0;
97 } elsif (m/-cp/) { # Posterize
98 $doposter = 1;
99 $haszero = 0;
100 } elsif (m/-c0/) { # Turn off falsecolor operation
101 $docont = '0';
102 $legwidth = 0;
103 $legheight = 0;
104 } elsif (m/-palettes/) { # Show all available palettes
105 $scale = 45824; # 256 * 179
106 $showpal = 1;
107 } elsif (m/-e/) {
108 $doextrem = 1;
109 $needfile = 1;
110 # Oops! Illegal option
111 } else {
112 die("bad option \"$_\"\n");
113 }
114 }
115
116 if (($legwidth <= 20) || ($legheight <= 40)) {
117 # Legend is too small to be legible. Don't bother doing one.
118 $legwidth = 0;
119 $legheight = 0;
120 }
121
122 # Temporary directory. Will be removed upon successful program exit.
123 my $td = tempdir( CLEANUP => 1 );
124
125 if ($needfile && $picture eq '-') {
126 # Pretend that $td/stdin.rad is the actual filename.
127 $picture = "$td/stdin.hdr";
128 open(FHpic, ">$picture") or
129 die("Unable to write to file $picture\n");
130 # Input is from STDIN: Capture to file.
131 while (<>) {
132 print FHpic;
133 }
134 close(FHpic);
135
136 if ($cpict eq '-') {
137 $cpict = $picture;
138 }
139 }
140
141 # Find a good scale for auto mode.
142 if ($scale =~ m/[aA].*/) {
143 my @histo = split(/\s/, `phisto $picture`);
144 # e.g. $ phisto tests/richmond.hdr| tail -2
145 # 3.91267 14
146 # 3.94282 6
147 my $LogLmax = $histo[-4];
148 $scale = $mult / 179 * 10**$LogLmax;
149 }
150
151 if ($doposter) {
152 # -cp -> $doposter = 1
153 my $newv = join( "seg2(v)", split("v", $redv) );
154 $redv = $newv;
155 $newv = join( "seg2(v)", split("v", $bluv) );
156 $bluv = $newv;
157 $newv = join( "seg2(v)", split("v", $grnv) );
158 $grnv = $newv;
159 } elsif ($docont) {
160 # -cl -> $docont = a
161 # -cb -> $docont = b
162 my $newv = join( "(v-1/ndivs)*ndivs/(ndivs-1)", split("v", $redv) );
163 $redv = $newv;
164 $newv = join( "(v-1/ndivs)*ndivs/(ndivs-1)", split("v", $bluv) );
165 $bluv = $newv;
166 $newv = join( "(v-1/ndivs)*ndivs/(ndivs-1)", split("v", $grnv) );
167 $grnv = $newv;
168 }
169
170 my $pc0 = "$td/pc0.cal";
171 open(FHpc0, ">$pc0");
172 print FHpc0 <<EndOfPC0;
173 PI : 3.14159265358979323846 ;
174 scale : $scale ;
175 mult : $mult ;
176 ndivs : $ndivs ;
177 gamma : 2.2;
178
179 or(a,b) : if(a,a,b);
180 EPS : 1e-7;
181 neq(a,b) : if(a-b-EPS,1,b-a-EPS);
182 btwn(a,x,b) : if(a-x,-1,b-x);
183 clip(x) : min(1,max(x,0));
184 frac(x) : x - floor(x);
185 boundary(a,b) : neq(floor(ndivs*a),floor(ndivs*b));
186 round(x) : floor(x+.5);
187
188 spec_red(x) = 1.6*x - .6;
189 spec_grn(x) = if(x-.375, 1.6-1.6*x, 8/3*x);
190 spec_blu(x) = 1 - 8/3*x;
191
192 pm3d_red(x) = sqrt(clip(x)) ^ gamma;
193 pm3d_grn(x) = clip(x*x*x) ^ gamma;
194 pm3d_blu(x) = clip(sin(2*PI*clip(x))) ^ gamma;
195
196 hot_red(x) = clip(3*x) ^ gamma;
197 hot_grn(x) = clip(3*x - 1) ^ gamma;
198 hot_blu(x) = clip(3*x - 2) ^ gamma;
199
200 eco_red(x) = clip(2*x) ^ gamma;
