root/radiance/ray/src/px/clrtab.c
Changes since 2.18: +17 -17 lines
Diff to previous 2.18
Revision 2.18 - (view) (download) (annotate) - [selected]
Mon Sep 19 02:23:58 2005 UTC (18 years, 8 months ago) by greg
Changes since 2.17: +1 -5 lines
Diff to previous 2.17
Sun Mar 28 20:33:13 2004 UTC (20 years, 1 month ago) by schorsch
Changes since 2.16: +84 -51 lines
Diff to previous 2.16 , to selected 2.18
Diff to previous 2.15 , to selected 2.18
Changes since 2.14: +9 -5 lines
Diff to previous 2.14 , to selected 2.18
Tue May 13 17:58:33 2003 UTC (21 years ago) by greg
Diff to previous 2.13 , to selected 2.18
Wed Apr 23 00:52:34 2003 UTC (21 years, 1 month ago) by greg
Diff to previous 2.12 , to selected 2.18
Changes since 2.11: +2 -5 lines
Diff to previous 2.11 , to selected 2.18
Mon Dec 12 12:15:51 1994 UTC (29 years, 5 months ago) by greg
Changes since 2.10: +4 -0 lines
Diff to previous 2.10 , to selected 2.18
added static function definitions
Fri Jun 10 12:51:16 1994 UTC (29 years, 11 months ago) by greg
Diff to previous 2.9 , to selected 2.18
Thu Dec 9 12:04:23 1993 UTC (30 years, 5 months ago) by greg
Diff to previous 2.8 , to selected 2.18
added dith_colrs() reset to new_clrtab() function
Thu Dec 9 11:57:15 1993 UTC (30 years, 5 months ago) by greg
Changes since 2.7: +6 -5 lines
Diff to previous 2.7 , to selected 2.18
changed dith_colrs() so it can be reset by dith_colrs(NULL, NULL, 0)
Thu Jun 10 15:45:18 1993 UTC (30 years, 11 months ago) by greg
Diff to previous 2.6 , to selected 2.18
another 16-bit integer fix in mktabent()
Wed May 5 10:18:05 1993 UTC (31 years ago) by greg
Diff to previous 2.5 , to selected 2.18
changed int to long in split() (16-bit bug fix)
Tue Feb 23 15:11:59 1993 UTC (31 years, 3 months ago) by greg
Changes since 2.4: +9 -3 lines
Diff to previous 2.4 , to selected 2.18
bug fix -- overflow problem in mktabent()
Fri Feb 5 09:45:40 1993 UTC (31 years, 3 months ago) by greg
Changes since 2.3: +9 -3 lines
Diff to previous 2.3 , to selected 2.18
made CLOSEST define dependent on value of SPEED
Tue Oct 13 11:36:20 1992 UTC (31 years, 7 months ago) by greg
Changes since 2.2: +6 -6 lines
Diff to previous 2.2 , to selected 2.18
changed ra_t8 to use clrtab.c
Tue Oct 13 09:07:51 1992 UTC (31 years, 7 months ago) by greg
Changes since 2.1: +114 -0 lines
Diff to previous 2.1 , to selected 2.18
added closest color calculation
Mon Oct 12 12:58:39 1992 UTC (31 years, 7 months ago) by greg
Diff to selected 2.18
