root/radiance/ray/src/px/falsecolor.csh
Revision 2.15 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Nov 18 22:50:21 2005 UTC (18 years, 6 months ago) by greg
Changes since 2.14: +13 -13 lines
Made false color scale less bloody than before
Revision 2.14 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Nov 18 22:17:16 2005 UTC (18 years, 6 months ago) by greg
Changes since 2.13: +13 -13 lines
Made colorscale a little less bloody
Sat Nov 12 06:14:51 2005 UTC (18 years, 7 months ago) by greg
Changes since 2.12: +39 -10 lines
Improved default ordinal color scale in falsecolor
Wed Feb 16 05:40:11 2005 UTC (19 years, 3 months ago) by greg
Tue Jan 18 03:59:41 2005 UTC (19 years, 4 months ago) by greg
Sat Jul 31 17:56:56 2004 UTC (19 years, 10 months ago) by greg
Added quote around label, so * doesn't mess it up
Mon Mar 8 21:39:32 2004 UTC (20 years, 3 months ago) by greg
Changes since 2.8: +18 -1 lines
Thu Sep 5 13:02:58 1996 UTC (27 years, 9 months ago) by greg
fixed up decimal placement somewhat
Wed May 19 09:50:51 1993 UTC (31 years ago) by greg
made falsecolor accept non-integer decades with -log option
Revision 2.5 - (view) (download) (as text) (annotate) - [selected]
Thu Dec 17 12:32:49 1992 UTC (31 years, 5 months ago) by greg
fixed label offsets
Thu Oct 1 10:05:24 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.3: +5 -2 lines
changed label offset
Fri Aug 21 15:46:11 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.2: +25 -4 lines
added -e option for printing extrema on image
Mon Apr 6 17:54:11 1992 UTC (32 years, 2 months ago) by greg
changed contour lines to appear on values rather than between
Tue Nov 12 16:05:47 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.9 , to selected 2.5
Revision 1.9 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Oct 26 15:20:08 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.8 , to selected 2.5
fixed wrong constant
Fri Aug 9 15:13:15 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.7: +1 -0 lines
Diff to previous 1.7 , to selected 2.5
added definition of PI
Revision 1.7 - (view) (download) (as text) (annotate) - [select for diffs]
Wed May 29 14:10:09 1991 UTC (33 years ago) by greg
Diff to previous 1.6 , to selected 2.5
fixed problem with btwn definition
Tue May 28 16:06:46 1991 UTC (33 years ago) by greg
Diff to previous 1.5 , to selected 2.5
changed contour lines so they don't extend past v==1
Mon May 27 09:00:38 1991 UTC (33 years ago) by greg
Changes since 1.4: +39 -32 lines
Diff to previous 1.4 , to selected 2.5
fixed some bugs
Fri May 24 17:23:01 1991 UTC (33 years ago) by greg
Changes since 1.3: +8 -6 lines
Diff to previous 1.3 , to selected 2.5
fixed bug related to exposure compensations
Thu May 23 16:41:38 1991 UTC (33 years ago) by greg
Changes since 1.2: +24 -10 lines
added -log option
Revision 1.2 - (view) (download) (as text) (annotate) - [select for diffs]
Thu May 23 14:22:00 1991 UTC (33 years ago) by greg
added anti-aliasing to the text
Thu May 23 13:45:18 1991 UTC (33 years ago) by greg
Diff to selected 2.5
Links to HEAD: (view) (download) (as text) (annotate) Links to rad3R8: (view) (download) (as text) (annotate)
