1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
5 |
* aedimage.c - RADIANCE driver for AED 512 terminal. |
6 |
7 |
* 3/20/86 |
8 |
* 3/3/88 Added calls to Paul Heckbert's ciq routines |
9 |
10 |
11 |
#include <stdio.h> |
12 |
13 |
#include <math.h> |
14 |
15 |
#include <signal.h> |
16 |
17 |
#include <sys/ioctl.h> |
18 |
19 |
#include "pic.h" |
20 |
21 |
#include "color.h" |
22 |
23 |
24 |
/* AED command characters */ |
25 |
26 |
#define AEDFMT "1888N" /* Format string to send to AED */ |
27 |
#define CSTAT 0100 /* Console status: lower case */ |
28 |
#define SCS 96 /* Set Console Status */ |
29 |
#define SCT 75 /* Set color lookup table */ |
30 |
#define SEC 67 /* Set color for vector drawing */ |
31 |
#define MOV 81 /* Set CAP (current access pointer) to x, y */ |
32 |
#define MVR 105 /* Set CAP relative */ |
33 |
#define DVA 65 /* Draw vector to new CAP x, y */ |
34 |
#define DVR 108 /* Draw vector relative */ |
35 |
#define WHS 88 /* Write horizontal scan */ |
36 |
#define WHR 92 /* Write horizontal runs */ |
37 |
#define OPT 40 /* Miscellaneous terminal control */ |
38 |
#define SEN 71 /* Set encoding types */ |
39 |
#define RST 48 /* Reset terminal */ |
40 |
#define FFD 12 /* Clear screen */ |
41 |
#define SCS 96 /* Set status */ |
42 |
#define DAI 114 /* Define area of interest */ |
43 |
#define EJC 85 /* Enable Joystick cursor positioning */ |
44 |
#define DJC 100 /* Disable Joystick cursor positioning */ |
45 |
#define SCC 99 /* Set Cursor Colors */ |
46 |
#define SCP 93 /* Set Cursor Parameters */ |
47 |
#define RCP 106 /* Read Cursor Position */ |
48 |
#define MAXRLEN 255 /* Maximum runlength for a span */ |
49 |
#define NUL 0 /* Null terminates run sequences */ |
50 |
#define ESC 27 /* Escape starts a command sequence */ |
51 |
#define END 1 /* Ctrl-A used to terminate command mode */ |
52 |
53 |
#define BLK 0 /* color table entry for black */ |
54 |
#define WHT 7 /* color table entry for white */ |
55 |
56 |
#define command(c) (putc(ESC, stdout), putc(c, stdout)) |
57 |
#define byte(b) putc(b, stdout) |
58 |
#define flush() fflush(stdout) |
59 |
60 |
#define GAMMA 2.5 /* gamma value used in correction */ |
61 |
62 |
#define MINCOLOR 8 /* start of device color table */ |
63 |
64 |
#define NCOLORS 248 /* available color table size */ |
65 |
66 |
#define NROWS 512 /* maximum # rows for output */ |
67 |
#define NCOLS 512 /* maximum # columns for output */ |
68 |
69 |
int dither = 0; /* dither colors? */ |
70 |
71 |
int greyscale = 0; /* grey only? */ |
72 |
73 |
int initialized = 0; |
74 |
struct sgttyb oldflags; |
75 |
int oldlmode; |
76 |
77 |
int intrcnt = 0; /* interrupt well */ |
78 |
79 |
#define disintr() (intrcnt--) /* disable interrupts */ |
80 |
#define enaintr() onintr() /* enable interrupts */ |
