1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: clrtab.c,v 2.15 2003/06/30 14:59:12 schorsch Exp $"; |
3 |
#endif |
4 |
5 |
* Simple median-cut color quantization based on colortab.c |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include <string.h> |
11 |
12 |
#include "standard.h" |
13 |
#include "color.h" |
14 |
15 |
/* histogram resolution */ |
16 |
#define NRED 36 |
17 |
#define NGRN 48 |
18 |
#define NBLU 24 |
19 |
#define HMAX NGRN |
20 |
/* minimum box count for adaptive partition */ |
21 |
#define MINSAMP 7 |
22 |
/* color partition */ |
23 |
#define set_branch(p,c) ((c)<<2|(p)) |
24 |
#define part(cn) ((cn)>>2) |
25 |
#define prim(cn) ((cn)&3) |
26 |
/* our color table (global) */ |
27 |
extern BYTE clrtab[256][3]; |
28 |
/* histogram of colors / color assignments */ |
29 |
static unsigned histo[NRED][NGRN][NBLU]; |
30 |
#define cndx(c) histo[((c)[RED]*NRED)>>8][((c)[GRN]*NGRN)>>8][((c)[BLU]*NBLU)>>8] |
31 |
/* initial color cube boundary */ |
32 |
static int CLRCUBE[3][2] = {0,NRED,0,NGRN,0,NBLU}; |
33 |
/* maximum propagated error during dithering */ |
34 |
#define MAXERR 20 |
35 |
/* define CLOSEST to get closest colors */ |
36 |
#ifndef CLOSEST |
37 |
#ifdef SPEED |
38 |
#if SPEED > 8 |
39 |
#define CLOSEST 1 /* this step takes a little longer */ |
40 |
#endif |
41 |
#endif |
42 |
#endif |
43 |
44 |
static cut(), mktabent(), closest(), addneigh(), setclosest(); |
45 |
static int split(); |
46 |
static unsigned dist(); |
47 |
48 |
49 |
new_histo(n) /* clear our histogram */ |
50 |
int n; |
51 |
52 |
memset((void *)histo, '\0', sizeof(histo)); |
53 |
return(0); |
54 |
55 |
56 |
57 |
cnt_pixel(col) /* add pixel to our histogram */ |
58 |
register BYTE col[]; |
59 |
60 |
cndx(col)++; |
61 |
62 |
63 |
64 |
cnt_colrs(cs, n) /* add a scanline to our histogram */ |
65 |
register COLR *cs; |
66 |
register int n; |
67 |
68 |
while (n-- > 0) { |
69 |
cndx(cs[0])++; |
70 |
cs++; |
71 |
72 |
73 |
74 |
75 |
new_clrtab(ncolors) /* make new color table using ncolors */ |
76 |
int ncolors; |
77 |
78 |
if (ncolors < 1) |
79 |
return(0); |
80 |
if (ncolors > 256) |
81 |
ncolors = 256; |
82 |
/* partition color space */ |
83 |
cut(CLRCUBE, 0, ncolors); |
84 |
#ifdef CLOSEST |
85 |
closest(ncolors); /* ensure colors picked are closest */ |
86 |
#endif |
87 |
/* reset dithering function */ |
88 |
dith_colrs((BYTE *)NULL, (COLR *)NULL, 0); |
89 |
/* return new color table size */ |
90 |
return(ncolors); |
91 |
92 |
93 |
94 |
int |
95 |
map_pixel(col) /* get pixel for color */ |
96 |
97 |
98 |
return(cndx(col)); |
99 |
100 |
101 |
102 |
map_colrs(bs, cs, n) /* convert a scanline to color index values */ |
103 |
register BYTE *bs; |
104 |
105 |
register int n; |
106 |
107 |
while (n-- > 0) { |
108 |
*bs++ = cndx(cs[0]); |
109 |
cs++; |
110 |
111 |
112 |
113 |
114 |
dith_colrs(bs, cs, n) /* convert scanline to dithered index values */ |
115 |
116 |
117 |
int n; |
118 |
119 |
static short (*cerr)[3] = NULL; |
120 |
static int N = 0; |
121 |
int err[3], errp[3]; |
122 |
register int x, i; |
123 |
124 |
if (n != N) { /* get error propogation array */ |
125 |
if (N) { |
126 |
free((void *)cerr); |
127 |
cerr = NULL; |
128 |
129 |
if (n) |
130 |
cerr = (short (*)[3])malloc(3*n*sizeof(short)); |
131 |
if (cerr == NULL) { |
132 |
N = 0; |
133 |
map_colrs(bs, cs, n); |
134 |
return; |
135 |
136 |
N = n; |
137 |
memset((void *)cerr, '\0', 3*N*sizeof(short)); |
138 |
139 |
err[0] = err[1] = err[2] = 0; |
140 |
