root/radiance/ray/src/px/falsecolor.pl
Revision: 2.2
Committed: Tue Jan 4 17:00:02 2011 UTC (13 years, 5 months ago) by greg
Fixed problem with zero label width/height
1 #!/usr/bin/perl -w
2 # RCSid $Id: falsecolor.pl,v 2.1 2010/10/05 00:59:39 greg Exp $
3
4 use strict;
5 use File::Temp qw/ tempdir /;
6 use POSIX qw/ floor /;
7
8 my $mult = 179.0; # Multiplier. Default W/sr/m2 -> cd/m2
9 my $label = 'cd/m2'; # Units shown in legend
10 my $scale = 1000; # Top of the scale
11 my $decades = 0; # Default is linear mapping
12 my $redv = 'def_red(v)'; # Mapping function for R,G,B
13 my $grnv = 'def_grn(v)';
14 my $bluv = 'def_blu(v)';
15 my $ndivs = 8; # Number of lines in legend
16 my $picture = '-';
17 my $cpict = '';
18 my $legwidth = 100; # Legend width and height
19 my $legheight = 200;
20 my $docont = ''; # Contours
21 my $loff = 0; # Offset for drop-shadow
22 my $doextrem = 0; # Don't mark extrema
23 my $needfile = 0;
24
25 while ($#ARGV >= 0) {
26 # Options with qualifiers
27 if ("$ARGV[0]" eq '-lw') { # Legend width
28 $legwidth = $ARGV[1];
29 shift @ARGV;
30 } elsif ("$ARGV[0]" eq '-lh') { # Legend height
31 $legheight = $ARGV[1];
32 shift @ARGV;
33 } elsif ("$ARGV[0]" eq '-m') { # Multiplier
34 $mult = $ARGV[1];
35 shift @ARGV;
36 } elsif ("$ARGV[0]" eq '-s') { # Scale
37 $scale = $ARGV[1];
38 shift @ARGV;
39 if ($scale =~ m/[aA].*/) {
40 $needfile = 1;
41 }
42 } elsif ("$ARGV[0]" eq '-l') { # Label
43 $label = $ARGV[1];
44 shift @ARGV;
45 } elsif ("$ARGV[0]" eq '-log') { # Logarithmic mapping
46 $decades = $ARGV[1];
47 shift @ARGV;
48 } elsif ("$ARGV[0]" eq '-r') {
49 $redv = $ARGV[1];
50 shift @ARGV;
51 } elsif ("$ARGV[0]" eq '-g') {
52 $grnv = $ARGV[1];
53 shift @ARGV;
54 } elsif ("$ARGV[0]" eq '-b') {
55 $bluv = $ARGV[1];
56 shift @ARGV;
57 } elsif ("$ARGV[0]" eq '-pal') {
58 $redv = "$ARGV[1]_red(v)";
59 $grnv = "$ARGV[1]_grn(v)";
60 $bluv = "$ARGV[1]_blu(v)";
61 shift @ARGV;
62 } elsif ("$ARGV[0]" eq '-i') { # Image for intensity mapping
63 $picture = $ARGV[1];
64 shift @ARGV;
65 } elsif ("$ARGV[0]" eq '-p') { # Image for background
66 $cpict = $ARGV[1];
67 shift @ARGV;
68 } elsif ("$ARGV[0]" eq '-ip' || "$ARGV[0]" eq '-pi') {
69 $picture = $ARGV[1];
70 $cpict = $ARGV[1];
71 shift @ARGV;
72 } elsif ("$ARGV[0]" eq '-n') { # Number of contour lines
73 $ndivs = $ARGV[1];
74 shift @ARGV;
75
76 # Switches
77 } elsif ("$ARGV[0]" eq '-cl') { # Contour lines
78 $docont = 'a';
79 $loff = 12;
80 } elsif ("$ARGV[0]" eq '-cb') { # Contour bands
81 $docont = 'b';
82 $loff = 13;
83 } elsif ("$ARGV[0]" eq '-e') {
84 $doextrem = 1;
85 $needfile = 1;
86
87 # Oops! Illegal option
88 } else {
89 die("bad option \"$ARGV[0]\"\n");
90 }
91 shift @ARGV;
92 }
93
94 # Temporary directory. Will be removed upon successful program exit.
95 my $td = tempdir( CLEANUP => 1 );
96
97 if ($needfile == 1 && $picture eq '-') {
98 $picture = $td . '/' . $picture;
99 open(FHpic, ">$picture") or
100 die("Unable to write to file $picture\n");
101 close(FHpic);
102 }
103
104 # Find a good scale for auto mode.
