| 1 |
/* Copyright (c) 1992 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Simple median-cut color quantization based on colortab.c
| 9 |
| 10 |
| 11 |
#include "standard.h"
| 12 |
| 13 |
#include "color.h"
| 14 |
/* histogram resolution */
| 15 |
#define NRED 36
| 16 |
#define NGRN 48
| 17 |
#define NBLU 24
| 18 |
#define HMAX NGRN
| 19 |
/* minimum box count for adaptive partition */
| 20 |
#define MINSAMP 7
| 21 |
/* color partition */
| 22 |
#define set_branch(p,c) ((c)<<2|(p))
| 23 |
#define part(cn) ((cn)>>2)
| 24 |
#define prim(cn) ((cn)&3)
| 25 |
/* our color table (global) */
| 26 |
BYTE clrtab[256][3];
| 27 |
/* histogram of colors / color assignments */
| 28 |
static unsigned histo[NRED][NGRN][NBLU];
| 29 |
#define cndx(c) histo[((c)[RED]*NRED)>>8][((c)[GRN]*NGRN)>>8][((c)[BLU]*NBLU)>>8]
| 30 |
/* initial color cube boundary */
| 31 |
static int CLRCUBE[3][2] = {0,NRED,0,NGRN,0,NBLU};
| 32 |
/* maximum propagated error during dithering */
| 33 |
#define MAXERR 20
| 34 |
/* define CLOSEST to get closest colors */
| 35 |
#define CLOSEST 1
| 36 |
| 37 |
| 38 |
new_histo() /* clear our histogram */
| 39 |
| 40 |
bzero((char *)histo, sizeof(histo));
| 41 |
| 42 |
| 43 |
| 44 |
cnt_pixel(col) /* add pixel to our histogram */
| 45 |
register BYTE col[];
| 46 |
| 47 |
cndx(col)++;
| 48 |
| 49 |
| 50 |
| 51 |
cnt_colrs(cs, n) /* add a scanline to our histogram */
| 52 |
register COLR *cs;
| 53 |
register int n;
| 54 |
| 55 |
while (n-- > 0) {
| 56 |
cndx(cs[0])++;
| 57 |
cs++;
| 58 |
| 59 |
| 60 |
| 61 |
| 62 |
new_clrtab(ncolors) /* make new color table using ncolors */
| 63 |
int ncolors;
| 64 |
| 65 |
if (ncolors < 1)
| 66 |
return(0);
| 67 |
if (ncolors > 256)
| 68 |
ncolors = 256;
| 69 |
/* partition color space */
| 70 |
cut(CLRCUBE, 0, ncolors);
| 71 |
#ifdef CLOSEST
| 72 |
closest(ncolors); /* ensure colors picked are closest */
| 73 |
#endif
| 74 |
/* return new color table size */
| 75 |
return(ncolors);
| 76 |
| 77 |
| 78 |
| 79 |
int
| 80 |
map_pixel(col) /* get pixel for color */
| 81 |
| 82 |
| 83 |
return(cndx(col));
| 84 |
| 85 |
| 86 |
| 87 |
map_colrs(bs, cs, n) /* convert a scanline to color index values */
| 88 |
register BYTE *bs;
| 89 |
register COLR *cs;
| 90 |
register int n;
| 91 |
| 92 |
while (n-- > 0) {
| 93 |
*bs++ = cndx(cs[0]);
| 94 |
cs++;
| 95 |
| 96 |
| 97 |
| 98 |
| 99 |
dith_colrs(bs, cs, n) /* convert scanline to dithered index values */
| 100 |
register BYTE *bs;
| 101 |
register COLR *cs;
| 102 |
int n;
| 103 |
| 104 |
static short (*cerr)[3];
| 105 |
static int N = 0;
| 106 |
int err[3], errp[3];
| 107 |
register int x, i;
| 108 |
| 109 |
if (n != N) { /* get error propogation array */
| 110 |
if (N)
| 111 |
cerr = (short (*)[3])realloc((char *)cerr,
| 112 |
3*n*sizeof(short));
| 113 |
else
| 114 |
cerr = (short (*)[3])malloc(3*n*sizeof(short));
| 115 |
if (cerr == NULL) {
| 116 |
N = 0;
| 117 |
map_colrs(bs, cs, n);
| 118 |
return;
| 119 |
| 120 |
N = n;
| 121 |
bzero((char *)cerr, 3*N*sizeof(short));
| 122 |
| 123 |
err[0] = err[1] = err[2] = 0;
| 124 |
for (x = 0; x < n; x++) {
| 125 |
for (i = 0; i < 3; i++) { /* dither value */
| 126 |
errp[i] = err[i];
| 127 |
err[i] += cerr[x][i];
| 128 |
#ifdef MAXERR
| 129 |
if (err[i] > MAXERR) err[i] = MAXERR;
| 130 |
