--- ray/src/px/clrtab.c 2003/06/30 14:59:12 2.15 +++ ray/src/px/clrtab.c 2011/05/20 02:06:39 2.19 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: clrtab.c,v 2.15 2003/06/30 14:59:12 schorsch Exp $"; +static const char RCSid[] = "$Id: clrtab.c,v 2.19 2011/05/20 02:06:39 greg Exp $"; #endif /* * Simple median-cut color quantization based on colortab.c @@ -11,6 +11,7 @@ static const char RCSid[] = "$Id: clrtab.c,v 2.15 2003 #include "standard.h" #include "color.h" +#include "clrtab.h" /* histogram resolution */ #define NRED 36 @@ -24,46 +25,55 @@ static const char RCSid[] = "$Id: clrtab.c,v 2.15 2003 #define part(cn) ((cn)>>2) #define prim(cn) ((cn)&3) /* our color table (global) */ -extern BYTE clrtab[256][3]; +extern uby8 clrtab[256][3]; /* histogram of colors / color assignments */ static unsigned histo[NRED][NGRN][NBLU]; #define cndx(c) histo[((c)[RED]*NRED)>>8][((c)[GRN]*NGRN)>>8][((c)[BLU]*NBLU)>>8] /* initial color cube boundary */ -static int CLRCUBE[3][2] = {0,NRED,0,NGRN,0,NBLU}; +static int CLRCUBE[3][2] = {{0,NRED},{0,NGRN},{0,NBLU}}; /* maximum propagated error during dithering */ #define MAXERR 20 /* define CLOSEST to get closest colors */ #ifndef CLOSEST -#ifdef SPEED -#if SPEED > 8 #define CLOSEST 1 /* this step takes a little longer */ #endif -#endif -#endif -static cut(), mktabent(), closest(), addneigh(), setclosest(); -static int split(); -static unsigned dist(); +#ifdef CLOSEST +static void closest(int n); +static void setclosest(uby8 *nl[], int r, int g, int b); +static void addneigh(uby8 *nl[], int i, int j); +static unsigned int dist(uby8 col[3], int r, int g, int b); +#endif +static void cut(int box[3][2], int c0, int c1); +static int split(int box[3][2]); +static void mktabent(int p, int box[3][2]); -new_histo(n) /* clear our histogram */ -int n; + +extern int +new_histo( /* clear our histogram */ + int n +) { memset((void *)histo, '\0', sizeof(histo)); return(0); } -cnt_pixel(col) /* add pixel to our histogram */ -register BYTE col[]; +extern void +cnt_pixel( /* add pixel to our histogram */ + register uby8 col[] +) { cndx(col)++; } -cnt_colrs(cs, n) /* add a scanline to our histogram */ -register COLR *cs; -register int n; +extern void +cnt_colrs( /* add a scanline to our histogram */ + register COLR *cs, + register int n +) { while (n-- > 0) { cndx(cs[0])++; @@ -72,8 +82,10 @@ register int n; } -new_clrtab(ncolors) /* make new color table using ncolors */ -int ncolors; +extern int +new_clrtab( /* make new color table using ncolors */ + int ncolors +) { if (ncolors < 1) return(0); @@ -85,24 +97,27 @@ int ncolors; closest(ncolors); /* ensure colors picked are closest */ #endif /* reset dithering function */ - dith_colrs((BYTE *)NULL, (COLR *)NULL, 0); + dith_colrs((uby8 *)NULL, (COLR *)NULL, 0); /* return new color table size */ return(ncolors); } -int -map_pixel(col) /* get pixel for color */ -register BYTE col[]; +extern int +map_pixel( /* get pixel for color */ + register uby8 col[] +) { return(cndx(col)); } -map_colrs(bs, cs, n) /* convert a scanline to color index values */ -register BYTE *bs; -register COLR *cs; -register int n; +extern void +map_colrs( /* convert a scanline to color index values */ + register uby8 *bs, + register COLR *cs, + register int n +) { while (n-- > 0) { *bs++ = cndx(cs[0]); @@ -111,10 +126,12 @@ register int n; } -dith_colrs(bs, cs, n) /* convert scanline to dithered index values */ -register BYTE *bs; -register COLR *cs; -int n; +extern void +dith_colrs( /* convert scanline to dithered index values */ + register uby8 *bs, + register COLR *cs, + int n +) { static short (*cerr)[3] = NULL; static int N = 0; @@ -159,10 +176,12 @@ int n; } -static -cut(box, c0, c1) /* partition color space */ -register int box[3][2]; -int c0, c1; +static void +cut( /* partition color space */ + register int box[3][2], + int c0, + int c1 +) { register int branch; int kb[3][2]; @@ -185,8 +204,9 @@ int c0, c1; static int -split(box) /* find median cut for box */ -register int box[3][2]; +split( /* find median cut for box */ + register int box[3][2] +) { #define c0 r register int r, g, b; @@ -242,10 +262,11 @@ register int box[3][2]; } -static -mktabent(p, box) /* compute average color for box and assign */ -int p; -register int box[3][2]; +static void +mktabent( /* compute average color for box and assign */ + int p, + register int box[3][2] +) { unsigned long sum[3]; unsigned r, g; @@ -257,7 +278,7 @@ register int box[3][2]; for (r = box[RED][0]; r < box[RED][1]; r++) for (g = box[GRN][0]; g < box[GRN][1]; g++) for (b = box[BLU][0]; b < box[BLU][1]; b++) { - if (c = histo[r][g][b]) { + if ( (c = histo[r][g][b]) ) { n += c; sum[RED] += (long)c*r; sum[GRN] += (long)c*g; @@ -285,16 +306,17 @@ register int box[3][2]; #ifdef CLOSEST #define NBSIZ 32 -static -closest(n) /* make sure we have the closest colors */ -int n; +static void +closest( /* make sure we have the closest colors */ + int n +) { - BYTE *neigh[256]; + uby8 *neigh[256]; register int r, g, b; #define i r /* get space for neighbor lists */ for (i = 0; i < n; i++) { - if ((neigh[i] = (BYTE *)malloc(NBSIZ)) == NULL) { + if ((neigh[i] = (uby8 *)malloc(NBSIZ)) == NULL) { while (i--) free(neigh[i]); return; /* ENOMEM -- abandon effort */ @@ -324,11 +346,12 @@ int n; } -static -addneigh(nl, i, j) /* i and j are neighbors; add them to list */ -register BYTE *nl[]; -register int i; -int j; +static void +addneigh( /* i and j are neighbors; add them to list */ + register uby8 *nl[], + register int i, + int j +) { int nc; char *nnl; @@ -345,7 +368,7 @@ int j; t+NBSIZ)) == NULL) t--; else - nl[i] = (BYTE *)nnl; + nl[i] = (uby8 *)nnl; } nl[i][t] = i; /* terminator */ } @@ -354,10 +377,13 @@ int j; } -static unsigned -dist(col, r, g, b) /* find distance from clrtab entry to r,g,b */ -register BYTE col[3]; -int r, g, b; +static unsigned int +dist( /* find distance from clrtab entry to r,g,b */ + register uby8 col[3], + int r, + int g, + int b +) { register int tmp; register unsigned sum; @@ -372,15 +398,18 @@ int r, g, b; } -static -setclosest(nl, r, g, b) /* find index closest to color and assign */ -BYTE *nl[]; -int r, g, b; +static void +setclosest( /* find index closest to color and assign */ + uby8 *nl[], + int r, + int g, + int b +) { int ident; unsigned min; register unsigned d; - register BYTE *p; + register uby8 *p; /* get starting value */ min = dist(clrtab[ident=histo[r][g][b]], r, g, b); /* find minimum */
