root/radiance/ray/src/px/clrtab.c
Revision: 2.3
Committed: Tue Oct 13 11:36:20 1992 UTC (31 years, 7 months ago) by greg
Changes since 2.2: +6 -6 lines
changed ra_t8 to use clrtab.c
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Simple median-cut color quantization based on colortab.c
9 */
10
11 #include "standard.h"
12
13 #include "color.h"
14 /* histogram resolution */
15 #define NRED 36
16 #define NGRN 48
17 #define NBLU 24
18 #define HMAX NGRN
19 /* minimum box count for adaptive partition */
20 #define MINSAMP 7
21 /* color partition */
22 #define set_branch(p,c) ((c)<<2|(p))
23 #define part(cn) ((cn)>>2)
24 #define prim(cn) ((cn)&3)
25 /* our color table (global) */
26 BYTE clrtab[256][3];
27 /* histogram of colors / color assignments */
28 static unsigned histo[NRED][NGRN][NBLU];
29 #define cndx(c) histo[((c)[RED]*NRED)>>8][((c)[GRN]*NGRN)>>8][((c)[BLU]*NBLU)>>8]
30 /* initial color cube boundary */
31 static int CLRCUBE[3][2] = {0,NRED,0,NGRN,0,NBLU};
32 /* maximum propagated error during dithering */
33 #define MAXERR 20
34 /* define CLOSEST to get closest colors */
35 #define CLOSEST 1
36
37
38 new_histo() /* clear our histogram */
39 {
40 bzero((char *)histo, sizeof(histo));
41 }
42
43
44 cnt_pixel(col) /* add pixel to our histogram */
45 register BYTE col[];
46 {
47 cndx(col)++;
48 }
49
50
51 cnt_colrs(cs, n) /* add a scanline to our histogram */
52 register COLR *cs;
53 register int n;
54 {
55 while (n-- > 0) {
56 cndx(cs[0])++;
57 cs++;
58 }
59 }
60
61
62 new_clrtab(ncolors) /* make new color table using ncolors */
63 int ncolors;
64 {
65 if (ncolors < 1)
66 return(0);
67 if (ncolors > 256)
68 ncolors = 256;
69 /* partition color space */
70 cut(CLRCUBE, 0, ncolors);
71 #ifdef CLOSEST
72 closest(ncolors); /* ensure colors picked are closest */
73 #endif
74 /* return new color table size */
75 return(ncolors);
76 }
77
78
79 int
80 map_pixel(col) /* get pixel for color */
81 register BYTE col[];
82 {
83 return(cndx(col));
84 }
85
86
87 map_colrs(bs, cs, n) /* convert a scanline to color index values */
88 register BYTE *bs;
89 register COLR *cs;
90 register int n;
91 {
92 while (n-- > 0) {
93 *bs++ = cndx(cs[0]);
94 cs++;
95 }
96 }
97
98
99 dith_colrs(bs, cs, n) /* convert scanline to dithered index values */
100 register BYTE *bs;
101 register COLR *cs;
102 int n;
103 {
104 static short (*cerr)[3];
105 static int N = 0;
106 int err[3], errp[3];
107 register int x, i;
108
109 if (n != N) { /* get error propogation array */
110 if (N)
111 cerr = (short (*)[3])realloc((char *)cerr,
112 3*n*sizeof(short));
113 else
114 cerr = (short (*)[3])malloc(3*n*sizeof(short));
115 if (cerr == NULL) {
116 N = 0;
117 map_colrs(bs, cs, n);
118 return;
119 }
120 N = n;
121 bzero((char *)cerr, 3*N*sizeof(short));
122 }
123 err[0] = err[1] = err[2] = 0;
124 for (x = 0; x < n; x++) {
125 for (i = 0; i < 3; i++) { /* dither value */
126 errp[i] = err[i];
127 err[i] += cerr[x][i];
128 #ifdef MAXERR
129 if (err[i] > MAXERR) err[i] = MAXERR;
130 else if (err[i] < -MAXERR) err[i] = -MAXERR;
131 #endif
