root/radiance/ray/src/px/falsecolor.csh
Revision: 2.20
Committed: Wed May 27 15:38:29 2009 UTC (14 years, 11 months ago) by greg
Content type: application/x-csh
Changes since 2.19: +8 -4 lines
Aesthetic improvements to color scale code.
# User Rev Content
1 greg 2.8 #!/bin/csh -fe
2 greg 2.20 # RCSid: $Id: falsecolor.csh,v 2.19 2008/11/10 19:08:19 greg Exp $
3 greg 1.1 #
4     # Create false color image with legend
5     #
6 greg 2.9 # Added user-definable legend 2004/01/20 Rob Guglielmetti
7
8 greg 1.1 onintr quit
9 greg 2.18 set td=`mktemp -d /tmp/fc.XXXXXX`
10 greg 1.9 set mult=179
11 greg 1.1 set label=Nits
12     set scale=1000
13 greg 1.3 set decades=0
14 greg 2.13 set redv='def_red(v)'
15     set grnv='def_grn(v)'
16     set bluv='def_blu(v)'
17 greg 1.1 set ndivs=8
18     set picture='-'
19     set cpict=
20 greg 2.4 set loff=0
21 greg 1.5 set legwidth=100
22     set legheight=200
23 greg 1.1 while ($#argv > 0)
24     switch ($argv[1])
25 greg 2.9 case -lw:
26     shift argv
27     set legwidth="$argv[1]"
28     breaksw
29     case -lh:
30     shift argv
31     set legheight="$argv[1]"
32     breaksw
33 greg 1.1 case -m:
34     shift argv
35     set mult="$argv[1]"
36     breaksw
37     case -s:
38     shift argv
39     set scale="$argv[1]"
40 greg 2.16 if ("$scale" =~ [aA]*) set needfile
41 greg 1.1 breaksw
42     case -l:
43     shift argv
44     set label="$argv[1]"
45     breaksw
46 greg 1.3 case -log:
47     shift argv
48     set decades=$argv[1]
49     breaksw
50 greg 1.1 case -r:
51     shift argv
52     set redv="$argv[1]"
53     breaksw
54     case -g:
55     shift argv
56     set grnv="$argv[1]"
57     breaksw
58     case -b:
59     shift argv
60     set bluv="$argv[1]"
61     breaksw
62 greg 2.16 case -spec:
63 greg 2.20 set redv='old_red(v)'
64     set grnv='old_grn(v)'
65     set bluv='old_blu(v)'
66 greg 2.16 breaksw
67 greg 1.1 case -i:
68     shift argv
69     set picture="$argv[1]"
70     breaksw
71     case -p:
72     shift argv
73     set cpict="$argv[1]"
74     breaksw
75     case -ip:
76     case -pi:
77 greg 1.2 shift argv
78 greg 1.1 set picture="$argv[1]"
79     set cpict="$argv[1]"
80     breaksw
81     case -cl:
82     set docont=a
83 greg 2.5 set loff=12
84 greg 1.1 breaksw
85     case -cb:
86     set docont=b
87 greg 2.5 set loff=13
88 greg 1.1 breaksw
89 greg 2.3 case -e:
90     set doextrem
91     set needfile
92     breaksw
93 greg 1.1 case -n:
94 greg 1.2 shift argv
95 greg 1.1 set ndivs="$argv[1]"
96 greg 1.2 breaksw
97 greg 1.1 default:
98 greg 2.11 echo bad option "'$argv[1]'"
99 greg 1.1 exit 1
100     endsw
101     shift argv
102     end
103 greg 2.16 if ($?needfile && "$picture" == '-') then
104     cat > $td/picture
