--- ray/src/px/clrtab.c 1993/02/23 15:11:59 2.5 +++ ray/src/px/clrtab.c 1994/12/12 12:15:51 2.11 @@ -23,7 +23,7 @@ static char SCCSid[] = "$SunId$ LBL"; #define part(cn) ((cn)>>2) #define prim(cn) ((cn)&3) /* our color table (global) */ -BYTE clrtab[256][3]; +extern BYTE clrtab[256][3]; /* histogram of colors / color assignments */ static unsigned histo[NRED][NGRN][NBLU]; #define cndx(c) histo[((c)[RED]*NRED)>>8][((c)[GRN]*NGRN)>>8][((c)[BLU]*NBLU)>>8] @@ -40,10 +40,16 @@ static int CLRCUBE[3][2] = {0,NRED,0,NGRN,0,NBLU}; #endif #endif +static cut(), mktabent(), closest(), addneigh(), setclosest(); +static int split(); +static unsigned dist(); -new_histo() /* clear our histogram */ + +new_histo(n) /* clear our histogram */ +int n; { bzero((char *)histo, sizeof(histo)); + return(0); } @@ -77,6 +83,8 @@ int ncolors; #ifdef CLOSEST closest(ncolors); /* ensure colors picked are closest */ #endif + /* reset dithering function */ + dith_colrs((BYTE *)NULL, (COLR *)NULL, 0); /* return new color table size */ return(ncolors); } @@ -107,16 +115,17 @@ register BYTE *bs; register COLR *cs; int n; { - static short (*cerr)[3]; + static short (*cerr)[3] = NULL; static int N = 0; int err[3], errp[3]; register int x, i; if (n != N) { /* get error propogation array */ - if (N) - cerr = (short (*)[3])realloc((char *)cerr, - 3*n*sizeof(short)); - else + if (N) { + free((char *)cerr); + cerr = NULL; + } + if (n) cerr = (short (*)[3])malloc(3*n*sizeof(short)); if (cerr == NULL) { N = 0; @@ -181,7 +190,7 @@ register int box[3][2]; #define c0 r register int r, g, b; int pri; - int t[HMAX], med; + long t[HMAX], med; /* find dominant axis */ pri = RED; if (box[GRN][1]-box[GRN][0] > box[pri][1]-box[pri][0]) @@ -238,7 +247,8 @@ int p; register int box[3][2]; { unsigned long sum[3]; - unsigned r, g, n; + unsigned r, g; + unsigned long n; register unsigned b, c; /* sum pixels in box */ n = 0; @@ -254,7 +264,7 @@ register int box[3][2]; } histo[r][g][b] = p; /* assign pixel */ } - if (n >= (1<<23)/HMAX) { /* avoid overflow */ + if (n >= (1L<<23)/HMAX) { /* avoid overflow */ sum[RED] /= n; sum[GRN] /= n; sum[BLU] /= n;
