root/radiance/ray/src/px/falsecolor.csh
Revision: 2.7
Committed: Thu Sep 5 13:02:58 1996 UTC (27 years, 8 months ago) by greg
Content type: application/x-csh
fixed up decimal placement somewhat
1 #!/bin/csh -f
2 # SCCSid "$SunId$ LBL"
3 #
4 # Create false color image with legend
5 #
6 set td=/usr/tmp/fc$$
7 onintr quit
8 set mult=179
9 set label=Nits
10 set scale=1000
11 set decades=0
12 set redv='1.6*v-.6'
13 set grnv='if(v-.375,1.6-1.6*v,8/3*v)'
14 set bluv='1-8/3*v'
15 set ndivs=8
16 set picture='-'
17 set cpict=
18 set loff=0
19 set legwidth=100
20 set legheight=200
21 while ($#argv > 0)
22 switch ($argv[1])
23 case -m:
24 shift argv
25 set mult="$argv[1]"
26 breaksw
27 case -s:
28 shift argv
29 set scale="$argv[1]"
30 breaksw
31 case -l:
32 shift argv
33 set label="$argv[1]"
34 breaksw
35 case -log:
36 shift argv
37 set decades=$argv[1]
38 breaksw
39 case -r:
40 shift argv
41 set redv="$argv[1]"
42 breaksw
43 case -g:
44 shift argv
45 set grnv="$argv[1]"
46 breaksw
47 case -b:
48 shift argv
49 set bluv="$argv[1]"
50 breaksw
51 case -i:
52 shift argv
53 set picture="$argv[1]"
54 breaksw
55 case -p:
56 shift argv
57 set cpict="$argv[1]"
58 breaksw
59 case -ip:
60 case -pi:
61 shift argv
62 set picture="$argv[1]"
63 set cpict="$argv[1]"
64 breaksw
65 case -cl:
66 set docont=a
67 set loff=12
68 breaksw
69 case -cb:
70 set docont=b
71 set loff=13
72 breaksw
73 case -e:
74 set doextrem
75 set needfile
76 breaksw
77 case -n:
78 shift argv
79 set ndivs="$argv[1]"
80 breaksw
81 default:
82 echo bad option "'$argv[1]'" >/dev/tty
83 exit 1
84 endsw
85 shift argv
86 end
87 mkdir $td
88 cat > $td/pc0.cal <<_EOF_
89 PI : 3.14159265358979323846 ;
90 scale : $scale ;
91 mult : $mult ;
92 ndivs : $ndivs ;
93
94 or(a,b) : if(a,a,b);
95 EPS : 1e-7;
96 neq(a,b) : if(a-b-EPS,1,b-a-EPS);
97 btwn(a,x,b) : if(a-x,-1,b-x);
98 clip(x) : if(x-1,1,if(x,x,0));
99 frac(x) : x - floor(x);
100 boundary(a,b) : neq(floor(ndivs*a+.5),floor(ndivs*b+.5));
101
102 isconta = if(btwn(0,v,1),or(boundary(vleft,vright),boundary(vabove,vbelow)),-1);
103 iscontb = if(btwn(0,v,1),btwn(.4,frac(ndivs*v),.6),-1);
104
105 ro = if(in,clip($redv),ra);
106 go = if(in,clip($grnv),ga);
107 bo = if(in,clip($bluv),ba);
108
109 ra = 0;
110 ga = 0;
111 ba = 0;
112
113 in = 1;
114 _EOF_
115 cat > $td/pc1.cal <<_EOF_
116 norm : mult/scale/le(1);
117
118 v = map(li(1)*norm);
119
120 vleft = map(li(1,-1,0)*norm);
121 vright = map(li(1,1,0)*norm);
122 vabove = map(li(1,0,1)*norm);
123 vbelow = map(li(1,0,-1)*norm);
124
125 map(x) = x;
126
127 ra = ri(nfiles);
128 ga = gi(nfiles);
129 ba = bi(nfiles);
130 _EOF_
131 set pc0args=(-f $td/pc0.cal)
132 set pc1args=(-f $td/pc1.cal)
133 if ($?docont) then
134 set pc0args=($pc0args -e "in=iscont$docont")
135 endif
136 if ("$cpict" == "") then
137 set pc1args=($pc1args -e 'ra=0;ga=0;ba=0')
138 else if ("$cpict" == "$picture") then
139 set cpict=
140 endif
141 if ($?needfile && "$picture" == '-') then
142 cat > $td/picture
143 set picture=$td/picture
144 endif
145 if ("$decades" != "0") then
146 set pc1args=($pc1args -e "map(x)=if(x-10^-$decades,log10(x)/$decades+1,0)")
147 set imap="imap(y)=10^((y-1)*$decades)"
148 else
149 set imap="imap(y)=y"
150 endif
151 pcomb $pc0args -e 'v=(y+.5)/yres;vleft=v;vright=v' \
152 -e 'vbelow=(y-.5)/yres;vabove=(y+1.5)/yres' \
153 -x $legwidth -y $legheight > $td/scol.pic
154 ( echo $label; cnt $ndivs \
155 | rcalc -e '$1='"($scale)*imap(($ndivs-.5-"'$1'")/$ndivs)" \
156 -e "$imap" | sed -e 's/\(\.[0-9][0-9][0-9]\)[0-9]*/\1/' ) \
157 | psign -s -.15 -cf 1 1 1 -cb 0 0 0 \
158 -h `ev "floor($legheight/$ndivs+.5)"` > $td/slab.pic
159 if ( $?doextrem ) then
160 pextrem -o $picture > $td/extrema
161 set minpos=`sed 2d $td/extrema | rcalc -e '$2=$2;$1=$1+'"$legwidth"`
162 set minval=`rcalc -e '$1=($3*.27+$4*.67+$5*.06)*'"$mult" $td/extrema | sed -e 2d -e 's/\(\.[0-9][0-9][0-9]\)[0-9]*/\1/'`
163 set maxpos=`sed 1d $td/extrema | rcalc -e '$2=$2;$1=$1+'"$legwidth"`
164 set maxval=`rcalc -e '$1=($3*.27+$4*.67+$5*.06)*'"$mult" $td/extrema | sed -e 1d -e 's/\(\.[0-9][0-9][0-9]\)[0-9]*/\1/'`
165 psign -s -.15 -a 2 -h 16 $minval > $td/minv.pic
166 psign -s -.15 -a 2 -h 16 $maxval > $td/maxv.pic
167 pcomb $pc0args $pc1args $picture $cpict \
168 | pcompos $td/scol.pic 0 0 -t .2 $td/slab.pic 0 $loff \
169 - $legwidth 0 $td/minv.pic $minpos $td/maxv.pic $maxpos
170 else
171 pcomb $pc0args $pc1args $picture $cpict \
172 | pcompos $td/scol.pic 0 0 -t .2 $td/slab.pic 0 $loff - $legwidth 0
173 endif
174 quit:
175 rm -rf $td
