root/Development/ray/src/px/clrtab.c
Revision: 2.12
Committed: Sat Feb 22 02:07:27 2003 UTC (22 years, 10 months ago) by greg
Changes since 2.11: +2 -5 lines
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.12 static const char RCSid[] = "$Id$";
3 greg 2.1 #endif
4     /*
5     * Simple median-cut color quantization based on colortab.c
6     */
7
8     #include "standard.h"
9
10     #include "color.h"
11     /* histogram resolution */
12     #define NRED 36
13     #define NGRN 48
14     #define NBLU 24
15     #define HMAX NGRN
16     /* minimum box count for adaptive partition */
17     #define MINSAMP 7
18     /* color partition */
19     #define set_branch(p,c) ((c)<<2|(p))
20     #define part(cn) ((cn)>>2)
21     #define prim(cn) ((cn)&3)
22     /* our color table (global) */
23 greg 2.10 extern BYTE clrtab[256][3];
24 greg 2.1 /* histogram of colors / color assignments */
25     static unsigned histo[NRED][NGRN][NBLU];
26     #define cndx(c) histo[((c)[RED]*NRED)>>8][((c)[GRN]*NGRN)>>8][((c)[BLU]*NBLU)>>8]
27     /* initial color cube boundary */
28     static int CLRCUBE[3][2] = {0,NRED,0,NGRN,0,NBLU};
29     /* maximum propagated error during dithering */
30     #define MAXERR 20
31 greg 2.2 /* define CLOSEST to get closest colors */
32 greg 2.4 #ifndef CLOSEST
33     #ifdef SPEED
34     #if SPEED > 8
35     #define CLOSEST 1 /* this step takes a little longer */
36     #endif
37     #endif
38     #endif
39 greg 2.1
40 greg 2.11 static cut(), mktabent(), closest(), addneigh(), setclosest();
41     static int split();
42     static unsigned dist();
43
44 greg 2.1
45 greg 2.10 new_histo(n) /* clear our histogram */
46     int n;
47 greg 2.1 {
48     bzero((char *)histo, sizeof(histo));
49 greg 2.10 return(0);
50 greg 2.1 }
51
52
53     cnt_pixel(col) /* add pixel to our histogram */
54     register BYTE col[];
55     {
56     cndx(col)++;
57     }
58
59
60     cnt_colrs(cs, n) /* add a scanline to our histogram */
61     register COLR *cs;
62     register int n;
63     {
64     while (n-- > 0) {
65     cndx(cs[0])++;
66     cs++;
67     }
68     }
69
70
71     new_clrtab(ncolors) /* make new color table using ncolors */
72     int ncolors;
73     {
74     if (ncolors < 1)
75     return(0);
76     if (ncolors > 256)
77     ncolors = 256;
78     /* partition color space */
79     cut(CLRCUBE, 0, ncolors);
80 greg 2.2 #ifdef CLOSEST
81     closest(ncolors); /* ensure colors picked are closest */
82     #endif
83 greg 2.9 /* reset dithering function */
84     dith_colrs((BYTE *)NULL, (COLR *)NULL, 0);
85 greg 2.1 /* return new color table size */
86     return(ncolors);
87     }
88
89
90     int
91     map_pixel(col) /* get pixel for color */
92     register BYTE col[];
93     {
94     return(cndx(col));
95     }
96
97
98     map_colrs(bs, cs, n) /* convert a scanline to color index values */
99     register BYTE *bs;
100     register COLR *cs;
101     register int n;
102     {
103     while (n-- > 0) {
104     *bs++ = cndx(cs[0]);
105     cs++;
106     }
107     }
108
109
110     dith_colrs(bs, cs, n) /* convert scanline to dithered index values */
111     register BYTE *bs;
112     register COLR *cs;
113     int n;
114     {
115 greg 2.8 static short (*cerr)[3] = NULL;
116 greg 2.1 static int N = 0;
117     int err[3], errp[3];
118     register int x, i;
119
120     if (n != N) { /* get error propogation array */
121 greg 2.8 if (N) {
122 greg 2.12 free((void *)cerr);
123 greg 2.8 cerr = NULL;
124     }
125     if (n)
126 greg 2.1 cerr = (short (*)[3])malloc(3*n*sizeof(short));
127     if (cerr == NULL) {
128     N = 0;
129     map_colrs(bs, cs, n);
130     return;
131     }
132     N = n;
133     bzero((char *)cerr, 3*N*sizeof(short));
134     }
135     err[0] = err[1] = err[2] = 0;