201 eco_grn(x) = clip(2*(x-0.5)) ^ gamma;
202 eco_blu(x) = clip(2*(0.5-x)) ^ gamma;
203
204 interp_arr2(i,x,f):(i+1-x)*f(i)+(x-i)*f(i+1);
205 interp_arr(x,f):if(x-1,if(f(0)-x,interp_arr2(floor(x),x,f),f(f(0))),f(1));
206
207 interp_tbo2(x,f):f(round(x*255)+1)+(f(min(255,round(x*255)+1)+1)-f(round(x*255)+1))*(x*255-round(x*255));
208 interp_tbo(x,f):if(x-1,f(256),if(x,interp_tbo2(x,f),f(1)));
209
210 def_redp(i):select(i,0.18848,0.05468174,
211 0.00103547,8.311144e-08,7.449763e-06,0.0004390987,0.001367254,
212 0.003076,0.01376382,0.06170773,0.1739422,0.2881156,0.3299725,
213 0.3552663,0.372552,0.3921184,0.4363976,0.6102754,0.7757267,
214 0.9087369,1,1,0.9863);
215 def_red(x):interp_arr(x/0.0454545+1,def_redp);
216
217 def_grnp(i):select(i,0.0009766,2.35501e-05,
218 0.0008966244,0.0264977,0.1256843,0.2865799,0.4247083,0.4739468,
219 0.4402732,0.3671876,0.2629843,0.1725325,0.1206819,0.07316644,
220 0.03761026,0.01612362,0.004773749,6.830967e-06,0.00803605,
221 0.1008085,0.3106831,0.6447838,0.9707);
222 def_grn(x):interp_arr(x/0.0454545+1,def_grnp);
223
224 def_blup(i):select(i,0.2666,0.3638662,0.4770437,
225 0.5131397,0.5363797,0.5193677,0.4085123,0.1702815,0.05314236,
226 0.05194055,0.08564082,0.09881395,0.08324373,0.06072902,
227 0.0391076,0.02315354,0.01284458,0.005184709,0.001691774,
228 2.432735e-05,1.212949e-05,0.006659406,0.02539);
229 def_blu(x):interp_arr(x/0.0454545+1,def_blup);
230
231 tbo_redp(i):select(i,0.18995,0.19483,0.19956,0.20415,0.2086,0.21291,0.21708,0.22111,0.225,0.22875,0.23236,0.23582,0.23915,0.24234,0.24539,0.2483,0.25107,0.25369,0.25618,0.25853,0.26074,0.2628,0.26473,0.26652,0.26816,0.26967,0.27103,0.27226,0.27334,0.27429,0.27509,0.27576,0.27628,0.27667,0.27691,0.27701,0.27698,0.2768,0.27648,0.27603,0.27543,0.27469,0.27381,0.27273,0.27106,0.26878,0.26592,0.26252,0.25862,0.25425,0.24946,0.24427,0.23874,0.23288,0.22676,0.22039,0.21382,0.20708,0.20021,0.19326,0.18625,0.17923,0.17223,0.16529,0.15844,0.15173,0.14519,0.13886,0.13278,0.12698,0.12151,0.11639,0.11167,0.10738,0.10357,0.10026,0.0975,0.09532,0.09377,0.09287,0.09267,0.0932,0.09451,0.09662,0.09958,0.10342,0.10815,0.11374,0.12014,0.12733,0.13526,0.14391,0.15323,0.16319,0.17377,0.18491,0.19659,0.20877,0.22142,0.23449,0.24797,0.2618,0.27597,0.29042,0.30513,0.32006,0.33517,0.35043,0.36581,0.38127,0.39678,0.41229,0.42778,0.44321,0.45854,0.47375,0.48879,0.50362,0.51822,0.53255,0.54658,0.56026,0.57357,0.58646,0.59891,0.61088,0.62233,0.63323,0.64362,0.65394,0.66428,0.67462,0.68494,0.69525,0.70553,0.71577,0.72596,0.7361,0.74617,0.75617,0.76608,0.77591,0.78563,0.79524,0.80473,0.8141,0.82333,0.83241,0.84133,0.8501,0.85868,0.86709,0.8753,0.88331,0.89112,0.8987,0.90605,0.91317,0.92004,0.92666,0.93301,0.93909,0.94489,0.95039,0.9556,0.96049,0.96507,0.96931,0.97323,0.97679,0.98,0.98289,0.98549,0.98781,0.98986,0.99163,0.99314,0.99438,0.99535,0.99607,0.99654,0.99675