root/radiance/ray/src/px/falsecolor.pl
Revision: 2.10
Committed: Tue Apr 15 21:34:31 2014 UTC (10 years, 2 months ago) by greg
CVS Tags: rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R2P1
Changes since 2.9: +3 -2 lines
Added handling of file names with spaces
1 #!/usr/bin/perl -w
2 # RCSid $Id: falsecolor.pl,v 2.9 2013/04/04 02:59:20 greg Exp $
3
4 use warnings;
5 use strict;
6 use File::Temp qw/ tempdir /;
7 use POSIX qw/ floor /;
8
9 my @palettes = ('def', 'spec', 'pm3d', 'hot', 'eco');
10
11 my $mult = 179.0; # Multiplier. Default W/sr/m2 -> cd/m2
12 my $label = 'cd/m2'; # Units shown in legend
13 my $scale = 1000; # Top of the scale
14 my $decades = 0; # Default is linear mapping
15 my $pal = 'def'; # Palette
16 my $redv = "${pal}_red(v)"; # Mapping functions for R,G,B
17 my $grnv = "${pal}_grn(v)";
18 my $bluv = "${pal}_blu(v)";
19 my $ndivs = 8; # Number of lines in legend
20 my $picture = '-';
21 my $cpict = '';
22 my $legwidth = 100; # Legend width and height
23 my $legheight = 200;
24 my $docont = ''; # Contours: -cl and -cb
25 my $doposter = 0; # Posterization: -cp
26 my $loff = 0; # Offset to align with values
27 my $doextrem = 0; # Don't mark extrema
28 my $needfile = 0;
29 my $showpal = 0; # Show availabel colour palettes
30
31 while ($#ARGV >= 0) {
32 $_ = shift;
33 # Options with qualifiers
34 if (m/-lw/) { # Legend width
35 $legwidth = shift;
36 } elsif (m/-lh/) { # Legend height
37 $legheight = shift;
38 } elsif (m/-m/) { # Multiplier
39 $mult = shift;
40 } elsif (m/-spec/) {
41 die("depricated option '-spec'. Please use '-pal spec' instead.");
42 } elsif (m/-s/) { # Scale
43 $scale = shift;
44 if ($scale =~ m/[aA].*/) {
45 $needfile = 1;
46 }
47 } elsif (m/-l$/) { # Label
48 $label = shift;
49 } elsif (m/-log/) { # Logarithmic mapping
50 $decades = shift;
51 } elsif (m/-r/) { # Custom palette functions for R,G,B
52 $redv = shift;
53 } elsif (m/-g/) {
54 $grnv = shift;
55 } elsif (m/-b/) {
56 $bluv = shift;
57 } elsif (m/-pal$/) { # Color palette
58 $pal = shift;
59 if (! grep $_ eq $pal, @palettes) {
60 die("invalid palette '$pal'.\n");
61 }
62 $redv = "${pal}_red(v)";
63 $grnv = "${pal}_grn(v)";
64 $bluv = "${pal}_blu(v)";
65 } elsif (m/-i$/) { # Image for intensity mapping
66 $picture = shift;
67 } elsif (m/-p$/) { # Image for background
68 $cpict = shift;
69 } elsif (m/-ip/ || m/-pi/) {
70 $picture = shift;
71 $cpict = $picture;
72 } elsif (m/-n/) { # Number of contour lines
73 $ndivs = shift;
74
75 # Switches
76 } elsif (m/-cl/) { # Contour lines
77 $docont = 'a';
78 $loff = 0.48;
79 } elsif (m/-cb/) { # Contour bands
80 $docont = 'b';
81 $loff = 0.52;
82 } elsif (m/-cp/) { # Posterize
83 $doposter = 1;
84 } elsif (m/-palettes/) { # Show all available palettes
85 $scale = 45824; # 256 * 179
86 $showpal = 1;
87 } elsif (m/-e/) {
88 $doextrem = 1;
89 $needfile = 1;
90
91 # Oops! Illegal option
92 } else {
93 die("bad option \"$_\"\n");
94 }
95 }
96
97 # Temporary directory. Will be removed upon successful program exit.
