1 |
/* Copyright (c) 1993 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Simple median-cut color quantization based on colortab.c |
9 |
10 |
11 |
#include "standard.h" |
12 |
13 |
#include "color.h" |
14 |
/* histogram resolution */ |
15 |
#define NRED 36 |
16 |
#define NGRN 48 |
17 |
#define NBLU 24 |
18 |
#define HMAX NGRN |
19 |
/* minimum box count for adaptive partition */ |
20 |
#define MINSAMP 7 |
21 |
/* color partition */ |
22 |
#define set_branch(p,c) ((c)<<2|(p)) |
23 |
#define part(cn) ((cn)>>2) |
24 |
#define prim(cn) ((cn)&3) |
25 |
/* our color table (global) */ |
26 |
BYTE clrtab[256][3]; |
27 |
/* histogram of colors / color assignments */ |
28 |
static unsigned histo[NRED][NGRN][NBLU]; |
29 |
#define cndx(c) histo[((c)[RED]*NRED)>>8][((c)[GRN]*NGRN)>>8][((c)[BLU]*NBLU)>>8] |
30 |
/* initial color cube boundary */ |
31 |
static int CLRCUBE[3][2] = {0,NRED,0,NGRN,0,NBLU}; |
32 |
/* maximum propagated error during dithering */ |
33 |
#define MAXERR 20 |
34 |
/* define CLOSEST to get closest colors */ |
35 |
#ifndef CLOSEST |
36 |
#ifdef SPEED |
37 |
#if SPEED > 8 |
38 |
#define CLOSEST 1 /* this step takes a little longer */ |
39 |
#endif |
40 |
#endif |
41 |
#endif |
42 |
43 |
44 |
new_histo() /* clear our histogram */ |
45 |
46 |
bzero((char *)histo, sizeof(histo)); |
47 |
48 |
49 |
50 |
cnt_pixel(col) /* add pixel to our histogram */ |
51 |
register BYTE col[]; |
52 |
53 |
cndx(col)++; |
54 |
55 |
56 |
57 |
cnt_colrs(cs, n) /* add a scanline to our histogram */ |
58 |
register COLR *cs; |
59 |
register int n; |
60 |
61 |
while (n-- > 0) { |
62 |
cndx(cs[0])++; |
63 |
cs++; |
64 |
65 |
66 |
67 |
68 |
new_clrtab(ncolors) /* make new color table using ncolors */ |
69 |
int ncolors; |
70 |
71 |
if (ncolors < 1) |
72 |
return(0); |
73 |
if (ncolors > 256) |
74 |
ncolors = 256; |
75 |
/* partition color space */ |
76 |
cut(CLRCUBE, 0, ncolors); |
77 |
#ifdef CLOSEST |
78 |
closest(ncolors); /* ensure colors picked are closest */ |
79 |
#endif |
80 |
/* return new color table size */ |
81 |
return(ncolors); |
82 |
83 |
84 |
85 |
int |
86 |
map_pixel(col) /* get pixel for color */ |
87 |
88 |
89 |
return(cndx(col)); |
90 |
91 |
92 |
93 |
map_colrs(bs, cs, n) /* convert a scanline to color index values */ |
94 |
register BYTE *bs; |
95 |
96 |
register int n; |
97 |
98 |
while (n-- > 0) { |
99 |
*bs++ = cndx(cs[0]); |
100 |
cs++; |
101 |
102 |
103 |
104 |
105 |
dith_colrs(bs, cs, n) /* convert scanline to dithered index values */ |
106 |
107 |
108 |
int n; |
109 |
110 |
static short (*cerr)[3]; |
111 |
static int N = 0; |
112 |
int err[3], errp[3]; |
113 |
register int x, i; |
114 |
115 |
if (n != N) { /* get error propogation array */ |
116 |
if (N) |
117 |
cerr = (short (*)[3])realloc((char *)cerr, |
118 |
3*n*sizeof(short)); |
119 |
else |
120 |
cerr = (short (*)[3])malloc(3*n*sizeof(short)); |
121 |
if (cerr == NULL) { |
122 |
N = 0; |
123 |
map_colrs(bs, cs, n); |
124 |
return; |
125 |
126 |
N = n; |
127 |
bzero((char *)cerr, 3*N*sizeof(short)); |
128 |
129 |
err[0] = err[1] = err[2] = 0; |
130 |
for (x = 0; x < n; x++) { |
131 |
for (i = 0; i < 3; i++) { /* dither value */ |
132 |
errp[i] = err[i]; |
133 |
err[i] += cerr[x][i]; |
134 |
#ifdef MAXERR |
135 |
if (err[i] > MAXERR) err[i] = MAXERR; |
136 |
else if (err[i] < -MAXERR) err[i] = -MAXERR; |
137 |