,0.99672,0.99644,0.99593,0.99517,0.99419,0.99297,0.99153,0.98987,0.98799,0.9859,0.9836,0.98108,0.97837,0.97545,0.97234,0.96904,0.96555,0.96187,0.95801,0.95398,0.94977,0.94538,0.94084,0.93612,0.93125,0.92623,0.92105,0.91572,0.91024,0.90463,0.89888,0.89298,0.88691,0.88066,0.87422,0.8676,0.86079,0.8538,0.84662,0.83926,0.83172,0.82399,0.81608,0.80799,0.79971,0.79125,0.7826,0.77377,0.76476,0.75556,0.74617,0.73661,0.72686,0.71692,0.7068,0.6965,0.68602,0.67535,0.66449,0.65345,0.64223,0.63082,0.61923,0.60746,0.5955,0.58336,0.57103,0.55852,0.54583,0.53295,0.51989,0.50664,0.49321,0.4796);
232 tbo_red(x):interp_tbo(x,tbo_redp) ^ gamma;
233
234 tbo_grnp(i):select(i,0.07176,0.08339,0.09498,0.10652,0.11802,0.12947,0.14087,0.15223,0.16354,0.17481,0.18603,0.1972,0.20833,0.21941,0.23044,0.24143,0.25237,0.26327,0.27412,0.28492,0.29568,0.30639,0.31706,0.32768,0.33825,0.34878,0.35926,0.3697,0.38008,0.39043,0.40072,0.41097,0.42118,0.43134,0.44145,0.45152,0.46153,0.47151,0.48144,0.49132,0.50115,0.51094,0.52069,0.5304,0.54015,0.54995,0.55979,0.56967,0.57958,0.5895,0.59943,0.60937,0.61931,0.62923,0.63913,0.64901,0.65886,0.66866,0.67842,0.68812,0.69775,0.70732,0.7168,0.7262,0.73551,0.74472,0.75381,0.76279,0.77165,0.78037,0.78896,0.7974,0.80569,0.81381,0.82177,0.82955,0.83714,0.84455,0.85175,0.85875,0.86554,0.87211,0.87844,0.88454,0.8904,0.896,0.90142,0.90673,0.91193,0.91701,0.92197,0.9268,0.93151,0.93609,0.94053,0.94484,0.94901,0.95304,0.95692,0.96065,0.96423,0.96765,0.97092,0.97403,0.97697,0.97974,0.98234,0.98477,0.98702,0.98909,0.99098,0.99268,0.99419,0.99551,0.99663,0.99755,0.99828,0.99879,0.9991,0.99919,0.99907,0.99873,0.99817,0.99739,0.99638,0.99514,0.99366,0.99195,0.98999,0.98775,0.98524,0.98246,0.97941,0.9761,0.97255,0.96875,0.9647,0.96043,0.95593,0.95121,0.94627,0.94113,0.93579,0.93025,0.92452,0.91861,0.91253,0.90627,0.89986,0.89328,0.88655,0.87968,0.87267,0.86553,0.85826,0.85087,0.84337,0.83576,0.82806,0.82025,0.81236,0.80439,0.79634,0.78823,0.78005,0.77181,0.76352,0.75519,0.74682,0.73842,0.73,0.7214,0.7125,0.7033,0.69382,0.68408,0.67408,0.66386,0.65341,0.64277,0.63193,0.62093,0.60977,0.59846,0.58703,0.57549,0.56386,0.55214,0.54036,0.52854,0.51667,0.50479,0.49291,0.48104,0.4692,0.4574,0.44565,0.43399,0.42241,0.41093,0.39958,0.38836,0.37729,0.36638,0.35566,0.34513,0.33482,0.32473,0.31489,0.3053,0.29599,0.28696,0.27824,0.26981,0.26152,0.25334,0.24526,0.2373,0.22945,0.2217,0.21407,0.20654,0.19912,0.19182,0.18462,0.17753,0.17055,0.16368,0.15693,0.15028,0.14374,0.13731,0.13098,0.12477,0.11867,0.11268,0.1068,0.10102,0.09536,0.0898,0.08436,0.07902,0.0738,0.06868,0.06367,0.05878,0.05399,0.04931,0.04474,0.04028,0.03593,0.03169,0.02756,0.02354,0.01963,0.01583);
235 tbo_grn(x):interp_tbo(x,tbo_grnp) ^ gamma;
236
