| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: aedimage.c,v 2.6 2004/01/02 12:47:01 schorsch Exp $";
| 3 |
#endif
| 4 |
| 5 |
* aedimage.c - RADIANCE driver for AED 512 terminal.
| 6 |
| 7 |
* 3/20/86
| 8 |
* 3/3/88 Added calls to Paul Heckbert's ciq routines
| 9 |
| 10 |
| 11 |
#include <stdio.h>
| 12 |
#include <math.h>
| 13 |
#include <signal.h>
| 14 |
#include <sys/ioctl.h>
| 15 |
| 16 |
#include "pic.h"
| 17 |
#include "resolu.h"
| 18 |
#include "color.h"
| 19 |
| 20 |
| 21 |
/* AED command characters */
| 22 |
| 23 |
#define AEDFMT "1888N" /* Format string to send to AED */
| 24 |
#define CSTAT 0100 /* Console status: lower case */
| 25 |
#define SCS 96 /* Set Console Status */
| 26 |
#define SCT 75 /* Set color lookup table */
| 27 |
#define SEC 67 /* Set color for vector drawing */
| 28 |
#define MOV 81 /* Set CAP (current access pointer) to x, y */
| 29 |
#define MVR 105 /* Set CAP relative */
| 30 |
#define DVA 65 /* Draw vector to new CAP x, y */
| 31 |
#define DVR 108 /* Draw vector relative */
| 32 |
#define WHS 88 /* Write horizontal scan */
| 33 |
#define WHR 92 /* Write horizontal runs */
| 34 |
#define OPT 40 /* Miscellaneous terminal control */
| 35 |
#define SEN 71 /* Set encoding types */
| 36 |
#define RST 48 /* Reset terminal */
| 37 |
#define FFD 12 /* Clear screen */
| 38 |
#define SCS 96 /* Set status */
| 39 |
#define DAI 114 /* Define area of interest */
| 40 |
#define EJC 85 /* Enable Joystick cursor positioning */
| 41 |
#define DJC 100 /* Disable Joystick cursor positioning */
| 42 |
#define SCC 99 /* Set Cursor Colors */
| 43 |
#define SCP 93 /* Set Cursor Parameters */
| 44 |
#define RCP 106 /* Read Cursor Position */
| 45 |
#define MAXRLEN 255 /* Maximum runlength for a span */
| 46 |
#define NUL 0 /* Null terminates run sequences */
| 47 |
#define ESC 27 /* Escape starts a command sequence */
| 48 |
#define END 1 /* Ctrl-A used to terminate command mode */
| 49 |
| 50 |
#define BLK 0 /* color table entry for black */
| 51 |
#define WHT 7 /* color table entry for white */
| 52 |
| 53 |
#define command(c) (putc(ESC, stdout), putc(c, stdout))
| 54 |
#define byte(b) putc(b, stdout)
| 55 |
#define flush() fflush(stdout)
| 56 |
| 57 |
#define GAMMA 2.5 /* gamma value used in correction */
| 58 |
| 59 |
#define MINCOLOR 8 /* start of device color table */
| 60 |
| 61 |
#define NCOLORS 248 /* available color table size */
| 62 |
| 63 |
#define NROWS 512 /* maximum # rows for output */
| 64 |
#define NCOLS 512 /* maximum # columns for output */
| 65 |
| 66 |
int dither = 0; /* dither colors? */
| 67 |
| 68 |
int greyscale = 0; /* grey only? */
| 69 |
| 70 |
int initialized = 0;
| 71 |
struct sgttyb oldflags;
| 72 |
int oldlmode;
| 73 |
| 74 |
int intrcnt = 0; /* interrupt well */
| 75 |
| 76 |
#define disintr() (intrcnt--) /* disable interrupts */
| 77 |
#define enaintr() onintr() /* enable interrupts */
| 78 |
| 79 |
char *progname;
| 80 |
| 81 |
char errmsg[128];
| 82 |
| 83 |
COLR scanline[NCOLS];
| 84 |
| 85 |
colormap colrtbl;
| 86 |
| 87 |
int cury;
| 88 |
| 89 |
int xmax, ymax;
| 90 |
| 91 |
FILE *fin;
| 92 |
| 93 |
extern long ftell();
| 94 |
long scanpos[NROWS];
| 95 |
| 96 |
double exposure = 1.0;
| 97 |
int wrong_fmt = 0;