105     set picture=$td/picture
106     endif
107     if ("$scale" =~ [aA]*) then
108     set LogLmax=`phisto $picture | tail -2 | sed -n '1s/ [0-9]*$//p'`
109     set scale=`ev "$mult/179*10^$LogLmax"`
110     endif
111 greg 1.5 cat > $td/pc0.cal <<_EOF_
112 greg 1.8 PI : 3.14159265358979323846 ;
113 greg 1.1 scale : $scale ;
114     mult : $mult ;
115     ndivs : $ndivs ;
116
117     or(a,b) : if(a,a,b);
118     EPS : 1e-7;
119     neq(a,b) : if(a-b-EPS,1,b-a-EPS);
120 greg 1.7 btwn(a,x,b) : if(a-x,-1,b-x);
121 greg 1.5 clip(x) : if(x-1,1,if(x,x,0));
122 greg 1.1 frac(x) : x - floor(x);
123 greg 2.2 boundary(a,b) : neq(floor(ndivs*a+.5),floor(ndivs*b+.5));
124 greg 1.1
125 greg 2.20 old_red(x) = 1.6*x - .6;
126     old_grn(x) = if(x-.375, 1.6-1.6*x, 8/3*x);
127     old_blu(x) = 1 - 8/3*x;
128
129 greg 2.13 interp_arr2(i,x,f):(i+1-x)*f(i)+(x-i)*f(i+1);
130     interp_arr(x,f):if(x-1,if(f(0)-x,interp_arr2(floor(x),x,f),f(f(0))),f(1));
131     def_redp(i):select(i,0.18848,0.05468174,
132 greg 2.15 0.00103547,8.311144e-08,7.449763e-06,0.0004390987,0.001367254,
133     0.003076,0.01376382,0.06170773,0.1739422,0.2881156,0.3299725,
134     0.3552663,0.372552,0.3921184,0.4363976,0.6102754,0.7757267,
135     0.9087369,1,1,0.9863);
136 greg 2.13 def_red(x):interp_arr(x/0.0454545+1,def_redp);
137 greg 2.14 def_grnp(i):select(i,0.0009766,2.35501e-05,
138 greg 2.15 0.0008966244,0.0264977,0.1256843,0.2865799,0.4247083,0.4739468,
139     0.4402732,0.3671876,0.2629843,0.1725325,0.1206819,0.07316644,
140     0.03761026,0.01612362,0.004773749,6.830967e-06,0.00803605,
141     0.1008085,0.3106831,0.6447838,0.9707);
142 greg 2.13 def_grn(x):interp_arr(x/0.0454545+1,def_grnp);
143     def_blup(i):select(i,0.2666,0.3638662,0.4770437,
144 greg 2.15 0.5131397,0.5363797,0.5193677,0.4085123,0.1702815,0.05314236,
145     0.05194055,0.08564082,0.09881395,0.08324373,0.06072902,
146     0.0391076,0.02315354,0.01284458,0.005184709,0.001691774,
147     2.432735e-05,1.212949e-05,0.006659406,0.02539);
148 greg 2.13 def_blu(x):interp_arr(x/0.0454545+1,def_blup);
149
150 greg 1.6 isconta = if(btwn(0,v,1),or(boundary(vleft,vright),boundary(vabove,vbelow)),-1);
151 greg 1.5 iscontb = if(btwn(0,v,1),btwn(.4,frac(ndivs*v),.6),-1);
152 greg 1.1
153 greg 1.5 ra = 0;
154     ga = 0;
155     ba = 0;
156
157     in = 1;
158 greg 2.13
159     ro = if(in,clip($redv),ra);
160     go = if(in,clip($grnv),ga);
161     bo = if(in,clip($bluv),ba);
162 greg 1.5 _EOF_
163     cat > $td/pc1.cal <<_EOF_
164     norm : mult/scale/le(1);
165
166 greg 1.4 v = map(li(1)*norm);
167 greg 1.5
168 greg 1.4 vleft = map(li(1,-1,0)*norm);
169     vright = map(li(1,1,0)*norm);
170     vabove = map(li(1,0,1)*norm);