237 tbo_blup(i):select(i,0.23217,0.26149,0.29024,0.31844,0.34607,0.37314,0.39964,0.42558,0.45096,0.47578,0.50004,0.52373,0.54686,0.56942,0.59142,0.61286,0.63374,0.65406,0.67381,0.693,0.71162,0.72968,0.74718,0.76412,0.7805,0.79631,0.81156,0.82624,0.84037,0.85393,0.86692,0.87936,0.89123,0.90254,0.91328,0.92347,0.93309,0.94214,0.95064,0.95857,0.96594,0.97275,0.97899,0.98461,0.9893,0.99303,0.99583,0.99773,0.99876,0.99896,0.99835,0.99697,0.99485,0.99202,0.98851,0.98436,0.97959,0.97423,0.96833,0.9619,0.95498,0.94761,0.93981,0.93161,0.92305,0.91416,0.90496,0.8955,0.8858,0.8759,0.86581,0.85559,0.84525,0.83484,0.82437,0.81389,0.80342,0.79299,0.78264,0.7724,0.7623,0.75237,0.74265,0.73316,0.72393,0.715,0.70599,0.69651,0.6866,0.67627,0.66556,0.65448,0.64308,0.63137,0.61938,0.60713,0.59466,0.58199,0.56914,0.55614,0.54303,0.52981,0.51653,0.50321,0.48987,0.47654,0.46325,0.45002,0.43688,0.42386,0.41098,0.39826,0.38575,0.37345,0.3614,0.34963,0.33816,0.32701,0.31622,0.30581,0.29581,0.28623,0.27712,0.26849,0.26038,0.2528,0.24579,0.23937,0.23356,0.22835,0.2237,0.2196,0.21602,0.21294,0.21032,0.20815,0.2064,0.20504,0.20406,0.20343,0.20311,0.2031,0.20336,0.20386,0.20459,0.20552,0.20663,0.20788,0.20926,0.21074,0.2123,0.21391,0.21555,0.21719,0.2188,0.22038,0.22188,0.22328,0.22456,0.2257,0.22667,0.22744,0.228,0.22831,0.22836,0.22811,0.22754,0.22663,0.22536,0.22369,0.22161,0.21918,0.2165,0.21358,0.21043,0.20706,0.20348,0.19971,0.19577,0.19165,0.18738,0.18297,0.17842,0.17376,0.16899,0.16412,0.15918,0.15417,0.1491,0.14398,0.13883,0.13367,0.12849,0.12332,0.11817,0.11305,0.10797,0.10294,0.09798,0.0931,0.08831,0.08362,0.07905,0.07461,0.07031,0.06616,0.06218,0.05837,0.05475,0.05134,0.04814,0.04516,0.04243,0.03993,0.03753,0.03521,0.03297,0.03082,0.02875,0.02677,0.02487,0.02305,0.02131,0.01966,0.01809,0.0166,0.0152,0.01387,0.01264,0.01148,0.01041,0.00942,0.00851,0.00769,0.00695,0.00629,0.00571,0.00522,0.00481,0.00449,0.00424,0.00408,0.00401,0.00401,0.0041,0.00427,0.00453,0.00486,0.00529,0.00579,0.00638,0.00705,0.0078,0.00863,0.00955,0.01055);
238 tbo_blu(x):interp_tbo(x,tbo_blup) ^ gamma;
239
240 isconta = if(btwn(1/ndivs/2,v,1+1/ndivs/2),or(boundary(vleft,vright),boundary(vabove,vbelow)),-1);
241 iscontb = if(btwn(1/ndivs/2,v,1+1/ndivs/2),-btwn(.1,frac(ndivs*v),.9),-1);
242 iscont0 = -1;
243
244 seg(x)=(floor(v*ndivs)+.5)/ndivs;
245 seg2(x)=(seg(x)-1/ndivs)*ndivs/(ndivs-1);
246
247 ra = 0;
248 ga = 0;
249 ba = 0;
250
251 in = 1;
252
253 ro = if(in,clip($redv),ra);
254 go = if(in,clip($grnv),ga);
255 bo = if(in,clip($bluv),ba);
256 EndOfPC0
257 close FHpc0;
258
259 my $pc1 = "$td/pc1.cal";
260 open(FHpc1, ">$pc1");
261 print FHpc1 <<EndOfPC1;
262 norm : mult/scale/le(1);
263
264 v = map(li(1)*norm);
265
266 vleft = map(li(1,-1,0)*norm);
267 vright = map(li(1,1,0)*norm);
268 vabove = map(li(1,0,1)*norm);
269 vbelow = map(li(1,0,-1)*norm);
270
271 map(x) = x;
272
273 ra = ri(nfiles);
274 ga = gi(nfiles);
275 ba = bi(nfiles);
276 EndOfPC1
277 close FHpc1;
278
