root/radiance/ray/src/px/clrtab.c
Mon Sep 19 02:23:58 2005 UTC (18 years, 8 months ago) by greg
Changes since 2.17: +1 -5 lines
Diff to previous 2.17 , to selected 2.9
Sun Mar 28 20:33:13 2004 UTC (20 years, 1 month ago) by schorsch
Changes since 2.16: +84 -51 lines
Diff to previous 2.16 , to selected 2.9
Diff to previous 2.15 , to selected 2.9
Changes since 2.14: +9 -5 lines
Tue May 13 17:58:33 2003 UTC (21 years ago) by greg
Changes since 2.11: +2 -5 lines
Mon Dec 12 12:15:51 1994 UTC (29 years, 5 months ago) by greg
Changes since 2.10: +4 -0 lines
added static function definitions
Fri Jun 10 12:51:16 1994 UTC (29 years, 11 months ago) by greg
Thu Dec 9 12:04:23 1993 UTC (30 years, 5 months ago) by greg
added dith_colrs() reset to new_clrtab() function
Thu Dec 9 11:57:15 1993 UTC (30 years, 5 months ago) by greg
Changes since 2.7: +6 -5 lines
changed dith_colrs() so it can be reset by dith_colrs(NULL, NULL, 0)
Thu Jun 10 15:45:18 1993 UTC (30 years, 11 months ago) by greg
another 16-bit integer fix in mktabent()
Wed May 5 10:18:05 1993 UTC (31 years ago) by greg
changed int to long in split() (16-bit bug fix)
Tue Feb 23 15:11:59 1993 UTC (31 years, 2 months ago) by greg
Changes since 2.4: +9 -3 lines
bug fix -- overflow problem in mktabent()
Fri Feb 5 09:45:40 1993 UTC (31 years, 3 months ago) by greg
Changes since 2.3: +9 -3 lines
made CLOSEST define dependent on value of SPEED
Tue Oct 13 11:36:20 1992 UTC (31 years, 7 months ago) by greg
Changes since 2.2: +6 -6 lines
changed ra_t8 to use clrtab.c
Tue Oct 13 09:07:51 1992 UTC (31 years, 7 months ago) by greg
Changes since 2.1: +114 -0 lines
added closest color calculation
Mon Oct 12 12:58:39 1992 UTC (31 years, 7 months ago) by greg
Diff to selected 2.9
