1 |
#!/usr/bin/perl -w |
2 |
# RCSid $Id$ |
3 |
4 |
use strict; |
5 |
use File::Temp qw/ tempdir /; |
6 |
use POSIX qw/ floor /; |
7 |
8 |
my $mult = 179.0; # Multiplier. Default W/sr/m2 -> cd/m2 |
9 |
my $label = 'cd/m2'; # Units shown in legend |
10 |
my $scale = 1000; # Top of the scale |
11 |
my $decades = 0; # Default is linear mapping |
12 |
my $redv = 'def_red(v)'; # Mapping function for R,G,B |
13 |
my $grnv = 'def_grn(v)'; |
14 |
my $bluv = 'def_blu(v)'; |
15 |
my $ndivs = 8; # Number of lines in legend |
16 |
my $picture = '-'; |
17 |
my $cpict = ''; |
18 |
my $legwidth = 100; # Legend width and height |
19 |
my $legheight = 200; |
20 |
my $docont = ''; # Contours |
21 |
my $loff = 0; # Offset for drop-shadow |
22 |
my $doextrem = 0; # Don't mark extrema |
23 |
my $needfile = 0; |
24 |
25 |
while ($#ARGV >= 0) { |
26 |
# Options with qualifiers |
27 |
if ("$ARGV[0]" eq '-lw') { # Legend width |
28 |
$legwidth = $ARGV[1]; |
29 |
shift @ARGV; |
30 |
} elsif ("$ARGV[0]" eq '-lh') { # Legend height |
31 |
$legheight = $ARGV[1]; |
32 |
shift @ARGV; |
33 |
} elsif ("$ARGV[0]" eq '-m') { # Multiplier |
34 |
$mult = $ARGV[1]; |
35 |
shift @ARGV; |
36 |
} elsif ("$ARGV[0]" eq '-s') { # Scale |
37 |
$scale = $ARGV[1]; |
38 |
shift @ARGV; |
39 |
if ($scale =~ m/[aA].*/) { |
40 |
$needfile = 1; |
41 |
42 |
} elsif ("$ARGV[0]" eq '-l') { # Label |
43 |
$label = $ARGV[1]; |
44 |
shift @ARGV; |
45 |
} elsif ("$ARGV[0]" eq '-log') { # Logarithmic mapping |
46 |
$decades = $ARGV[1]; |
47 |
shift @ARGV; |
48 |
} elsif ("$ARGV[0]" eq '-r') { |
49 |
$redv = $ARGV[1]; |
50 |
shift @ARGV; |
51 |
} elsif ("$ARGV[0]" eq '-g') { |
52 |
$grnv = $ARGV[1]; |
53 |
shift @ARGV; |
54 |
} elsif ("$ARGV[0]" eq '-b') { |
55 |
$bluv = $ARGV[1]; |
56 |
shift @ARGV; |
57 |
} elsif ("$ARGV[0]" eq '-pal') { |
58 |
$redv = "$ARGV[1]_red(v)"; |
59 |
$grnv = "$ARGV[1]_grn(v)"; |
60 |
$bluv = "$ARGV[1]_blu(v)"; |
61 |
shift @ARGV; |
62 |
} elsif ("$ARGV[0]" eq '-i') { # Image for intensity mapping |
63 |
$picture = $ARGV[1]; |
64 |
shift @ARGV; |
65 |
} elsif ("$ARGV[0]" eq '-p') { # Image for background |
66 |
$cpict = $ARGV[1]; |
67 |
shift @ARGV; |
68 |
} elsif ("$ARGV[0]" eq '-ip' || "$ARGV[0]" eq '-pi') { |
69 |
70 |
71 |
shift @ARGV; |
72 |
} elsif ("$ARGV[0]" eq '-n') { # Number of contour lines |
73 |
$ndivs = $ARGV[1]; |
74 |
shift @ARGV; |
75 |
76 |
# Switches |
77 |
} elsif ("$ARGV[0]" eq '-cl') { # Contour lines |
78 |
$docont = 'a'; |
79 |
$loff = 12; |
80 |
} elsif ("$ARGV[0]" eq '-cb') { # Contour bands |