171     vbelow = map(li(1,0,-1)*norm);
172 greg 1.1
173 greg 1.5 map(x) = x;
174 greg 1.1
175     ra = ri(nfiles);
176     ga = gi(nfiles);
177     ba = bi(nfiles);
178     _EOF_
179 greg 1.5 set pc0args=(-f $td/pc0.cal)
180     set pc1args=(-f $td/pc1.cal)
181 greg 1.1 if ($?docont) then
182 greg 1.5 set pc0args=($pc0args -e "in=iscont$docont")
183 greg 1.1 endif
184     if ("$cpict" == "") then
185 greg 1.5 set pc1args=($pc1args -e 'ra=0;ga=0;ba=0')
186 greg 1.1 else if ("$cpict" == "$picture") then
187     set cpict=
188     endif
189 greg 2.6 if ("$decades" != "0") then
190 greg 1.5 set pc1args=($pc1args -e "map(x)=if(x-10^-$decades,log10(x)/$decades+1,0)")
191 greg 1.3 set imap="imap(y)=10^((y-1)*$decades)"
192     else
193     set imap="imap(y)=y"
194     endif
195 greg 2.9 if ( $legwidth > 20 && $legheight > 40 ) then
196 greg 1.5 pcomb $pc0args -e 'v=(y+.5)/yres;vleft=v;vright=v' \
197     -e 'vbelow=(y-.5)/yres;vabove=(y+1.5)/yres' \
198 greg 2.19 -x $legwidth -y $legheight > $td/scol.hdr
199 greg 2.10 ( echo "$label"; cnt $ndivs \
200 greg 1.3 | rcalc -e '$1='"($scale)*imap(($ndivs-.5-"'$1'")/$ndivs)" \
201 greg 2.7 -e "$imap" | sed -e 's/\(\.[0-9][0-9][0-9]\)[0-9]*/\1/' ) \
202 greg 2.3 | psign -s -.15 -cf 1 1 1 -cb 0 0 0 \
203 greg 2.19 -h `ev "floor($legheight/$ndivs+.5)"` > $td/slab.hdr
204 greg 2.9 else
205     set legwidth=0
206     set legheight=0
207 greg 2.19 (echo "" ; echo "-Y 1 +X 1" ; echo "aaa" ) > $td/scol.hdr
208     cp $td/scol.hdr $td/slab.hdr
209 greg 2.9 endif
210 greg 2.3 if ( $?doextrem ) then
211     pextrem -o $picture > $td/extrema
212     set minpos=`sed 2d $td/extrema | rcalc -e '$2=$2;$1=$1+'"$legwidth"`
213 greg 2.7 set minval=`rcalc -e '$1=($3*.27+$4*.67+$5*.06)*'"$mult" $td/extrema | sed -e 2d -e 's/\(\.[0-9][0-9][0-9]\)[0-9]*/\1/'`
214 greg 2.3 set maxpos=`sed 1d $td/extrema | rcalc -e '$2=$2;$1=$1+'"$legwidth"`
215 greg 2.7 set maxval=`rcalc -e '$1=($3*.27+$4*.67+$5*.06)*'"$mult" $td/extrema | sed -e 1d -e 's/\(\.[0-9][0-9][0-9]\)[0-9]*/\1/'`
216 greg 2.19 psign -s -.15 -a 2 -h 16 $minval > $td/minv.hdr
217     psign -s -.15 -a 2 -h 16 $maxval > $td/maxv.hdr
218 greg 2.3 pcomb $pc0args $pc1args $picture $cpict \
219 greg 2.19 | pcompos $td/scol.hdr 0 0 \
220     +t .1 "\!pcomb -e 'lo=1-gi(1)' $td/slab.hdr" \
221     `ev 2 $loff-1` -t .5 $td/slab.hdr 0 $loff \
222     - $legwidth 0 $td/minv.hdr $minpos $td/maxv.hdr $maxpos
223 greg 2.3 else
224     pcomb $pc0args $pc1args $picture $cpict \
225 greg 2.19 | pcompos $td/scol.hdr 0 0 \
226     +t .1 "\!pcomb -e 'lo=1-gi(1)' $td/slab.hdr" \
227     `ev 2 $loff-1` -t .5 $td/slab.hdr 0 $loff \
228 greg 2.13 - $legwidth 0
229 greg 2.3 endif
230 greg 1.1 quit:
231 greg 1.5 rm -rf $td
