root/radiance/ray/src/px/ciq.c
Sun Mar 28 20:33:13 2004 UTC (20 years ago) by schorsch
Changes since 2.4: +31 -15 lines
Mon Jun 30 14:59:12 2003 UTC (20 years, 9 months ago) by schorsch
Changes since 2.3: +5 -3 lines
Tue May 13 17:58:33 2003 UTC (20 years, 11 months ago) by greg
Changes since 2.1: +7 -10 lines
Diff to previous 2.1
Tue Nov 12 16:04:10 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 1.6
Tue Dec 4 11:25:45 1990 UTC (33 years, 4 months ago) by greg
Changes since 1.5: +1 -0 lines
Diff to previous 1.5
added standard.h to take care of bcopy() incompatibilities
Thu Jan 18 23:58:14 1990 UTC (34 years, 3 months ago) by greg
Diff to previous 1.4
Fri Apr 7 16:36:12 1989 UTC (35 years ago) by ph
Changes since 1.3: +14 -3 lines
Diff to previous 1.3
ciq() now calls initializeclosest() fixing a bug, also error clamping
Fri Apr 7 13:30:09 1989 UTC (35 years ago) by greg
Changes since 1.2: +3 -0 lines
Diff to previous 1.2
initialize histogram in makehist()
Thu Feb 2 14:10:33 1989 UTC (35 years, 2 months ago) by greg
Diff to previous 1.1
Fixed SCCSid
Thu Feb 2 10:49:08 1989 UTC (35 years, 2 months ago) by greg