136     for (x = 0; x < n; x++) {
137     for (i = 0; i < 3; i++) { /* dither value */
138     errp[i] = err[i];
139     err[i] += cerr[x][i];
140     #ifdef MAXERR
141     if (err[i] > MAXERR) err[i] = MAXERR;
142     else if (err[i] < -MAXERR) err[i] = -MAXERR;
143     #endif
144     err[i] += cs[x][i];
145     if (err[i] < 0) err[i] = 0;
146     else if (err[i] > 255) err[i] = 255;
147     }
148     bs[x] = cndx(err);
149     for (i = 0; i < 3; i++) { /* propagate error */
150     err[i] -= clrtab[bs[x]][i];
151     err[i] /= 3;
152     cerr[x][i] = err[i] + errp[i];
153     }
154     }
155     }
156
157
158     static
159     cut(box, c0, c1) /* partition color space */
160     register int box[3][2];
161     int c0, c1;
162     {
163     register int branch;
164     int kb[3][2];
165
166     if (c1-c0 <= 1) { /* assign pixel */
167     mktabent(c0, box);
168     return;
169     }
170     /* split box */
171     branch = split(box);
172     bcopy((char *)box, (char *)kb, sizeof(kb));
173     /* do left (lesser) branch */
174     kb[prim(branch)][1] = part(branch);
175     cut(kb, c0, (c0+c1)>>1);
176     /* do right branch */
177     kb[prim(branch)][0] = part(branch);
178     kb[prim(branch)][1] = box[prim(branch)][1];
179     cut(kb, (c0+c1)>>1, c1);
180     }
181
182
183     static int
184     split(box) /* find median cut for box */
185     register int box[3][2];
186     {
187     #define c0 r
188     register int r, g, b;
189     int pri;
190 greg 2.6 long t[HMAX], med;
191 greg 2.1 /* find dominant axis */
192     pri = RED;
193     if (box[GRN][1]-box[GRN][0] > box[pri][1]-box[pri][0])
194     pri = GRN;
195     if (box[BLU][1]-box[BLU][0] > box[pri][1]-box[pri][0])
196     pri = BLU;
197     /* sum histogram over box */
198     med = 0;
199     switch (pri) {
200     case RED:
201     for (r = box[RED][0]; r < box[RED][1]; r++) {
202     t[r] = 0;
203     for (g = box[GRN][0]; g < box[GRN][1]; g++)
204     for (b = box[BLU][0]; b < box[BLU][1]; b++)
205     t[r] += histo[r][g][b];
206     med += t[r];
207     }
208     break;
209     case GRN:
210     for (g = box[GRN][0]; g < box[GRN][1]; g++) {
211     t[g] = 0;
212     for (b = box[BLU][0]; b < box[BLU][1]; b++)
213     for (r = box[RED][0]; r < box[RED][1]; r++)
214     t[g] += histo[r][g][b];
215     med += t[g];
216     }
217     break;
218     case BLU:
219     for (b = box[BLU][0]; b < box[BLU][1]; b++) {
220     t[b] = 0;
221     for (r = box[RED][0]; r < box[RED][1]; r++)
222     for (g = box[GRN][0]; g < box[GRN][1]; g++)
223     t[b] += histo[r][g][b];
224     med += t[b];
225     }
226     break;
227     }
228     if (med < MINSAMP) /* if too sparse, split at midpoint */
229     return(set_branch(pri,(box[pri][0]+box[pri][1])>>1));
230     /* find median position */
231     med >>= 1;
232     for (c0 = box[pri][0]; med > 0; c0++)
233     med -= t[c0];
234     if (c0 > (box[pri][0]+box[pri][1])>>1) /* if past the midpoint */
235     c0--; /* part left of median */
236     return(set_branch(pri,c0));
237     #undef c0
238     }
239
240
241     static
242     mktabent(p, box) /* compute average color for box and assign */
243     int p;
244     register int box[3][2];
245     {
246 greg 2.5 unsigned long sum[3];
247 greg 2.7 unsigned r, g;
248     unsigned long n;
249 greg 2.5 register unsigned b, c;
250 greg 2.1 /* sum pixels in box */
251     n = 0;
252     sum[RED] = sum[GRN] = sum[BLU] = 0;
253     for (r = box[RED][0]; r < box[RED][1]; r++)
254     for (g = box[GRN][0]; g < box[GRN][1]; g++)
255     for (b = box[BLU][0]; b < box[BLU][1]; b++) {
256     if (c = histo[r][g][b]) {
257     n += c;
258     sum[RED] += (long)c*r;
259     sum[GRN] += (long)c*g;
260     sum[BLU] += (long)c*b;
261     }
262     histo[r][g][b] = p; /* assign pixel */
