1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
5 |
* d48c.c - driver for dicomed D48 film recorder w/ color optics. |
6 |
7 |
* 3/26/87 |
8 |
9 |
10 |
#include <stdio.h> |
11 |
12 |
#include <signal.h> |
13 |
14 |
#include "color.h" |
15 |
16 |
17 |
#define HSIZE 4096 /* device width */ |
18 |
#define VSIZE 4096 /* device height */ |
19 |
20 |
#define MAXMULT 15 /* maximum element size */ |
21 |
22 |
/* dicomed commands */ |
23 |
#define O_ECS 0 /* encoded command select */ |
24 |
#define O_CONF 03400 /* configuration code */ |
25 |
#define O_FES 020000 /* function element select */ |
26 |
#define O_VPA 040000 /* vector or position absolute */ |
27 |
#define O_ICS 0100000 /* initial condition select */ |
28 |
#define O_PES 0120000 /* point element select */ |
29 |
30 |
/* ECS commands */ |
31 |
#define ECS_FA 07 /* film advance */ |
32 |
#define ECS_RED 011 /* select red filter */ |
33 |
#define ECS_GRN 012 /* select green filter */ |
34 |
#define ECS_BLU 014 /* select blue filter */ |
35 |
#define ECS_NEU 017 /* select neutral filter */ |
36 |
#define ECS_RAS 020 /* select raster mode */ |
37 |
#define ECS_COL 022 /* select color mode */ |
38 |
#define ECS_BW 023 /* select black and white mode */ |
39 |
#define ECS_BT 024 /* bypass translation tables */ |
40 |
41 |
/* FES functions */ |
42 |
#define FES_RE 030000 /* raster element */ |
43 |
#define FES_RL 0170000 /* run length */ |
44 |
45 |
/* ICS fields */ |
46 |
#define ICS_HVINT 040 /* interchange h and v axes */ |
47 |
#define ICS_VREV 0100 /* reverse v axis direction */ |
48 |
#define ICS_HREV 0200 /* reverse h axis direction */ |
49 |
50 |
int nrows; /* number of rows for output */ |
51 |
int ncols; /* number of columns for output */ |
52 |
53 |
int mult; /* number of h/v points per elem. */ |
54 |
55 |
int hhome; /* offset for h */ |
56 |
int vhome; /* offset for v */ |
57 |
58 |
/* dicomed configurations */ |
59 |
#define C_POLAROID 0 /* polaroid print */ |
60 |
#define C_35FRES 1 /* 35mm full resolution */ |
61 |
#define C_35FFRA 2 /* 35mm full frame */ |
62 |
#define C_SHEET 3 /* 4X5 sheet film */ |
63 |
64 |
#define NCONF 4 /* number of configurations */ |
65 |
66 |
struct config { |
67 |
char *name; /* configuration name */ |
68 |
int ccode; /* configuration code */ |
69 |
int icsfield; /* initial condition select */ |
70 |
int hbeg, vbeg; /* coord. origin */ |
71 |
int hsiz, vsiz; /* dimensions */ |
72 |
} ctab[NCONF] = { |
73 |
{ "polaroid", 11, ICS_HVINT|ICS_VREV, 0, 0, 4096, 4096 }, |
74 |
{ "35r", 5, 0, 0, 0, 4096, 4096 }, |
75 |
{ "35f", 7, 0, 39, 692, 4018, 2712 }, |
76 |
{ "sheet", 10, ICS_HVINT|ICS_VREV, 0, 0, 4096, 4096 }, |
77 |
78 |
79 |
#define NEU 3 /* neutral color */ |
80 |
81 |
struct filter { |
82 |
float cv[3]; /* filter color vector */ |
83 |
char *fn; /* file name for this color */ |
84 |
FILE *fp; /* stream for this color */ |
85 |
