1 |
#!/bin/csh -fe |
2 |
# RCSid: $Id: falsecolor.csh,v 2.13 2005/11/12 06:14:51 greg Exp $ |
3 |
4 |
# Create false color image with legend |
5 |
6 |
# Added user-definable legend 2004/01/20 Rob Guglielmetti |
7 |
8 |
set td=/tmp/fc$$ |
9 |
onintr quit |
10 |
set mult=179 |
11 |
set label=Nits |
12 |
set scale=1000 |
13 |
set decades=0 |
14 |
# set redv='1.6*v-.6' |
15 |
# set grnv='if(v-.375,1.6-1.6*v,8/3*v)' |
16 |
# set bluv='1-8/3*v' |
17 |
set redv='def_red(v)' |
18 |
set grnv='def_grn(v)' |
19 |
set bluv='def_blu(v)' |
20 |
set ndivs=8 |
21 |
set picture='-' |
22 |
set cpict= |
23 |
set loff=0 |
24 |
set legwidth=100 |
25 |
set legheight=200 |
26 |
while ($#argv > 0) |
27 |
switch ($argv[1]) |
28 |
case -lw: |
29 |
shift argv |
30 |
set legwidth="$argv[1]" |
31 |
breaksw |
32 |
case -lh: |
33 |
shift argv |
34 |
set legheight="$argv[1]" |
35 |
breaksw |
36 |
case -m: |
37 |
shift argv |
38 |
set mult="$argv[1]" |
39 |
breaksw |
40 |
case -s: |
41 |
shift argv |
42 |
set scale="$argv[1]" |
43 |
breaksw |
44 |
case -l: |
45 |
shift argv |
46 |
set label="$argv[1]" |
47 |
breaksw |
48 |
case -log: |
49 |
shift argv |
50 |
set decades=$argv[1] |
51 |
breaksw |
52 |
case -r: |
53 |
shift argv |
54 |
set redv="$argv[1]" |
55 |
breaksw |
56 |
case -g: |
57 |
shift argv |
58 |
set grnv="$argv[1]" |
59 |
breaksw |
60 |
case -b: |
61 |
shift argv |
62 |
set bluv="$argv[1]" |
63 |
breaksw |
64 |
case -i: |
65 |
shift argv |
66 |
set picture="$argv[1]" |
67 |
breaksw |
68 |
case -p: |
69 |
shift argv |
70 |
set cpict="$argv[1]" |
71 |
breaksw |
72 |
case -ip: |
73 |
case -pi: |
74 |
shift argv |
75 |
76 |
77 |
breaksw |
78 |
case -cl: |
79 |
set docont=a |
80 |
set loff=12 |
81 |
breaksw |
82 |
case -cb: |
83 |
set docont=b |
84 |
set loff=13 |
85 |
breaksw |
86 |
case -e: |
87 |
set doextrem |
88 |
set needfile |
89 |
breaksw |
90 |
case -n: |
91 |
shift argv |
92 |
set ndivs="$argv[1]" |
93 |
breaksw |
94 |
default: |
95 |
echo bad option "'$argv[1]'" |
96 |
exit 1 |
97 |
endsw |
98 |
shift argv |
99 |
end |
100 |
mkdir $td |
101 |
cat > $td/pc0.cal <<_EOF_ |
102 |
PI : 3.14159265358979323846 ; |
103 |
scale : $scale ; |
104 |
mult : $mult ; |
105 |
ndivs : $ndivs ; |
106 |
107 |
or(a,b) : if(a,a,b); |
108 |
EPS : 1e-7; |
109 |
neq(a,b) : if(a-b-EPS,1,b-a-EPS); |
110 |
btwn(a,x,b) : if(a-x,-1,b-x); |
111 |
clip(x) : if(x-1,1,if(x,x,0)); |
112 |
frac(x) : x - floor(x); |
113 |
boundary(a,b) : neq(floor(ndivs*a+.5),floor(ndivs*b+.5)); |
114 |
115 |
interp_arr2(i,x,f):(i+1-x)*f(i)+(x-i)*f(i+1); |
116 |
interp_arr(x,f):if(x-1,if(f(0)-x,interp_arr2(floor(x),x,f),f(f(0))),f(1)); |
117 |
def_redp(i):select(i,0.18848,0.05468174, |
118 |
0.00103547,8.311144e-08,7.449763e-06,0.0004390987,0.001389302, |
119 |
0.003306035,0.01381413,0.0563861,0.1534137,0.2581243,0.3059902, |
120 |
0.3449827,0.3791056,0.4138921,0.4678283,0.624231,0.7732902, |
121 |
0.9067587,1,1,0.9863); |
122 |
def_red(x):interp_arr(x/0.0454545+1,def_redp); |
123 |
def_grnp(i):select(i,0.0009766,2.35501e-05, |
124 |
0.0008966244,0.0264977,0.1256843,0.2865799,0.424867,0.4750973, |
125 |
0.4403898,0.3568169,0.244569,0.1643434,0.1297663,0.1001566, |
126 |
0.07522873,0.05465921,0.03394894,0.001412969,0.00681687, |
127 |
0.0974651,0.3106831,0.6447838,0.9707); |
128 |
def_grn(x):interp_arr(x/0.0454545+1,def_grnp); |
129 |
def_blup(i):select(i,0.2666,0.3638662,0.4770437, |