263     }
264 greg 2.7 if (n >= (1L<<23)/HMAX) { /* avoid overflow */
265 greg 2.5 sum[RED] /= n;
266     sum[GRN] /= n;
267     sum[BLU] /= n;
268     n = 1;
269     }
270 greg 2.1 if (n) { /* compute average */
271     clrtab[p][RED] = sum[RED]*256/NRED/n;
272     clrtab[p][GRN] = sum[GRN]*256/NGRN/n;
273     clrtab[p][BLU] = sum[BLU]*256/NBLU/n;
274     } else { /* empty box -- use midpoint */
275     clrtab[p][RED] = (box[RED][0]+box[RED][1])*256/NRED/2;
276     clrtab[p][GRN] = (box[GRN][0]+box[GRN][1])*256/NGRN/2;
277     clrtab[p][BLU] = (box[BLU][0]+box[BLU][1])*256/NBLU/2;
278     }
279     }
280 greg 2.2
281
282     #ifdef CLOSEST
283     #define NBSIZ 32
284     static
285     closest(n) /* make sure we have the closest colors */
286     int n;
287     {
288     BYTE *neigh[256];
289     register int r, g, b;
290     #define i r
291     /* get space for neighbor lists */
292     for (i = 0; i < n; i++) {
293     if ((neigh[i] = (BYTE *)malloc(NBSIZ)) == NULL) {
294     while (i--)
295     free(neigh[i]);
296     return; /* ENOMEM -- abandon effort */
297     }
298     neigh[i][0] = i; /* identity is terminator */
299     }
300     /* make neighbor lists */
301 greg 2.3 for (r = 0; r < NRED; r++)
302     for (g = 0; g < NGRN; g++)
303     for (b = 0; b < NBLU; b++) {
304     if (r < NRED-1 && histo[r][g][b] != histo[r+1][g][b])
305 greg 2.2 addneigh(neigh, histo[r][g][b], histo[r+1][g][b]);
306 greg 2.3 if (g < NGRN-1 && histo[r][g][b] != histo[r][g+1][b])
307 greg 2.2 addneigh(neigh, histo[r][g][b], histo[r][g+1][b]);
308 greg 2.3 if (b < NBLU-1 && histo[r][g][b] != histo[r][g][b+1])
309 greg 2.2 addneigh(neigh, histo[r][g][b], histo[r][g][b+1]);
310     }
311     /* assign closest values */
312     for (r = 0; r < NRED; r++)
313     for (g = 0; g < NGRN; g++)
314     for (b = 0; b < NBLU; b++)
315     setclosest(neigh, r, g, b);
316     /* free neighbor lists */
317     for (i = 0; i < n; i++)
318     free(neigh[i]);
319     #undef i
320     }
321
322
323     static
324     addneigh(nl, i, j) /* i and j are neighbors; add them to list */
325     register BYTE *nl[];
326     register int i;
327     int j;
328     {
329     int nc;
330     char *nnl;
331     register int t;
332
333     for (nc = 0; nc < 2; nc++) { /* do both neighbors */
334     for (t = 0; nl[i][t] != i; t++)
335     if (nl[i][t] == j)
336     break; /* in list already */
337     if (nl[i][t] == i) { /* add to list */
338     nl[i][t++] = j;
339     if (t % NBSIZ == 0) { /* enlarge list */
340     if ((nnl = realloc(nl[i], t+NBSIZ)) == NULL)
341     t--;
342     else
343     nl[i] = (BYTE *)nnl;
344     }
345     nl[i][t] = i; /* terminator */
346     }
347     t = i; i = j; j = t; /* swap and do it again */
348     }
349     }
350
351
352     static unsigned
353     dist(col, r, g, b) /* find distance from clrtab entry to r,g,b */
354     register BYTE col[3];
355     int r, g, b;
356     {
357 greg 2.4 register int tmp;
358 greg 2.2 register unsigned sum;
359
360     tmp = col[RED]*NRED/256 - r;
361     sum = tmp*tmp;
362     tmp = col[GRN]*NGRN/256 - g;
363     sum += tmp*tmp;
364     tmp = col[BLU]*NBLU/256 - b;
365     sum += tmp*tmp;
366     return(sum);
367     }
368
369
370     static
371     setclosest(nl, r, g, b) /* find index closest to color and assign */
372     BYTE *nl[];
373     int r, g, b;
374     {
375     int ident;
376     unsigned min;
377     register unsigned d;
378     register BYTE *p;
379     /* get starting value */
380     min = dist(clrtab[ident=histo[r][g][b]], r, g, b);
381     /* find minimum */
382     for (p = nl[ident]; *p != ident; p++)
383     if ((d = dist(clrtab[*p], r, g, b)) < min) {
384     min = d;
385     histo[r][g][b] = *p;
386     }
387     }
388     #endif
