root/radiance/ray/src/px/clrtab.c
Revision: 2.8
Committed: Thu Dec 9 11:57:15 1993 UTC (30 years, 5 months ago) by greg
Changes since 2.7: +6 -5 lines
changed dith_colrs() so it can be reset by dith_colrs(NULL, NULL, 0)
1 /* Copyright (c) 1993 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Simple median-cut color quantization based on colortab.c
9 */
10
11 #include "standard.h"
12
13 #include "color.h"
14 /* histogram resolution */
15 #define NRED 36
16 #define NGRN 48
17 #define NBLU 24
18 #define HMAX NGRN
19 /* minimum box count for adaptive partition */
20 #define MINSAMP 7
21 /* color partition */
22 #define set_branch(p,c) ((c)<<2|(p))
23 #define part(cn) ((cn)>>2)
24 #define prim(cn) ((cn)&3)
25 /* our color table (global) */
26 BYTE clrtab[256][3];
27 /* histogram of colors / color assignments */
28 static unsigned histo[NRED][NGRN][NBLU];
29 #define cndx(c) histo[((c)[RED]*NRED)>>8][((c)[GRN]*NGRN)>>8][((c)[BLU]*NBLU)>>8]
30 /* initial color cube boundary */
31 static int CLRCUBE[3][2] = {0,NRED,0,NGRN,0,NBLU};
32 /* maximum propagated error during dithering */
33 #define MAXERR 20
34 /* define CLOSEST to get closest colors */
35 #ifndef CLOSEST
36 #ifdef SPEED
37 #if SPEED > 8
38 #define CLOSEST 1 /* this step takes a little longer */
39 #endif
40 #endif
41 #endif
42
43
44 new_histo() /* clear our histogram */
45 {
46 bzero((char *)histo, sizeof(histo));
47 }
48
49
50 cnt_pixel(col) /* add pixel to our histogram */
51 register BYTE col[];
52 {
53 cndx(col)++;
54 }
55
56
57 cnt_colrs(cs, n) /* add a scanline to our histogram */
58 register COLR *cs;
59 register int n;
60 {
61 while (n-- > 0) {
62 cndx(cs[0])++;
63 cs++;
64 }
65 }
66
67
68 new_clrtab(ncolors) /* make new color table using ncolors */
69 int ncolors;
70 {
71 if (ncolors < 1)
72 return(0);
73 if (ncolors > 256)
74 ncolors = 256;
75 /* partition color space */
76 cut(CLRCUBE, 0, ncolors);
77 #ifdef CLOSEST
78 closest(ncolors); /* ensure colors picked are closest */
79 #endif
80 /* return new color table size */
81 return(ncolors);
82 }
83
84
85 int
86 map_pixel(col) /* get pixel for color */
87 register BYTE col[];
88 {
89 return(cndx(col));
90 }
91
92
93 map_colrs(bs, cs, n) /* convert a scanline to color index values */
94 register BYTE *bs;
95 register COLR *cs;
96 register int n;
97 {
98 while (n-- > 0) {
99 *bs++ = cndx(cs[0]);
100 cs++;
101 }
102 }
103
104
105 dith_colrs(bs, cs, n) /* convert scanline to dithered index values */
106 register BYTE *bs;
107 register COLR *cs;
108 int n;
109 {
110 static short (*cerr)[3] = NULL;
111 static int N = 0;
112 int err[3], errp[3];
113 register int x, i;
114
115 if (n != N) { /* get error propogation array */
116 if (N) {
117 free((char *)cerr);
118 cerr = NULL;
119 }
120 if (n)
121 cerr = (short (*)[3])malloc(3*n*sizeof(short));
122 if (cerr == NULL) {
123 N = 0;
124 map_colrs(bs, cs, n);
125 return;
126 }
127 N = n;
128 bzero((char *)cerr, 3*N*sizeof(short));
129 }
130 err[0] = err[1] = err[2] = 0;
131 for (x = 0; x < n; x++) {
132 for (i = 0; i < 3; i++) { /* dither value */
133 errp[i] = err[i];
134 err[i] += cerr[x][i];
135 #ifdef MAXERR
136 if (err[i] > MAXERR) err[i] = MAXERR;
