--- ray/src/px/falsecolor.csh 1991/05/23 13:45:18 1.1 +++ ray/src/px/falsecolor.csh 1992/04/06 17:54:11 2.2 @@ -3,17 +3,20 @@ # # Create false color image with legend # -set tempdir=/usr/tmp/fc$$ +set td=/usr/tmp/fc$$ onintr quit -set mult=470 +set mult=179 set label=Nits set scale=1000 -set redv='2*v-1' -set grnv='if(v-.5,2-2*v,2*v)' -set bluv='1-2*v' +set decades=0 +set redv='1.6*v-.6' +set grnv='if(v-.375,1.6-1.6*v,8/3*v)' +set bluv='1-8/3*v' set ndivs=8 set picture='-' set cpict= +set legwidth=100 +set legheight=200 while ($#argv > 0) switch ($argv[1]) case -m: @@ -28,6 +31,10 @@ while ($#argv > 0) shift argv set label="$argv[1]" breaksw + case -log: + shift argv + set decades=$argv[1] + breaksw case -r: shift argv set redv="$argv[1]" @@ -50,7 +57,7 @@ while ($#argv > 0) breaksw case -ip: case -pi: - shiftargv + shift argv set picture="$argv[1]" set cpict="$argv[1]" breaksw @@ -61,17 +68,18 @@ while ($#argv > 0) set docont=b breaksw case -n: - shiftargv + shift argv set ndivs="$argv[1]" - breadsw + breaksw default: - echo bad option "'$argv[1]'" + echo bad option "'$argv[1]'" >/dev/tty exit 1 endsw shift argv end -mkdir $tempdir -cat > $tempdir/pc.cal <<_EOF_ +mkdir $td +cat > $td/pc0.cal <<_EOF_ +PI : 3.14159265358979323846 ; scale : $scale ; mult : $mult ; ndivs : $ndivs ; @@ -79,49 +87,65 @@ ndivs : $ndivs ; or(a,b) : if(a,a,b); EPS : 1e-7; neq(a,b) : if(a-b-EPS,1,b-a-EPS); -btwn(a,b) : if(a-x,-1,b-x); +btwn(a,x,b) : if(a-x,-1,b-x); +clip(x) : if(x-1,1,if(x,x,0)); frac(x) : x - floor(x); -boundary(a,b) : neq(floor(ndivs*a),floor(ndivs*b)); +boundary(a,b) : neq(floor(ndivs*a+.5),floor(ndivs*b+.5)); -red=$redv; -grn=$grnv; -blu=$bluv; +isconta = if(btwn(0,v,1),or(boundary(vleft,vright),boundary(vabove,vbelow)),-1); +iscontb = if(btwn(0,v,1),btwn(.4,frac(ndivs*v),.6),-1); -v = li(1)*(mult/scale); -vleft = li(1,-1,0)*(mult/scale); -vright = li(1,1,0)*(mult/scale); -vabove = li(1,0,1)*(mult/scale); -vbelow = li(1,0,-1)*(mult/scale); -isconta = or(boundary(vleft,vright),boundary(vabove,vbelow)); -iscontb = if(btwn(0,v,1),btwn(.4,frac(ndivs*v),.6),0); +ro = if(in,clip($redv),ra); +go = if(in,clip($grnv),ga); +bo = if(in,clip($bluv),ba); -ro = if(in,red,ra); -go = if(in,grn,ga); -bo = if(in,blu,ba); +ra = 0; +ga = 0; +ba = 0; +in = 1; +_EOF_ +cat > $td/pc1.cal <<_EOF_ +norm : mult/scale/le(1); + +v = map(li(1)*norm); + +vleft = map(li(1,-1,0)*norm); +vright = map(li(1,1,0)*norm); +vabove = map(li(1,0,1)*norm); +vbelow = map(li(1,0,-1)*norm); + +map(x) = x; + ra = ri(nfiles); ga = gi(nfiles); ba = bi(nfiles); - -in = 1; _EOF_ -set pcargs=(-o -f $tempdir/pc.cal) +set pc0args=(-f $td/pc0.cal) +set pc1args=(-f $td/pc1.cal) if ($?docont) then - set pcargs=($pcargs -e "in=iscont$docont") + set pc0args=($pc0args -e "in=iscont$docont") endif if ("$cpict" == "") then - set pcargs=($pcargs -e 'ra=0;ga=0;ba=0') + set pc1args=($pc1args -e 'ra=0;ga=0;ba=0') else if ("$cpict" == "$picture") then set cpict= endif -pcomb $pcargs -e 'v=(y+.5)/200;vleft=v;vright=v' \ - -e 'vbelow=(y-.5)/200;vabove=(y+1.5)/200' \ - -e 'ra=0;ga=0;ba=0' -x 100 -y 200 \ - > $tempdir/scol.pic -(echo $label; cnt $ndivs |rcalc -e '$1='"($scale)/$ndivs*($ndivs"'-.5-$1)') \ - | psign -cf 1 1 1 -cb 0 0 0 -h `ev "floor(200/$ndivs+.5)"` \ - > $tempdir/slab.pic -pcomb $pcargs $picture $cpict \ - | pcompos $tempdir/scol.pic 0 0 -t .5 $tempdir/slab.pic 25 0 - 100 0 +if ($decades > 0) then + set pc1args=($pc1args -e "map(x)=if(x-10^-$decades,log10(x)/$decades+1,0)") + set imap="imap(y)=10^((y-1)*$decades)" +else + set imap="imap(y)=y" +endif +pcomb $pc0args -e 'v=(y+.5)/yres;vleft=v;vright=v' \ + -e 'vbelow=(y-.5)/yres;vabove=(y+1.5)/yres' \ + -x $legwidth -y $legheight > $td/scol.pic +( echo $label; cnt $ndivs \ + | rcalc -e '$1='"($scale)*imap(($ndivs-.5-"'$1'")/$ndivs)" \ + -e "$imap" ) \ + | psign -cf 1 1 1 -cb 0 0 0 -h `ev "floor(2*$legheight/$ndivs+.5)"` \ + | pfilt -1 -x /2 -y /2 > $td/slab.pic +pcomb $pc0args $pc1args $picture $cpict \ + | pcompos $td/scol.pic 0 0 -t .2 $td/slab.pic 25 0 - $legwidth 0 quit: -rm -rf $tempdir +rm -rf $td
