root/Development/ray/src/px/clrtab.c
Revision: 2.19
Committed: Fri May 20 02:06:39 2011 UTC (14 years, 7 months ago) by greg
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1, HEAD
Changes since 2.18: +17 -17 lines
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.19 static const char RCSid[] = "$Id: clrtab.c,v 2.18 2005/09/19 02:23:58 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Simple median-cut color quantization based on colortab.c
6     */
7
8 schorsch 2.15 #include "copyright.h"
9
10     #include <string.h>
11
12 greg 2.1 #include "standard.h"
13 schorsch 2.15 #include "color.h"
14 schorsch 2.17 #include "clrtab.h"
15 greg 2.1
16     /* histogram resolution */
17     #define NRED 36
18     #define NGRN 48
19     #define NBLU 24
20     #define HMAX NGRN
21     /* minimum box count for adaptive partition */
22     #define MINSAMP 7
23     /* color partition */
24     #define set_branch(p,c) ((c)<<2|(p))
25     #define part(cn) ((cn)>>2)
26     #define prim(cn) ((cn)&3)
27     /* our color table (global) */
28 greg 2.19 extern uby8 clrtab[256][3];
29 greg 2.1 /* histogram of colors / color assignments */
30     static unsigned histo[NRED][NGRN][NBLU];
31     #define cndx(c) histo[((c)[RED]*NRED)>>8][((c)[GRN]*NGRN)>>8][((c)[BLU]*NBLU)>>8]
32     /* initial color cube boundary */
33 schorsch 2.17 static int CLRCUBE[3][2] = {{0,NRED},{0,NGRN},{0,NBLU}};
34 greg 2.1 /* maximum propagated error during dithering */
35     #define MAXERR 20
36 greg 2.2 /* define CLOSEST to get closest colors */
37 greg 2.4 #ifndef CLOSEST
38     #define CLOSEST 1 /* this step takes a little longer */
39     #endif
40 greg 2.1
41 schorsch 2.17
42     #ifdef CLOSEST
43     static void closest(int n);
44 greg 2.19 static void setclosest(uby8 *nl[], int r, int g, int b);
45     static void addneigh(uby8 *nl[], int i, int j);
46     static unsigned int dist(uby8 col[3], int r, int g, int b);
47 schorsch 2.17 #endif
48     static void cut(int box[3][2], int c0, int c1);
49     static int split(int box[3][2]);
50     static void mktabent(int p, int box[3][2]);
51 greg 2.11
52 greg 2.1
53 schorsch 2.17 extern int
54     new_histo( /* clear our histogram */
55     int n
56     )
57 greg 2.1 {
58 schorsch 2.15 memset((void *)histo, '\0', sizeof(histo));
59 greg 2.10 return(0);
60 greg 2.1 }
61
62
63 schorsch 2.17 extern void
64     cnt_pixel( /* add pixel to our histogram */
65 greg 2.19 register uby8 col[]
66 schorsch 2.17 )
67 greg 2.1 {
68     cndx(col)++;
69     }
70
71
72 schorsch 2.17 extern void
73     cnt_colrs( /* add a scanline to our histogram */
74     register COLR *cs,
75     register int n
76     )
77 greg 2.1 {
78     while (n-- > 0) {
79     cndx(cs[0])++;
80     cs++;
81     }
82     }
83
84
85 schorsch 2.17 extern int
86     new_clrtab( /* make new color table using ncolors */
87     int ncolors
88     )
89 greg 2.1 {
90     if (ncolors < 1)
91     return(0);
92     if (ncolors > 256)
93     ncolors = 256;
94     /* partition color space */
95     cut(CLRCUBE, 0, ncolors);
96 greg 2.2 #ifdef CLOSEST
97     closest(ncolors); /* ensure colors picked are closest */
