root/Development/ray/src/px/cut.c
Revision: 2.4
Committed: Sun Mar 28 20:33:13 2004 UTC (21 years, 9 months ago) by schorsch
CVS Tags: rad3R6P1, rad3R6
Changes since 2.3: +13 -5 lines
2 static const char RCSid[] = "$Id: cut.c,v 2.3 2003/07/27 22:12:03 schorsch Exp $";
5 CUT - Median bisection (k-d tree) algorithm for color image quantization
6
7 flaw: doesn't always create as many colors as requested
8 because the binary subdivision is always done in a balanced tree and when a box
9 contains only one color it's unsplittable
10
11 Paul Heckbert
12 */
13
14 #include "ciq.h"
15
16 struct index {short *o; int freq;};
17 /* offset and pixel count for a box */
18
19 struct pail {struct plum *first; int freak;};
20 /* each pail is a bucket containing plums */
21
22 struct plum {struct plum *next; int code;};
23 /* a color in a pail's linked list */
24
25 static short off[len];
26 /* color codes: offsets of colors in hist array */
27
28 static void splitbox(struct index *ii, struct index *io);
29
30
31 int
32 makecm( /* subdivide colorspace to generate a colormap*/
33 int nw,
34 int *na /* number of colors wanted, actual */
35 )
36 {
37 int i,m,n,freq,weight,sr,sg,sb;
38 short *o;
39 struct index index[257]; /* pointers into off */
40 /* index[i].o is pointer to code for first color in box i */
41
42 for (o=off, *na=i=0; i<len; i++)
43 if (hist[i]) {
44 (*na)++;
45 *o++ = i; /* initialize offsets */
46 }
47 index[0].o = off; /* start with one big box which contains all *na colors */
48 index[0].freq = xmax*ymax; /* and (sum of hist[i]) pixels */
49 index[1].o = off+*na;
50
51 /* breadth-first binary subdivision: try to make nw boxes */
52 for (m=1; m<nw; m<<=1) {
53 /*printf("%d ",m);*/
54 index[m<<1].o = index[m].o;
55 for (i=m-1; i>=0; --i) splitbox(index+i,index+(i<<1));
56 }
57 for (n=i=0; i<m && n<nw; i++) if (index[i+1].o>index[i].o) {
58 sr = sg = sb = (freq = index[i].freq)>>1;
59 for (o=index[i].o; o<index[i+1].o; o++) {
60 weight = hist[*o];
61 /* find weighted average of colors in box i */
62 sr += red(*o)*weight;
63 sg += gre(*o)*weight;
64 sb += blu(*o)*weight;
65 }
66 color[0][n] = sr/freq;
67 color[1][n] = sg/freq;
68 color[2][n] = sb/freq;
69 /* printf("color[%d]=(%3d,%3d,%3d) freq=%d\n",
70 n,color[0][n],color[1][n],color[2][n],freq); */
71 n++;
72 }
73 /*printf("[%d empty boxes] from %d to %d colors\n",nw-n,*na,n);*/
74 return n;
75 }
76
77 static void
78 splitbox( /* split a box in two: half of the pixels from */
79 struct index *ii, /* box ii will go into io, the other half into io+1 */
80 struct index *io
81 )
82 {
83 register short *o,*o1,*o2;
84 register int shift,count,k,freq,r,g,b,r1,g1,b1,r2,g2,b2;
85 struct pail pail[32],*p,*q; /* buckets for sorting colors */
86 struct plum plum[len],*pl=plum,*u; /* colors */
87
88 o1 = ii[0].o;
89 o2 = ii[1].o;
90 freq = ii[0].freq; /* number of pixels with color in this box */
91 r1 = g1 = b1 = 256; r2 = g2 = b2 = -1;
92 for (o=o1; o<o2; o++) {
93 r = red(*o);
94 g = gre(*o);
95 b = blu(*o);
96 if (r<r1) r1 = r; if (r>r2) r2 = r; /* find min&max r, g, and b */
97 if (g<g1) g1 = g; if (g>g2) g2 = g;
98 if (b<b1) b1 = b; if (b>b2) b2 = b;
99 }
100
101 /* adaptive partitioning: find dominant dimension */
102 shift = r2-r1>g2-g1?r2-r1>=b2-b1?10:0:g2-g1>=b2-b1?5:0;
103 /* printf("splitbox %3d-%3d %3dx%3dx%3d %c ",
104 o1-off,o2-off,r2-r1,g2-g1,b2-b1,shift==10?'R':shift==5?'G':'B'); */
105
106 for (p=pail, k=0; k<32; k++, p++) { /* start with empty pails */
107 p->first = 0;
108 p->freak = 0;
109 }
110 for (o=o1; o<o2; o++) {
111 p = pail+(*o>>shift&31); /* find appropriate pail */
112 pl->code = *o;
113 pl->next = p->first;
114 p->first = pl++; /* add new plum to pail */
115 p->freak += hist[*o];
116 }
117
118 /* find median along dominant dimension */
119 for (count=freq>>1, p=pail; count>0; p++) count -= p->freak;
120
121 if (p>pail && count+(p-1)->freak<-count) /* back up one? */
122 count += (--p)->freak;
123
124 io[1].o = o1; /* in case of empty box */
125 for (o=o1, q=pail; o<o2;) { /* dump the pails to reorder colors in box */
126 for (u=q->first; u; u=u->next) *o++ = u->code;
127 if (++q==p) io[1].o = o; /* place partition at offset o */
128 }
129 io[0].o = o1;
130 io[0].freq = (freq>>1)-count;
131 io[1].freq = ((freq+1)>>1)+count;
132 /* printf(" at %3d %d=%d+%d\n",io[1].o-off,freq,io[0].freq,io[1].freq); */
133 }