| 98 |
| 99 |
static gethfunc checkhead;
| 100 |
| 101 |
| 102 |
main(argc, argv)
| 103 |
int argc;
| 104 |
char *argv[];
| 105 |
| 106 |
int onintr();
| 107 |
char sbuf[256];
| 108 |
register int i;
| 109 |
| 110 |
progname = argv[0];
| 111 |
| 112 |
#ifdef SIGTSTP
| 113 |
signal(SIGTSTP, SIG_IGN);
| 114 |
#endif
| 115 |
if (signal(SIGINT, onintr) == SIG_IGN)
| 116 |
signal(SIGINT, SIG_IGN);
| 117 |
| 118 |
for (i = 1; i < argc; i++)
| 119 |
if (argv[i][0] == '-')
| 120 |
switch (argv[i][1]) {
| 121 |
case 'd':
| 122 |
dither = !dither;
| 123 |
break;
| 124 |
case 'b':
| 125 |
greyscale = !greyscale;
| 126 |
break;
| 127 |
default:
| 128 |
goto userr;
| 129 |
| 130 |
else
| 131 |
break;
| 132 |
| 133 |
if (i+1 != argc)
| 134 |
goto userr;
| 135 |
| 136 |
if ((fin = fopen(argv[i], "r")) == NULL) {
| 137 |
sprintf(errmsg, "can't open file \"%s\"", argv[i]);
| 138 |
quitmsg(errmsg);
| 139 |
| 140 |
/* get header */
| 141 |
getheader(fin, checkhead, NULL);
| 142 |
if (wrong_fmt)
| 143 |
quitmsg("input must be a Radiance picture");
| 144 |
/* get picture dimensions */
| 145 |
if (fgetresolu(&xmax, &ymax, fin) < 0)
| 146 |
quitmsg("bad picture size");
| 147 |
if (xmax > NCOLS || ymax > NROWS)
| 148 |
quitmsg("resolution mismatch");
| 149 |
| 150 |
init(); /* initialize terminal for output */
| 151 |
| 152 |
for (i = 0; i < NROWS; i++)
| 153 |
scanpos[i] = -1;
| 154 |
| 155 |
if (greyscale) /* map colors and display */
| 156 |
biq(dither,NCOLORS,1,colrtbl);
| 157 |
else
| 158 |
ciq(dither,NCOLORS,1,colrtbl);
| 159 |
| 160 |
loopcom();
| 161 |
| 162 |
quitmsg(NULL);
| 163 |
userr:
| 164 |
fprintf(stderr, "Usage: %s [-d][-b] input\n", progname);
| 165 |
quit(1);
| 166 |
| 167 |
| 168 |
| 169 |
static int
| 170 |
checkhead( /* deal with line from header */
| 171 |
char *line,
| 172 |
void *p
| 173 |
| 174 |
| 175 |
char fmt[32];
| 176 |
| 177 |
if (isexpos(line))
| 178 |
exposure *= exposval(line);
| 179 |
else if (isformat(line)) {
| 180 |
formatval(fmt, line);
| 181 |
wrong_fmt = strcmp(fmt, COLRFMT);
| 182 |
| 183 |
return(0);
| 184 |
| 185 |
| 186 |
| 187 |
init() /* initialize terminal */
| 188 |
| 189 |
struct sgttyb flags;
| 190 |
int lmode;
| 191 |
| 192 |
if (isatty(1)) {
| 193 |
/* Set literal mode so AED gets bit 8 */
| 194 |
ioctl(1, TIOCLGET, &oldlmode);
| 195 |
lmode = oldlmode | LLITOUT | LNOFLSH;
| 196 |
ioctl(1, TIOCLSET, &lmode);
| 197 |
ioctl(1, TIOCLGET, &lmode); /* 4.2 bug */
| 198 |
/* Turn terminal echoing off */
| 199 |
ioctl(1, TIOCGETP, &oldflags);
| 200 |
ioctl(1, TIOCGETP, &flags);
| 201 |
flags.sg_flags &= ~ECHO;
| 202 |
ioctl(1, TIOCSETP, &flags);
| 203 |
initialized = 1;
| 204 |
} else
| 205 |
quitmsg("output must be to a terminal");
| 206 |
| 207 |
/* Reset AED and tell it the data format */
| 208 |
command(RST);
| 209 |
longwait(2);
| 210 |
command(OPT);
| 211 |
byte(6); byte(1); /* AED command set */
| 212 |
command(SEN); fputs(AEDFMT, stdout);
| 213 |
command(SCS); byte(CSTAT); /* console status */
| 214 |
command(FFD); /* clear screen */
| 215 |
flush();
| 216 |
| 217 |
| 218 |
| 219 |
onintr() /* die gracefully */
| 220 |
| 221 |
if (++intrcnt > 0)
| 222 |
quitmsg("interrupt");
| 223 |
| 224 |
| 225 |
| 226 |