98     #endif
99 greg 2.9 /* reset dithering function */
100 greg 2.19 dith_colrs((uby8 *)NULL, (COLR *)NULL, 0);
101 greg 2.1 /* return new color table size */
102     return(ncolors);
103     }
104
105
106 schorsch 2.17 extern int
107     map_pixel( /* get pixel for color */
108 greg 2.19 register uby8 col[]
109 schorsch 2.17 )
110 greg 2.1 {
111     return(cndx(col));
112     }
113
114
115 schorsch 2.17 extern void
116     map_colrs( /* convert a scanline to color index values */
117 greg 2.19 register uby8 *bs,
118 schorsch 2.17 register COLR *cs,
119     register int n
120     )
121 greg 2.1 {
122     while (n-- > 0) {
123     *bs++ = cndx(cs[0]);
124     cs++;
125     }
126     }
127
128
129 schorsch 2.17 extern void
130     dith_colrs( /* convert scanline to dithered index values */
131 greg 2.19 register uby8 *bs,
132 schorsch 2.17 register COLR *cs,
133     int n
134     )
135 greg 2.1 {
136 greg 2.8 static short (*cerr)[3] = NULL;
137 greg 2.1 static int N = 0;
138     int err[3], errp[3];
139     register int x, i;
140
141     if (n != N) { /* get error propogation array */
142 greg 2.8 if (N) {
143 greg 2.12 free((void *)cerr);
144 greg 2.8 cerr = NULL;
145     }
146     if (n)
147 greg 2.1 cerr = (short (*)[3])malloc(3*n*sizeof(short));
148     if (cerr == NULL) {
149     N = 0;
150     map_colrs(bs, cs, n);
151     return;
152     }
153     N = n;
154 schorsch 2.15 memset((void *)cerr, '\0', 3*N*sizeof(short));
155 greg 2.1 }
156     err[0] = err[1] = err[2] = 0;
157     for (x = 0; x < n; x++) {
158     for (i = 0; i < 3; i++) { /* dither value */
159     errp[i] = err[i];
160     err[i] += cerr[x][i];
161     #ifdef MAXERR
162     if (err[i] > MAXERR) err[i] = MAXERR;
163     else if (err[i] < -MAXERR) err[i] = -MAXERR;
164     #endif
165     err[i] += cs[x][i];
166     if (err[i] < 0) err[i] = 0;
167     else if (err[i] > 255) err[i] = 255;
168     }
169     bs[x] = cndx(err);
170     for (i = 0; i < 3; i++) { /* propagate error */
171     err[i] -= clrtab[bs[x]][i];
172     err[i] /= 3;
173     cerr[x][i] = err[i] + errp[i];
174     }
175     }
176     }
177
178
179 schorsch 2.17 static void
180     cut( /* partition color space */
181     register int box[3][2],
182     int c0,
183     int c1
184     )
185 greg 2.1 {
186     register int branch;
187     int kb[3][2];
188
189     if (c1-c0 <= 1) { /* assign pixel */
190     mktabent(c0, box);
191     return;
192     }
193     /* split box */
194     branch = split(box);
195 schorsch 2.15 memcpy((void *)kb, (void *)box, sizeof(kb));
196 greg 2.1 /* do left (lesser) branch */
197     kb[prim(branch)][1] = part(branch);
198     cut(kb, c0, (c0+c1)>>1);
199     /* do right branch */
200     kb[prim(branch)][0] = part(branch);
201     kb[prim(branch)][1] = box[prim(branch)][1];
202     cut(kb, (c0+c1)>>1, c1);
203     }
204
205
206     static int
207 schorsch 2.17 split( /* find median cut for box */
208     register int box[3][2]
209     )
210 greg 2.1 {
211     #define c0 r
212     register int r, g, b;
213     int pri;
214 greg 2.6 long t[HMAX], med;
215 greg 2.1 /* find dominant axis */
216     pri = RED;