279 my $pc0args = "-f $pc0";
280 my $pc1args = "-f $pc1";
281
282 if ($showpal) {
283 my $pc = "pcompos -a 1";
284 foreach my $pal (@palettes) {
285 my $fcimg = "$td/$pal.hdr";
286 my $lbimg = "$td/${pal}_label.hdr";
287 system "psign -cb 0 0 0 -cf 1 1 1 -h 20 $pal > $lbimg";
288 my $cmd = qq[pcomb $pc0args -e "v=x/256"];
289 $cmd .= qq[ -e "ro=clip(${pal}_red(v));go=clip(${pal}_grn(v));bo=clip(${pal}_blu(v))"];
290 $cmd .= qq[ -x 256 -y 30 > $fcimg];
291 system "$cmd";
292 $pc .= " $fcimg $lbimg";
293 }
294 system "$pc";
295 exit 0;
296 }
297
298 if ($cpict eq '' && $docont ne '0') {
299 $pc1args .= qq[ -e "ra=0;ga=0;ba=0"];
300 } elsif ($cpict eq $picture) {
301 $cpict = '';
302 }
303
304 # Logarithmic mapping
305 if ($decades > 0) {
306 $pc1args .= qq[ -e "map(x)=if(x-10^-$decades,log10(x)/$decades+1,0)"];
307 }
308
309 # Contours
310 if ($docont ne '') {
311 # -cl -> $docont = a
312 # -cb -> $docont = b
313 # -c0 -> $docont = FALSE
314 $pc0args .= qq[ -e "in=iscont$docont"];
315 }
316 # Colours in the legend
317 my $scolpic = "$td/scol.hdr";
318
319 # Labels in the legend
320 my $slabpic = "$td/slab.hdr";
321 my $cmd;
322 if ($legwidth > 0) {
323 # Legend: Create the text labels
324 my $sheight = int($legheight / $ndivs );
325 my $theight = int($legwidth/(8/1.67));
326 my $stheight = $sheight <= $theight ? $sheight : $theight;
327 my $vlegheight = int($sheight * $ndivs * (1+1.5/$ndivs));
328 my $tslabpic = "$td/slabT.hdr";
329 system "psign -s -.15 -cf 1 1 1 -cb 0 0 0 -h $stheight $label > $tslabpic";
330 my $loop = $ndivs+$haszero;
331 my $hlegheight = int($sheight * ($loop) + $sheight * .5);
332 my $pcompost = qq[pcompos -b 0 0 0 =-0 $tslabpic 0 $hlegheight ];
333 for (my $i=0; $i<$loop; $i++) {
334 my $imap = ($ndivs - $i) / $ndivs;
335 my $value = $scale;
336 if ($decades > 0) {
337 $value *= 10**(($imap - 1) * $decades);
338 } else {
339 $value *= $imap;
340 }
341 # Limit decimal places
342 if ($scaledigits <= 0) {
343 $value =~ s/\.[0-9]*//;
344 } else {
345 $value =~ s/(\.[0-9]{$scaledigits})[0-9]*/$1/;
346 }
347 $tslabpic = "$td/slab$i.hdr";
348 system "psign -s -.15 -cf 1 1 1 -cb 0 0 0 -h $stheight $value > $tslabpic";
349 $hlegheight = int($sheight * ($loop - $i - 1) + $sheight * .5);
350 $pcompost .= qq[=-0 $tslabpic 0 $hlegheight ];
351 }
352 $pcompost .= qq[ > $slabpic];
353 system $pcompost;
354
355 # Legend: Create the background colours
356 $cmd = qq[pcomb $pc0args];
357 $cmd .= qq[ -x $legwidth -y $vlegheight];
358 $cmd .= qq[ -e "v=(y+.5-$sheight)/(yres/(1+1.5/$ndivs));vleft=v;vright=v"];
359 $cmd .= qq[ -e "vbelow=(y-.5-$sheight)/(yres/(1+1.5/$ndivs));vabove=(y+1.5-$sheight)/(yres/(1+1.5/$ndivs))"];
360 $cmd .= qq[ -e "ra=0;ga=0;ba=0;"];
361 $cmd .= qq[ > $scolpic];
362 system $cmd;
363 } else {
364 # Create dummy colour scale and legend labels so we don't
365 # need to change the final command line.