98 my $td = tempdir( CLEANUP => 1 );
99
100 if ($needfile == 1 && $picture eq '-') {
101 # Pretend that $td/stdin.rad is the actual filename.
102 $picture = "$td/stdin.hdr";
103 open(FHpic, ">$picture") or
104 die("Unable to write to file $picture\n");
105 # Input is from STDIN: Capture to file.
106 while (<>) {
107 print FHpic;
108 }
109 close(FHpic);
110
111 if ($cpict eq '-') {
112 $cpict = "$td/stdin.hdr";
113 }
114 }
115
116 # Find a good scale for auto mode.
117 if ($scale =~ m/[aA].*/) {
118 my @histo = split(/\s/, `phisto $picture| tail -2`);
119 # e.g. $ phisto tests/richmond.hdr| tail -2
120 # 3.91267 14
121 # 3.94282 6
122 my $LogLmax = $histo[0];
123 $scale = $mult / 179 * 10**$LogLmax;
124 }
125
126 my $pc0 = "$td/pc0.cal";
127 open(FHpc0, ">$pc0");
128 print FHpc0 <<EndOfPC0;
129 PI : 3.14159265358979323846 ;
130 scale : $scale ;
131 mult : $mult ;
132 ndivs : $ndivs ;
133 gamma : 2.2;
134
135 or(a,b) : if(a,a,b);
136 EPS : 1e-7;
137 neq(a,b) : if(a-b-EPS,1,b-a-EPS);
138 btwn(a,x,b) : if(a-x,-1,b-x);
139 clip(x) : if(x-1,1,if(x,x,0));
140 frac(x) : x - floor(x);
141 boundary(a,b) : neq(floor(ndivs*a+.5),floor(ndivs*b+.5));
142
143 spec_red(x) = 1.6*x - .6;
144 spec_grn(x) = if(x-.375, 1.6-1.6*x, 8/3*x);
145 spec_blu(x) = 1 - 8/3*x;
146
147 pm3d_red(x) = sqrt(x) ^ gamma;
148 pm3d_grn(x) = (x*x*x) ^ gamma;
149 pm3d_blu(x) = clip(sin(2*PI*clip(x))) ^ gamma;
150
151 hot_red(x) = clip(3*x) ^ gamma;
152 hot_grn(x) = clip(3*x - 1) ^ gamma;
153 hot_blu(x) = clip(3*x - 2) ^ gamma;
154
155 eco_red(x) = clip(2*x) ^ gamma;
156 eco_grn(x) = clip(2*(x-0.5)) ^ gamma;
157 eco_blu(x) = clip(2*(0.5-x)) ^ gamma;
158
159 interp_arr2(i,x,f):(i+1-x)*f(i)+(x-i)*f(i+1);
160 interp_arr(x,f):if(x-1,if(f(0)-x,interp_arr2(floor(x),x,f),f(f(0))),f(1));
161
162 def_redp(i):select(i,0.18848,0.05468174,
163 0.00103547,8.311144e-08,7.449763e-06,0.0004390987,0.001367254,
164 0.003076,0.01376382,0.06170773,0.1739422,0.2881156,0.3299725,
165 0.3552663,0.372552,0.3921184,0.4363976,0.6102754,0.7757267,
166 0.9087369,1,1,0.9863);
167 def_red(x):interp_arr(x/0.0454545+1,def_redp);
168
169 def_grnp(i):select(i,0.0009766,2.35501e-05,
170 0.0008966244,0.0264977,0.1256843,0.2865799,0.4247083,0.4739468,
171 0.4402732,0.3671876,0.2629843,0.1725325,0.1206819,0.07316644,
172 0.03761026,0.01612362,0.004773749,6.830967e-06,0.00803605,
173 0.1008085,0.3106831,0.6447838,0.9707);
174 def_grn(x):interp_arr(x/0.0454545+1,def_grnp);
175
176 def_blup(i):select(i,0.2666,0.3638662,0.4770437,
177 0.5131397,0.5363797,0.5193677,0.4085123,0.1702815,0.05314236,
178 0.05194055,0.08564082,0.09881395,0.08324373,0.06072902,
179 0.0391076,0.02315354,0.01284458,0.005184709,0.001691774,
180 2.432735e-05,1.212949e-05,0.006659406,0.02539);
181 def_blu(x):interp_arr(x/0.0454545+1,def_blup);
182
183 isconta = if(btwn(0,v,1),or(boundary(vleft,vright),boundary(vabove,vbelow)),-1);
184 iscontb = if(btwn(0,v,1),btwn(.4,frac(ndivs*v),.6),-1);
185