quitmsg(err) /* uninitialize terminal and exit */
| 227 |
char *err;
| 228 |
| 229 |
if (initialized) { /* close AED */
| 230 |
command(DJC); /* disable cursor */
| 231 |
command(SEC);
| 232 |
byte(WHT); /* Set color to white */
| 233 |
aedsetcap(0, 0); /* Put cursor in a good place */
| 234 |
byte(END);
| 235 |
flush();
| 236 |
ioctl(1, TIOCSETP, &oldflags);
| 237 |
ioctl(1, TIOCLSET, &oldlmode);
| 238 |
putchar('\n');
| 239 |
| 240 |
if (err != NULL) {
| 241 |
fprintf(stderr, "%s: %s\n", progname, err);
| 242 |
exit(1);
| 243 |
| 244 |
exit(0);
| 245 |
| 246 |
| 247 |
| 248 |
void
| 249 |
eputs(s)
| 250 |
char *s;
| 251 |
| 252 |
fputs(s, stderr);
| 253 |
| 254 |
| 255 |
| 256 |
void
| 257 |
quit(status)
| 258 |
int status;
| 259 |
| 260 |
quitmsg(status ? "aborted" : NULL);
| 261 |
| 262 |
| 263 |
| 264 |
loopcom() /* print pixel values interactively */
| 265 |
| 266 |
int coffset[3]; /* color table offset */
| 267 |
| 268 |
COLOR cval, ctmp;
| 269 |
int rept, x, y, j;
| 270 |
register int com, i;
| 271 |
/* Set raw mode on input */
| 272 |
ioctl(0, TIOCGETP, &flags);
| 273 |
flags.sg_flags |= RAW;
| 274 |
| 275 |
ioctl(0, TIOCSETP, &flags);
| 276 |
| 277 |
coffset[0] = coffset[1] = coffset[2] = 0;
| 278 |
/* set cursor type */
| 279 |
command(SCC);
| 280 |
byte(BLK); byte(WHT); byte(15);
| 281 |
command(SCP);
| 282 |
byte('+'); byte(0); byte(1);
| 283 |
/* loop on command */
| 284 |
for ( ; ; ) {
| 285 |
command(EJC); /* enable cursor */
| 286 |
flush();
| 287 |
rept = 0; /* get command */
| 288 |
while ((com = getc(stdin)) >= '0' && com <= '9')
| 289 |
rept = rept*10 + com - '0';
| 290 |
if (rept == 0) rept = 1;
| 291 |
| 292 |
switch (com) {
| 293 |
case '\r':
| 294 |
case '\n':
| 295 |
case 'l':
| 296 |
case 'L':
| 297 |
case 'c':
| 298 |
case 'C':
| 299 |
case 'p':
| 300 |
case 'P':
| 301 |
case '=':
| 302 |
aedgetcap(&x, &y); /* get cursor position */
| 303 |
y = ymax-1-y;
| 304 |
if (y < 0 || scanpos[y] == -1) /* off picture? */
| 305 |
break;
| 306 |
/* get value */
| 307 |
setcolor(cval, 0.0, 0.0, 0.0);
| 308 |
for (j = rept-1; j >= 0; j--) {
| 309 |
if (y+j >= NROWS || scanpos[y+j] == -1)
| 310 |
continue;
| 311 |
getscan(y+j);
| 312 |
for (i = 0; i < rept; i++)
| 313 |
if (x+i < xmax) {
| 314 |
colr_color(ctmp, scanline[x+i]);
| 315 |
addcolor(cval, ctmp);
| 316 |
| 317 |
| 318 |
scalecolor(cval, 1.0/(rept*rept));
| 319 |
/* print value */
| 320 |
command(SEC);
| 321 |
byte(scanline[(x+20)%xmax][EXP] >= COLXS ? BLK : WHT);
| 322 |
byte(END);
| 323 |
switch (com) {
| 324 |
case '\r':
| 325 |
case '\n':
| 326 |
printf("%-3g", intens(cval)/exposure);
| 327 |
break;
| 328 |
case 'l':
| 329 |
case 'L':
| 330 |
printf("%-3gL", luminance(cval)/exposure);
| 331 |
break;
| 332 |
case 'c':
| 333 |
case 'C':
| 334 |
printf("(%.2f,%.2f,%.2f)",
| 335 |
colval(cval,RED),
| 336 |
colval(cval,GRN),
| 337 |
colval(cval,BLU));
| 338 |
break;
| 339 |
case 'p':
| 340 |
case 'P':
| 341 |
printf("(%d,%d)", x, y);
| 342 |
break;
| 343 |
case '=':
| 344 |
printf("(%d,%d,%d)", coffset[0],
| 345 |
coffset[1], coffset[2]);
| 346 |
break;
| 347 |
| 348 |
break;
| 349 |
case 'w':
| 350 |
rept = -rept;
| 351 |
case 'W':
| 352 |
coffset[0] += rept;
| 353 |
coffset[1] += rept;
| 354 |
coffset[2] += rept;