217     if (box[GRN][1]-box[GRN][0] > box[pri][1]-box[pri][0])
218     pri = GRN;
219     if (box[BLU][1]-box[BLU][0] > box[pri][1]-box[pri][0])
220     pri = BLU;
221     /* sum histogram over box */
222     med = 0;
223     switch (pri) {
224     case RED:
225     for (r = box[RED][0]; r < box[RED][1]; r++) {
226     t[r] = 0;
227     for (g = box[GRN][0]; g < box[GRN][1]; g++)
228     for (b = box[BLU][0]; b < box[BLU][1]; b++)
229     t[r] += histo[r][g][b];
230     med += t[r];
231     }
232     break;
233     case GRN:
234     for (g = box[GRN][0]; g < box[GRN][1]; g++) {
235     t[g] = 0;
236     for (b = box[BLU][0]; b < box[BLU][1]; b++)
237     for (r = box[RED][0]; r < box[RED][1]; r++)
238     t[g] += histo[r][g][b];
239     med += t[g];
240     }
241     break;
242     case BLU:
243     for (b = box[BLU][0]; b < box[BLU][1]; b++) {
244     t[b] = 0;
245     for (r = box[RED][0]; r < box[RED][1]; r++)
246     for (g = box[GRN][0]; g < box[GRN][1]; g++)
247     t[b] += histo[r][g][b];
248     med += t[b];
249     }
250     break;
251     }
252     if (med < MINSAMP) /* if too sparse, split at midpoint */
253     return(set_branch(pri,(box[pri][0]+box[pri][1])>>1));
254     /* find median position */
255     med >>= 1;
256     for (c0 = box[pri][0]; med > 0; c0++)
257     med -= t[c0];
258     if (c0 > (box[pri][0]+box[pri][1])>>1) /* if past the midpoint */
259     c0--; /* part left of median */
260     return(set_branch(pri,c0));
261     #undef c0
262     }
263
264
265 schorsch 2.17 static void
266     mktabent( /* compute average color for box and assign */
267     int p,
268     register int box[3][2]
269     )
270 greg 2.1 {
271 greg 2.5 unsigned long sum[3];
272 greg 2.7 unsigned r, g;
273     unsigned long n;
274 greg 2.5 register unsigned b, c;
275 greg 2.1 /* sum pixels in box */
276     n = 0;
277     sum[RED] = sum[GRN] = sum[BLU] = 0;
278     for (r = box[RED][0]; r < box[RED][1]; r++)
279     for (g = box[GRN][0]; g < box[GRN][1]; g++)
280     for (b = box[BLU][0]; b < box[BLU][1]; b++) {
281 schorsch 2.16 if ( (c = histo[r][g][b]) ) {
282 greg 2.1 n += c;
283     sum[RED] += (long)c*r;
284     sum[GRN] += (long)c*g;
285     sum[BLU] += (long)c*b;
286     }
287     histo[r][g][b] = p; /* assign pixel */
288     }
289 greg 2.7 if (n >= (1L<<23)/HMAX) { /* avoid overflow */
290 greg 2.5 sum[RED] /= n;
291     sum[GRN] /= n;
292     sum[BLU] /= n;
293     n = 1;
294     }
295 greg 2.1 if (n) { /* compute average */
296     clrtab[p][RED] = sum[RED]*256/NRED/n;
297     clrtab[p][GRN] = sum[GRN]*256/NGRN/n;
298     clrtab[p][BLU] = sum[BLU]*256/NBLU/n;
299     } else { /* empty box -- use midpoint */
300     clrtab[p][RED] = (box[RED][0]+box[RED][1])*256/NRED/2;
301     clrtab[p][GRN] = (box[GRN][0]+box[GRN][1])*256/NGRN/2;
302     clrtab[p][BLU] = (box[BLU][0]+box[BLU][1])*256/NBLU/2;
303     }
304     }
305 greg 2.2
306
307     #ifdef CLOSEST
308     #define NBSIZ 32
309 schorsch 2.17 static void
310     closest( /* make sure we have the closest colors */
311     int n
312     )
313 greg 2.2 {
314 greg 2.19 uby8 *neigh[256];
315 greg 2.2 register int r, g, b;
