--- ray/src/px/clrtab.c 1992/10/12 12:58:39 2.1 +++ ray/src/px/clrtab.c 1992/10/13 09:07:51 2.2 @@ -31,6 +31,8 @@ static unsigned histo[NRED][NGRN][NBLU]; static int CLRCUBE[3][2] = {0,NRED,0,NGRN,0,NBLU}; /* maximum propagated error during dithering */ #define MAXERR 20 + /* define CLOSEST to get closest colors */ +#define CLOSEST 1 new_histo() /* clear our histogram */ @@ -66,6 +68,9 @@ int ncolors; ncolors = 256; /* partition color space */ cut(CLRCUBE, 0, ncolors); +#ifdef CLOSEST + closest(ncolors); /* ensure colors picked are closest */ +#endif /* return new color table size */ return(ncolors); } @@ -253,3 +258,112 @@ register int box[3][2]; clrtab[p][BLU] = (box[BLU][0]+box[BLU][1])*256/NBLU/2; } } + + +#ifdef CLOSEST +#define NBSIZ 32 +static +closest(n) /* make sure we have the closest colors */ +int n; +{ + BYTE *neigh[256]; + register int r, g, b; +#define i r + /* get space for neighbor lists */ + for (i = 0; i < n; i++) { + if ((neigh[i] = (BYTE *)malloc(NBSIZ)) == NULL) { + while (i--) + free(neigh[i]); + return; /* ENOMEM -- abandon effort */ + } + neigh[i][0] = i; /* identity is terminator */ + } + /* make neighbor lists */ + for (r = 0; r < NRED-1; r++) + for (g = 0; g < NGRN-1; g++) + for (b = 0; b < NBLU-1; b++) { + if (histo[r][g][b] != histo[r+1][g][b]) + addneigh(neigh, histo[r][g][b], histo[r+1][g][b]); + if (histo[r][g][b] != histo[r][g+1][b]) + addneigh(neigh, histo[r][g][b], histo[r][g+1][b]); + if (histo[r][g][b] != histo[r][g][b+1]) + addneigh(neigh, histo[r][g][b], histo[r][g][b+1]); + } + /* assign closest values */ + for (r = 0; r < NRED; r++) + for (g = 0; g < NGRN; g++) + for (b = 0; b < NBLU; b++) + setclosest(neigh, r, g, b); + /* free neighbor lists */ + for (i = 0; i < n; i++) + free(neigh[i]); +#undef i +} + + +static +addneigh(nl, i, j) /* i and j are neighbors; add them to list */ +register BYTE *nl[]; +register int i; +int j; +{ + int nc; + char *nnl; + register int t; + + for (nc = 0; nc < 2; nc++) { /* do both neighbors */ + for (t = 0; nl[i][t] != i; t++) + if (nl[i][t] == j) + break; /* in list already */ + if (nl[i][t] == i) { /* add to list */ + nl[i][t++] = j; + if (t % NBSIZ == 0) { /* enlarge list */ + if ((nnl = realloc(nl[i], t+NBSIZ)) == NULL) + t--; + else + nl[i] = (BYTE *)nnl; + } + nl[i][t] = i; /* terminator */ + } + t = i; i = j; j = t; /* swap and do it again */ + } +} + + +static unsigned +dist(col, r, g, b) /* find distance from clrtab entry to r,g,b */ +register BYTE col[3]; +int r, g, b; +{ + register unsigned tmp; + register unsigned sum; + + tmp = col[RED]*NRED/256 - r; + sum = tmp*tmp; + tmp = col[GRN]*NGRN/256 - g; + sum += tmp*tmp; + tmp = col[BLU]*NBLU/256 - b; + sum += tmp*tmp; + return(sum); +} + + +static +setclosest(nl, r, g, b) /* find index closest to color and assign */ +BYTE *nl[]; +int r, g, b; +{ + int ident; + unsigned min; + register unsigned d; + register BYTE *p; + /* get starting value */ + min = dist(clrtab[ident=histo[r][g][b]], r, g, b); + /* find minimum */ + for (p = nl[ident]; *p != ident; p++) + if ((d = dist(clrtab[*p], r, g, b)) < min) { + min = d; + histo[r][g][b] = *p; + } +} +#endif