137 else if (err[i] < -MAXERR) err[i] = -MAXERR;
138 #endif
139 err[i] += cs[x][i];
140 if (err[i] < 0) err[i] = 0;
141 else if (err[i] > 255) err[i] = 255;
142 }
143 bs[x] = cndx(err);
144 for (i = 0; i < 3; i++) { /* propagate error */
145 err[i] -= clrtab[bs[x]][i];
146 err[i] /= 3;
147 cerr[x][i] = err[i] + errp[i];
148 }
149 }
150 }
151
152
153 static
154 cut(box, c0, c1) /* partition color space */
155 register int box[3][2];
156 int c0, c1;
157 {
158 register int branch;
159 int kb[3][2];
160
161 if (c1-c0 <= 1) { /* assign pixel */
162 mktabent(c0, box);
163 return;
164 }
165 /* split box */
166 branch = split(box);
167 bcopy((char *)box, (char *)kb, sizeof(kb));
168 /* do left (lesser) branch */
169 kb[prim(branch)][1] = part(branch);
170 cut(kb, c0, (c0+c1)>>1);
171 /* do right branch */
172 kb[prim(branch)][0] = part(branch);
173 kb[prim(branch)][1] = box[prim(branch)][1];
174 cut(kb, (c0+c1)>>1, c1);
175 }
176
177
178 static int
179 split(box) /* find median cut for box */
180 register int box[3][2];
181 {
182 #define c0 r
183 register int r, g, b;
184 int pri;
185 long t[HMAX], med;
186 /* find dominant axis */
187 pri = RED;
188 if (box[GRN][1]-box[GRN][0] > box[pri][1]-box[pri][0])
189 pri = GRN;
190 if (box[BLU][1]-box[BLU][0] > box[pri][1]-box[pri][0])
191 pri = BLU;
192 /* sum histogram over box */
193 med = 0;
194 switch (pri) {
195 case RED:
196 for (r = box[RED][0]; r < box[RED][1]; r++) {
197 t[r] = 0;
198 for (g = box[GRN][0]; g < box[GRN][1]; g++)
199 for (b = box[BLU][0]; b < box[BLU][1]; b++)
200 t[r] += histo[r][g][b];
201 med += t[r];
202 }
203 break;
204 case GRN:
205 for (g = box[GRN][0]; g < box[GRN][1]; g++) {
206 t[g] = 0;
207 for (b = box[BLU][0]; b < box[BLU][1]; b++)
208 for (r = box[RED][0]; r < box[RED][1]; r++)
209 t[g] += histo[r][g][b];
210 med += t[g];
211 }
212 break;
213 case BLU:
214 for (b = box[BLU][0]; b < box[BLU][1]; b++) {
215 t[b] = 0;
216 for (r = box[RED][0]; r < box[RED][1]; r++)
217 for (g = box[GRN][0]; g < box[GRN][1]; g++)
218 t[b] += histo[r][g][b];
219 med += t[b];
220 }
221 break;
222 }
223 if (med < MINSAMP) /* if too sparse, split at midpoint */
224 return(set_branch(pri,(box[pri][0]+box[pri][1])>>1));
225 /* find median position */
226 med >>= 1;
227 for (c0 = box[pri][0]; med > 0; c0++)
228 med -= t[c0];
229 if (c0 > (box[pri][0]+box[pri][1])>>1) /* if past the midpoint */
230 c0--; /* part left of median */
231 return(set_branch(pri,c0));
232 #undef c0
233 }
234
235
236 static
237 mktabent(p, box) /* compute average color for box and assign */
238 int p;
239 register int box[3][2];
240 {
241 unsigned long sum[3];
242 unsigned r, g;
243 unsigned long n;
244 register unsigned b, c;
245 /* sum pixels in box */
246 n = 0;
247 sum[RED] = sum[GRN] = sum[BLU] = 0;
248 for (r = box[RED][0]; r < box[RED][1]; r++)
249 for (g = box[GRN][0]; g < box[GRN][1]; g++)
250 for (b = box[BLU][0]; b < box[BLU][1]; b++) {
251 if (c = histo[r][g][b]) {
252 n += c;
253 sum[RED] += (long)c*r;
254 sum[GRN] += (long)c*g;
255 sum[BLU] += (long)c*b;
256 }
257 histo[r][g][b] = p; /* assign pixel */
258 }
259 if (n >= (1L<<23)/HMAX) { /* avoid overflow */
