Aesthetic improvements to color scale code.
Made temporary files safe from malicious attackers
Bug fix in -spec option
Added -spec and "-s auto" options to falsecolor
Made false color scale less bloody than before
Made colorscale a little less bloody
Improved default ordinal color scale in falsecolor
Added quote around label, so * doesn't mess it up
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
fixed up decimal placement somewhat
made falsecolor accept non-integer decades with -log option
fixed label offsets
changed label offset
added -e option for printing extrema on image
changed contour lines to appear on values rather than between
fixed wrong constant
added definition of PI
fixed problem with btwn definition
changed contour lines so they don't extend past v==1
fixed some bugs
fixed bug related to exposure compensations
added -log option
added anti-aliasing to the text
