1 |
#!/bin/csh -f |
2 |
# SCCSid "$SunId$ LBL" |
3 |
4 |
# Create false color image with legend |
5 |
6 |
set td=/usr/tmp/fc$$ |
7 |
onintr quit |
8 |
set mult=179 |
9 |
set label=Nits |
10 |
set scale=1000 |
11 |
set decades=0 |
12 |
set redv='1.6*v-.6' |
13 |
set grnv='if(v-.375,1.6-1.6*v,8/3*v)' |
14 |
set bluv='1-8/3*v' |
15 |
set ndivs=8 |
16 |
set picture='-' |
17 |
set cpict= |
18 |
set loff=0 |
19 |
set legwidth=100 |
20 |
set legheight=200 |
21 |
while ($#argv > 0) |
22 |
switch ($argv[1]) |
23 |
case -m: |
24 |
shift argv |
25 |
set mult="$argv[1]" |
26 |
breaksw |
27 |
case -s: |
28 |
shift argv |
29 |
set scale="$argv[1]" |
30 |
breaksw |
31 |
case -l: |
32 |
shift argv |
33 |
set label="$argv[1]" |
34 |
breaksw |
35 |
case -log: |
36 |
shift argv |
37 |
set decades=$argv[1] |
38 |
breaksw |
39 |
case -r: |
40 |
shift argv |
41 |
set redv="$argv[1]" |
42 |
breaksw |
43 |
case -g: |
44 |
shift argv |
45 |
set grnv="$argv[1]" |
46 |
breaksw |
47 |
case -b: |
48 |
shift argv |
49 |
set bluv="$argv[1]" |
50 |
breaksw |
51 |
case -i: |
52 |
shift argv |
53 |
set picture="$argv[1]" |
54 |
breaksw |
55 |
case -p: |
56 |
shift argv |
57 |
set cpict="$argv[1]" |
58 |
breaksw |
59 |
case -ip: |
60 |
case -pi: |
61 |
shift argv |
62 |
63 |
64 |
breaksw |
65 |
case -cl: |
66 |
set docont=a |
67 |
set loff=12 |
68 |
breaksw |
69 |
case -cb: |
70 |
set docont=b |
71 |
set loff=13 |
72 |
breaksw |
73 |
case -e: |
74 |
set doextrem |
75 |
set needfile |
76 |
breaksw |
77 |
case -n: |
78 |
shift argv |
79 |
set ndivs="$argv[1]" |
80 |
breaksw |
81 |
default: |
82 |
echo bad option "'$argv[1]'" >/dev/tty |
83 |
exit 1 |
84 |
endsw |
85 |
shift argv |
86 |
end |
87 |
mkdir $td |
88 |
cat > $td/pc0.cal <<_EOF_ |
89 |
PI : 3.14159265358979323846 ; |
90 |
scale : $scale ; |
91 |
mult : $mult ; |
92 |
ndivs : $ndivs ; |
93 |
94 |
or(a,b) : if(a,a,b); |
95 |
EPS : 1e-7; |
96 |
neq(a,b) : if(a-b-EPS,1,b-a-EPS); |
97 |
btwn(a,x,b) : if(a-x,-1,b-x); |
98 |
clip(x) : if(x-1,1,if(x,x,0)); |
99 |
frac(x) : x - floor(x); |
100 |
boundary(a,b) : neq(floor(ndivs*a+.5),floor(ndivs*b+.5)); |
101 |
102 |
isconta = if(btwn(0,v,1),or(boundary(vleft,vright),boundary(vabove,vbelow)),-1); |
103 |
iscontb = if(btwn(0,v,1),btwn(.4,frac(ndivs*v),.6),-1); |
104 |
105 |
ro = if(in,clip($redv),ra); |
106 |
go = if(in,clip($grnv),ga); |
107 |
bo = if(in,clip($bluv),ba); |
108 |
109 |
ra = 0; |