81 |
82 |
char *progname; |
83 |
84 |
char errmsg[128]; |
85 |
86 |
COLR scanline[NCOLS]; |
87 |
88 |
colormap colrtbl; |
89 |
90 |
int cury; |
91 |
92 |
int xmax, ymax; |
93 |
94 |
FILE *fin; |
95 |
96 |
extern long ftell(); |
97 |
long scanpos[NROWS]; |
98 |
99 |
double exposure = 1.0; |
100 |
int wrong_fmt = 0; |
101 |
102 |
103 |
main(argc, argv) |
104 |
int argc; |
105 |
char *argv[]; |
106 |
107 |
int onintr(), checkhead(); |
108 |
char sbuf[256]; |
109 |
register int i; |
110 |
111 |
progname = argv[0]; |
112 |
113 |
#ifdef SIGTSTP |
114 |
signal(SIGTSTP, SIG_IGN); |
115 |
#endif |
116 |
if (signal(SIGINT, onintr) == SIG_IGN) |
117 |
signal(SIGINT, SIG_IGN); |
118 |
119 |
for (i = 1; i < argc; i++) |
120 |
if (argv[i][0] == '-') |
121 |
switch (argv[i][1]) { |
122 |
case 'd': |
123 |
dither = !dither; |
124 |
break; |
125 |
case 'b': |
126 |
greyscale = !greyscale; |
127 |
break; |
128 |
default: |
129 |
goto userr; |
130 |
131 |
else |
132 |
break; |
133 |
134 |
if (i+1 != argc) |
135 |
goto userr; |
136 |
137 |
if ((fin = fopen(argv[i], "r")) == NULL) { |
138 |
sprintf(errmsg, "can't open file \"%s\"", argv[i]); |
139 |
quitmsg(errmsg); |
140 |
141 |
/* get header */ |
142 |
getheader(fin, checkhead, NULL); |
143 |
if (wrong_fmt) |
144 |
quitmsg("input must be a Radiance picture"); |
145 |
/* get picture dimensions */ |
146 |
if (fgetresolu(&xmax, &ymax, fin) < 0) |
147 |
quitmsg("bad picture size"); |
148 |
if (xmax > NCOLS || ymax > NROWS) |
149 |
quitmsg("resolution mismatch"); |
150 |
151 |
init(); /* initialize terminal for output */ |
152 |
153 |
for (i = 0; i < NROWS; i++) |
154 |
scanpos[i] = -1; |
155 |
156 |
if (greyscale) /* map colors and display */ |
157 |
biq(dither,NCOLORS,1,colrtbl); |
158 |
else |
159 |
ciq(dither,NCOLORS,1,colrtbl); |
160 |
161 |
loopcom(); |
162 |
163 |
quitmsg(NULL); |
164 |
userr: |
165 |
fprintf(stderr, "Usage: %s [-d][-b] input\n", progname); |
166 |
quit(1); |
167 |
168 |
169 |
170 |
int |
171 |
checkhead(line) /* deal with line from header */ |
172 |
char *line; |
173 |
174 |
char fmt[32]; |
175 |
176 |
if (isexpos(line)) |
177 |
exposure *= exposval(line); |
178 |
else if (isformat(line)) { |
179 |
formatval(fmt, line); |
180 |
wrong_fmt = strcmp(fmt, COLRFMT); |
181 |
182 |
return(0); |
183 |
184 |
185 |
186 |
init() /* initialize terminal */ |
187 |
188 |
struct sgttyb flags; |
189 |
int lmode; |
190 |
191 |
if (isatty(1)) { |
192 |
/* Set literal mode so AED gets bit 8 */ |
193 |
ioctl(1, TIOCLGET, &oldlmode); |
194 |
lmode = oldlmode | LLITOUT | LNOFLSH; |
195 |
ioctl(1, TIOCLSET, &lmode); |
196 |
ioctl(1, TIOCLGET, &lmode); /* 4.2 bug */ |
197 |
/* Turn terminal echoing off */ |
198 |
ioctl(1, TIOCGETP, &oldflags); |