105 if ($scale =~ m/[aA].*/) {
106 my $LogLmax = `phisto $picture| tail -2| sed -n '1s/[0-9]*\$//p'`;
107 $scale = $mult / 179 * 10**$LogLmax;
108 }
109
110 my $pc0 = $td . '/pc0.cal';
111 open(FHpc0, ">$pc0");
112 print FHpc0 <<EndOfPC0;
113 PI : 3.14159265358979323846 ;
114 scale : $scale ;
115 mult : $mult ;
116 ndivs : $ndivs ;
117 gamma : 2.2;
118
119 or(a,b) : if(a,a,b);
120 EPS : 1e-7;
121 neq(a,b) : if(a-b-EPS,1,b-a-EPS);
122 btwn(a,x,b) : if(a-x,-1,b-x);
123 clip(x) : if(x-1,1,if(x,x,0));
124 frac(x) : x - floor(x);
125 boundary(a,b) : neq(floor(ndivs*a+.5),floor(ndivs*b+.5));
126
127 spec_red(x) = 1.6*x - .6;
128 spec_grn(x) = if(x-.375, 1.6-1.6*x, 8/3*x);
129 spec_blu(x) = 1 - 8/3*x;
130
131 pm3d_red(x) = sqrt(x) ^ gamma;
132 pm3d_grn(x) = x*x*x ^ gamma;
133 pm3d_blu(x) = clip(sin(2*PI*x)) ^ gamma;
134
135 hot_red(x) = clip(3*x) ^ gamma;
136 hot_grn(x) = clip(3*x - 1) ^ gamma;
137 hot_blu(x) = clip(3*x - 2) ^ gamma;
138
139 interp_arr2(i,x,f):(i+1-x)*f(i)+(x-i)*f(i+1);
140 interp_arr(x,f):if(x-1,if(f(0)-x,interp_arr2(floor(x),x,f),f(f(0))),f(1));
141
142 def_redp(i):select(i,0.18848,0.05468174,
143 0.00103547,8.311144e-08,7.449763e-06,0.0004390987,0.001367254,
144 0.003076,0.01376382,0.06170773,0.1739422,0.2881156,0.3299725,
145 0.3552663,0.372552,0.3921184,0.4363976,0.6102754,0.7757267,
146 0.9087369,1,1,0.9863);
147 def_red(x):interp_arr(x/0.0454545+1,def_redp);
148
149 def_grnp(i):select(i,0.0009766,2.35501e-05,
150 0.0008966244,0.0264977,0.1256843,0.2865799,0.4247083,0.4739468,
151 0.4402732,0.3671876,0.2629843,0.1725325,0.1206819,0.07316644,
152 0.03761026,0.01612362,0.004773749,6.830967e-06,0.00803605,
153 0.1008085,0.3106831,0.6447838,0.9707);
154 def_grn(x):interp_arr(x/0.0454545+1,def_grnp);
155
156 def_blup(i):select(i,0.2666,0.3638662,0.4770437,
157 0.5131397,0.5363797,0.5193677,0.4085123,0.1702815,0.05314236,
158 0.05194055,0.08564082,0.09881395,0.08324373,0.06072902,
159 0.0391076,0.02315354,0.01284458,0.005184709,0.001691774,
160 2.432735e-05,1.212949e-05,0.006659406,0.02539);
161 def_blu(x):interp_arr(x/0.0454545+1,def_blup);
162
163 isconta = if(btwn(0,v,1),or(boundary(vleft,vright),boundary(vabove,vbelow)),-1);
164 iscontb = if(btwn(0,v,1),btwn(.4,frac(ndivs*v),.6),-1);
165
166 ra = 0;
167 ga = 0;
168 ba = 0;
169
170 in = 1;
171
172 ro = if(in,clip($redv),ra);
173 go = if(in,clip($grnv),ga);
174 bo = if(in,clip($bluv),ba);
175 EndOfPC0
176
177 my $pc1 = $td . '/pc1.cal';
178 open(FHpc1, ">$pc1");
179 print FHpc1 <<EndOfPC1;
180 norm : mult/scale/le(1);
181
182 v = map(li(1)*norm);
183
184 vleft = map(li(1,-1,0)*norm);
185 vright = map(li(1,1,0)*norm);
186 vabove = map(li(1,0,1)*norm);
187 vbelow = map(li(1,0,-1)*norm);
188
189 map(x) = x;
190
191 ra = ri(nfiles);
192 ga = gi(nfiles);
193 ba = bi(nfiles);
194 EndOfPC1
195
196 my $pc0args = "-f $pc0";
197 my $pc1args = "-f $pc1";
198
199 # Contour lines or bands
200 if ($docont ne '') {
201 $pc0args .= " -e 'in=iscont$docont'";
202 }
203
204 if ($cpict eq '') {
205 $pc1args .= " -e 'ra=0;ga=0;ba=0'";
206 } elsif ($cpict eq $picture) {
207 $cpict = '';
208 }
209
210 # Logarithmic mapping