132 err[i] += cs[x][i];
133 if (err[i] < 0) err[i] = 0;
134 else if (err[i] > 255) err[i] = 255;
135 }
136 bs[x] = cndx(err);
137 for (i = 0; i < 3; i++) { /* propagate error */
138 err[i] -= clrtab[bs[x]][i];
139 err[i] /= 3;
140 cerr[x][i] = err[i] + errp[i];
141 }
142 }
143 }
144
145
146 static
147 cut(box, c0, c1) /* partition color space */
148 register int box[3][2];
149 int c0, c1;
150 {
151 register int branch;
152 int kb[3][2];
153
154 if (c1-c0 <= 1) { /* assign pixel */
155 mktabent(c0, box);
156 return;
157 }
158 /* split box */
159 branch = split(box);
160 bcopy((char *)box, (char *)kb, sizeof(kb));
161 /* do left (lesser) branch */
162 kb[prim(branch)][1] = part(branch);
163 cut(kb, c0, (c0+c1)>>1);
164 /* do right branch */
165 kb[prim(branch)][0] = part(branch);
166 kb[prim(branch)][1] = box[prim(branch)][1];
167 cut(kb, (c0+c1)>>1, c1);
168 }
169
170
171 static int
172 split(box) /* find median cut for box */
173 register int box[3][2];
174 {
175 #define c0 r
176 register int r, g, b;
177 int pri;
178 int t[HMAX], med;
179 /* find dominant axis */
180 pri = RED;
181 if (box[GRN][1]-box[GRN][0] > box[pri][1]-box[pri][0])
182 pri = GRN;
183 if (box[BLU][1]-box[BLU][0] > box[pri][1]-box[pri][0])
184 pri = BLU;
185 /* sum histogram over box */
186 med = 0;
187 switch (pri) {
188 case RED:
189 for (r = box[RED][0]; r < box[RED][1]; r++) {
190 t[r] = 0;
191 for (g = box[GRN][0]; g < box[GRN][1]; g++)
192 for (b = box[BLU][0]; b < box[BLU][1]; b++)
193 t[r] += histo[r][g][b];
194 med += t[r];
195 }
196 break;
197 case GRN:
198 for (g = box[GRN][0]; g < box[GRN][1]; g++) {
199 t[g] = 0;
200 for (b = box[BLU][0]; b < box[BLU][1]; b++)
201 for (r = box[RED][0]; r < box[RED][1]; r++)
202 t[g] += histo[r][g][b];
203 med += t[g];
204 }
205 break;
206 case BLU:
207 for (b = box[BLU][0]; b < box[BLU][1]; b++) {
208 t[b] = 0;
209 for (r = box[RED][0]; r < box[RED][1]; r++)
210 for (g = box[GRN][0]; g < box[GRN][1]; g++)
211 t[b] += histo[r][g][b];
212 med += t[b];
213 }
214 break;
215 }
216 if (med < MINSAMP) /* if too sparse, split at midpoint */
217 return(set_branch(pri,(box[pri][0]+box[pri][1])>>1));
218 /* find median position */
219 med >>= 1;
220 for (c0 = box[pri][0]; med > 0; c0++)
221 med -= t[c0];
222 if (c0 > (box[pri][0]+box[pri][1])>>1) /* if past the midpoint */
223 c0--; /* part left of median */
224 return(set_branch(pri,c0));
225 #undef c0
226 }
227
228
229 static
230 mktabent(p, box) /* compute average color for box and assign */
231 int p;
232 register int box[3][2];
233 {
234 long sum[3];
235 int r, g, n;
236 register int b, c;
237 /* sum pixels in box */
238 n = 0;
239 sum[RED] = sum[GRN] = sum[BLU] = 0;
240 for (r = box[RED][0]; r < box[RED][1]; r++)
241 for (g = box[GRN][0]; g < box[GRN][1]; g++)
242 for (b = box[BLU][0]; b < box[BLU][1]; b++) {
243 if (c = histo[r][g][b]) {
244 n += c;
245 sum[RED] += (long)c*r;
246 sum[GRN] += (long)c*g;
247 sum[BLU] += (long)c*b;
248 }
249 histo[r][g][b] = p; /* assign pixel */
250 }
251 if (n) { /* compute average */
