--- ray/src/px/falsecolor.csh 1991/05/27 09:00:38 1.5 +++ ray/src/px/falsecolor.csh 2005/02/16 05:40:11 2.12 @@ -1,11 +1,13 @@ -#!/bin/csh -f -# SCCSid "$SunId$ LBL" +#!/bin/csh -fe +# RCSid: $Id: falsecolor.csh,v 2.12 2005/02/16 05:40:11 greg Exp $ # # Create false color image with legend # -set td=/usr/tmp/fc$$ +# Added user-definable legend 2004/01/20 Rob Guglielmetti + +set td=/tmp/fc$$ onintr quit -set mult=470 +set mult=179 set label=Nits set scale=1000 set decades=0 @@ -15,10 +17,19 @@ set bluv='1-8/3*v' set ndivs=8 set picture='-' set cpict= +set loff=0 set legwidth=100 set legheight=200 while ($#argv > 0) switch ($argv[1]) + case -lw: + shift argv + set legwidth="$argv[1]" + breaksw + case -lh: + shift argv + set legheight="$argv[1]" + breaksw case -m: shift argv set mult="$argv[1]" @@ -63,22 +74,29 @@ while ($#argv > 0) breaksw case -cl: set docont=a + set loff=12 breaksw case -cb: set docont=b + set loff=13 breaksw + case -e: + set doextrem + set needfile + breaksw case -n: shift argv set ndivs="$argv[1]" breaksw default: - echo bad option "'$argv[1]'" >/dev/tty + echo bad option "'$argv[1]'" exit 1 endsw shift argv end mkdir $td cat > $td/pc0.cal <<_EOF_ +PI : 3.14159265358979323846 ; scale : $scale ; mult : $mult ; ndivs : $ndivs ; @@ -86,12 +104,12 @@ ndivs : $ndivs ; or(a,b) : if(a,a,b); EPS : 1e-7; neq(a,b) : if(a-b-EPS,1,b-a-EPS); -btwn(a,b) : if(a-x,-1,b-x); +btwn(a,x,b) : if(a-x,-1,b-x); clip(x) : if(x-1,1,if(x,x,0)); frac(x) : x - floor(x); -boundary(a,b) : neq(floor(ndivs*a),floor(ndivs*b)); +boundary(a,b) : neq(floor(ndivs*a+.5),floor(ndivs*b+.5)); -isconta = or(boundary(vleft,vright),boundary(vabove,vbelow)); +isconta = if(btwn(0,v,1),or(boundary(vleft,vright),boundary(vabove,vbelow)),-1); iscontb = if(btwn(0,v,1),btwn(.4,frac(ndivs*v),.6),-1); ro = if(in,clip($redv),ra); @@ -130,21 +148,45 @@ if ("$cpict" == "") then else if ("$cpict" == "$picture") then set cpict= endif -if ($decades > 0) then +if ($?needfile && "$picture" == '-') then + cat > $td/picture + set picture=$td/picture +endif +if ("$decades" != "0") then set pc1args=($pc1args -e "map(x)=if(x-10^-$decades,log10(x)/$decades+1,0)") set imap="imap(y)=10^((y-1)*$decades)" else set imap="imap(y)=y" endif +if ( $legwidth > 20 && $legheight > 40 ) then pcomb $pc0args -e 'v=(y+.5)/yres;vleft=v;vright=v' \ -e 'vbelow=(y-.5)/yres;vabove=(y+1.5)/yres' \ -x $legwidth -y $legheight > $td/scol.pic -( echo $label; cnt $ndivs \ +( echo "$label"; cnt $ndivs \ | rcalc -e '$1='"($scale)*imap(($ndivs-.5-"'$1'")/$ndivs)" \ - -e "$imap" ) \ - | psign -cf 1 1 1 -cb 0 0 0 -h `ev "floor(2*$legheight/$ndivs+.5)"` \ - | pfilt -1 -x /2 -y /2 > $td/slab.pic -pcomb $pc0args $pc1args $picture $cpict \ - | pcompos $td/scol.pic 0 0 -t .2 $td/slab.pic 25 0 - $legwidth 0 + -e "$imap" | sed -e 's/\(\.[0-9][0-9][0-9]\)[0-9]*/\1/' ) \ + | psign -s -.15 -cf 1 1 1 -cb 0 0 0 \ + -h `ev "floor($legheight/$ndivs+.5)"` > $td/slab.pic +else + set legwidth=0 + set legheight=0 + (echo "" ; echo "-Y 1 +X 1" ; echo "aaa" ) > $td/scol.pic + cp $td/scol.pic $td/slab.pic +endif +if ( $?doextrem ) then + pextrem -o $picture > $td/extrema + set minpos=`sed 2d $td/extrema | rcalc -e '$2=$2;$1=$1+'"$legwidth"` + set minval=`rcalc -e '$1=($3*.27+$4*.67+$5*.06)*'"$mult" $td/extrema | sed -e 2d -e 's/\(\.[0-9][0-9][0-9]\)[0-9]*/\1/'` + set maxpos=`sed 1d $td/extrema | rcalc -e '$2=$2;$1=$1+'"$legwidth"` + set maxval=`rcalc -e '$1=($3*.27+$4*.67+$5*.06)*'"$mult" $td/extrema | sed -e 1d -e 's/\(\.[0-9][0-9][0-9]\)[0-9]*/\1/'` + psign -s -.15 -a 2 -h 16 $minval > $td/minv.pic + psign -s -.15 -a 2 -h 16 $maxval > $td/maxv.pic + pcomb $pc0args $pc1args $picture $cpict \ + | pcompos $td/scol.pic 0 0 -t .2 $td/slab.pic 0 $loff \ + - $legwidth 0 $td/minv.pic $minpos $td/maxv.pic $maxpos +else + pcomb $pc0args $pc1args $picture $cpict \ + | pcompos $td/scol.pic 0 0 -t .2 $td/slab.pic 0 $loff - $legwidth 0 +endif quit: rm -rf $td