} ftab[4] = { |
86 |
{ {1.0, 0.0, 0.0}, NULL, NULL }, /* red */ |
87 |
{ {0.0, 1.0, 0.0}, NULL, NULL }, /* green */ |
88 |
{ {0.0, 0.0, 1.0}, NULL, NULL }, /* blue */ |
89 |
{ {0.3, 0.59, 0.11}, NULL, NULL }, /* neutral */ |
90 |
91 |
92 |
#define f_val(col,f) ( colval(col,0)*ftab[f].cv[0] + \ |
93 |
colval(col,1)*ftab[f].cv[1] + \ |
94 |
colval(col,2)*ftab[f].cv[2] ) |
95 |
96 |
float neumap[] = { /* neutral map, log w/ E6 */ |
97 |
.0, .0, |
98 |
.0004, .059, |
99 |
.0008, .122, |
100 |
.0018, .184, |
101 |
.0033, .247, |
102 |
.0061, .310, |
103 |
.0119, .373, |
104 |
.0202, .435, |
105 |
.0373, .498, |
106 |
.065, .561, |
107 |
.113, .624, |
108 |
.199, .686, |
109 |
.300, .749, |
110 |
.432, .812, |
111 |
.596, .875, |
112 |
.767, .937, |
113 |
1.000, 1.000, |
114 |
115 |
116 |
117 |
#define TEMPLATE "/tmp/dXXXXXX" |
118 |
119 |
int docolor = 1; /* color? */ |
120 |
121 |
int cftype = C_35FFRA; /* configuration type */ |
122 |
123 |
char *progname; /* program name */ |
124 |
125 |
126 |
main(argc, argv) |
127 |
int argc; |
128 |
char *argv[]; |
129 |
130 |
int quit(); |
131 |
int i; |
132 |
133 |
if (signal(SIGINT, quit) == SIG_IGN) |
134 |
signal(SIGINT, SIG_IGN); |
135 |
if (signal(SIGHUP, quit) == SIG_IGN) |
136 |
137 |
signal(SIGTERM, quit); |
138 |
signal(SIGPIPE, quit); |
139 |
signal(SIGXCPU, quit); |
140 |
signal(SIGXFSZ, quit); |
141 |
142 |
progname = argv[0]; |
143 |
144 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) |
145 |
switch (argv[i][1]) { |
146 |
case 'c': /* color */ |
147 |
docolor = 1; |
148 |
break; |
149 |
case 'b': /* black and white */ |
150 |
docolor = 0; |
151 |
break; |
152 |
case 't': /* type */ |
153 |
settype(argv[++i]); |
154 |
break; |
155 |
default: |
156 |
fprintf(stderr, "%s: Unknown option: %s\n", |
157 |
progname, argv[i]); |
158 |
quit(1); |
159 |
break; |
160 |
161 |
162 |
if (i < argc) |
163 |
for ( ; i < argc; i++) |
164 |
dofile(argv[i]); |
165 |
else |
166 |
dofile(NULL); |
167 |
168 |
quit(0); |
169 |
170 |
171 |
172 |
settype(cname) /* set configuration type */ |
173 |
char *cname; |
174 |
175 |
for (cftype = 0; cftype < NCONF; cftype++) |
176 |
if (!strcmp(cname, ctab[cftype].name)) |
177 |
return; |
178 |
179 |
fprintf(stderr, "%s: Unknown type: %s\n", progname, cname); |
180 |
quit(1); |
181 |
182 |
183 |
184 |
void |
185 |
quit(code) /* quit program */ |
186 |
int code; |
187 |
188 |
int i; |
189 |
190 |
for (i = 0; i < 4; i++) |
191 |
if (ftab[i].fn != NULL) |
192 |
unlink(ftab[i].fn); |
193 |
exit(code); |
194 |
195 |
196 |
197 |
dofile(fname) /* convert file to dicomed format */ |
198 |
char *fname; |
199 |
200 |
FILE *fin; |
201 |
char sbuf[128]; |
202 |
COLOR scanline[HSIZE]; |
203 |
int i; |
204 |
205 |
if (fname == NULL) { |
206 |
fin = stdin; |
207 |
fname = "<stdin>"; |
208 |
} else if ((fin = fopen(fname, "r")) == NULL) { |
209 |
fprintf(stderr, "%s: Cannot open: %s\n", progname, fname); |