199 |
ioctl(1, TIOCGETP, &flags); |
200 |
flags.sg_flags &= ~ECHO; |
201 |
ioctl(1, TIOCSETP, &flags); |
202 |
initialized = 1; |
203 |
} else |
204 |
quitmsg("output must be to a terminal"); |
205 |
206 |
/* Reset AED and tell it the data format */ |
207 |
command(RST); |
208 |
longwait(2); |
209 |
command(OPT); |
210 |
byte(6); byte(1); /* AED command set */ |
211 |
command(SEN); fputs(AEDFMT, stdout); |
212 |
command(SCS); byte(CSTAT); /* console status */ |
213 |
command(FFD); /* clear screen */ |
214 |
flush(); |
215 |
216 |
217 |
218 |
onintr() /* die gracefully */ |
219 |
220 |
if (++intrcnt > 0) |
221 |
quitmsg("interrupt"); |
222 |
223 |
224 |
225 |
quitmsg(err) /* uninitialize terminal and exit */ |
226 |
char *err; |
227 |
228 |
if (initialized) { /* close AED */ |
229 |
command(DJC); /* disable cursor */ |
230 |
command(SEC); |
231 |
byte(WHT); /* Set color to white */ |
232 |
aedsetcap(0, 0); /* Put cursor in a good place */ |
233 |
byte(END); |
234 |
flush(); |
235 |
ioctl(1, TIOCSETP, &oldflags); |
236 |
ioctl(1, TIOCLSET, &oldlmode); |
237 |
putchar('\n'); |
238 |
239 |
if (err != NULL) { |
240 |
fprintf(stderr, "%s: %s\n", progname, err); |
241 |
exit(1); |
242 |
243 |
exit(0); |
244 |
245 |
246 |
247 |
void |
248 |
eputs(s) |
249 |
char *s; |
250 |
251 |
fputs(s, stderr); |
252 |
253 |
254 |
255 |
void |
256 |
quit(status) |
257 |
int status; |
258 |
259 |
quitmsg(status ? "aborted" : NULL); |
260 |
261 |
262 |
263 |
loopcom() /* print pixel values interactively */ |
264 |
265 |
int coffset[3]; /* color table offset */ |
266 |
267 |
COLOR cval, ctmp; |
268 |
int rept, x, y, j; |
269 |
register int com, i; |
270 |
/* Set raw mode on input */ |
271 |
ioctl(0, TIOCGETP, &flags); |
272 |
flags.sg_flags |= RAW; |
273 |
274 |
ioctl(0, TIOCSETP, &flags); |
275 |
276 |
coffset[0] = coffset[1] = coffset[2] = 0; |
277 |
/* set cursor type */ |
278 |
command(SCC); |
279 |
byte(BLK); byte(WHT); byte(15); |
280 |
command(SCP); |
281 |
byte('+'); byte(0); byte(1); |
282 |
/* loop on command */ |
283 |
for ( ; ; ) { |
284 |
command(EJC); /* enable cursor */ |
285 |
flush(); |
286 |
rept = 0; /* get command */ |
287 |
while ((com = getc(stdin)) >= '0' && com <= '9') |
288 |
rept = rept*10 + com - '0'; |
289 |
if (rept == 0) rept = 1; |
290 |
291 |
switch (com) { |
292 |
case '\r': |
293 |
case '\n': |
294 |
case 'l': |
295 |
case 'L': |
296 |
case 'c': |
297 |
case 'C': |
298 |
case 'p': |
299 |
case 'P': |
300 |
case '=': |
301 |
aedgetcap(&x, &y); /* get cursor position */ |
302 |
y = ymax-1-y; |
303 |
if (y < 0 || scanpos[y] == -1) /* off picture? */ |
304 |
break; |
305 |
/* get value */ |
306 |
setcolor(cval, 0.0, 0.0, 0.0); |
307 |
for (j = rept-1; j >= 0; j--) { |
308 |