81 |
$docont = 'b'; |
82 |
$loff = 13; |
83 |
} elsif ("$ARGV[0]" eq '-e') { |
84 |
$doextrem = 1; |
85 |
$needfile = 1; |
86 |
87 |
# Oops! Illegal option |
88 |
} else { |
89 |
die("bad option \"$ARGV[0]\"\n"); |
90 |
91 |
shift @ARGV; |
92 |
93 |
94 |
# Temporary directory. Will be removed upon successful program exit. |
95 |
my $td = tempdir( CLEANUP => 1 ); |
96 |
97 |
if ($needfile == 1 && $picture eq '-') { |
98 |
$picture = $td . '/' . $picture; |
99 |
open(FHpic, ">$picture") or |
100 |
die("Unable to write to file $picture\n"); |
101 |
close(FHpic); |
102 |
103 |
104 |
# Find a good scale for auto mode. |
105 |
106 |
my $LogLmax = `phisto $picture| tail -2| sed -n '1s/[0-9]*\$//p'`; |
107 |
$scale = $mult / 179 * 10**$LogLmax; |
108 |
109 |
110 |
my $pc0 = $td . '/pc0.cal'; |
111 |
open(FHpc0, ">$pc0"); |
112 |
print FHpc0 <<EndOfPC0; |
113 |
PI : 3.14159265358979323846 ; |
114 |
scale : $scale ; |
115 |
mult : $mult ; |
116 |
ndivs : $ndivs ; |
117 |
gamma : 2.2; |
118 |
119 |
or(a,b) : if(a,a,b); |
120 |
EPS : 1e-7; |
121 |
neq(a,b) : if(a-b-EPS,1,b-a-EPS); |
122 |
btwn(a,x,b) : if(a-x,-1,b-x); |
123 |
clip(x) : if(x-1,1,if(x,x,0)); |
124 |
frac(x) : x - floor(x); |
125 |
boundary(a,b) : neq(floor(ndivs*a+.5),floor(ndivs*b+.5)); |
126 |
127 |
spec_red(x) = 1.6*x - .6; |
128 |
spec_grn(x) = if(x-.375, 1.6-1.6*x, 8/3*x); |
129 |
spec_blu(x) = 1 - 8/3*x; |
130 |
131 |
pm3d_red(x) = sqrt(x) ^ gamma; |
132 |
pm3d_grn(x) = x*x*x ^ gamma; |
133 |
pm3d_blu(x) = clip(sin(2*PI*x)) ^ gamma; |
134 |
135 |
hot_red(x) = clip(3*x) ^ gamma; |
136 |
hot_grn(x) = clip(3*x - 1) ^ gamma; |
137 |
hot_blu(x) = clip(3*x - 2) ^ gamma; |
138 |
139 |
interp_arr2(i,x,f):(i+1-x)*f(i)+(x-i)*f(i+1); |
140 |
interp_arr(x,f):if(x-1,if(f(0)-x,interp_arr2(floor(x),x,f),f(f(0))),f(1)); |
141 |
142 |
def_redp(i):select(i,0.18848,0.05468174, |
143 |
0.00103547,8.311144e-08,7.449763e-06,0.0004390987,0.001367254, |
144 |
0.003076,0.01376382,0.06170773,0.1739422,0.2881156,0.3299725, |
145 |
0.3552663,0.372552,0.3921184,0.4363976,0.6102754,0.7757267, |
146 |
0.9087369,1,1,0.9863); |
147 |
def_red(x):interp_arr(x/0.0454545+1,def_redp); |
148 |
149 |
def_grnp(i):select(i,0.0009766,2.35501e-05, |
150 |
0.0008966244,0.0264977,0.1256843,0.2865799,0.4247083,0.4739468, |
151 |
0.4402732,0.3671876,0.2629843,0.1725325,0.1206819,0.07316644, |
152 |
0.03761026,0.01612362,0.004773749,6.830967e-06,0.00803605, |
153 |
0.1008085,0.3106831,0.6447838,0.9707); |
154 |