else if (err[i] < -MAXERR) err[i] = -MAXERR;
| 131 |
#endif
| 132 |
err[i] += cs[x][i];
| 133 |
if (err[i] < 0) err[i] = 0;
| 134 |
else if (err[i] > 255) err[i] = 255;
| 135 |
| 136 |
bs[x] = cndx(err);
| 137 |
for (i = 0; i < 3; i++) { /* propagate error */
| 138 |
err[i] -= clrtab[bs[x]][i];
| 139 |
err[i] /= 3;
| 140 |
cerr[x][i] = err[i] + errp[i];
| 141 |
| 142 |
| 143 |
| 144 |
| 145 |
| 146 |
static
| 147 |
cut(box, c0, c1) /* partition color space */
| 148 |
register int box[3][2];
| 149 |
int c0, c1;
| 150 |
| 151 |
register int branch;
| 152 |
int kb[3][2];
| 153 |
| 154 |
if (c1-c0 <= 1) { /* assign pixel */
| 155 |
mktabent(c0, box);
| 156 |
return;
| 157 |
| 158 |
/* split box */
| 159 |
branch = split(box);
| 160 |
bcopy((char *)box, (char *)kb, sizeof(kb));
| 161 |
/* do left (lesser) branch */
| 162 |
kb[prim(branch)][1] = part(branch);
| 163 |
cut(kb, c0, (c0+c1)>>1);
| 164 |
/* do right branch */
| 165 |
kb[prim(branch)][0] = part(branch);
| 166 |
kb[prim(branch)][1] = box[prim(branch)][1];
| 167 |
cut(kb, (c0+c1)>>1, c1);
| 168 |
| 169 |
| 170 |
| 171 |
static int
| 172 |
split(box) /* find median cut for box */
| 173 |
| 174 |
| 175 |
#define c0 r
| 176 |
register int r, g, b;
| 177 |
int pri;
| 178 |
int t[HMAX], med;
| 179 |
/* find dominant axis */
| 180 |
pri = RED;
| 181 |
if (box[GRN][1]-box[GRN][0] > box[pri][1]-box[pri][0])
| 182 |
pri = GRN;
| 183 |
if (box[BLU][1]-box[BLU][0] > box[pri][1]-box[pri][0])
| 184 |
pri = BLU;
| 185 |
/* sum histogram over box */
| 186 |
med = 0;
| 187 |
switch (pri) {
| 188 |
case RED:
| 189 |
for (r = box[RED][0]; r < box[RED][1]; r++) {
| 190 |
t[r] = 0;
| 191 |
for (g = box[GRN][0]; g < box[GRN][1]; g++)
| 192 |
for (b = box[BLU][0]; b < box[BLU][1]; b++)
| 193 |
t[r] += histo[r][g][b];
| 194 |
med += t[r];
| 195 |
| 196 |
break;
| 197 |
case GRN:
| 198 |
for (g = box[GRN][0]; g < box[GRN][1]; g++) {
| 199 |
t[g] = 0;
| 200 |
| 201 |
| 202 |
t[g] += histo[r][g][b];
| 203 |
med += t[g];
| 204 |
| 205 |
break;
| 206 |
case BLU:
| 207 |
for (b = box[BLU][0]; b < box[BLU][1]; b++) {
| 208 |
t[b] = 0;
| 209 |
| 210 |
| 211 |
t[b] += histo[r][g][b];
| 212 |
med += t[b];
| 213 |
| 214 |
break;
| 215 |
| 216 |
if (med < MINSAMP) /* if too sparse, split at midpoint */
| 217 |
return(set_branch(pri,(box[pri][0]+box[pri][1])>>1));
| 218 |
/* find median position */
| 219 |
med >>= 1;
| 220 |
for (c0 = box[pri][0]; med > 0; c0++)
| 221 |
med -= t[c0];
| 222 |
if (c0 > (box[pri][0]+box[pri][1])>>1) /* if past the midpoint */
| 223 |
c0--; /* part left of median */
| 224 |
return(set_branch(pri,c0));
| 225 |
#undef c0
| 226 |
| 227 |
| 228 |
| 229 |
static
| 230 |
mktabent(p, box) /* compute average color for box and assign */
| 231 |
int p;
| 232 |
| 233 |
| 234 |
long sum[3];
| 235 |
int r, g, n;
| 236 |
register int b, c;
| 237 |
/* sum pixels in box */
| 238 |
n = 0;
| 239 |
sum[RED] = sum[GRN] = sum[BLU] = 0;
| 240 |
| 241 |
| 242 |
| 243 |
if (c = histo[r][g][b]) {
| 244 |
n += c;
| 245 |
sum[RED] += (long)c*r;
| 246 |
sum[GRN] += (long)c*g;
| 247 |
sum[BLU] += (long)c*b;
| 248 |
| 249 |
histo[r][g][b] = p; /* assign pixel */
| 250 |
| 251 |
if (n) { /* compute average */
| 252 |
clrtab[p][RED] = sum[RED]*256/NRED/n;
| 253 |
clrtab[p][GRN] = sum[GRN]*256/NGRN/n;
| 254 |
