root/radiance/ray/src/px/closest.c
Revision: 2.4
Committed: Sun Mar 28 20:33:13 2004 UTC (20 years, 1 month ago) by schorsch
CVS Tags: rad3R6P1, rad3R6
Changes since 2.3: +25 -9 lines
# User Rev Content
1 greg 1.1 #ifndef lint
2 schorsch 2.4 static const char RCSid[] = "$Id: closest.c,v 2.3 2003/07/27 22:12:03 schorsch Exp $";
3 greg 1.1 #endif
4 greg 1.2 /*
5 greg 1.1 CLOSEST - nearest-color lookup by locally ordered search
6     we use distance in rgb space as color metric
7
8     fillbucket subroutine makes trimmed, sorted lists of
9     possible closest colors to speed the closest searching.
10     About 6 times faster than exhaustive.
11
12     Paul Heckbert
13     */
14
15 schorsch 2.4 #include <stdlib.h>
16
17 greg 1.1 #include "ciq.h"
18
19     #define inf 3*256*256
20 ph 1.3 #define key(r,g,b) (((r)&0xe0)<<1|((g)&0xe0)>>2|((b)&0xe0)>>5)
21     /* 9-bit hash key: rrrgggbbb */
22 greg 1.1
23 ph 1.3 static struct thing {int mindist,pv;} space[512*257],*next,*bucket[512];
24 greg 1.1 /* sorted lists of colors */
25
26 ph 1.3 static int nfill,tests,calls;
27 greg 1.1 static char filled[512]; /* has bucket[key] been filled yet? */
28     static int sq[511];
29
30 schorsch 2.4 static int compare(const void *a, const void *b);
31     static void fillbucket(int k);
32
33
34     void
35     initializeclosest(void) { /* reset the buckets */
36 greg 1.1 int k;
37     nfill = tests = calls = 0;
38     for (k=0; k<512; k++) filled[k] = 0;
39     next = space;
40     }
41
42 schorsch 2.4 int
43     closest( /* find pv of colormap color closest to (r,g,b) */
44     int r,
45     int g,
46     int b
47     )
48 greg 1.1 {
49     register struct thing *p;
50 ph 1.3 register int *rsq,*gsq,*bsq,dist,min;
51     int best,k;
52 greg 1.1 struct thing *p0;
53
54 ph 1.3 k = key(r,g,b);
55     if (!filled[k]) fillbucket(k);
56 greg 1.1 min = inf;
57     rsq = sq+255-r;
58     gsq = sq+255-g;
59     bsq = sq+255-b;
60
61     /* stop looking when best is closer than next could be */
62 ph 1.3 for (p0=p=bucket[k]; min>p->mindist; p++) {
63 greg 1.1 dist = rsq[color[0][p->pv]] + gsq[color[1][p->pv]] +
64     bsq[color[2][p->pv]];
65     if (dist<min) {
66     best = p->pv;
67     min = dist;
68     }
69     }
70     tests += p-p0;
71     calls++;
72     return best;
73     }
74
75     #define H 16 /* half-width of a bucket */
76
77 schorsch 2.4 static int
78     compare(
79     const void *a,
80     const void *b
81     )
82 greg 1.1 {
83 schorsch 2.4 return ((struct thing*)a)->mindist - ((struct thing*)b)->mindist;
84 greg 1.1 }
85
86 schorsch 2.4 static void
87     fillbucket( /* make list of colormap colors which could be closest */
88     int k /* matches for colors in bucket #k */
89     )
90 greg 1.1 {
91     register int r,g,b,j,dist,*rsq,*gsq,*bsq,min,best;
92     struct thing *p,*q;
93
94     if (!sq[0]) for (j= -255; j<256; j++) sq[j+255] = j*j;
95
96 schorsch 2.3 r = (k>>1&0xe0)|H; /* center of 32x32x32 cubical bucket */
97     g = (k<<2&0xe0)|H;
98     b = (k<<5&0xe0)|H;
99 greg 1.1 rsq = sq+255-r;
100     gsq = sq+255-g;
101     bsq = sq+255-b;
102     bucket[k] = p = next;
103     min = inf;
104
105     for (j=0; j<n; j++, p++) {
106     p->pv = j;
107     dist = 0; /* compute distance from cube surface */
108     if (color[0][j]< r-H) dist += rsq[color[0][j]+H];
109     else if (color[0][j]>=r+H) dist += rsq[color[0][j]-H+1];
110     if (color[1][j]< g-H) dist += gsq[color[1][j]+H];
111     else if (color[1][j]>=g+H) dist += gsq[color[1][j]-H+1];
112     if (color[2][j]< b-H) dist += bsq[color[2][j]+H];
113     else if (color[2][j]>=b+H) dist += bsq[color[2][j]-H+1];
114     p->mindist = dist; /* for termination test in closest */
115     dist = rsq[color[0][j]]+gsq[color[1][j]]+bsq[color[2][j]];
116     if (dist<min) { /* find color closest to cube center */
117     best = j;
118     min = dist;
119     }
120     }
121
122     dist = rsq[color[0][best]+(color[0][best]<r?1-H:H)] +
123     gsq[color[1][best]+(color[1][best]<g?1-H:H)] +
124     bsq[color[2][best]+(color[2][best]<b?1-H:H)];
125     /* dist is an upper bound on mindist: maximum possible distance */
126     /* between a color in the bucket and its nearest neighbor */
127
128     /* eliminate colors which couldn't be closest */
129     for (p=q=next, j=0; j<n; j++, p++)
130     if (p->mindist<dist) {
131     q->mindist = p->mindist;
132     q->pv = p->pv;
133     q++;
134     }
135     if (q<=next) fprintf(stderr,"ERROR: empty bucket!\n");
136
137     /* and sort the list by mindist */
138     qsort(next,q-next,sizeof(struct thing),compare);
139     q->mindist = inf; /* list terminator */
140     next = q+1;
141     filled[k] = 1;
142     nfill++;
143     }
144
145     /*endclosest() {
146     printf("filled %d buckets, averaging %d colors per list, %d of which were tested\n",
147     nfill,(next-space-nfill)/nfill,tests/calls);
148     }*/
