root/radiance/ray/src/px/falsecolor.pl
Revision: 2.12
Committed: Mon Sep 25 18:48:11 2017 UTC (7 years, 7 months ago) by greg
Changes since 2.11: +80 -51 lines
Improvements to falsecolor legend by David G-M and Stephen W
1 #!/usr/bin/perl -w
2 # RCSid $Id: falsecolor.pl,v 2.11 2017/09/05 22:42:52 greg Exp $
3
4 use warnings;
5 use strict;
6 use File::Temp qw/ tempdir /;
7 use POSIX qw/ floor /;
8
9 my @palettes = ('def', 'spec', 'pm3d', 'hot', 'eco');
10
11 my $mult = 179.0; # Multiplier. Default W/sr/m2 -> cd/m2
12 my $label = 'cd/m2'; # Units shown in legend
13 my $scale = 1000; # Top of the scale
14 my $scaledigits = 3; # Number of maximum digits for numbers in legend
15 my $decades = 0; # Default is linear mapping
16 my $pal = 'def'; # Palette
17 my $redv = "${pal}_red(v)"; # Mapping functions for R,G,B
18 my $grnv = "${pal}_grn(v)";
19 my $bluv = "${pal}_blu(v)";
20 my $ndivs = 8; # Number of lines in legend
21 my $picture = '-';
22 my $cpict = '';
23 my $legwidth = 100; # Legend width and height
24 my $legheight = 200;
25 my $haszero = 1; # print 0 in scale for falsecolor images only
26 my $docont = ''; # Contours: -cl and -cb
27 my $doposter = 0; # Posterization: -cp
28 my $doextrem = 0; # Don't mark extrema
29 my $needfile = 0;
30 my $showpal = 0; # Show availabel colour palettes
31
32 while ($#ARGV >= 0) {
33 $_ = shift;
34 # Options with qualifiers
35 if (m/-lw/) { # Legend width
36 $legwidth = shift;
37 } elsif (m/-lh/) { # Legend height
38 $legheight = shift;
39 } elsif (m/-m/) { # Multiplier
40 $mult = shift;
41 } elsif (m/-spec/) {
42 die("depricated option '-spec'. Please use '-pal spec' instead.");
43 } elsif (m/-s/) { # Scale
44 $scale = shift;
45 if ($scale =~ m/[aA].*/) {
46 $needfile = 1;
47 }
48 } elsif (m/-d/) { # Number of maximum digits for numbers in legend
49 $scaledigits = shift;
50 } elsif (m/-l$/) { # Label
51 $label = shift;
52 } elsif (m/-log/) { # Logarithmic mapping
53 $decades = shift;
54 } elsif (m/-r/) { # Custom palette functions for R,G,B
55 $redv = shift;
56 } elsif (m/-g/) {
57 $grnv = shift;
58 } elsif (m/-b/) {
59 $bluv = shift;
60 } elsif (m/-pal$/) { # Color palette
61 $pal = shift;
62 if (! grep $_ eq $pal, @palettes) {
63 die("invalid palette '$pal'.\n");
64 }
65 $redv = "${pal}_red(v)";
66 $grnv = "${pal}_grn(v)";
67 $bluv = "${pal}_blu(v)";
68 } elsif (m/-i$/) { # Image for intensity mapping
69 $picture = shift;
70 } elsif (m/-p$/) { # Image for background
71 $cpict = shift;
72 } elsif (m/-ip/ || m/-pi/) {
73 $picture = shift;
74 $cpict = $picture;
75 } elsif (m/-n/) { # Number of contour lines
76 $ndivs = shift;
77
78 # Switches
79 } elsif (m/-cl/) { # Contour lines
80 $docont = 'a';
81 $haszero = 0;
82 } elsif (m/-cb/) { # Contour bands
83 $docont = 'b';
84 $haszero = 0;
85 } elsif (m/-cp/) { # Posterize
86 $doposter = 1;
87 $haszero = 0;
88 } elsif (m/-palettes/) { # Show all available palettes
89 $scale = 45824; # 256 * 179
90 $showpal = 1;
91 } elsif (m/-e/) {
92 $doextrem = 1;
93 $needfile = 1;
94 # Oops! Illegal option
95 } else {
96 die("bad option \"$_\"\n");
97 }
98 }
99
100 if (($legwidth <= 20) || ($legheight <= 40)) {
101 # Legend is too small to be legible. Don't bother doing one.
102 $legwidth = 0;
103 $legheight = 0;
104 }
105
106 # Temporary directory. Will be removed upon successful program exit.