252 clrtab[p][RED] = sum[RED]*256/NRED/n;
253 clrtab[p][GRN] = sum[GRN]*256/NGRN/n;
254 clrtab[p][BLU] = sum[BLU]*256/NBLU/n;
255 } else { /* empty box -- use midpoint */
256 clrtab[p][RED] = (box[RED][0]+box[RED][1])*256/NRED/2;
257 clrtab[p][GRN] = (box[GRN][0]+box[GRN][1])*256/NGRN/2;
258 clrtab[p][BLU] = (box[BLU][0]+box[BLU][1])*256/NBLU/2;
259 }
260 }
261
262
263 #ifdef CLOSEST
264 #define NBSIZ 32
265 static
266 closest(n) /* make sure we have the closest colors */
267 int n;
268 {
269 BYTE *neigh[256];
270 register int r, g, b;
271 #define i r
272 /* get space for neighbor lists */
273 for (i = 0; i < n; i++) {
274 if ((neigh[i] = (BYTE *)malloc(NBSIZ)) == NULL) {
275 while (i--)
276 free(neigh[i]);
277 return; /* ENOMEM -- abandon effort */
278 }
279 neigh[i][0] = i; /* identity is terminator */
280 }
281 /* make neighbor lists */
282 for (r = 0; r < NRED; r++)
283 for (g = 0; g < NGRN; g++)
284 for (b = 0; b < NBLU; b++) {
285 if (r < NRED-1 && histo[r][g][b] != histo[r+1][g][b])
286 addneigh(neigh, histo[r][g][b], histo[r+1][g][b]);
287 if (g < NGRN-1 && histo[r][g][b] != histo[r][g+1][b])
288 addneigh(neigh, histo[r][g][b], histo[r][g+1][b]);
289 if (b < NBLU-1 && histo[r][g][b] != histo[r][g][b+1])
290 addneigh(neigh, histo[r][g][b], histo[r][g][b+1]);
291 }
292 /* assign closest values */
293 for (r = 0; r < NRED; r++)
294 for (g = 0; g < NGRN; g++)
295 for (b = 0; b < NBLU; b++)
296 setclosest(neigh, r, g, b);
297 /* free neighbor lists */
298 for (i = 0; i < n; i++)
299 free(neigh[i]);
300 #undef i
301 }
302
303
304 static
305 addneigh(nl, i, j) /* i and j are neighbors; add them to list */
306 register BYTE *nl[];
307 register int i;
308 int j;
309 {
310 int nc;
311 char *nnl;
312 register int t;
313
314 for (nc = 0; nc < 2; nc++) { /* do both neighbors */
315 for (t = 0; nl[i][t] != i; t++)
316 if (nl[i][t] == j)
317 break; /* in list already */
318 if (nl[i][t] == i) { /* add to list */
319 nl[i][t++] = j;
320 if (t % NBSIZ == 0) { /* enlarge list */
321 if ((nnl = realloc(nl[i], t+NBSIZ)) == NULL)
322 t--;
323 else
324 nl[i] = (BYTE *)nnl;
325 }
326 nl[i][t] = i; /* terminator */
327 }
328 t = i; i = j; j = t; /* swap and do it again */
329 }
330 }
331
332
333 static unsigned
334 dist(col, r, g, b) /* find distance from clrtab entry to r,g,b */
335 register BYTE col[3];
336 int r, g, b;
337 {
338 register unsigned tmp;
339 register unsigned sum;
340
341 tmp = col[RED]*NRED/256 - r;
342 sum = tmp*tmp;
343 tmp = col[GRN]*NGRN/256 - g;
344 sum += tmp*tmp;
345 tmp = col[BLU]*NBLU/256 - b;
346 sum += tmp*tmp;
347 return(sum);
348 }
349
350
351 static
352 setclosest(nl, r, g, b) /* find index closest to color and assign */
353 BYTE *nl[];
354 int r, g, b;
355 {
356 int ident;
357 unsigned min;
358 register unsigned d;
359 register BYTE *p;
360 /* get starting value */
361 min = dist(clrtab[ident=histo[r][g][b]], r, g, b);
362 /* find minimum */
363 for (p = nl[ident]; *p != ident; p++)
364 if ((d = dist(clrtab[*p], r, g, b)) < min) {
365 min = d;
366 histo[r][g][b] = *p;
367 }
368 }
369 #endif
