root/radiance/ray/src/px/closest.c
Revision: 1.2
Committed: Thu Feb 2 14:10:34 1989 UTC (35 years, 4 months ago) by greg
Fixed SCCSid
1 /* Copyright 1988 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 CLOSEST - nearest-color lookup by locally ordered search
9 we use distance in rgb space as color metric
10
11 fillbucket subroutine makes trimmed, sorted lists of
12 possible closest colors to speed the closest searching.
13 About 6 times faster than exhaustive.
14
15 Paul Heckbert
16 */
17
18 #include "ciq.h"
19
20 #define inf 3*256*256
21 #define key ((r&0xe0)<<1|(g&0xe0)>>2|(b&0xe0)>>5) /* hash key: rrrgggbbb */
22
23 static struct thing {int mindist,pv;} space[512*257],*next=space,*bucket[512];
24 /* sorted lists of colors */
25
26 static int nfill=0,tests=0,calls=0;
27 static char filled[512]; /* has bucket[key] been filled yet? */
28 static int sq[511];
29
30 initialize() { /* reset the buckets */
31 int k;
32 nfill = tests = calls = 0;
33 for (k=0; k<512; k++) filled[k] = 0;
34 next = space;
35 }
36
37 closest(r,g,b) /* find pv of colormap color closest to (r,g,b) */
38 int r,g,b;
39 {
40 register struct thing *p;
41 register int *rsq,*gsq,*bsq,dist,min,best;
42 struct thing *p0;
43
44 if (!filled[key]) fillbucket(key);
45 min = inf;
46 rsq = sq+255-r;
47 gsq = sq+255-g;
48 bsq = sq+255-b;
49
50 /* stop looking when best is closer than next could be */
51 for (p0=p=bucket[key]; min>p->mindist; p++) {
52 dist = rsq[color[0][p->pv]] + gsq[color[1][p->pv]] +
53 bsq[color[2][p->pv]];
54 if (dist<min) {
55 best = p->pv;
56 min = dist;
57 }
58 }
59 tests += p-p0;
60 calls++;
61 return best;
62 }
63
64 #define H 16 /* half-width of a bucket */
65
66 compare(a,b)
67 register struct thing *a,*b;
68 {
69 return a->mindist-b->mindist;
70 }
71
72 fillbucket(k) /* make list of colormap colors which could be closest */
73 int k; /* matches for colors in bucket #k */
74 {
75 register int r,g,b,j,dist,*rsq,*gsq,*bsq,min,best;
76 struct thing *p,*q;
77
78 if (!sq[0]) for (j= -255; j<256; j++) sq[j+255] = j*j;
79
80 r = k>>1&0xe0|H; /* center of 32x32x32 cubical bucket */
81 g = k<<2&0xe0|H;
82 b = k<<5&0xe0|H;
83 rsq = sq+255-r;
84 gsq = sq+255-g;
85 bsq = sq+255-b;
86 bucket[k] = p = next;
87 min = inf;
88
89 for (j=0; j<n; j++, p++) {
90 p->pv = j;
91 dist = 0; /* compute distance from cube surface */
92 if (color[0][j]< r-H) dist += rsq[color[0][j]+H];
93 else if (color[0][j]>=r+H) dist += rsq[color[0][j]-H+1];
94 if (color[1][j]< g-H) dist += gsq[color[1][j]+H];
95 else if (color[1][j]>=g+H) dist += gsq[color[1][j]-H+1];
96 if (color[2][j]< b-H) dist += bsq[color[2][j]+H];
97 else if (color[2][j]>=b+H) dist += bsq[color[2][j]-H+1];
98 p->mindist = dist; /* for termination test in closest */
99 dist = rsq[color[0][j]]+gsq[color[1][j]]+bsq[color[2][j]];
100 if (dist<min) { /* find color closest to cube center */
101 best = j;
102 min = dist;
103 }
104 }
105
106 dist = rsq[color[0][best]+(color[0][best]<r?1-H:H)] +
107 gsq[color[1][best]+(color[1][best]<g?1-H:H)] +
108 bsq[color[2][best]+(color[2][best]<b?1-H:H)];
109 /* dist is an upper bound on mindist: maximum possible distance */
110 /* between a color in the bucket and its nearest neighbor */
111
112 /* eliminate colors which couldn't be closest */
113 for (p=q=next, j=0; j<n; j++, p++)
114 if (p->mindist<dist) {
115 q->mindist = p->mindist;
116 q->pv = p->pv;
117 q++;
118 }
119 if (q<=next) fprintf(stderr,"ERROR: empty bucket!\n");
120
121 /* and sort the list by mindist */
122 qsort(next,q-next,sizeof(struct thing),compare);
123 q->mindist = inf; /* list terminator */
124 next = q+1;
125 filled[k] = 1;
126 nfill++;
127 }
128
129 /*endclosest() {
130 printf("filled %d buckets, averaging %d colors per list, %d of which were tested\n",
131 nfill,(next-space-nfill)/nfill,tests/calls);
132 }*/