107 my $td = tempdir( CLEANUP => 1 );
108
109 if ($needfile == 1 && $picture eq '-') {
110 # Pretend that $td/stdin.rad is the actual filename.
111 $picture = "$td/stdin.hdr";
112 open(FHpic, ">$picture") or
113 die("Unable to write to file $picture\n");
114 # Input is from STDIN: Capture to file.
115 while (<>) {
116 print FHpic;
117 }
118 close(FHpic);
119
120 if ($cpict eq '-') {
121 $cpict = "$td/stdin.hdr";
122 }
123 }
124
125 # Find a good scale for auto mode.
126 if ($scale =~ m/[aA].*/) {
127 my @histo = split(/\s/, `phisto $picture| tail -2`);
128 # e.g. $ phisto tests/richmond.hdr| tail -2
129 # 3.91267 14
130 # 3.94282 6
131 my $LogLmax = $histo[0];
132 $scale = $mult / 179 * 10**$LogLmax;
133 }
134
135 if ($docont ne '') {
136 # -cl -> $docont = a
137 # -cb -> $docont = b
138 my $newv = join( "(v-1/ndivs)*ndivs/(ndivs-1)", split("v", $redv) );
139 $redv = $newv;
140 $newv = join( "(v-1/ndivs)*ndivs/(ndivs-1)", split("v", $bluv) );
141 $bluv = $newv;
142 $newv = join( "(v-1/ndivs)*ndivs/(ndivs-1)", split("v", $grnv) );
143 $grnv = $newv;
144 } elsif ($doposter == 1) {
145 # -cp -> $doposter = 1
146 my $newv = join( "seg2(v)", split("v", $redv) );
147 $redv = $newv;
148 $newv = join( "seg2(v)", split("v", $bluv) );
149 $bluv = $newv;
150 $newv = join( "seg2(v)", split("v", $grnv) );
151 $grnv = $newv;
152 }
153
154 my $pc0 = "$td/pc0.cal";
155 open(FHpc0, ">$pc0");
156 print FHpc0 <<EndOfPC0;
157 PI : 3.14159265358979323846 ;
158 scale : $scale ;
159 mult : $mult ;
160 ndivs : $ndivs ;
161 gamma : 2.2;
162
163 or(a,b) : if(a,a,b);
164 EPS : 1e-7;
165 neq(a,b) : if(a-b-EPS,1,b-a-EPS);
166 btwn(a,x,b) : if(a-x,-1,b-x);
167 clip(x) : if(x-1,1,if(x,x,0));
168 frac(x) : x - floor(x);
169 boundary(a,b) : neq(floor(ndivs*a),floor(ndivs*b));
170
171 spec_red(x) = 1.6*x - .6;
172 spec_grn(x) = if(x-.375, 1.6-1.6*x, 8/3*x);
173 spec_blu(x) = 1 - 8/3*x;
174
175 pm3d_red(x) = sqrt(clip(x)) ^ gamma;
176 pm3d_grn(x) = clip(x*x*x) ^ gamma;
177 pm3d_blu(x) = clip(sin(2*PI*clip(x))) ^ gamma;
178
179 hot_red(x) = clip(3*x) ^ gamma;
180 hot_grn(x) = clip(3*x - 1) ^ gamma;
181 hot_blu(x) = clip(3*x - 2) ^ gamma;
182
183 eco_red(x) = clip(2*x) ^ gamma;
184 eco_grn(x) = clip(2*(x-0.5)) ^ gamma;
185 eco_blu(x) = clip(2*(0.5-x)) ^ gamma;
186
187 interp_arr2(i,x,f):(i+1-x)*f(i)+(x-i)*f(i+1);
188 interp_arr(x,f):if(x-1,if(f(0)-x,interp_arr2(floor(x),x,f),f(f(0))),f(1));
189
190 def_redp(i):select(i,0.18848,0.05468174,
191 0.00103547,8.311144e-08,7.449763e-06,0.0004390987,0.001367254,
192 0.003076,0.01376382,0.06170773,0.1739422,0.2881156,0.3299725,
193 0.3552663,0.372552,0.3921184,0.4363976,0.6102754,0.7757267,
194 0.9087369,1,1,0.9863);
195 def_red(x):interp_arr(x/0.0454545+1,def_redp);
196
197 def_grnp(i):select(i,0.0009766,2.35501e-05,
198 0.0008966244,0.0264977,0.1256843,0.2865799,0.4247083,0.4739468,
199 0.4402732,0.3671876,0.2629843,0.1725325,0.1206819,0.07316644,
200 0.03761026,0.01612362,0.004773749,6.830967e-06,0.00803605,
201 0.1008085,0.3106831,0.6447838,0.9707);
202 def_grn(x):interp_arr(x/0.0454545+1,def_grnp);