for (x = 0; x < n; x++) { |
141 |
for (i = 0; i < 3; i++) { /* dither value */ |
142 |
errp[i] = err[i]; |
143 |
err[i] += cerr[x][i]; |
144 |
#ifdef MAXERR |
145 |
if (err[i] > MAXERR) err[i] = MAXERR; |
146 |
else if (err[i] < -MAXERR) err[i] = -MAXERR; |
147 |
#endif |
148 |
err[i] += cs[x][i]; |
149 |
if (err[i] < 0) err[i] = 0; |
150 |
else if (err[i] > 255) err[i] = 255; |
151 |
152 |
bs[x] = cndx(err); |
153 |
for (i = 0; i < 3; i++) { /* propagate error */ |
154 |
err[i] -= clrtab[bs[x]][i]; |
155 |
err[i] /= 3; |
156 |
cerr[x][i] = err[i] + errp[i]; |
157 |
158 |
159 |
160 |
161 |
162 |
static |
163 |
cut(box, c0, c1) /* partition color space */ |
164 |
register int box[3][2]; |
165 |
int c0, c1; |
166 |
167 |
register int branch; |
168 |
int kb[3][2]; |
169 |
170 |
if (c1-c0 <= 1) { /* assign pixel */ |
171 |
mktabent(c0, box); |
172 |
return; |
173 |
174 |
/* split box */ |
175 |
branch = split(box); |
176 |
memcpy((void *)kb, (void *)box, sizeof(kb)); |
177 |
/* do left (lesser) branch */ |
178 |
kb[prim(branch)][1] = part(branch); |
179 |
cut(kb, c0, (c0+c1)>>1); |
180 |
/* do right branch */ |
181 |
kb[prim(branch)][0] = part(branch); |
182 |
kb[prim(branch)][1] = box[prim(branch)][1]; |
183 |
cut(kb, (c0+c1)>>1, c1); |
184 |
185 |
186 |
187 |
static int |
188 |
split(box) /* find median cut for box */ |
189 |
190 |
191 |
#define c0 r |
192 |
register int r, g, b; |
193 |
int pri; |
194 |
long t[HMAX], med; |
195 |
/* find dominant axis */ |
196 |
pri = RED; |
197 |
if (box[GRN][1]-box[GRN][0] > box[pri][1]-box[pri][0]) |
198 |
pri = GRN; |
199 |
if (box[BLU][1]-box[BLU][0] > box[pri][1]-box[pri][0]) |
200 |
pri = BLU; |
201 |
/* sum histogram over box */ |
202 |
med = 0; |
203 |
switch (pri) { |
204 |
case RED: |
205 |
for (r = box[RED][0]; r < box[RED][1]; r++) { |
206 |
t[r] = 0; |
207 |
for (g = box[GRN][0]; g < box[GRN][1]; g++) |
208 |
for (b = box[BLU][0]; b < box[BLU][1]; b++) |
209 |
t[r] += histo[r][g][b]; |
210 |
med += t[r]; |
211 |
212 |
break; |
213 |
case GRN: |
214 |
for (g = box[GRN][0]; g < box[GRN][1]; g++) { |
215 |
t[g] = 0; |
216 |
217 |
for (r = box[RED][0]; r < box[RED][1]; r++) |
218 |
t[g] += histo[r][g][b]; |
219 |
med += t[g]; |
220 |
221 |
break; |
222 |
case BLU: |
223 |
for (b = box[BLU][0]; b < box[BLU][1]; b++) { |
224 |
t[b] = 0; |
225 |
226 |
227 |
t[b] += histo[r][g][b]; |
228 |
med += t[b]; |
229 |
230 |
break; |
231 |
232 |
if (med < MINSAMP) /* if too sparse, split at midpoint */ |
233 |
return(set_branch(pri,(box[pri][0]+box[pri][1])>>1)); |
234 |
/* find median position */ |
235 |
med >>= 1; |
236 |
for (c0 = box[pri][0]; med > 0; c0++) |
237 |
med -= t[c0]; |
238 |
if (c0 > (box[pri][0]+box[pri][1])>>1) /* if past the midpoint */ |
239 |
c0--; /* part left of median */ |
240 |
return(set_branch(pri,c0)); |
241 |
#undef c0 |
242 |
243 |
244 |
245 |
static |
246 |
mktabent(p, box) /* compute average color for box and assign */ |
247 |
int p; |
248 |
249 |
250 |
unsigned long sum[3]; |
251 |
unsigned r, g; |
252 |
unsigned long n; |
253 |
register unsigned b, c; |
254 |
/* sum pixels in box */ |
255 |
n = 0; |
256 |
sum[RED] = sum[GRN] = sum[BLU] = 0; |
257 |
258 |
259 |
260 |
if ( (c = histo[r][g][b]) ) { |
261 |
n += c; |
262 |
sum[RED] += (long)c*r; |
263 |
sum[GRN] += (long)c*g; |
264 |
sum[BLU] += (long)c*b; |
265 |
266 |
histo[r][g][b] = p; /* assign pixel */ |
267 |
268 |
if (n >= (1L<<23)/HMAX) { /* avoid overflow */ |
269 |
sum[RED] /= n; |
270 |