if (y+j >= NROWS || scanpos[y+j] == -1) |
309 |
continue; |
310 |
getscan(y+j); |
311 |
for (i = 0; i < rept; i++) |
312 |
if (x+i < xmax) { |
313 |
colr_color(ctmp, scanline[x+i]); |
314 |
addcolor(cval, ctmp); |
315 |
316 |
317 |
scalecolor(cval, 1.0/(rept*rept)); |
318 |
/* print value */ |
319 |
command(SEC); |
320 |
byte(scanline[(x+20)%xmax][EXP] >= COLXS ? BLK : WHT); |
321 |
byte(END); |
322 |
switch (com) { |
323 |
case '\r': |
324 |
case '\n': |
325 |
printf("%-3g", intens(cval)/exposure); |
326 |
break; |
327 |
case 'l': |
328 |
case 'L': |
329 |
printf("%-3gL", luminance(cval)/exposure); |
330 |
break; |
331 |
case 'c': |
332 |
case 'C': |
333 |
printf("(%.2f,%.2f,%.2f)", |
334 |
colval(cval,RED), |
335 |
colval(cval,GRN), |
336 |
colval(cval,BLU)); |
337 |
break; |
338 |
case 'p': |
339 |
case 'P': |
340 |
printf("(%d,%d)", x, y); |
341 |
break; |
342 |
case '=': |
343 |
printf("(%d,%d,%d)", coffset[0], |
344 |
coffset[1], coffset[2]); |
345 |
break; |
346 |
347 |
break; |
348 |
case 'w': |
349 |
rept = -rept; |
350 |
case 'W': |
351 |
coffset[0] += rept; |
352 |
coffset[1] += rept; |
353 |
coffset[2] += rept; |
354 |
movecolor(coffset); |
355 |
break; |
356 |
case 'r': |
357 |
rept = -rept; |
358 |
case 'R': |
359 |
360 |
361 |
break; |
362 |
case 'g': |
363 |
rept = -rept; |
364 |
case 'G': |
365 |
366 |
367 |
break; |
368 |
case 'b': |
369 |
rept = -rept; |
370 |
case 'B': |
371 |
372 |
373 |
break; |
374 |
case '!': |
375 |
376 |
377 |
break; |
378 |
case 'C'-'@': |
379 |
case 'q': |
380 |
case 'Q': |
381 |
return; |
382 |
383 |
384 |
385 |
386 |
387 |
getscan(y) |
388 |
int y; |
389 |
390 |
if (y != cury) { |
391 |
if (scanpos[y] == -1) |
392 |
quitmsg("cannot seek in getscan"); |
393 |
if (fseek(fin, scanpos[y], 0) == -1) |
394 |
quitmsg("fseek error"); |
395 |
cury = y; |
396 |
} else |
397 |
scanpos[y] = ftell(fin); |
398 |
399 |
if (freadcolrs(scanline, xmax, fin) < 0) |
400 |
quitmsg("read error"); |
401 |
402 |
cury++; |
403 |
404 |
405 |
406 |
picreadline3(y, l3) /* read in 3-byte scanline */ |
407 |
int y; |
408 |
register rgbpixel *l3; |
409 |
410 |
register int i; |
411 |
/* read scanline */ |
412 |
getscan(y); |
413 |
/* convert scanline */ |
414 |
normcolrs(scanline, xmax, 0); |
415 |
for (i = 0; i < xmax; i++) { |
416 |
l3[i].r = scanline[i][RED]; |
417 |
l3[i].g = scanline[i][GRN]; |
418 |
l3[i].b = scanline[i][BLU]; |
419 |
420 |
421 |
422 |
423 |
picwriteline(y, l) /* output scan line of pixel values */ |
424 |
int y; |
425 |
register pixel *l; |
426 |
427 |
int curpix; |
428 |
register int n, ncols; |
429 |
430 |
disintr(); /* disable interrupts */ |
431 |
aedsetcap(0, ymax-1-y); |
432 |
command(DAI); |
433 |
aedcoord(xmax-1, ymax-1-y); |
434 |
ncols = xmax; |
435 |