366 system "pcomb -x 1 -y 1 -e lo=1 > $scolpic";
367 system "pcomb -x 1 -y 1 -e lo=1 > $slabpic";
368 }
369
370 # Legend: Invert the text labels (for dropshadow)
371 my $slabinvpic = "$td/slabinv.hdr";
372 system qq[pcomb -e "lo=1-gi(1)" $slabpic > $slabinvpic];
373
374 my $sh0 = -int($legheight / $ndivs / 2);
375 if ($haszero < 1) {
376 $sh0 = -int($legheight / ($ndivs)*1.5);
377 }
378
379 # Command line without extrema
380
381 $cmd = qq[pcomb $pc0args $pc1args "$picture"];
382 $cmd .= qq[ "$cpict"] if ($cpict);
383 $cmd .= qq[ | pcompos -h -b 0 0 0 $scolpic 0 $sh0 +t .1 $slabinvpic 2 -1];
384 $cmd .= qq[ -t .5 $slabpic 0 0 - $legwidth 0];
385
386 my $cheight = 32;
387
388 if ($overlayWH[0] && $overlayWH[1]) {
389 # Overlay picture matrix values
390 my @picWH = split ' ', `getinfo -d < $picture`;
391 @picWH = ($picWH[3], $picWH[1]);
392 if ($#overlayRect != 3) {
393 @overlayRect = (0, 0, @picWH);
394 }
395 if ($overlayRect[2] <= $overlayRect[0] ||
396 $overlayRect[3] <= $overlayRect[1]) {
397 die("Illegal overlay rectangle\n");
398 }
399 # Compute spacing between values
400 my @cropWH = ($overlayRect[2]-$overlayRect[0], $overlayRect[3]-$overlayRect[1]);
401 my $ohspacing = $cropWH[0] / $overlayWH[0];
402 my $ovspacing = $cropWH[1] / $overlayWH[1];
403 # Compute character height from spacing
404 $cheight = int($ovspacing * 0.67 + 0.5);
405 if ($cheight >= 1.67/10 * $ohspacing) {
406 $cheight = int(1.67/10 * $ohspacing);
407 }
408 if ($cheight < 10) {
409 die "Overlay matrix spacing too tight\n";
410 }
411 my $cmd1 = qq[pcompos -x $cropWH[0] -y $cropWH[1] "$picture" @overlayRect[0..1]];
412 $cmd1 .= qq[ | pfilt -1 -b -x /$cheight -y /$cheight];
413 $cmd1 .= qq[ | pfilt -1 -r .5 -x $cropWH[0] -y $cropWH[1]];
414 $cmd1 .= qq[ | pvalue -o -h -H -b -d -e $mult];
415 # Compute matrix label center positions in subimage
416 my @xpos;
417 foreach (0 .. ($overlayWH[0]-1)) {
418 $xpos[$_] = int($ohspacing * ($_ + 0.5));
419 }
420 my @ypos;
421 foreach (0 .. ($overlayWH[1]-1)) {
422 $ypos[$_] = int($ovspacing * ($_ + 0.5));
423 }
424 open(FHsamp, "$cmd1 |");
425 $cmd1 = qq[pcompos -h -b 0 0 0 -x $cropWH[0] -y $cropWH[1]];
426 my $pscmd = qq[psign -s -.15 -cf 1 1 1 -cb 0 0 0 -h $cheight];
427 for (my $y = 0; $y < $cropWH[1]; $y++) {
428 my $ymatch = grep /^$y$/, @ypos;
429 my $cmd2 = qq[pcompos -b 0 0 0 -x $cropWH[0]];
430 for (my $x = 0; $x < $cropWH[0]; $x++) {
431 my $sampv = <FHsamp>;
432 next if (! $ymatch);
433 next if (! grep /^$x$/, @xpos);
434 chomp $sampv;
435 # Reformatting assumes %e from pvalue
436 $sampv =~ /^\s*([0-9])\.([0-9]+)[eE]([-+]?[0-9]+)$/;
