--- ray/src/px/d48c.c 2003/10/27 10:24:51 1.4 +++ ray/src/px/d48c.c 2004/03/28 20:33:13 1.5 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: d48c.c,v 1.4 2003/10/27 10:24:51 schorsch Exp $"; +static const char RCSid[] = "$Id: d48c.c,v 1.5 2004/03/28 20:33:13 schorsch Exp $"; #endif /* * d48c.c - driver for dicomed D48 film recorder w/ color optics. @@ -8,8 +8,10 @@ static const char RCSid[] = "$Id: d48c.c,v 1.4 2003/10 */ #include +#include #include +#include "paths.h" #include "rterror.h" #include "color.h" @@ -114,18 +116,27 @@ float neumap[] = { /* neutral map, log w/ E6 */ }; -#define TEMPLATE "/tmp/dXXXXXX" - int docolor = 1; /* color? */ int cftype = C_35FFRA; /* configuration type */ char *progname; /* program name */ +static void settype(char *cname); +static void dofile(char *fname); +static void d_init(void); +static void scanout(COLOR *scan, int y); +static void d_done(void); +static void runlength(COLOR *scan, int f); +static double mapfilter(COLOR col, int f); +static void transfer(FILE *fin, FILE *fout); -main(argc, argv) -int argc; -char *argv[]; + +int +main( + int argc, + char *argv[] +) { int i; @@ -173,11 +184,14 @@ char *argv[]; dofile(NULL); quit(0); + return 0; /* pro forma return */ } -settype(cname) /* set configuration type */ -char *cname; +static void +settype( /* set configuration type */ + char *cname +) { for (cftype = 0; cftype < NCONF; cftype++) if (!strcmp(cname, ctab[cftype].name)) @@ -200,8 +214,10 @@ quit(int code) /* quit program */ } -dofile(fname) /* convert file to dicomed format */ -char *fname; +static void +dofile( /* convert file to dicomed format */ + char *fname +) { FILE *fin; char sbuf[128]; @@ -257,9 +273,10 @@ char *fname; } -d_init() /* set up dicomed, files */ +static void +d_init(void) /* set up dicomed, files */ { - char *mktemp(); + //char *mktemp(); /* initial condition select */ putw(O_ICS|ctab[cftype].icsfield, stdout); /* configuration code */ @@ -317,9 +334,11 @@ d_init() /* set up dicomed, files */ } -scanout(scan, y) /* output scan line */ -COLOR *scan; -int y; +static void +scanout( /* output scan line */ + COLOR *scan, + int y +) { int i; /* uses horiz. flyback */ @@ -331,7 +350,8 @@ int y; } -d_done() /* flush files, finish frame */ +static void +d_done(void) /* flush files, finish frame */ { if (docolor) { transfer(ftab[RED].fp, stdout); @@ -346,11 +366,13 @@ d_done() /* flush files, finish frame */ } -runlength(scan, f) /* do scanline for filter f */ -COLOR *scan; -int f; +static void +runlength( /* do scanline for filter f */ + COLOR *scan, + int f +) { - double mapfilter(); + //double mapfilter(); BYTE ebuf[2*HSIZE]; register int j; register BYTE *ep; @@ -382,10 +404,11 @@ int f; } -double -mapfilter(col, f) /* map filter value */ -COLOR col; -register int f; +static double +mapfilter( /* map filter value */ + COLOR col, + register int f +) { static float *mp[4] = {neumap, neumap, neumap, neumap}; double x, y; @@ -406,17 +429,24 @@ register int f; } -putw(w, fp) /* output a (short) word */ -int w; -register FILE *fp; +/* XXX replaces putw() from stdio.h. Do we really need this? */ +int +putw( /* output a (short) word */ + int w, + register FILE *fp +) { putc(w&0377, fp); /* in proper order! */ putc(w>>8, fp); + return 0; } -transfer(fin, fout) /* transfer fin contents to fout, close fin */ -register FILE *fin, *fout; +static void +transfer( /* transfer fin contents to fout, close fin */ + register FILE *fin, + register FILE *fout +) { register int c;