#endif |
138 |
err[i] += cs[x][i]; |
139 |
if (err[i] < 0) err[i] = 0; |
140 |
else if (err[i] > 255) err[i] = 255; |
141 |
142 |
bs[x] = cndx(err); |
143 |
for (i = 0; i < 3; i++) { /* propagate error */ |
144 |
err[i] -= clrtab[bs[x]][i]; |
145 |
err[i] /= 3; |
146 |
cerr[x][i] = err[i] + errp[i]; |
147 |
148 |
149 |
150 |
151 |
152 |
static |
153 |
cut(box, c0, c1) /* partition color space */ |
154 |
register int box[3][2]; |
155 |
int c0, c1; |
156 |
157 |
register int branch; |
158 |
int kb[3][2]; |
159 |
160 |
if (c1-c0 <= 1) { /* assign pixel */ |
161 |
mktabent(c0, box); |
162 |
return; |
163 |
164 |
/* split box */ |
165 |
branch = split(box); |
166 |
bcopy((char *)box, (char *)kb, sizeof(kb)); |
167 |
/* do left (lesser) branch */ |
168 |
kb[prim(branch)][1] = part(branch); |
169 |
cut(kb, c0, (c0+c1)>>1); |
170 |
/* do right branch */ |
171 |
kb[prim(branch)][0] = part(branch); |
172 |
kb[prim(branch)][1] = box[prim(branch)][1]; |
173 |
cut(kb, (c0+c1)>>1, c1); |
174 |
175 |
176 |
177 |
static int |
178 |
split(box) /* find median cut for box */ |
179 |
180 |
181 |
#define c0 r |
182 |
register int r, g, b; |
183 |
int pri; |
184 |
long t[HMAX], med; |
185 |
/* find dominant axis */ |
186 |
pri = RED; |
187 |
if (box[GRN][1]-box[GRN][0] > box[pri][1]-box[pri][0]) |
188 |
pri = GRN; |
189 |
if (box[BLU][1]-box[BLU][0] > box[pri][1]-box[pri][0]) |
190 |
pri = BLU; |
191 |
/* sum histogram over box */ |
192 |
med = 0; |
193 |
switch (pri) { |
194 |
case RED: |
195 |
for (r = box[RED][0]; r < box[RED][1]; r++) { |
196 |
t[r] = 0; |
197 |
for (g = box[GRN][0]; g < box[GRN][1]; g++) |
198 |
for (b = box[BLU][0]; b < box[BLU][1]; b++) |
199 |
t[r] += histo[r][g][b]; |
200 |
med += t[r]; |
201 |
202 |
break; |
203 |
case GRN: |
204 |
for (g = box[GRN][0]; g < box[GRN][1]; g++) { |
205 |
t[g] = 0; |
206 |
207 |
for (r = box[RED][0]; r < box[RED][1]; r++) |
208 |
t[g] += histo[r][g][b]; |
209 |
med += t[g]; |
210 |
211 |
break; |
212 |
case BLU: |
213 |
for (b = box[BLU][0]; b < box[BLU][1]; b++) { |
214 |
t[b] = 0; |
215 |
216 |
217 |
t[b] += histo[r][g][b]; |
218 |
med += t[b]; |
219 |
220 |
break; |
221 |
222 |
if (med < MINSAMP) /* if too sparse, split at midpoint */ |
223 |
return(set_branch(pri,(box[pri][0]+box[pri][1])>>1)); |
224 |
/* find median position */ |
225 |
med >>= 1; |
226 |
for (c0 = box[pri][0]; med > 0; c0++) |
227 |
med -= t[c0]; |
228 |
if (c0 > (box[pri][0]+box[pri][1])>>1) /* if past the midpoint */ |
229 |
c0--; /* part left of median */ |
230 |
return(set_branch(pri,c0)); |
231 |
#undef c0 |
232 |
233 |
234 |
235 |
static |
236 |
mktabent(p, box) /* compute average color for box and assign */ |
237 |
int p; |
238 |
239 |
240 |
unsigned long sum[3]; |
241 |
unsigned r, g; |
242 |
unsigned long n; |
243 |
register unsigned b, c; |
244 |
/* sum pixels in box */ |
245 |
n = 0; |
246 |
sum[RED] = sum[GRN] = sum[BLU] = 0; |
247 |
248 |
249 |
250 |
if (c = histo[r][g][b]) { |
251 |
n += c; |
252 |
sum[RED] += (long)c*r; |
253 |
sum[GRN] += (long)c*g; |
254 |
sum[BLU] += (long)c*b; |
255 |
256 |
histo[r][g][b] = p; /* assign pixel */ |
257 |
258 |
if (n >= (1L<<23)/HMAX) { /* avoid overflow */ |
259 |
sum[RED] /= n; |
260 |
sum[GRN] /= n; |
261 |
sum[BLU] /= n; |
262 |
n = 1; |
263 |
264 |
if (n) { /* compute average */ |
265 |
clrtab[p][RED] = sum[RED]*256/NRED/n; |