if (dither) { /* pixel run lengths short */ |
436 |
command(WHS); |
437 |
while (ncols-- > 0) |
438 |
byte(MINCOLOR + *l++); |
439 |
} else { /* pixel run lengths long */ |
440 |
command(WHR); |
441 |
while (ncols-- > 0) { |
442 |
curpix = *l++; |
443 |
for (n = 1; n < MAXRLEN; n++) { |
444 |
if (ncols <= 0 || *l != curpix) |
445 |
break; |
446 |
l++; ncols--; |
447 |
448 |
byte(n); |
449 |
byte(MINCOLOR + curpix); |
450 |
451 |
byte(NUL); |
452 |
453 |
flush(); |
454 |
enaintr(); /* enable interrupts */ |
455 |
456 |
457 |
458 |
459 |
* aedsetcap - sets AED's current access pointer to (x, y). Used |
460 |
* before writing a span to put it in the right place. |
461 |
462 |
463 |
aedsetcap(x, y) |
464 |
register int x, y; |
465 |
466 |
command(MOV); |
467 |
aedcoord(x, y); |
468 |
469 |
470 |
471 |
* aedcoord - puts out an (x, y) coordinate in AED 8 bit format. |
472 |
473 |
474 |
aedcoord(x, y) |
475 |
476 |
477 |
putc(((x >> 4) & 0x30) | ((y >> 8) & 0x3), stdout); |
478 |
putc(x & 0xff, stdout); |
479 |
putc(y & 0xff, stdout); |
480 |
481 |
482 |
483 |
aedgetcap(xp, yp) /* get cursor postion */ |
484 |
int *xp, *yp; |
485 |
486 |
register int c; |
487 |
/* get cursor postition */ |
488 |
command(RCP); |
489 |
flush(); |
490 |
c = getc(stdin); |
491 |
*xp = (c & 0x30) << 4; |
492 |
*yp = (c & 0x3) << 8; |
493 |
*xp |= getc(stdin); |
494 |
*yp |= getc(stdin); |
495 |
496 |
497 |
498 |
movecolor(offset) /* move our color table up or down */ |
499 |
int offset[3]; |
500 |
501 |
register int i, j, c; |
502 |
503 |
disintr(); |
504 |
command(SCT); |
505 |
byte(MINCOLOR); |
506 |
byte(NCOLORS); |
507 |
for (i = 0; i < NCOLORS; i++) |
508 |
for (j = 0; j < 3; j++) { |
509 |
c = colrtbl[j][i] + offset[j]; |
510 |
if (c < 0) |
511 |
byte(0); |
512 |
else if (c > 255) |
513 |
byte(255); |
514 |
else |
515 |
byte(c); |
516 |
517 |
shortwait(20); |
518 |
enaintr(); |
519 |
520 |
521 |
522 |
picreadcm(map) /* do gamma correction */ |
523 |
colormap map; |
524 |
525 |
register int i, val; |
526 |
527 |
for (i = 0; i < 256; i++) { |
528 |
val = pow((i+0.5)/256.0, 1.0/GAMMA) * 256.0; |
529 |
map[0][i] = map[1][i] = map[2][i] = val; |
530 |
531 |
532 |
533 |
534 |
picwritecm(map) /* write out color map */ |
535 |
colormap map; |
536 |
537 |
register int i, j; |
538 |
539 |
disintr(); |
540 |
command(SCT); |
541 |
byte(MINCOLOR); |
542 |
byte(NCOLORS); |
543 |
544 |
for (j = 0; j < 3; j++) |
545 |
byte(map[j][i]); |
546 |
shortwait(20); |
547 |
enaintr(); |
548 |
549 |
550 |
551 |
longwait(t) /* longer wait */ |
552 |
int t; |
553 |
554 |
flush(); |
555 |
sleep(t); |
556 |
557 |
558 |
559 |
shortwait(t) /* shorter wait */ |
560 |
int t; |
561 |
562 |
register long l = t*1000; |
563 |
564 |
flush(); |
565 |
while (l--) |
566 |
567 |
