root/radiance/ray/src/px/cut.c
Revision: 2.3
Committed: Sun Jul 27 22:12:03 2003 UTC (20 years, 10 months ago) by schorsch
2 static const char RCSid[] = "$Id: cut.c,v 2.2 2003/02/22 02:07:27 greg Exp $";
5 CUT - Median bisection (k-d tree) algorithm for color image quantization
6
7 flaw: doesn't always create as many colors as requested
8 because the binary subdivision is always done in a balanced tree and when a box
9 contains only one color it's unsplittable
10
11 Paul Heckbert
12 */
13
14 #include "ciq.h"
15
16 struct index {short *o; int freq;};
17 /* offset and pixel count for a box */
18
19 struct pail {struct plum *first; int freak;};
20 /* each pail is a bucket containing plums */
21
22 struct plum {struct plum *next; int code;};
23 /* a color in a pail's linked list */
24
25 static short off[len];
26 /* color codes: offsets of colors in hist array */
27
28
29 makecm(nw,na) /* subdivide colorspace to generate a colormap*/
30 int nw,*na; /* number of colors wanted, actual */
31 {
32 int i,m,n,freq,weight,sr,sg,sb;
33 short *o;
34 struct index index[257]; /* pointers into off */
35 /* index[i].o is pointer to code for first color in box i */
36
37 for (o=off, *na=i=0; i<len; i++)
38 if (hist[i]) {
39 (*na)++;
40 *o++ = i; /* initialize offsets */
41 }
42 index[0].o = off; /* start with one big box which contains all *na colors */
43 index[0].freq = xmax*ymax; /* and (sum of hist[i]) pixels */
44 index[1].o = off+*na;
45
46 /* breadth-first binary subdivision: try to make nw boxes */
47 for (m=1; m<nw; m<<=1) {
48 /*printf("%d ",m);*/
49 index[m<<1].o = index[m].o;
50 for (i=m-1; i>=0; --i) splitbox(index+i,index+(i<<1));
51 }
52 for (n=i=0; i<m && n<nw; i++) if (index[i+1].o>index[i].o) {
53 sr = sg = sb = (freq = index[i].freq)>>1;
54 for (o=index[i].o; o<index[i+1].o; o++) {
55 weight = hist[*o];
56 /* find weighted average of colors in box i */
57 sr += red(*o)*weight;
58 sg += gre(*o)*weight;
59 sb += blu(*o)*weight;
60 }
61 color[0][n] = sr/freq;
62 color[1][n] = sg/freq;
63 color[2][n] = sb/freq;
64 /* printf("color[%d]=(%3d,%3d,%3d) freq=%d\n",
65 n,color[0][n],color[1][n],color[2][n],freq); */
66 n++;
67 }
68 /*printf("[%d empty boxes] from %d to %d colors\n",nw-n,*na,n);*/
69 return n;
70 }
71
72 splitbox(ii,io) /* split a box in two: half of the pixels from */
73 struct index *ii,*io; /* box ii will go into io, the other half into io+1 */
74 {
75 register short *o,*o1,*o2;
76 register int shift,count,k,freq,r,g,b,r1,g1,b1,r2,g2,b2;
77 struct pail pail[32],*p,*q; /* buckets for sorting colors */
78 struct plum plum[len],*pl=plum,*u; /* colors */
79
80 o1 = ii[0].o;
81 o2 = ii[1].o;
82 freq = ii[0].freq; /* number of pixels with color in this box */
83 r1 = g1 = b1 = 256; r2 = g2 = b2 = -1;
84 for (o=o1; o<o2; o++) {
85 r = red(*o);
86 g = gre(*o);
87 b = blu(*o);
88 if (r<r1) r1 = r; if (r>r2) r2 = r; /* find min&max r, g, and b */
89 if (g<g1) g1 = g; if (g>g2) g2 = g;
90 if (b<b1) b1 = b; if (b>b2) b2 = b;
91 }
92
93 /* adaptive partitioning: find dominant dimension */
94 shift = r2-r1>g2-g1?r2-r1>=b2-b1?10:0:g2-g1>=b2-b1?5:0;
95 /* printf("splitbox %3d-%3d %3dx%3dx%3d %c ",
96 o1-off,o2-off,r2-r1,g2-g1,b2-b1,shift==10?'R':shift==5?'G':'B'); */
97
98 for (p=pail, k=0; k<32; k++, p++) { /* start with empty pails */
99 p->first = 0;
100 p->freak = 0;
101 }
102 for (o=o1; o<o2; o++) {
103 p = pail+(*o>>shift&31); /* find appropriate pail */
104 pl->code = *o;
105 pl->next = p->first;
106 p->first = pl++; /* add new plum to pail */
107 p->freak += hist[*o];
108 }
109
110 /* find median along dominant dimension */
111 for (count=freq>>1, p=pail; count>0; p++) count -= p->freak;
112
113 if (p>pail && count+(p-1)->freak<-count) /* back up one? */
114 count += (--p)->freak;
115
116 io[1].o = o1; /* in case of empty box */
117 for (o=o1, q=pail; o<o2;) { /* dump the pails to reorder colors in box */
118 for (u=q->first; u; u=u->next) *o++ = u->code;
119 if (++q==p) io[1].o = o; /* place partition at offset o */
120 }
121 io[0].o = o1;
122 io[0].freq = (freq>>1)-count;
123 io[1].freq = ((freq+1)>>1)+count;
124 /* printf(" at %3d %d=%d+%d\n",io[1].o-off,freq,io[0].freq,io[1].freq); */
125 }