def_grn(x):interp_arr(x/0.0454545+1,def_grnp); |
155 |
156 |
def_blup(i):select(i,0.2666,0.3638662,0.4770437, |
157 |
0.5131397,0.5363797,0.5193677,0.4085123,0.1702815,0.05314236, |
158 |
0.05194055,0.08564082,0.09881395,0.08324373,0.06072902, |
159 |
0.0391076,0.02315354,0.01284458,0.005184709,0.001691774, |
160 |
2.432735e-05,1.212949e-05,0.006659406,0.02539); |
161 |
def_blu(x):interp_arr(x/0.0454545+1,def_blup); |
162 |
163 |
isconta = if(btwn(0,v,1),or(boundary(vleft,vright),boundary(vabove,vbelow)),-1); |
164 |
iscontb = if(btwn(0,v,1),btwn(.4,frac(ndivs*v),.6),-1); |
165 |
166 |
ra = 0; |
167 |
ga = 0; |
168 |
ba = 0; |
169 |
170 |
in = 1; |
171 |
172 |
ro = if(in,clip($redv),ra); |
173 |
go = if(in,clip($grnv),ga); |
174 |
bo = if(in,clip($bluv),ba); |
175 |
EndOfPC0 |
176 |
177 |
my $pc1 = $td . '/pc1.cal'; |
178 |
open(FHpc1, ">$pc1"); |
179 |
print FHpc1 <<EndOfPC1; |
180 |
norm : mult/scale/le(1); |
181 |
182 |
v = map(li(1)*norm); |
183 |
184 |
vleft = map(li(1,-1,0)*norm); |
185 |
vright = map(li(1,1,0)*norm); |
186 |
vabove = map(li(1,0,1)*norm); |
187 |
vbelow = map(li(1,0,-1)*norm); |
188 |
189 |
map(x) = x; |
190 |
191 |
ra = ri(nfiles); |
192 |
ga = gi(nfiles); |
193 |
ba = bi(nfiles); |
194 |
EndOfPC1 |
195 |
196 |
my $pc0args = "-f $pc0"; |
197 |
my $pc1args = "-f $pc1"; |
198 |
199 |
# Contour lines or bands |
200 |
if ($docont ne '') { |
201 |
$pc0args .= " -e 'in=iscont$docont'"; |
202 |
203 |
204 |
if ($cpict eq '') { |
205 |
$pc1args .= " -e 'ra=0;ga=0;ba=0'"; |
206 |
} elsif ($cpict eq $picture) { |
207 |
$cpict = ''; |
208 |
209 |
210 |
211 |
if ($decades > 0) { |
212 |
$pc1args .= " -e 'map(x)=if(x-10^-$decades,log10(x)/$decades+1,0)'"; |
213 |
214 |
215 |
# Colours in the legend |
216 |
my $scolpic = $td . '/scol.hdr'; |
217 |
# Labels in the legend |
218 |
my $slabpic = $td . '/slab.hdr'; |
219 |
my $cmd; |
220 |
221 |
if ($legwidth > 20 && $legheight > 40) { |
222 |
# Legend: Create the background colours |
223 |
$cmd = "pcomb $pc0args -e 'v=(y+.5)/yres;vleft=v;vright=v'"; |
224 |
$cmd .= " -e 'vbelow=(y-.5)/yres;vabove=(y+1.5)/yres'"; |
225 |
$cmd .= " -x $legwidth -y $legheight > $scolpic"; |
226 |
system $cmd; |
227 |
228 |
# Legend: Create the text labels |
229 |
my $sheight = floor($legheight / $ndivs + 0.5); |
230 |
my $text = "$label"; |
231 |
my $value; |
232 |
my $i; |
233 |
for ($i=0; $i<$ndivs; $i++) { |
234 |
my $imap = ($ndivs - 0.5 - $i) / $ndivs; |
235 |
236 |
$value = $scale * 10**(($imap - 1) * $decades); |
237 |
} else { |
238 |