210 |
quit(1); |
211 |
212 |
/* discard header */ |
213 |
while (fgets(sbuf, sizeof(sbuf), fin) != NULL && sbuf[0] != '\n') |
214 |
215 |
/* get picture size */ |
216 |
if (fgets(sbuf, sizeof(sbuf), fin) == NULL || |
217 |
sscanf(sbuf, "-Y %d +X %d\n", &nrows, &ncols) != 2) { |
218 |
fprintf(stderr, "%s: Bad picture size: %s\n", progname, fname); |
219 |
quit(1); |
220 |
221 |
222 |
mult = ctab[cftype].hsiz / ncols; |
223 |
if (ctab[cftype].vsiz / nrows < mult) |
224 |
mult = ctab[cftype].vsiz / nrows; |
225 |
226 |
if (mult < 1) { |
227 |
fprintf(stderr, "%s: Resolution mismatch: %s\n", |
228 |
progname, fname); |
229 |
quit(1); |
230 |
231 |
if (mult > MAXMULT) |
232 |
mult = MAXMULT; /* maximum element size */ |
233 |
234 |
hhome = ctab[cftype].hbeg + (ctab[cftype].hsiz - ncols*mult)/2; |
235 |
vhome = ctab[cftype].vbeg + (ctab[cftype].vsiz - nrows*mult)/2; |
236 |
237 |
d_init(); |
238 |
239 |
for (i = nrows-1; i >= 0; i--) { |
240 |
if (freadscan(scanline, ncols, fin) < 0) { |
241 |
fprintf(stderr, "%s: Read error in row %d: %s\n", |
242 |
progname, i, fname); |
243 |
quit(1); |
244 |
245 |
scanout(scanline, i); |
246 |
247 |
248 |
d_done(); |
249 |
250 |
fclose(fin); |
251 |
252 |
253 |
254 |
d_init() /* set up dicomed, files */ |
255 |
256 |
char *mktemp(); |
257 |
258 |
putw(O_ICS|ctab[cftype].icsfield, stdout); |
259 |
260 |
putw(O_CONF|ctab[cftype].ccode, stdout); |
261 |
262 |
putw(O_ECS|ECS_RAS, stdout); |
263 |
/* color or black and white */ |
264 |
putw(O_ECS|(docolor?ECS_COL:ECS_BW), stdout); |
265 |
266 |
putw(O_ECS|ECS_BT, stdout); |
267 |
268 |
putw(O_PES|mult<<9|010, stdout); |
269 |
putw(mult<<9|010, stdout); |
270 |
putw(mult<<4|mult, stdout); |
271 |
272 |
if (docolor) { /* color output */ |
273 |
/* set up red file */ |
274 |
if (ftab[RED].fn == NULL) |
275 |
ftab[RED].fn = mktemp(TEMPLATE); |
276 |
if ((ftab[RED].fp = fopen(ftab[RED].fn, "w+")) == NULL) { |
277 |
fprintf(stderr, "%s: Cannot open: %s\n", |
278 |
progname, ftab[RED].fn); |
279 |
quit(1); |
280 |
281 |
putw(O_ECS|ECS_RED, ftab[RED].fp); /* red filter */ |
282 |
putw(O_VPA, ftab[RED].fp); /* home */ |
283 |
putw(hhome<<3, ftab[RED].fp); |
284 |
putw(vhome<<3, ftab[RED].fp); |
285 |
/* set up green file */ |
286 |
ftab[GRN].fp = stdout; |
287 |
putw(O_ECS|ECS_GRN, ftab[GRN].fp); /* green filter */ |
288 |
putw(O_VPA, ftab[GRN].fp); /* home */ |
289 |
putw(hhome<<3, ftab[GRN].fp); |
290 |
putw(vhome<<3, ftab[GRN].fp); |
291 |
/* set up blue file */ |
292 |
if (ftab[BLU].fn == NULL) |
293 |
ftab[BLU].fn = mktemp(TEMPLATE); |
294 |
if ((ftab[BLU].fp = fopen(ftab[BLU].fn, "w+")) == NULL) { |
295 |
296 |
progname, ftab[BLU].fn); |
297 |
quit(1); |
298 |
299 |
putw(O_ECS|ECS_BLU, ftab[BLU].fp); /* blue filter */ |
300 |
putw(O_VPA, ftab[BLU].fp); /* home */ |
301 |
putw(hhome<<3, ftab[BLU].fp); |
302 |
putw(vhome<<3, ftab[BLU].fp); |