266 |
clrtab[p][GRN] = sum[GRN]*256/NGRN/n; |
267 |
clrtab[p][BLU] = sum[BLU]*256/NBLU/n; |
268 |
} else { /* empty box -- use midpoint */ |
269 |
clrtab[p][RED] = (box[RED][0]+box[RED][1])*256/NRED/2; |
270 |
clrtab[p][GRN] = (box[GRN][0]+box[GRN][1])*256/NGRN/2; |
271 |
clrtab[p][BLU] = (box[BLU][0]+box[BLU][1])*256/NBLU/2; |
272 |
273 |
274 |
275 |
276 |
#ifdef CLOSEST |
277 |
#define NBSIZ 32 |
278 |
static |
279 |
closest(n) /* make sure we have the closest colors */ |
280 |
int n; |
281 |
282 |
BYTE *neigh[256]; |
283 |
284 |
#define i r |
285 |
/* get space for neighbor lists */ |
286 |
for (i = 0; i < n; i++) { |
287 |
if ((neigh[i] = (BYTE *)malloc(NBSIZ)) == NULL) { |
288 |
while (i--) |
289 |
free(neigh[i]); |
290 |
return; /* ENOMEM -- abandon effort */ |
291 |
292 |
neigh[i][0] = i; /* identity is terminator */ |
293 |
294 |
/* make neighbor lists */ |
295 |
for (r = 0; r < NRED; r++) |
296 |
for (g = 0; g < NGRN; g++) |
297 |
for (b = 0; b < NBLU; b++) { |
298 |
if (r < NRED-1 && histo[r][g][b] != histo[r+1][g][b]) |
299 |
addneigh(neigh, histo[r][g][b], histo[r+1][g][b]); |
300 |
if (g < NGRN-1 && histo[r][g][b] != histo[r][g+1][b]) |
301 |
addneigh(neigh, histo[r][g][b], histo[r][g+1][b]); |
302 |
if (b < NBLU-1 && histo[r][g][b] != histo[r][g][b+1]) |
303 |
addneigh(neigh, histo[r][g][b], histo[r][g][b+1]); |
304 |
305 |
/* assign closest values */ |
306 |
307 |
308 |
for (b = 0; b < NBLU; b++) |
309 |
setclosest(neigh, r, g, b); |
310 |
/* free neighbor lists */ |
311 |
for (i = 0; i < n; i++) |
312 |
free(neigh[i]); |
313 |
#undef i |
314 |
315 |
316 |
317 |
static |
318 |
addneigh(nl, i, j) /* i and j are neighbors; add them to list */ |
319 |
register BYTE *nl[]; |
320 |
register int i; |
321 |
int j; |
322 |
323 |
int nc; |
324 |
char *nnl; |
325 |
register int t; |
326 |
327 |
for (nc = 0; nc < 2; nc++) { /* do both neighbors */ |
328 |
for (t = 0; nl[i][t] != i; t++) |
329 |
if (nl[i][t] == j) |
330 |
break; /* in list already */ |
331 |
if (nl[i][t] == i) { /* add to list */ |
332 |
nl[i][t++] = j; |
333 |
if (t % NBSIZ == 0) { /* enlarge list */ |
334 |
if ((nnl = realloc(nl[i], t+NBSIZ)) == NULL) |
335 |
t--; |
336 |
else |
337 |
nl[i] = (BYTE *)nnl; |
338 |
339 |
nl[i][t] = i; /* terminator */ |
340 |
341 |
t = i; i = j; j = t; /* swap and do it again */ |
342 |
343 |
344 |
345 |
346 |
static unsigned |
347 |
dist(col, r, g, b) /* find distance from clrtab entry to r,g,b */ |
348 |
register BYTE col[3]; |
349 |
int r, g, b; |
350 |
351 |
register int tmp; |
352 |
register unsigned sum; |
353 |
354 |
tmp = col[RED]*NRED/256 - r; |
355 |
sum = tmp*tmp; |
356 |
tmp = col[GRN]*NGRN/256 - g; |
357 |
sum += tmp*tmp; |
358 |
tmp = col[BLU]*NBLU/256 - b; |
359 |
sum += tmp*tmp; |
360 |
return(sum); |
361 |
362 |
363 |
364 |
static |
365 |
setclosest(nl, r, g, b) /* find index closest to color and assign */ |
366 |
BYTE *nl[]; |
367 |
int r, g, b; |
368 |
369 |
int ident; |
370 |
unsigned min; |
371 |
register unsigned d; |
372 |
register BYTE *p; |
373 |
/* get starting value */ |
374 |
min = dist(clrtab[ident=histo[r][g][b]], r, g, b); |
375 |
/* find minimum */ |
376 |
for (p = nl[ident]; *p != ident; p++) |
377 |
if ((d = dist(clrtab[*p], r, g, b)) < min) { |
378 |
min = d; |
379 |
histo[r][g][b] = *p; |
380 |
381 |
382 |
#endif |