260 sum[RED] /= n;
261 sum[GRN] /= n;
262 sum[BLU] /= n;
263 n = 1;
264 }
265 if (n) { /* compute average */
266 clrtab[p][RED] = sum[RED]*256/NRED/n;
267 clrtab[p][GRN] = sum[GRN]*256/NGRN/n;
268 clrtab[p][BLU] = sum[BLU]*256/NBLU/n;
269 } else { /* empty box -- use midpoint */
270 clrtab[p][RED] = (box[RED][0]+box[RED][1])*256/NRED/2;
271 clrtab[p][GRN] = (box[GRN][0]+box[GRN][1])*256/NGRN/2;
272 clrtab[p][BLU] = (box[BLU][0]+box[BLU][1])*256/NBLU/2;
273 }
274 }
275
276
277 #ifdef CLOSEST
278 #define NBSIZ 32
279 static
280 closest(n) /* make sure we have the closest colors */
281 int n;
282 {
283 BYTE *neigh[256];
284 register int r, g, b;
285 #define i r
286 /* get space for neighbor lists */
287 for (i = 0; i < n; i++) {
288 if ((neigh[i] = (BYTE *)malloc(NBSIZ)) == NULL) {
289 while (i--)
290 free(neigh[i]);
291 return; /* ENOMEM -- abandon effort */
292 }
293 neigh[i][0] = i; /* identity is terminator */
294 }
295 /* make neighbor lists */
296 for (r = 0; r < NRED; r++)
297 for (g = 0; g < NGRN; g++)
298 for (b = 0; b < NBLU; b++) {
299 if (r < NRED-1 && histo[r][g][b] != histo[r+1][g][b])
300 addneigh(neigh, histo[r][g][b], histo[r+1][g][b]);
301 if (g < NGRN-1 && histo[r][g][b] != histo[r][g+1][b])
302 addneigh(neigh, histo[r][g][b], histo[r][g+1][b]);
303 if (b < NBLU-1 && histo[r][g][b] != histo[r][g][b+1])
304 addneigh(neigh, histo[r][g][b], histo[r][g][b+1]);
305 }
306 /* assign closest values */
307 for (r = 0; r < NRED; r++)
308 for (g = 0; g < NGRN; g++)
309 for (b = 0; b < NBLU; b++)
310 setclosest(neigh, r, g, b);
311 /* free neighbor lists */
312 for (i = 0; i < n; i++)
313 free(neigh[i]);
314 #undef i
315 }
316
317
318 static
319 addneigh(nl, i, j) /* i and j are neighbors; add them to list */
320 register BYTE *nl[];
321 register int i;
322 int j;
323 {
324 int nc;
325 char *nnl;
326 register int t;
327
328 for (nc = 0; nc < 2; nc++) { /* do both neighbors */
329 for (t = 0; nl[i][t] != i; t++)
330 if (nl[i][t] == j)
331 break; /* in list already */
332 if (nl[i][t] == i) { /* add to list */
333 nl[i][t++] = j;
334 if (t % NBSIZ == 0) { /* enlarge list */
335 if ((nnl = realloc(nl[i], t+NBSIZ)) == NULL)
336 t--;
337 else
338 nl[i] = (BYTE *)nnl;
339 }
340 nl[i][t] = i; /* terminator */
341 }
342 t = i; i = j; j = t; /* swap and do it again */
343 }
344 }
345
346
347 static unsigned
348 dist(col, r, g, b) /* find distance from clrtab entry to r,g,b */
349 register BYTE col[3];
350 int r, g, b;
351 {
352 register int tmp;
353 register unsigned sum;
354
355 tmp = col[RED]*NRED/256 - r;
356 sum = tmp*tmp;
357 tmp = col[GRN]*NGRN/256 - g;
358 sum += tmp*tmp;
359 tmp = col[BLU]*NBLU/256 - b;
360 sum += tmp*tmp;
361 return(sum);
362 }
363
364
365 static
366 setclosest(nl, r, g, b) /* find index closest to color and assign */
367 BYTE *nl[];
368 int r, g, b;
369 {
370 int ident;
371 unsigned min;
372 register unsigned d;
373 register BYTE *p;
374 /* get starting value */
375 min = dist(clrtab[ident=histo[r][g][b]], r, g, b);
376 /* find minimum */
377 for (p = nl[ident]; *p != ident; p++)
378 if ((d = dist(clrtab[*p], r, g, b)) < min) {
379 min = d;
380 histo[r][g][b] = *p;
381 }
382 }
383 #endif
