root/radiance/ray/src/px/closest.c
Revision: 2.5
Committed: Mon Nov 8 18:49:18 2004 UTC (20 years, 6 months ago) by greg
State: FILE REMOVED
Removed unused modules I missed last time
2 static const char RCSid[] = "$Id: closest.c,v 2.4 2004/03/28 20:33:13 schorsch Exp $";
5 CLOSEST - nearest-color lookup by locally ordered search
6 we use distance in rgb space as color metric
7
8 fillbucket subroutine makes trimmed, sorted lists of
9 possible closest colors to speed the closest searching.
10 About 6 times faster than exhaustive.
11
12 Paul Heckbert
13 */
14
15 #include <stdlib.h>
16
17 #include "ciq.h"
18
19 #define inf 3*256*256
20 #define key(r,g,b) (((r)&0xe0)<<1|((g)&0xe0)>>2|((b)&0xe0)>>5)
21 /* 9-bit hash key: rrrgggbbb */
22
23 static struct thing {int mindist,pv;} space[512*257],*next,*bucket[512];
24 /* sorted lists of colors */
25
26 static int nfill,tests,calls;
27 static char filled[512]; /* has bucket[key] been filled yet? */
28 static int sq[511];
29
30 static int compare(const void *a, const void *b);
31 static void fillbucket(int k);
32
33
34 void
35 initializeclosest(void) { /* reset the buckets */
36 int k;
37 nfill = tests = calls = 0;
38 for (k=0; k<512; k++) filled[k] = 0;
39 next = space;
40 }
41
42 int
43 closest( /* find pv of colormap color closest to (r,g,b) */
44 int r,
45 int g,
46 int b
47 )
48 {
49 register struct thing *p;
50 register int *rsq,*gsq,*bsq,dist,min;
51 int best,k;
52 struct thing *p0;
53
54 k = key(r,g,b);
55 if (!filled[k]) fillbucket(k);
56 min = inf;
57 rsq = sq+255-r;
58 gsq = sq+255-g;
59 bsq = sq+255-b;
60
61 /* stop looking when best is closer than next could be */
62 for (p0=p=bucket[k]; min>p->mindist; p++) {
63 dist = rsq[color[0][p->pv]] + gsq[color[1][p->pv]] +
64 bsq[color[2][p->pv]];
65 if (dist<min) {
66 best = p->pv;
67 min = dist;
68 }
69 }
70 tests += p-p0;
71 calls++;
72 return best;
73 }
74
75 #define H 16 /* half-width of a bucket */
76
77 static int
78 compare(
79 const void *a,
80 const void *b
81 )
82 {
83 return ((struct thing*)a)->mindist - ((struct thing*)b)->mindist;
84 }
85
86 static void
87 fillbucket( /* make list of colormap colors which could be closest */
88 int k /* matches for colors in bucket #k */
89 )
90 {
91 register int r,g,b,j,dist,*rsq,*gsq,*bsq,min,best;
92 struct thing *p,*q;
93
94 if (!sq[0]) for (j= -255; j<256; j++) sq[j+255] = j*j;
95
96 r = (k>>1&0xe0)|H; /* center of 32x32x32 cubical bucket */
97 g = (k<<2&0xe0)|H;
98 b = (k<<5&0xe0)|H;
99 rsq = sq+255-r;
100 gsq = sq+255-g;
101 bsq = sq+255-b;
102 bucket[k] = p = next;
103 min = inf;
104
105 for (j=0; j<n; j++, p++) {
106 p->pv = j;
107 dist = 0; /* compute distance from cube surface */
108 if (color[0][j]< r-H) dist += rsq[color[0][j]+H];
109 else if (color[0][j]>=r+H) dist += rsq[color[0][j]-H+1];
110 if (color[1][j]< g-H) dist += gsq[color[1][j]+H];
111 else if (color[1][j]>=g+H) dist += gsq[color[1][j]-H+1];
112 if (color[2][j]< b-H) dist += bsq[color[2][j]+H];
113 else if (color[2][j]>=b+H) dist += bsq[color[2][j]-H+1];
114 p->mindist = dist; /* for termination test in closest */
115 dist = rsq[color[0][j]]+gsq[color[1][j]]+bsq[color[2][j]];
116 if (dist<min) { /* find color closest to cube center */
117 best = j;
118 min = dist;
119 }
120 }
121
122 dist = rsq[color[0][best]+(color[0][best]<r?1-H:H)] +
123 gsq[color[1][best]+(color[1][best]<g?1-H:H)] +
124 bsq[color[2][best]+(color[2][best]<b?1-H:H)];
125 /* dist is an upper bound on mindist: maximum possible distance */
126 /* between a color in the bucket and its nearest neighbor */
127
128 /* eliminate colors which couldn't be closest */
129 for (p=q=next, j=0; j<n; j++, p++)
130 if (p->mindist<dist) {
131 q->mindist = p->mindist;
132 q->pv = p->pv;
133 q++;
134 }
135 if (q<=next) fprintf(stderr,"ERROR: empty bucket!\n");
136
137 /* and sort the list by mindist */
138 qsort(next,q-next,sizeof(struct thing),compare);
139 q->mindist = inf; /* list terminator */
140 next = q+1;
141 filled[k] = 1;
142 nfill++;
143 }
144
145 /*endclosest() {
146 printf("filled %d buckets, averaging %d colors per list, %d of which were tested\n",
147 nfill,(next-space-nfill)/nfill,tests/calls);
148 }*/