130 |
0.5131397,0.5363797,0.5193677,0.4091852,0.1732726,0.05331749, |
131 |
0.04184916,0.05768565,0.070331,0.0738812,0.07805368,0.08024318, |
132 |
0.07775604,0.06449649,0.01028498,0.0003090336,0.0004275006, |
133 |
0.002297005,0.01128842,0.02539); |
134 |
def_blu(x):interp_arr(x/0.0454545+1,def_blup); |
135 |
136 |
isconta = if(btwn(0,v,1),or(boundary(vleft,vright),boundary(vabove,vbelow)),-1); |
137 |
iscontb = if(btwn(0,v,1),btwn(.4,frac(ndivs*v),.6),-1); |
138 |
139 |
ra = 0; |
140 |
ga = 0; |
141 |
ba = 0; |
142 |
143 |
in = 1; |
144 |
145 |
ro = if(in,clip($redv),ra); |
146 |
go = if(in,clip($grnv),ga); |
147 |
bo = if(in,clip($bluv),ba); |
148 |
_EOF_ |
149 |
cat > $td/pc1.cal <<_EOF_ |
150 |
norm : mult/scale/le(1); |
151 |
152 |
v = map(li(1)*norm); |
153 |
154 |
vleft = map(li(1,-1,0)*norm); |
155 |
vright = map(li(1,1,0)*norm); |
156 |
vabove = map(li(1,0,1)*norm); |
157 |
vbelow = map(li(1,0,-1)*norm); |
158 |
159 |
map(x) = x; |
160 |
161 |
ra = ri(nfiles); |
162 |
ga = gi(nfiles); |
163 |
ba = bi(nfiles); |
164 |
_EOF_ |
165 |
set pc0args=(-f $td/pc0.cal) |
166 |
set pc1args=(-f $td/pc1.cal) |
167 |
if ($?docont) then |
168 |
set pc0args=($pc0args -e "in=iscont$docont") |
169 |
endif |
170 |
if ("$cpict" == "") then |
171 |
set pc1args=($pc1args -e 'ra=0;ga=0;ba=0') |
172 |
else if ("$cpict" == "$picture") then |
173 |
set cpict= |
174 |
endif |
175 |
if ($?needfile && "$picture" == '-') then |
176 |
cat > $td/picture |
177 |
set picture=$td/picture |
178 |
endif |
179 |
if ("$decades" != "0") then |
180 |
set pc1args=($pc1args -e "map(x)=if(x-10^-$decades,log10(x)/$decades+1,0)") |
181 |
set imap="imap(y)=10^((y-1)*$decades)" |
182 |
else |
183 |
set imap="imap(y)=y" |
184 |
endif |
185 |
if ( $legwidth > 20 && $legheight > 40 ) then |
186 |
pcomb $pc0args -e 'v=(y+.5)/yres;vleft=v;vright=v' \ |
187 |
-e 'vbelow=(y-.5)/yres;vabove=(y+1.5)/yres' \ |
188 |
-x $legwidth -y $legheight > $td/scol.pic |
189 |
( echo "$label"; cnt $ndivs \ |
190 |
| rcalc -e '$1='"($scale)*imap(($ndivs-.5-"'$1'")/$ndivs)" \ |
191 |
-e "$imap" | sed -e 's/\(\.[0-9][0-9][0-9]\)[0-9]*/\1/' ) \ |
192 |
| psign -s -.15 -cf 1 1 1 -cb 0 0 0 \ |
193 |
-h `ev "floor($legheight/$ndivs+.5)"` > $td/slab.pic |
194 |
else |
195 |
set legwidth=0 |
196 |
set legheight=0 |
197 |
(echo "" ; echo "-Y 1 +X 1" ; echo "aaa" ) > $td/scol.pic |
198 |
cp $td/scol.pic $td/slab.pic |
199 |
endif |
200 |
if ( $?doextrem ) then |
201 |
pextrem -o $picture > $td/extrema |
202 |
set minpos=`sed 2d $td/extrema | rcalc -e '$2=$2;$1=$1+'"$legwidth"` |
203 |
set minval=`rcalc -e '$1=($3*.27+$4*.67+$5*.06)*'"$mult" $td/extrema | sed -e 2d -e 's/\(\.[0-9][0-9][0-9]\)[0-9]*/\1/'` |
204 |
set maxpos=`sed 1d $td/extrema | rcalc -e '$2=$2;$1=$1+'"$legwidth"` |
205 |
set maxval=`rcalc -e '$1=($3*.27+$4*.67+$5*.06)*'"$mult" $td/extrema | sed -e 1d -e 's/\(\.[0-9][0-9][0-9]\)[0-9]*/\1/'` |
206 |
psign -s -.15 -a 2 -h 16 $minval > $td/minv.pic |
207 |
psign -s -.15 -a 2 -h 16 $maxval > $td/maxv.pic |
208 |
pcomb $pc0args $pc1args $picture $cpict \ |
209 |
| pcompos $td/scol.pic 0 0 \ |
210 |
+t .1 "\!pcomb -e 'lo=1-gi(1)' $td/slab.pic" \ |
211 |
`ev 2 $loff-1` -t .5 $td/slab.pic 0 $loff \ |
212 |
- $legwidth 0 $td/minv.pic $minpos $td/maxv.pic $maxpos |
213 |
else |
214 |
215 |
216 |
217 |
218 |
- $legwidth 0 |
219 |
endif |
220 |
quit: |
221 |
rm -rf $td |