316     #define i r
317     /* get space for neighbor lists */
318     for (i = 0; i < n; i++) {
319 greg 2.19 if ((neigh[i] = (uby8 *)malloc(NBSIZ)) == NULL) {
320 greg 2.2 while (i--)
321     free(neigh[i]);
322     return; /* ENOMEM -- abandon effort */
323     }
324     neigh[i][0] = i; /* identity is terminator */
325     }
326     /* make neighbor lists */
327 greg 2.3 for (r = 0; r < NRED; r++)
328     for (g = 0; g < NGRN; g++)
329     for (b = 0; b < NBLU; b++) {
330     if (r < NRED-1 && histo[r][g][b] != histo[r+1][g][b])
331 greg 2.2 addneigh(neigh, histo[r][g][b], histo[r+1][g][b]);
332 greg 2.3 if (g < NGRN-1 && histo[r][g][b] != histo[r][g+1][b])
333 greg 2.2 addneigh(neigh, histo[r][g][b], histo[r][g+1][b]);
334 greg 2.3 if (b < NBLU-1 && histo[r][g][b] != histo[r][g][b+1])
335 greg 2.2 addneigh(neigh, histo[r][g][b], histo[r][g][b+1]);
336     }
337     /* assign closest values */
338     for (r = 0; r < NRED; r++)
339     for (g = 0; g < NGRN; g++)
340     for (b = 0; b < NBLU; b++)
341     setclosest(neigh, r, g, b);
342     /* free neighbor lists */
343     for (i = 0; i < n; i++)
344     free(neigh[i]);
345     #undef i
346     }
347
348
349 schorsch 2.17 static void
350     addneigh( /* i and j are neighbors; add them to list */
351 greg 2.19 register uby8 *nl[],
352 schorsch 2.17 register int i,
353     int j
354     )
355 greg 2.2 {
356     int nc;
357     char *nnl;
358     register int t;
359
360     for (nc = 0; nc < 2; nc++) { /* do both neighbors */
361     for (t = 0; nl[i][t] != i; t++)
362     if (nl[i][t] == j)
363     break; /* in list already */
364     if (nl[i][t] == i) { /* add to list */
365     nl[i][t++] = j;
366     if (t % NBSIZ == 0) { /* enlarge list */
367 greg 2.13 if ((nnl = realloc((void *)nl[i],
368     t+NBSIZ)) == NULL)
369 greg 2.2 t--;
370     else
371 greg 2.19 nl[i] = (uby8 *)nnl;
372 greg 2.2 }
373     nl[i][t] = i; /* terminator */
374     }
375     t = i; i = j; j = t; /* swap and do it again */
376     }
377     }
378
379
380 schorsch 2.17 static unsigned int
381     dist( /* find distance from clrtab entry to r,g,b */
382 greg 2.19 register uby8 col[3],
383 schorsch 2.17 int r,
384     int g,
385     int b
386     )
387 greg 2.2 {
388 greg 2.4 register int tmp;
389 greg 2.2 register unsigned sum;
390
391     tmp = col[RED]*NRED/256 - r;
392     sum = tmp*tmp;
393     tmp = col[GRN]*NGRN/256 - g;
394     sum += tmp*tmp;
395     tmp = col[BLU]*NBLU/256 - b;
396     sum += tmp*tmp;
397     return(sum);
398     }
399
400
401 schorsch 2.17 static void
402     setclosest( /* find index closest to color and assign */
403 greg 2.19 uby8 *nl[],
404 schorsch 2.17 int r,
405     int g,
406     int b
407     )
408 greg 2.2 {
409     int ident;
410     unsigned min;
411     register unsigned d;
412 greg 2.19 register uby8 *p;
413 greg 2.2 /* get starting value */
414     min = dist(clrtab[ident=histo[r][g][b]], r, g, b);
415     /* find minimum */
416     for (p = nl[ident]; *p != ident; p++)
417     if ((d = dist(clrtab[*p], r, g, b)) < min) {
418     min = d;
419     histo[r][g][b] = *p;
420     }
421     }
422     #endif