211 if ($decades > 0) {
212 $pc1args .= " -e 'map(x)=if(x-10^-$decades,log10(x)/$decades+1,0)'";
213 }
214
215 # Colours in the legend
216 my $scolpic = $td . '/scol.hdr';
217 # Labels in the legend
218 my $slabpic = $td . '/slab.hdr';
219 my $cmd;
220
221 if ($legwidth > 20 && $legheight > 40) {
222 # Legend: Create the background colours
223 $cmd = "pcomb $pc0args -e 'v=(y+.5)/yres;vleft=v;vright=v'";
224 $cmd .= " -e 'vbelow=(y-.5)/yres;vabove=(y+1.5)/yres'";
225 $cmd .= " -x $legwidth -y $legheight > $scolpic";
226 system $cmd;
227
228 # Legend: Create the text labels
229 my $sheight = floor($legheight / $ndivs + 0.5);
230 my $text = "$label";
231 my $value;
232 my $i;
233 for ($i=0; $i<$ndivs; $i++) {
234 my $imap = ($ndivs - 0.5 - $i) / $ndivs;
235 if ($decades > 0) {
236 $value = $scale * 10**(($imap - 1) * $decades);
237 } else {
238 $value = $scale * $imap;
239 }
240 # Have no more than 3 decimal places
241 $value =~ s/(\.[0-9]{3})[0-9]*/$1/;
242 $text .= "\n$value";
243 }
244 $cmd = "echo '$text' | psign -s -.15 -cf 1 1 1 -cb 0 0 0";
245 $cmd .= " -h $sheight > $slabpic";
246 system $cmd;
247 } else {
248 # Legend is too small to be legible. Don't bother doing one.
249 $legwidth = 0;
250 $legheight = 0;
251 open(FHscolpic, ">$scolpic");
252 print FHscolpic "\n-Y 1 +X 1\naaa\n";
253 close(FHscolpic);
254 open(FHslabpic, ">$slabpic");
255 print FHslabpic "\n-Y 1 +X 1\naaa\n";
256 close(FHslabpic);
257 }
258
259 my $loff1 = $loff - 1;
260 # Command line without extrema
261 $cmd = "pcomb $pc0args $pc1args $picture $cpict";
262 $cmd .= "| pcompos $scolpic 0 0 +t .1";
263 $cmd .= " \"\!pcomb -e 'lo=1-gi(1)' $slabpic\" 2 $loff1";
264 $cmd .= " -t .5 $slabpic 0 $loff - $legwidth 0";
265
266 if ($doextrem == 1) {
267 # Get min/max image luminance
268 my $cmd1 = 'pextrem -o ' . $picture;
269 my $retval = `$cmd1`;
270 # e.g.
271 # x y r g b
272 # 193 207 3.070068e-02 3.118896e-02 1.995850e-02
273 # 211 202 1.292969e+00 1.308594e+00 1.300781e+00
274
275 my @extrema = split(/\s/, $retval);
276 my $lxmin = $extrema[0] + $legwidth;
277 my $ymin = $extrema[1];
278 my $rmin = $extrema[2];
279 my $gmin = $extrema[3];
280 my $bmin = $extrema[4];
281 my $lxmax = $extrema[5] + $legwidth;
282 my $ymax = $extrema[6];
283 my $rmax = $extrema[7];
284 my $gmax = $extrema[8];
285 my $bmax = $extrema[9];
286
287 # Weighted average of R,G,B
288 my $minpos = "$lxmin $ymin";
289 my $minval = ($rmin * .27 + $gmin * .67 + $bmin * .06) * $mult;
290 $minval =~ s/(\.[0-9]{3})[0-9]*/$1/;
291 my $maxpos = "$lxmax $ymax";
292 my $maxval = ($rmax * .27 + $gmax * .67 + $bmax * .06) * $mult;
293 $maxval =~ s/(\.[0-9]{3})[0-9]*/$1/;
294
295 # Create the labels for min/max intensity
296 my $minvpic = $td . '/minv.hdr';
297 $cmd1 = "psign -s -.15 -a 2 -h 16 $minval > $minvpic";
298 system $cmd1;
299 my $maxvpic = $td . '/maxv.hdr';
300 $cmd1 = "psign -s -.15 -a 2 -h 16 $maxval > $maxvpic";
301 system $cmd1;
302
303 # Add extrema labels to command line
304 $cmd .= " $minvpic $minpos $maxvpic $maxpos";
305 }
306
307 # Process image and combine with legend
308 system "$cmd";
309
310 #EOF