186 ra = 0;
187 ga = 0;
188 ba = 0;
189
190 in = 1;
191
192 ro = if(in,clip($redv),ra);
193 go = if(in,clip($grnv),ga);
194 bo = if(in,clip($bluv),ba);
195 EndOfPC0
196 close FHpc0;
197
198 my $pc1 = "$td/pc1.cal";
199 open(FHpc1, ">$pc1");
200 print FHpc1 <<EndOfPC1;
201 norm : mult/scale/le(1);
202
203 v = map(li(1)*norm);
204
205 vleft = map(li(1,-1,0)*norm);
206 vright = map(li(1,1,0)*norm);
207 vabove = map(li(1,0,1)*norm);
208 vbelow = map(li(1,0,-1)*norm);
209
210 map(x) = x;
211
212 ra = ri(nfiles);
213 ga = gi(nfiles);
214 ba = bi(nfiles);
215 EndOfPC1
216 close FHpc1;
217
218 my $pc0args = "-f $pc0";
219 my $pc1args = "-f $pc1";
220
221 if ($showpal == 1) {
222 my $pc = "pcompos -a 1";
223 foreach my $pal (@palettes) {
224 my $fcimg = "$td/$pal.hdr";
225 my $lbimg = "$td/${pal}_label.hdr";
226 system "psign -cb 0 0 0 -cf 1 1 1 -h 20 $pal > $lbimg";
227
228 my $cmd = qq[pcomb $pc0args -e "v=x/256"];
229 $cmd .= qq[ -e "ro=clip(${pal}_red(v));go=clip(${pal}_grn(v));bo=clip(${pal}_blu(v))"];
230 $cmd .= qq[ -x 256 -y 30 > $fcimg];
231 system "$cmd";
232 $pc .= " $fcimg $lbimg";
233 }
234 system "$pc";
235 exit 0;
236 }
237
238 # Contours
239 if ($docont ne '') {
240 # -cl -> $docont = a
241 # -cb -> $docont = b
242 $pc0args .= qq[ -e "in=iscont$docont"];
243 } elsif ($doposter == 1) {
244 # -cp -> $doposter = 1
245 $pc0args .= qq[ -e "ro=${pal}_red(seg(v));go=${pal}_grn(seg(v));bo=${pal}_blu(seg(v))"];
246 $pc0args .= q[ -e "seg(x)=(floor(v*ndivs)+.5)/ndivs"];
247 }
248
249 if ($cpict eq '') {
250 $pc1args .= qq[ -e "ra=0;ga=0;ba=0"];
251 } elsif ($cpict eq $picture) {
252 $cpict = '';
253 }
254
255 # Logarithmic mapping
256 if ($decades > 0) {
257 $pc1args .= qq[ -e "map(x)=if(x-10^-$decades,log10(x)/$decades+1,0)"];
258 }
259
260 # Colours in the legend
261 my $scolpic = "$td/scol.hdr";
262
263 # Labels in the legend
264 my $slabpic = "$td/slab.hdr";
265 my $cmd;
266
267 if (($legwidth > 20) && ($legheight > 40)) {
268 # Legend: Create the text labels
269 my $sheight = floor($legheight / $ndivs + 0.5);
270 $legheight = $sheight * $ndivs;
271 $loff = floor($loff * $sheight + 0.5);
272 my $text = "$label";
273 for (my $i=0; $i<$ndivs; $i++) {
274 my $imap = ($ndivs - 0.5 - $i) / $ndivs;
275 my $value = $scale;
276 if ($decades > 0) {
277 $value *= 10**(($imap - 1) * $decades);
278 } else {
279 $value *= $imap;
280 }
281
282 # Have no more than 3 decimal places
283 $value =~ s/(\.[0-9]{3})[0-9]*/$1/;
284 $text .= "\n$value";
285 }
286 open PSIGN, "| psign -s -.15 -cf 1 1 1 -cb 0 0 0 -h $sheight > $slabpic";
287 print PSIGN "$text\n";
288 close PSIGN;
289
290 # Legend: Create the background colours
291 $cmd = qq[pcomb $pc0args];
292 $cmd .= q[ -e "v=(y+.5)/yres;vleft=v;vright=v"];
293 $cmd .= q[ -e "vbelow=(y-.5)/yres;vabove=(y+1.5)/yres"];
294 $cmd .= qq[ -x $legwidth -y $legheight > $scolpic];
295 system $cmd;
296 } else {
297 # Legend is too small to be legible. Don't bother doing one.