437 my $manti = $1;
438 my $mantf = $2;
439 my $expi = $3;
440 if ($expi < -3) {
441 # use exponent format
442 } elsif ($expi < 0) {
443 my $pref = '0.';
444 for (my $i = $expi; ++$i < 0; ) {
445 $pref .= '0';
446 }
447 $sampv = $pref . $manti . $mantf;
448 } elsif ($expi < length($mantf)) {
449 $sampv = sprintf("%g", $sampv);
450 } elsif ($expi <= 6) {
451 $sampv = $manti . $mantf;
452 for (my $i = $expi - length($mantf); $i-- > 0; ) {
453 $sampv .= '0';
454 }
455 } # else use exponent format
456 $cmd2 .= qq[ =0- "!$pscmd $sampv" $x 0];
457 }
458 next if (! $ymatch);
459 my $rowpic = "$td/mrow$y.hdr";
460 system "$cmd2 > $rowpic";
461 $cmd1 .= qq[ =-0 $rowpic 0 ] . ($cropWH[1]-1 - $y);
462 }
463 close(FHsamp);
464 my $overpic = "$td/overlay.hdr";
465 system "$cmd1 > $overpic";
466 my $overinvpic = "$td/overinv.hdr";
467 system qq[pcomb -e "lo=1-gi(1)" $overpic > $overinvpic];
468 my $xleft = $legwidth + $overlayRect[0];
469 my $ybottom = $overlayRect[1];
470 $cmd .= qq[ +t .1 $overinvpic $xleft $ybottom];
471 # Offset from drop shadow
472 $xleft -= 2;
473 $ybottom += 1;
474 $cmd .= qq[ -t .5 $overpic $xleft $ybottom];
475 }
476
477 if ($doextrem) {
478 # Get min/max image luminance
479 my $cmd1 = 'pextrem -o ' . $picture;
480 my $retval = `$cmd1`;
481 # e.g.
482 # x y r g b
483 # 193 207 3.070068e-02 3.118896e-02 1.995850e-02
484 # 211 202 1.292969e+00 1.308594e+00 1.300781e+00
485
486 my @extrema = split(/\s/, $retval);
487 my ($lxmin, $ymin, $rmin, $gmin, $bmin, $lxmax, $ymax, $rmax, $gmax, $bmax) = @extrema;
488 $lxmin += $legwidth;
489 $lxmax += $legwidth;
490
491 # Weighted average of R,G,B
492 my $minval = ($rmin * .27 + $gmin * .67 + $bmin * .06) * $mult;
493 my $maxval = ($rmax * .27 + $gmax * .67 + $bmax * .06) * $mult;
494 if ($scaledigits <= 0) {
495 $minval =~ s/\.[0-9]*//;
496 $maxval =~ s/\.[0-9]*//;
497 } else {
498 $minval =~ s/(\.[0-9]{$scaledigits})[0-9]*/$1/;
499 $maxval =~ s/(\.[0-9]{$scaledigits})[0-9]*/$1/;
500 }
501 # Create the labels for min/max intensity
502 my $minvpic = "$td/minv.hdr";
503 system "psign -s -.15 -a 2 -h $cheight $minval > $minvpic";
504 my $maxvpic = "$td/maxv.hdr";
505 system "psign -s -.15 -a 2 -h $cheight $maxval > $maxvpic";
506
507 # Add extrema labels to command line
508 $cmd .= qq[ =00 $minvpic $lxmin $ymin =00 $maxvpic $lxmax $ymax];
509 }
510
511 # Clean up and simplify info header without constituent commands
512 $cmd .= qq[ | getinfo -r "EXPOSURE" "pcompos " "falsecolor @savedARGV"];
513
514 # Process image and combine with legend
515 exec $cmd;
516
517 #EOF