203
204 def_blup(i):select(i,0.2666,0.3638662,0.4770437,
205 0.5131397,0.5363797,0.5193677,0.4085123,0.1702815,0.05314236,
206 0.05194055,0.08564082,0.09881395,0.08324373,0.06072902,
207 0.0391076,0.02315354,0.01284458,0.005184709,0.001691774,
208 2.432735e-05,1.212949e-05,0.006659406,0.02539);
209 def_blu(x):interp_arr(x/0.0454545+1,def_blup);
210
211 isconta = if(btwn(1/ndivs/2,v,1+1/ndivs/2),or(boundary(vleft,vright),boundary(vabove,vbelow)),-1);
212 iscontb = if(btwn(1/ndivs/2,v,1+1/ndivs/2),-btwn(.1,frac(ndivs*v),.9),-1);
213
214 seg(x)=(floor(v*ndivs)+.5)/ndivs;
215 seg2(x)=(seg(x)-1/ndivs)*ndivs/(ndivs-1);
216
217 ra = 0;
218 ga = 0;
219 ba = 0;
220
221 in = 1;
222
223 ro = if(in,clip($redv),ra);
224 go = if(in,clip($grnv),ga);
225 bo = if(in,clip($bluv),ba);
226 EndOfPC0
227 close FHpc0;
228
229 my $pc1 = "$td/pc1.cal";
230 open(FHpc1, ">$pc1");
231 print FHpc1 <<EndOfPC1;
232 norm : mult/scale/le(1);
233
234 v = map(li(1)*norm);
235
236 vleft = map(li(1,-1,0)*norm);
237 vright = map(li(1,1,0)*norm);
238 vabove = map(li(1,0,1)*norm);
239 vbelow = map(li(1,0,-1)*norm);
240
241 map(x) = x;
242
243
244 ra = ri(nfiles);
245 ga = gi(nfiles);
246 ba = bi(nfiles);
247 EndOfPC1
248 close FHpc1;
249
250 my $pc0args = "-f $pc0";
251 my $pc1args = "-f $pc1";
252
253 if ($showpal == 1) {
254 my $pc = "pcompos -a 1";
255 foreach my $pal (@palettes) {
256 my $fcimg = "$td/$pal.hdr";
257 my $lbimg = "$td/${pal}_label.hdr";
258 system "psign -cb 0 0 0 -cf 1 1 1 -h 20 $pal > $lbimg";
259
260 my $cmd = qq[pcomb $pc0args -e "v=x/256"];
261 $cmd .= qq[ -e "ro=clip(${pal}_red(v));go=clip(${pal}_grn(v));bo=clip(${pal}_blu(v))"];
262 $cmd .= qq[ -x 256 -y 30 > $fcimg];
263 system "$cmd";
264 $pc .= " $fcimg $lbimg";
265 }
266 system "$pc";
267 exit 0;
268 }
269
270 # Contours
271 if ($docont ne '') {
272 # -cl -> $docont = a
273 # -cb -> $docont = b
274 $pc0args .= qq[ -e "in=iscont$docont"];
275 }
276
277 if ($cpict eq '') {
278 $pc1args .= qq[ -e "ra=0;ga=0;ba=0"];
279 } elsif ($cpict eq $picture) {
280 $cpict = '';
281 }
282
283 # Logarithmic mapping
284 if ($decades > 0) {
285 $pc1args .= qq[ -e "map(x)=if(x-10^-$decades,log10(x)/$decades+1,0)"];
286 }
287
288 # Colours in the legend
289 my $scolpic = "$td/scol.hdr";
290
291 # Labels in the legend
292 my $slabpic = "$td/slab.hdr";
293 my $cmd;
294 if ($legwidth > 0) {
295 # Legend: Create the text labels
296 my $sheight = floor($legheight / $ndivs );
297 my $theight = floor($legwidth/(8/1.67));
298 my $stheight = $sheight <= $theight ? $sheight : $theight;
299 my $vlegheight = $sheight * $ndivs * (1+1.5/$ndivs);
300 my $text = "$label\n";
301 my $tslabpic = "$td/slabT.hdr";
302 open PSIGN, "| psign -s -.15 -cf 1 1 1 -cb 0 0 0 -h $stheight > $tslabpic";
303 print PSIGN "$text";
304 close PSIGN;
305 my $loop = $ndivs+$haszero;
306 my $hlegheight = $sheight * ($loop) + $sheight * .5;
307 my $pcompost = qq[pcompos -b 0 0 0 =-0 $tslabpic 0 $hlegheight ];
308 for (my $i=0; $i<$loop; $i++) {
309 my $imap = ($ndivs - $i) / $ndivs;