298 $legwidth = 0;
299 $legheight = 0;
300 $loff = 0;
301
302 # Create dummy colour scale and legend labels so we don't
303 # need to change the final command line.
304 open(FHscolpic, ">$scolpic");
305 print FHscolpic "\n-Y 1 +X 1\naaa\n";
306 close(FHscolpic);
307 open(FHslabpic, ">$slabpic");
308 print FHslabpic "\n-Y 1 +X 1\naaa\n";
309 close(FHslabpic);
310 }
311
312 # Legend: Invert the text labels (for dropshadow)
313 my $slabinvpic = "$td/slabinv.hdr";
314 $cmd = qq[pcomb -e "lo=1-gi(1)" $slabpic > $slabinvpic];
315 system $cmd;
316
317 my $loff1 = $loff - 1;
318
319 # Command line without extrema
320 $cmd = qq[pcomb $pc0args $pc1args "$picture"];
321 $cmd .= qq[ "$cpict"] if ($cpict);
322 $cmd .= qq[ | pcompos $scolpic 0 0 +t .1 $slabinvpic 2 $loff1];
323 $cmd .= qq[ -t .5 $slabpic 0 $loff - $legwidth 0];
324
325 if ($doextrem == 1) {
326 # Get min/max image luminance
327 my $cmd1 = 'pextrem -o ' . $picture;
328 my $retval = `$cmd1`;
329 # e.g.
330 # x y r g b
331 # 193 207 3.070068e-02 3.118896e-02 1.995850e-02
332 # 211 202 1.292969e+00 1.308594e+00 1.300781e+00
333
334 my @extrema = split(/\s/, $retval);
335 my ($lxmin, $ymin, $rmin, $gmin, $bmin, $lxmax, $ymax, $rmax, $gmax, $bmax) = @extrema;
336 $lxmin += $legwidth;
337 $lxmax += $legwidth;
338
339 # Weighted average of R,G,B
340 my $minpos = "$lxmin $ymin";
341 my $minval = ($rmin * .27 + $gmin * .67 + $bmin * .06) * $mult;
342 $minval =~ s/(\.[0-9]{3})[0-9]*/$1/;
343 my $maxval = ($rmax * .27 + $gmax * .67 + $bmax * .06) * $mult;
344 $maxval =~ s/(\.[0-9]{3})[0-9]*/$1/;
345
346 # Create the labels for min/max intensity
347 my $minvpic = "$td/minv.hdr";
348 system "psign -s -.15 -a 2 -h 16 $minval > $minvpic";
349 my $maxvpic = "$td/maxv.hdr";
350 system "psign -s -.15 -a 2 -h 16 $maxval > $maxvpic";
351
352 # Add extrema labels to command line
353 $cmd .= qq[ $minvpic $minpos $maxvpic $lxmax $ymax];
354 }
355
356 # Process image and combine with legend
357 system "$cmd";
358
359 #EOF
