root/radiance/ray/src/px/falsecolor.csh
Revision: 1.5
Committed: Mon May 27 09:00:38 1991 UTC (32 years, 11 months ago) by greg
Content type: application/x-csh
Changes since 1.4: +39 -32 lines
fixed some bugs
1 #!/bin/csh -f
2 # SCCSid "$SunId$ LBL"
3 #
4 # Create false color image with legend
5 #
6 set td=/usr/tmp/fc$$
7 onintr quit
8 set mult=470
9 set label=Nits
10 set scale=1000
11 set decades=0
12 set redv='1.6*v-.6'
13 set grnv='if(v-.375,1.6-1.6*v,8/3*v)'
14 set bluv='1-8/3*v'
15 set ndivs=8
16 set picture='-'
17 set cpict=
18 set legwidth=100
19 set legheight=200
20 while ($#argv > 0)
21 switch ($argv[1])
22 case -m:
23 shift argv
24 set mult="$argv[1]"
25 breaksw
26 case -s:
27 shift argv
28 set scale="$argv[1]"
29 breaksw
30 case -l:
31 shift argv
32 set label="$argv[1]"
33 breaksw
34 case -log:
35 shift argv
36 set decades=$argv[1]
37 breaksw
38 case -r:
39 shift argv
40 set redv="$argv[1]"
41 breaksw
42 case -g:
43 shift argv
44 set grnv="$argv[1]"
45 breaksw
46 case -b:
47 shift argv
48 set bluv="$argv[1]"
49 breaksw
50 case -i:
51 shift argv
52 set picture="$argv[1]"
53 breaksw
54 case -p:
55 shift argv
56 set cpict="$argv[1]"
57 breaksw
58 case -ip:
59 case -pi:
60 shift argv
61 set picture="$argv[1]"
62 set cpict="$argv[1]"
63 breaksw
64 case -cl:
65 set docont=a
66 breaksw
67 case -cb:
68 set docont=b
69 breaksw
70 case -n:
71 shift argv
72 set ndivs="$argv[1]"
73 breaksw
74 default:
75 echo bad option "'$argv[1]'" >/dev/tty
76 exit 1
77 endsw
78 shift argv
79 end
80 mkdir $td
81 cat > $td/pc0.cal <<_EOF_
82 scale : $scale ;
83 mult : $mult ;
84 ndivs : $ndivs ;
85
86 or(a,b) : if(a,a,b);
87 EPS : 1e-7;
88 neq(a,b) : if(a-b-EPS,1,b-a-EPS);
89 btwn(a,b) : if(a-x,-1,b-x);
90 clip(x) : if(x-1,1,if(x,x,0));
91 frac(x) : x - floor(x);
92 boundary(a,b) : neq(floor(ndivs*a),floor(ndivs*b));
93
94 isconta = or(boundary(vleft,vright),boundary(vabove,vbelow));
95 iscontb = if(btwn(0,v,1),btwn(.4,frac(ndivs*v),.6),-1);
96
97 ro = if(in,clip($redv),ra);
98 go = if(in,clip($grnv),ga);
99 bo = if(in,clip($bluv),ba);
100
101 ra = 0;
102 ga = 0;
103 ba = 0;
104
105 in = 1;
106 _EOF_
107 cat > $td/pc1.cal <<_EOF_
108 norm : mult/scale/le(1);
109
110 v = map(li(1)*norm);
111
112 vleft = map(li(1,-1,0)*norm);
113 vright = map(li(1,1,0)*norm);
114 vabove = map(li(1,0,1)*norm);
115 vbelow = map(li(1,0,-1)*norm);
116
117 map(x) = x;
118
119 ra = ri(nfiles);
120 ga = gi(nfiles);
121 ba = bi(nfiles);
122 _EOF_
123 set pc0args=(-f $td/pc0.cal)
124 set pc1args=(-f $td/pc1.cal)
125 if ($?docont) then
126 set pc0args=($pc0args -e "in=iscont$docont")
127 endif
128 if ("$cpict" == "") then
129 set pc1args=($pc1args -e 'ra=0;ga=0;ba=0')
130 else if ("$cpict" == "$picture") then
131 set cpict=
132 endif
133 if ($decades > 0) then
134 set pc1args=($pc1args -e "map(x)=if(x-10^-$decades,log10(x)/$decades+1,0)")
135 set imap="imap(y)=10^((y-1)*$decades)"
136 else
137 set imap="imap(y)=y"
138 endif
139 pcomb $pc0args -e 'v=(y+.5)/yres;vleft=v;vright=v' \
140 -e 'vbelow=(y-.5)/yres;vabove=(y+1.5)/yres' \
141 -x $legwidth -y $legheight > $td/scol.pic
142 ( echo $label; cnt $ndivs \
143 | rcalc -e '$1='"($scale)*imap(($ndivs-.5-"'$1'")/$ndivs)" \
144 -e "$imap" ) \
145 | psign -cf 1 1 1 -cb 0 0 0 -h `ev "floor(2*$legheight/$ndivs+.5)"` \
146 | pfilt -1 -x /2 -y /2 > $td/slab.pic
147 pcomb $pc0args $pc1args $picture $cpict \
148 | pcompos $td/scol.pic 0 0 -t .2 $td/slab.pic 25 0 - $legwidth 0
149 quit:
150 rm -rf $td