310 my $value = $scale;
311 if ($decades > 0) {
312 $value *= 10**(($imap - 1) * $decades);
313 } else {
314 $value *= $imap;
315 }
316 # Have no more than 3 decimal places
317 $value =~ s/(\.[0-9]{$scaledigits})[0-9]*/$1/;
318 $text = "$value\n";
319 $tslabpic = "$td/slab$i.hdr";
320 open PSIGN, "| psign -s -.15 -cf 1 1 1 -cb 0 0 0 -h $stheight > $tslabpic";
321 print PSIGN "$text";
322 close PSIGN;
323 $hlegheight = $sheight * ($loop - $i - 1) + $sheight * .5;
324 $pcompost .= qq[=-0 $tslabpic 0 $hlegheight ];
325 }
326 $pcompost .= qq[ > $slabpic];
327 system $pcompost;
328
329 # Legend: Create the background colours
330 $cmd = qq[pcomb $pc0args];
331 $cmd .= qq[ -e "v=(y+.5-$sheight)/(yres/(1+1.5/$ndivs));;vleft=v;vright=v"];
332 $cmd .= qq[ -e "vbelow=(y-.5-$sheight)/(yres/(1+1.5/$ndivs));vabove=(y+1.5-$sheight)/(yres/(1+1.5/$ndivs))"];
333 $cmd .= qq[ -e "ra=0;ga=0;ba=0;"];
334 $cmd .= qq[ -x $legwidth -y $vlegheight > $scolpic];
335 system $cmd;
336 } else {
337 # Create dummy colour scale and legend labels so we don't
338 # need to change the final command line.
339 open(FHscolpic, ">$scolpic");
340 print FHscolpic "\n-Y 1 +X 1\naaa\n";
341 close(FHscolpic);
342 open(FHslabpic, ">$slabpic");
343 print FHslabpic "\n-Y 1 +X 1\naaa\n";
344 close(FHslabpic);
345 }
346
347 # Legend: Invert the text labels (for dropshadow)
348 my $slabinvpic = "$td/slabinv.hdr";
349 $cmd = qq[pcomb -e "lo=1-gi(1)" $slabpic > $slabinvpic];
350 system $cmd;
351
352
353 my $sh0 = -floor($legheight / $ndivs / 2);
354 if ($haszero < 1) {
355 $sh0 = -floor($legheight / ($ndivs)*1.5);
356 }
357
358 # Command line without extrema
359
360 $cmd = qq[pcomb $pc0args $pc1args "$picture"];
361 $cmd .= qq[ "$cpict"] if ($cpict);
362 $cmd .= qq[ | pcompos -b 0 0 0 $scolpic 0 $sh0 +t .1 $slabinvpic 2 -1 ];
363 $cmd .= qq[ -t .5 $slabpic 0 0 - $legwidth 0];
364
365 if ($doextrem == 1) {
366 # Get min/max image luminance
367 my $cmd1 = 'pextrem -o ' . $picture;
368 my $retval = `$cmd1`;
369 # e.g.
370 # x y r g b
371 # 193 207 3.070068e-02 3.118896e-02 1.995850e-02
372 # 211 202 1.292969e+00 1.308594e+00 1.300781e+00
373
374 my @extrema = split(/\s/, $retval);
375 my ($lxmin, $ymin, $rmin, $gmin, $bmin, $lxmax, $ymax, $rmax, $gmax, $bmax) = @extrema;
376 $lxmin += $legwidth;
377 $lxmax += $legwidth;
378
379 # Weighted average of R,G,B
380 my $minpos = "$lxmin $ymin";
381 my $minval = ($rmin * .27 + $gmin * .67 + $bmin * .06) * $mult;
382 $minval =~ s/(\.[0-9]{$scaledigits})[0-9]*/$1/;
383 my $maxval = ($rmax * .27 + $gmax * .67 + $bmax * .06) * $mult;
384 $maxval =~ s/(\.[0-9]{$scaledigits})[0-9]*/$1/;
385
386 # Create the labels for min/max intensity
387 my $minvpic = "$td/minv.hdr";
388 system "psign -s -.15 -a 2 -h 16 $minval > $minvpic";
389 my $maxvpic = "$td/maxv.hdr";
390 system "psign -s -.15 -a 2 -h 16 $maxval > $maxvpic";
391
392 # Add extrema labels to command line
393 $cmd .= qq[ $minvpic $minpos $maxvpic $lxmax $ymax];
394 }
395
396
397
398
399 # Process image and combine with legend
400 system "$cmd";
401
402 #EOF