clrtab[p][BLU] = sum[BLU]*256/NBLU/n;
| 255 |
} else { /* empty box -- use midpoint */
| 256 |
clrtab[p][RED] = (box[RED][0]+box[RED][1])*256/NRED/2;
| 257 |
clrtab[p][GRN] = (box[GRN][0]+box[GRN][1])*256/NGRN/2;
| 258 |
clrtab[p][BLU] = (box[BLU][0]+box[BLU][1])*256/NBLU/2;
| 259 |
| 260 |
| 261 |
| 262 |
| 263 |
#ifdef CLOSEST
| 264 |
#define NBSIZ 32
| 265 |
static
| 266 |
closest(n) /* make sure we have the closest colors */
| 267 |
int n;
| 268 |
| 269 |
BYTE *neigh[256];
| 270 |
| 271 |
#define i r
| 272 |
/* get space for neighbor lists */
| 273 |
for (i = 0; i < n; i++) {
| 274 |
if ((neigh[i] = (BYTE *)malloc(NBSIZ)) == NULL) {
| 275 |
while (i--)
| 276 |
free(neigh[i]);
| 277 |
return; /* ENOMEM -- abandon effort */
| 278 |
| 279 |
neigh[i][0] = i; /* identity is terminator */
| 280 |
| 281 |
/* make neighbor lists */
| 282 |
for (r = 0; r < NRED; r++)
| 283 |
for (g = 0; g < NGRN; g++)
| 284 |
for (b = 0; b < NBLU; b++) {
| 285 |
if (r < NRED-1 && histo[r][g][b] != histo[r+1][g][b])
| 286 |
addneigh(neigh, histo[r][g][b], histo[r+1][g][b]);
| 287 |
if (g < NGRN-1 && histo[r][g][b] != histo[r][g+1][b])
| 288 |
addneigh(neigh, histo[r][g][b], histo[r][g+1][b]);
| 289 |
if (b < NBLU-1 && histo[r][g][b] != histo[r][g][b+1])
| 290 |
addneigh(neigh, histo[r][g][b], histo[r][g][b+1]);
| 291 |
| 292 |
/* assign closest values */
| 293 |
| 294 |
| 295 |
| 296 |
setclosest(neigh, r, g, b);
| 297 |
/* free neighbor lists */
| 298 |
| 299 |
free(neigh[i]);
| 300 |
#undef i
| 301 |
| 302 |
| 303 |
| 304 |
static
| 305 |
addneigh(nl, i, j) /* i and j are neighbors; add them to list */
| 306 |
register BYTE *nl[];
| 307 |
register int i;
| 308 |
int j;
| 309 |
| 310 |
int nc;
| 311 |
char *nnl;
| 312 |
register int t;
| 313 |
| 314 |
for (nc = 0; nc < 2; nc++) { /* do both neighbors */
| 315 |
for (t = 0; nl[i][t] != i; t++)
| 316 |
if (nl[i][t] == j)
| 317 |
break; /* in list already */
| 318 |
if (nl[i][t] == i) { /* add to list */
| 319 |
nl[i][t++] = j;
| 320 |
if (t % NBSIZ == 0) { /* enlarge list */
| 321 |
if ((nnl = realloc(nl[i], t+NBSIZ)) == NULL)
| 322 |
t--;
| 323 |
else
| 324 |
nl[i] = (BYTE *)nnl;
| 325 |
| 326 |
nl[i][t] = i; /* terminator */
| 327 |
| 328 |
t = i; i = j; j = t; /* swap and do it again */
| 329 |
| 330 |
| 331 |
| 332 |
| 333 |
static unsigned
| 334 |
dist(col, r, g, b) /* find distance from clrtab entry to r,g,b */
| 335 |
register BYTE col[3];
| 336 |
int r, g, b;
| 337 |
| 338 |
register unsigned tmp;
| 339 |
register unsigned sum;
| 340 |
| 341 |
tmp = col[RED]*NRED/256 - r;
| 342 |
sum = tmp*tmp;
| 343 |
tmp = col[GRN]*NGRN/256 - g;
| 344 |
sum += tmp*tmp;
| 345 |
tmp = col[BLU]*NBLU/256 - b;
| 346 |
sum += tmp*tmp;
| 347 |
return(sum);
| 348 |
| 349 |
| 350 |
| 351 |
static
| 352 |
setclosest(nl, r, g, b) /* find index closest to color and assign */
| 353 |
BYTE *nl[];
| 354 |
int r, g, b;
| 355 |
| 356 |
int ident;
| 357 |
unsigned min;
| 358 |
register unsigned d;
| 359 |
register BYTE *p;
| 360 |
/* get starting value */
| 361 |
min = dist(clrtab[ident=histo[r][g][b]], r, g, b);
| 362 |
/* find minimum */
| 363 |
for (p = nl[ident]; *p != ident; p++)
| 364 |
if ((d = dist(clrtab[*p], r, g, b)) < min) {
| 365 |
min = d;
| 366 |
histo[r][g][b] = *p;
| 367 |
| 368 |
| 369 |
#endif
