root/radiance/ray/src/px/falsecolor.csh
Revision: 1.9
Committed: Sat Oct 26 15:20:08 1991 UTC (32 years, 6 months ago) by greg
Content type: application/x-csh
fixed wrong constant
1 #!/bin/csh -f
2 # SCCSid "$SunId$ LBL"
3 #
4 # Create false color image with legend
5 #
6 set td=/usr/tmp/fc$$
7 onintr quit
8 set mult=179
9 set label=Nits
10 set scale=1000
11 set decades=0
12 set redv='1.6*v-.6'
13 set grnv='if(v-.375,1.6-1.6*v,8/3*v)'
14 set bluv='1-8/3*v'
15 set ndivs=8
16 set picture='-'
17 set cpict=
18 set legwidth=100
19 set legheight=200
20 while ($#argv > 0)
21 switch ($argv[1])
22 case -m:
23 shift argv
24 set mult="$argv[1]"
25 breaksw
26 case -s:
27 shift argv
28 set scale="$argv[1]"
29 breaksw
30 case -l:
31 shift argv
32 set label="$argv[1]"
33 breaksw
34 case -log:
35 shift argv
36 set decades=$argv[1]
37 breaksw
38 case -r:
39 shift argv
40 set redv="$argv[1]"
41 breaksw
42 case -g:
43 shift argv
44 set grnv="$argv[1]"
45 breaksw
46 case -b:
47 shift argv
48 set bluv="$argv[1]"
49 breaksw
50 case -i:
51 shift argv
52 set picture="$argv[1]"
53 breaksw
54 case -p:
55 shift argv
56 set cpict="$argv[1]"
57 breaksw
58 case -ip:
59 case -pi:
60 shift argv
61 set picture="$argv[1]"
62 set cpict="$argv[1]"
63 breaksw
64 case -cl:
65 set docont=a
66 breaksw
67 case -cb:
68 set docont=b
69 breaksw
70 case -n:
71 shift argv
72 set ndivs="$argv[1]"
73 breaksw
74 default:
75 echo bad option "'$argv[1]'" >/dev/tty
76 exit 1
77 endsw
78 shift argv
79 end
80 mkdir $td
81 cat > $td/pc0.cal <<_EOF_
82 PI : 3.14159265358979323846 ;
83 scale : $scale ;
84 mult : $mult ;
85 ndivs : $ndivs ;
86
87 or(a,b) : if(a,a,b);
88 EPS : 1e-7;
89 neq(a,b) : if(a-b-EPS,1,b-a-EPS);
90 btwn(a,x,b) : if(a-x,-1,b-x);
91 clip(x) : if(x-1,1,if(x,x,0));
92 frac(x) : x - floor(x);
93 boundary(a,b) : neq(floor(ndivs*a),floor(ndivs*b));
94
95 isconta = if(btwn(0,v,1),or(boundary(vleft,vright),boundary(vabove,vbelow)),-1);
96 iscontb = if(btwn(0,v,1),btwn(.4,frac(ndivs*v),.6),-1);
97
98 ro = if(in,clip($redv),ra);
99 go = if(in,clip($grnv),ga);
100 bo = if(in,clip($bluv),ba);
101
102 ra = 0;
103 ga = 0;
104 ba = 0;
105
106 in = 1;
107 _EOF_
108 cat > $td/pc1.cal <<_EOF_
109 norm : mult/scale/le(1);
110
111 v = map(li(1)*norm);
112
113 vleft = map(li(1,-1,0)*norm);
114 vright = map(li(1,1,0)*norm);
115 vabove = map(li(1,0,1)*norm);
116 vbelow = map(li(1,0,-1)*norm);
117
118 map(x) = x;
119
120 ra = ri(nfiles);
121 ga = gi(nfiles);
122 ba = bi(nfiles);
123 _EOF_
124 set pc0args=(-f $td/pc0.cal)
125 set pc1args=(-f $td/pc1.cal)
126 if ($?docont) then
127 set pc0args=($pc0args -e "in=iscont$docont")
128 endif
129 if ("$cpict" == "") then
130 set pc1args=($pc1args -e 'ra=0;ga=0;ba=0')
131 else if ("$cpict" == "$picture") then
132 set cpict=
133 endif
134 if ($decades > 0) then
135 set pc1args=($pc1args -e "map(x)=if(x-10^-$decades,log10(x)/$decades+1,0)")
136 set imap="imap(y)=10^((y-1)*$decades)"
137 else
138 set imap="imap(y)=y"
139 endif
140 pcomb $pc0args -e 'v=(y+.5)/yres;vleft=v;vright=v' \
141 -e 'vbelow=(y-.5)/yres;vabove=(y+1.5)/yres' \
142 -x $legwidth -y $legheight > $td/scol.pic
143 ( echo $label; cnt $ndivs \
144 | rcalc -e '$1='"($scale)*imap(($ndivs-.5-"'$1'")/$ndivs)" \
145 -e "$imap" ) \
146 | psign -cf 1 1 1 -cb 0 0 0 -h `ev "floor(2*$legheight/$ndivs+.5)"` \
147 | pfilt -1 -x /2 -y /2 > $td/slab.pic
148 pcomb $pc0args $pc1args $picture $cpict \
149 | pcompos $td/scol.pic 0 0 -t .2 $td/slab.pic 25 0 - $legwidth 0
150 quit:
151 rm -rf $td