303 |
304 |
} else { /* black and white */ |
305 |
ftab[NEU].fp = stdout; |
306 |
putw(O_ECS|ECS_NEU, ftab[NEU].fp); /* neutral filter */ |
307 |
putw(O_VPA, ftab[NEU].fp); /* home */ |
308 |
putw(hhome<<3, ftab[NEU].fp); |
309 |
putw(vhome<<3, ftab[NEU].fp); |
310 |
311 |
312 |
313 |
314 |
scanout(scan, y) /* output scan line */ |
315 |
COLOR *scan; |
316 |
int y; |
317 |
318 |
int i; |
319 |
/* uses horiz. flyback */ |
320 |
if (docolor) |
321 |
for (i = 0; i < 3; i++) |
322 |
runlength(scan, i); |
323 |
else |
324 |
runlength(scan, NEU); |
325 |
326 |
327 |
328 |
d_done() /* flush files, finish frame */ |
329 |
330 |
if (docolor) { |
331 |
transfer(ftab[RED].fp, stdout); |
332 |
transfer(ftab[BLU].fp, stdout); |
333 |
334 |
putw(O_ECS|ECS_FA, stdout); /* film advance */ |
335 |
fflush(stdout); |
336 |
if (ferror(stdout)) { |
337 |
fprintf(stderr, "%s: Write error: <stdout>\n", progname); |
338 |
quit(1); |
339 |
340 |
341 |
342 |
343 |
runlength(scan, f) /* do scanline for filter f */ |
344 |
COLOR *scan; |
345 |
int f; |
346 |
347 |
double mapfilter(); |
348 |
BYTE ebuf[2*HSIZE]; |
349 |
register int j; |
350 |
register BYTE *ep; |
351 |
352 |
ep = ebuf; |
353 |
ep[0] = mapfilter(scan[0], f) * 255.9999; |
354 |
ep[1] = 1; |
355 |
ep += 2; |
356 |
for (j = 1; j < ncols; j++) { |
357 |
ep[0] = mapfilter(scan[j], f) * 255.9999; |
358 |
if (ep[0] == ep[-2] && ep[-1] < 255) |
359 |
ep[-1]++; |
360 |
else { |
361 |
ep[1] = 1; |
362 |
ep += 2; |
363 |
364 |
365 |
j = ep - ebuf; |
366 |
putw(O_FES, ftab[f].fp); |
367 |
putw(FES_RL|j>>1, ftab[f].fp); |
368 |
for (ep = ebuf; j-- > 0; ep++) |
369 |
putc(*ep, ftab[f].fp); |
370 |
371 |
if (ferror(ftab[f].fp)) { |
372 |
fprintf(stderr, "%s: Write error: %s\n", progname, |
373 |
ftab[f].fn==NULL ? "<stdout>" : ftab[f].fn); |
374 |
quit(1); |
375 |
376 |
377 |
378 |
379 |
double |
380 |
mapfilter(col, f) /* map filter value */ |
381 |
COLOR col; |
382 |
register int f; |
383 |
384 |
static float *mp[4] = {neumap, neumap, neumap, neumap}; |
385 |
double x, y; |
386 |
387 |
y = f_val(col,f); |
388 |
389 |
if (y >= 1.0) |
390 |
return(1.0); |
391 |
392 |
while (y >= mp[f][2]) |
393 |
mp[f] += 2; |
394 |
while (y < mp[f][0]) |
395 |
mp[f] -= 2; |
396 |
397 |
x = (y - mp[f][0]) / (mp[f][2] - mp[f][0]); |
398 |
399 |
return((1.0-x)*mp[f][1] + x*mp[f][3]); |
400 |
401 |
402 |
403 |
putw(w, fp) /* output a (short) word */ |
404 |
int w; |
405 |
register FILE *fp; |
406 |
407 |
putc(w&0377, fp); /* in proper order! */ |
408 |
putc(w>>8, fp); |
409 |
410 |
411 |
412 |
transfer(fin, fout) /* transfer fin contents to fout, close fin */ |
413 |
register FILE *fin, *fout; |
414 |
415 |
register int c; |
416 |
417 |
fseek(fin, 0L, 0); /* rewind input */ |
418 |
419 |
while ((c = getc(fin)) != EOF) /* transfer file */ |
420 |
putc(c, fout); |
421 |
422 |
fclose(fin); /* close input */ |
423 |