110 |
ga = 0; |
111 |
ba = 0; |
112 |
113 |
in = 1; |
114 |
_EOF_ |
115 |
cat > $td/pc1.cal <<_EOF_ |
116 |
norm : mult/scale/le(1); |
117 |
118 |
v = map(li(1)*norm); |
119 |
120 |
vleft = map(li(1,-1,0)*norm); |
121 |
vright = map(li(1,1,0)*norm); |
122 |
vabove = map(li(1,0,1)*norm); |
123 |
vbelow = map(li(1,0,-1)*norm); |
124 |
125 |
map(x) = x; |
126 |
127 |
ra = ri(nfiles); |
128 |
ga = gi(nfiles); |
129 |
ba = bi(nfiles); |
130 |
_EOF_ |
131 |
set pc0args=(-f $td/pc0.cal) |
132 |
set pc1args=(-f $td/pc1.cal) |
133 |
if ($?docont) then |
134 |
set pc0args=($pc0args -e "in=iscont$docont") |
135 |
endif |
136 |
if ("$cpict" == "") then |
137 |
set pc1args=($pc1args -e 'ra=0;ga=0;ba=0') |
138 |
else if ("$cpict" == "$picture") then |
139 |
set cpict= |
140 |
endif |
141 |
if ($?needfile && "$picture" == '-') then |
142 |
cat > $td/picture |
143 |
set picture=$td/picture |
144 |
endif |
145 |
if ($decades > 0) then |
146 |
set pc1args=($pc1args -e "map(x)=if(x-10^-$decades,log10(x)/$decades+1,0)") |
147 |
set imap="imap(y)=10^((y-1)*$decades)" |
148 |
else |
149 |
set imap="imap(y)=y" |
150 |
endif |
151 |
pcomb $pc0args -e 'v=(y+.5)/yres;vleft=v;vright=v' \ |
152 |
-e 'vbelow=(y-.5)/yres;vabove=(y+1.5)/yres' \ |
153 |
-x $legwidth -y $legheight > $td/scol.pic |
154 |
( echo $label; cnt $ndivs \ |
155 |
| rcalc -e '$1='"($scale)*imap(($ndivs-.5-"'$1'")/$ndivs)" \ |
156 |
-e "$imap" ) \ |
157 |
| psign -s -.15 -cf 1 1 1 -cb 0 0 0 \ |
158 |
-h `ev "floor($legheight/$ndivs+.5)"` > $td/slab.pic |
159 |
if ( $?doextrem ) then |
160 |
pextrem -o $picture > $td/extrema |
161 |
set minpos=`sed 2d $td/extrema | rcalc -e '$2=$2;$1=$1+'"$legwidth"` |
162 |
set minval=`rcalc -e '$1=($3*.3+$4*.59+$5*.11)*'"$mult" $td/extrema | sed -e 2d -e 's/\(.....\).*$/\1/'` |
163 |
set maxpos=`sed 1d $td/extrema | rcalc -e '$2=$2;$1=$1+'"$legwidth"` |
164 |
set maxval=`rcalc -e '$1=($3*.3+$4*.59+$5*.11)*'"$mult" $td/extrema | sed -e 1d -e 's/\(.....\).*$/\1/'` |
165 |
psign -s -.15 -a 2 -h 16 $minval > $td/minv.pic |
166 |
psign -s -.15 -a 2 -h 16 $maxval > $td/maxv.pic |
167 |
pcomb $pc0args $pc1args $picture $cpict \ |
168 |
| pcompos $td/scol.pic 0 0 -t .2 $td/slab.pic 0 $loff \ |
169 |
- $legwidth 0 $td/minv.pic $minpos $td/maxv.pic $maxpos |
170 |
else |
171 |
172 |
| pcompos $td/scol.pic 0 0 -t .2 $td/slab.pic 0 $loff - $legwidth 0 |
173 |
endif |
174 |
quit: |
175 |
rm -rf $td |