sum[GRN] /= n; |
271 |
sum[BLU] /= n; |
272 |
n = 1; |
273 |
274 |
if (n) { /* compute average */ |
275 |
clrtab[p][RED] = sum[RED]*256/NRED/n; |
276 |
clrtab[p][GRN] = sum[GRN]*256/NGRN/n; |
277 |
clrtab[p][BLU] = sum[BLU]*256/NBLU/n; |
278 |
} else { /* empty box -- use midpoint */ |
279 |
clrtab[p][RED] = (box[RED][0]+box[RED][1])*256/NRED/2; |
280 |
clrtab[p][GRN] = (box[GRN][0]+box[GRN][1])*256/NGRN/2; |
281 |
clrtab[p][BLU] = (box[BLU][0]+box[BLU][1])*256/NBLU/2; |
282 |
283 |
284 |
285 |
286 |
#ifdef CLOSEST |
287 |
#define NBSIZ 32 |
288 |
static |
289 |
closest(n) /* make sure we have the closest colors */ |
290 |
int n; |
291 |
292 |
BYTE *neigh[256]; |
293 |
294 |
#define i r |
295 |
/* get space for neighbor lists */ |
296 |
for (i = 0; i < n; i++) { |
297 |
if ((neigh[i] = (BYTE *)malloc(NBSIZ)) == NULL) { |
298 |
while (i--) |
299 |
free(neigh[i]); |
300 |
return; /* ENOMEM -- abandon effort */ |
301 |
302 |
neigh[i][0] = i; /* identity is terminator */ |
303 |
304 |
/* make neighbor lists */ |
305 |
for (r = 0; r < NRED; r++) |
306 |
for (g = 0; g < NGRN; g++) |
307 |
for (b = 0; b < NBLU; b++) { |
308 |
if (r < NRED-1 && histo[r][g][b] != histo[r+1][g][b]) |
309 |
addneigh(neigh, histo[r][g][b], histo[r+1][g][b]); |
310 |
if (g < NGRN-1 && histo[r][g][b] != histo[r][g+1][b]) |
311 |
addneigh(neigh, histo[r][g][b], histo[r][g+1][b]); |
312 |
if (b < NBLU-1 && histo[r][g][b] != histo[r][g][b+1]) |
313 |
addneigh(neigh, histo[r][g][b], histo[r][g][b+1]); |
314 |
315 |
/* assign closest values */ |
316 |
317 |
318 |
for (b = 0; b < NBLU; b++) |
319 |
setclosest(neigh, r, g, b); |
320 |
/* free neighbor lists */ |
321 |
for (i = 0; i < n; i++) |
322 |
free(neigh[i]); |
323 |
#undef i |
324 |
325 |
326 |
327 |
static |
328 |
addneigh(nl, i, j) /* i and j are neighbors; add them to list */ |
329 |
register BYTE *nl[]; |
330 |
register int i; |
331 |
int j; |
332 |
333 |
int nc; |
334 |
char *nnl; |
335 |
register int t; |
336 |
337 |
for (nc = 0; nc < 2; nc++) { /* do both neighbors */ |
338 |
for (t = 0; nl[i][t] != i; t++) |
339 |
if (nl[i][t] == j) |
340 |
break; /* in list already */ |
341 |
if (nl[i][t] == i) { /* add to list */ |
342 |
nl[i][t++] = j; |
343 |
if (t % NBSIZ == 0) { /* enlarge list */ |
344 |
if ((nnl = realloc((void *)nl[i], |
345 |
t+NBSIZ)) == NULL) |
346 |
t--; |
347 |
else |
348 |
nl[i] = (BYTE *)nnl; |
349 |
350 |
nl[i][t] = i; /* terminator */ |
351 |
352 |
t = i; i = j; j = t; /* swap and do it again */ |
353 |
354 |
355 |
356 |
357 |
static unsigned |
358 |
dist(col, r, g, b) /* find distance from clrtab entry to r,g,b */ |
359 |
register BYTE col[3]; |
360 |
int r, g, b; |
361 |
362 |
register int tmp; |
363 |
register unsigned sum; |
364 |
365 |
tmp = col[RED]*NRED/256 - r; |
366 |
sum = tmp*tmp; |
367 |
tmp = col[GRN]*NGRN/256 - g; |
368 |
sum += tmp*tmp; |
369 |
tmp = col[BLU]*NBLU/256 - b; |
370 |
sum += tmp*tmp; |
371 |
return(sum); |
372 |
373 |
374 |
375 |
static |
376 |
setclosest(nl, r, g, b) /* find index closest to color and assign */ |
377 |
BYTE *nl[]; |
378 |
int r, g, b; |
379 |
380 |
int ident; |
381 |
unsigned min; |
382 |
register unsigned d; |
383 |
register BYTE *p; |
384 |
/* get starting value */ |
385 |
min = dist(clrtab[ident=histo[r][g][b]], r, g, b); |
386 |
/* find minimum */ |
387 |
for (p = nl[ident]; *p != ident; p++) |
388 |
if ((d = dist(clrtab[*p], r, g, b)) < min) { |
389 |
min = d; |
390 |
histo[r][g][b] = *p; |
391 |
392 |
393 |
#endif |