$value = $scale * $imap; |
239 |
240 |
# Have no more than 3 decimal places |
241 |
$value =~ s/(\.[0-9]{3})[0-9]*/$1/; |
242 |
$text .= "\n$value"; |
243 |
244 |
$cmd = "echo '$text' | psign -s -.15 -cf 1 1 1 -cb 0 0 0"; |
245 |
$cmd .= " -h $sheight > $slabpic"; |
246 |
system $cmd; |
247 |
} else { |
248 |
# Legend is too small to be legible. Don't bother doing one. |
249 |
$legwidth = 0; |
250 |
$legheight = 0; |
251 |
open(FHscolpic, ">$scolpic"); |
252 |
print FHscolpic '\n-Y 1 +X 1\naaa\n'; |
253 |
close(FHscolpic); |
254 |
open(FHslabpic, ">$slabpic"); |
255 |
print FHslabpic '\n-Y 1 +X 1\naaa\n'; |
256 |
close(FHslabpic); |
257 |
258 |
259 |
my $loff1 = $loff - 1; |
260 |
# Command line without extrema |
261 |
$cmd = "pcomb $pc0args $pc1args $picture $cpict"; |
262 |
$cmd .= "| pcompos $scolpic 0 0 +t .1"; |
263 |
$cmd .= " \"\!pcomb -e 'lo=1-gi(1)' $slabpic\" 2 $loff1"; |
264 |
$cmd .= " -t .5 $slabpic 0 $loff - $legwidth 0"; |
265 |
266 |
if ($doextrem == 1) { |
267 |
# Get min/max image luminance |
268 |
my $cmd1 = 'pextrem -o ' . $picture; |
269 |
my $retval = `$cmd1`; |
270 |
# e.g. |
271 |
# x y r g b |
272 |
# 193 207 3.070068e-02 3.118896e-02 1.995850e-02 |
273 |
# 211 202 1.292969e+00 1.308594e+00 1.300781e+00 |
274 |
275 |
my @extrema = split(/\s/, $retval); |
276 |
my $lxmin = $extrema[0] + $legwidth; |
277 |
my $ymin = $extrema[1]; |
278 |
my $rmin = $extrema[2]; |
279 |
my $gmin = $extrema[3]; |
280 |
my $bmin = $extrema[4]; |
281 |
my $lxmax = $extrema[5] + $legwidth; |
282 |
my $ymax = $extrema[6]; |
283 |
my $rmax = $extrema[7]; |
284 |
my $gmax = $extrema[8]; |
285 |
my $bmax = $extrema[9]; |
286 |
287 |
# Weighted average of R,G,B |
288 |
my $minpos = "$lxmin $ymin"; |
289 |
my $minval = ($rmin * .27 + $gmin * .67 + $bmin * .06) * $mult; |
290 |
$minval =~ s/(\.[0-9]{3})[0-9]*/$1/; |
291 |
my $maxpos = "$lxmax $ymax"; |
292 |
my $maxval = ($rmax * .27 + $gmax * .67 + $bmax * .06) * $mult; |
293 |
$maxval =~ s/(\.[0-9]{3})[0-9]*/$1/; |
294 |
295 |
# Create the labels for min/max intensity |
296 |
my $minvpic = $td . '/minv.hdr'; |
297 |
$cmd1 = "psign -s -.15 -a 2 -h 16 $minval > $minvpic"; |
298 |
system $cmd1; |
299 |
my $maxvpic = $td . '/maxv.hdr'; |
300 |
$cmd1 = "psign -s -.15 -a 2 -h 16 $maxval > $maxvpic"; |
301 |
system $cmd1; |
302 |
303 |
# Add extrema labels to command line |
304 |
$cmd .= " $minvpic $minpos $maxvpic $maxpos"; |
305 |
306 |
307 |
# Process image and combine with legend |
308 |
system "$cmd"; |
309 |
310 |
#EOF |
