--- ray/src/px/clrtab.c 1992/10/12 12:58:39 2.1 +++ ray/src/px/clrtab.c 1993/12/09 12:04:23 2.9 @@ -1,4 +1,4 @@ -/* Copyright (c) 1992 Regents of the University of California */ +/* Copyright (c) 1993 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -31,6 +31,14 @@ static unsigned histo[NRED][NGRN][NBLU]; static int CLRCUBE[3][2] = {0,NRED,0,NGRN,0,NBLU}; /* maximum propagated error during dithering */ #define MAXERR 20 + /* define CLOSEST to get closest colors */ +#ifndef CLOSEST +#ifdef SPEED +#if SPEED > 8 +#define CLOSEST 1 /* this step takes a little longer */ +#endif +#endif +#endif new_histo() /* clear our histogram */ @@ -66,6 +74,11 @@ int ncolors; ncolors = 256; /* partition color space */ cut(CLRCUBE, 0, ncolors); +#ifdef CLOSEST + closest(ncolors); /* ensure colors picked are closest */ +#endif + /* reset dithering function */ + dith_colrs((BYTE *)NULL, (COLR *)NULL, 0); /* return new color table size */ return(ncolors); } @@ -96,16 +109,17 @@ register BYTE *bs; register COLR *cs; int n; { - static short (*cerr)[3]; + static short (*cerr)[3] = NULL; static int N = 0; int err[3], errp[3]; register int x, i; if (n != N) { /* get error propogation array */ - if (N) - cerr = (short (*)[3])realloc((char *)cerr, - 3*n*sizeof(short)); - else + if (N) { + free((char *)cerr); + cerr = NULL; + } + if (n) cerr = (short (*)[3])malloc(3*n*sizeof(short)); if (cerr == NULL) { N = 0; @@ -170,7 +184,7 @@ register int box[3][2]; #define c0 r register int r, g, b; int pri; - int t[HMAX], med; + long t[HMAX], med; /* find dominant axis */ pri = RED; if (box[GRN][1]-box[GRN][0] > box[pri][1]-box[pri][0]) @@ -226,9 +240,10 @@ mktabent(p, box) /* compute average color for box and int p; register int box[3][2]; { - long sum[3]; - int r, g, n; - register int b, c; + unsigned long sum[3]; + unsigned r, g; + unsigned long n; + register unsigned b, c; /* sum pixels in box */ n = 0; sum[RED] = sum[GRN] = sum[BLU] = 0; @@ -243,6 +258,12 @@ register int box[3][2]; } histo[r][g][b] = p; /* assign pixel */ } + if (n >= (1L<<23)/HMAX) { /* avoid overflow */ + sum[RED] /= n; + sum[GRN] /= n; + sum[BLU] /= n; + n = 1; + } if (n) { /* compute average */ clrtab[p][RED] = sum[RED]*256/NRED/n; clrtab[p][GRN] = sum[GRN]*256/NGRN/n; @@ -253,3 +274,112 @@ register int box[3][2]; clrtab[p][BLU] = (box[BLU][0]+box[BLU][1])*256/NBLU/2; } } + + +#ifdef CLOSEST +#define NBSIZ 32 +static +closest(n) /* make sure we have the closest colors */ +int n; +{ + BYTE *neigh[256]; + register int r, g, b; +#define i r + /* get space for neighbor lists */ + for (i = 0; i < n; i++) { + if ((neigh[i] = (BYTE *)malloc(NBSIZ)) == NULL) { + while (i--) + free(neigh[i]); + return; /* ENOMEM -- abandon effort */ + } + neigh[i][0] = i; /* identity is terminator */ + } + /* make neighbor lists */ + for (r = 0; r < NRED; r++) + for (g = 0; g < NGRN; g++) + for (b = 0; b < NBLU; b++) { + if (r < NRED-1 && histo[r][g][b] != histo[r+1][g][b]) + addneigh(neigh, histo[r][g][b], histo[r+1][g][b]); + if (g < NGRN-1 && histo[r][g][b] != histo[r][g+1][b]) + addneigh(neigh, histo[r][g][b], histo[r][g+1][b]); + if (b < NBLU-1 && histo[r][g][b] != histo[r][g][b+1]) + addneigh(neigh, histo[r][g][b], histo[r][g][b+1]); + } + /* assign closest values */ + for (r = 0; r < NRED; r++) + for (g = 0; g < NGRN; g++) + for (b = 0; b < NBLU; b++) + setclosest(neigh, r, g, b); + /* free neighbor lists */ + for (i = 0; i < n; i++) + free(neigh[i]); +#undef i +} + + +static +addneigh(nl, i, j) /* i and j are neighbors; add them to list */ +register BYTE *nl[]; +register int i; +int j; +{ + int nc; + char *nnl; + register int t; + + for (nc = 0; nc < 2; nc++) { /* do both neighbors */ + for (t = 0; nl[i][t] != i; t++) + if (nl[i][t] == j) + break; /* in list already */ + if (nl[i][t] == i) { /* add to list */ + nl[i][t++] = j; + if (t % NBSIZ == 0) { /* enlarge list */ + if ((nnl = realloc(nl[i], t+NBSIZ)) == NULL) + t--; + else + nl[i] = (BYTE *)nnl; + } + nl[i][t] = i; /* terminator */ + } + t = i; i = j; j = t; /* swap and do it again */ + } +} + + +static unsigned +dist(col, r, g, b) /* find distance from clrtab entry to r,g,b */ +register BYTE col[3]; +int r, g, b; +{ + register int tmp; + register unsigned sum; + + tmp = col[RED]*NRED/256 - r; + sum = tmp*tmp; + tmp = col[GRN]*NGRN/256 - g; + sum += tmp*tmp; + tmp = col[BLU]*NBLU/256 - b; + sum += tmp*tmp; + return(sum); +} + + +static +setclosest(nl, r, g, b) /* find index closest to color and assign */ +BYTE *nl[]; +int r, g, b; +{ + int ident; + unsigned min; + register unsigned d; + register BYTE *p; + /* get starting value */ + min = dist(clrtab[ident=histo[r][g][b]], r, g, b); + /* find minimum */ + for (p = nl[ident]; *p != ident; p++) + if ((d = dist(clrtab[*p], r, g, b)) < min) { + min = d; + histo[r][g][b] = *p; + } +} +#endif