| 355 |
movecolor(coffset);
| 356 |
break;
| 357 |
case 'r':
| 358 |
rept = -rept;
| 359 |
case 'R':
| 360 |
coffset[0] += rept;
| 361 |
movecolor(coffset);
| 362 |
break;
| 363 |
case 'g':
| 364 |
rept = -rept;
| 365 |
case 'G':
| 366 |
coffset[1] += rept;
| 367 |
movecolor(coffset);
| 368 |
break;
| 369 |
case 'b':
| 370 |
rept = -rept;
| 371 |
case 'B':
| 372 |
coffset[2] += rept;
| 373 |
movecolor(coffset);
| 374 |
break;
| 375 |
case '!':
| 376 |
| 377 |
movecolor(coffset);
| 378 |
break;
| 379 |
case 'C'-'@':
| 380 |
case 'q':
| 381 |
case 'Q':
| 382 |
return;
| 383 |
| 384 |
| 385 |
| 386 |
| 387 |
| 388 |
getscan(y)
| 389 |
int y;
| 390 |
| 391 |
if (y != cury) {
| 392 |
if (scanpos[y] == -1)
| 393 |
quitmsg("cannot seek in getscan");
| 394 |
if (fseek(fin, scanpos[y], 0) == -1)
| 395 |
quitmsg("fseek error");
| 396 |
cury = y;
| 397 |
} else
| 398 |
scanpos[y] = ftell(fin);
| 399 |
| 400 |
if (freadcolrs(scanline, xmax, fin) < 0)
| 401 |
quitmsg("read error");
| 402 |
| 403 |
cury++;
| 404 |
| 405 |
| 406 |
| 407 |
picreadline3(y, l3) /* read in 3-byte scanline */
| 408 |
int y;
| 409 |
register rgbpixel *l3;
| 410 |
| 411 |
register int i;
| 412 |
/* read scanline */
| 413 |
getscan(y);
| 414 |
/* convert scanline */
| 415 |
normcolrs(scanline, xmax, 0);
| 416 |
for (i = 0; i < xmax; i++) {
| 417 |
l3[i].r = scanline[i][RED];
| 418 |
l3[i].g = scanline[i][GRN];
| 419 |
l3[i].b = scanline[i][BLU];
| 420 |
| 421 |
| 422 |
| 423 |
| 424 |
picwriteline(y, l) /* output scan line of pixel values */
| 425 |
int y;
| 426 |
register pixel *l;
| 427 |
| 428 |
int curpix;
| 429 |
register int n, ncols;
| 430 |
| 431 |
disintr(); /* disable interrupts */
| 432 |
aedsetcap(0, ymax-1-y);
| 433 |
command(DAI);
| 434 |
aedcoord(xmax-1, ymax-1-y);
| 435 |
ncols = xmax;
| 436 |
if (dither) { /* pixel run lengths short */
| 437 |
command(WHS);
| 438 |
while (ncols-- > 0)
| 439 |
byte(MINCOLOR + *l++);
| 440 |
} else { /* pixel run lengths long */
| 441 |
command(WHR);
| 442 |
while (ncols-- > 0) {
| 443 |
curpix = *l++;
| 444 |
for (n = 1; n < MAXRLEN; n++) {
| 445 |
if (ncols <= 0 || *l != curpix)
| 446 |
break;
| 447 |
l++; ncols--;
| 448 |
| 449 |
byte(n);
| 450 |
byte(MINCOLOR + curpix);
| 451 |
| 452 |
byte(NUL);
| 453 |
| 454 |
flush();
| 455 |
enaintr(); /* enable interrupts */
| 456 |
| 457 |
| 458 |
| 459 |
| 460 |
* aedsetcap - sets AED's current access pointer to (x, y). Used
| 461 |
* before writing a span to put it in the right place.
| 462 |
| 463 |
| 464 |
aedsetcap(x, y)
| 465 |
register int x, y;
| 466 |
| 467 |
command(MOV);
| 468 |
aedcoord(x, y);
| 469 |
| 470 |
| 471 |
| 472 |
* aedcoord - puts out an (x, y) coordinate in AED 8 bit format.
| 473 |
| 474 |
| 475 |
aedcoord(x, y)
| 476 |
register int x, y;
| 477 |
| 478 |
putc(((x >> 4) & 0x30) | ((y >> 8) & 0x3), stdout);
| 479 |
putc(x & 0xff, stdout);
| 480 |
putc(y & 0xff, stdout);
| 481 |
| 482 |
| 483 |
| 484 |
aedgetcap(xp, yp) /* get cursor postion */
| 485 |
int *xp, *yp;
| 486 |
| 487 |
register int c;
| 488 |
/* get cursor postition */
| 489 |
command(RCP);
| 490 |
flush();
| 491 |
c = getc(stdin);
| 492 |
*xp = (c & 0x30) << 4;
| 493 |
*yp = (c & 0x3) << 8;
| 494 |
*xp |= getc(stdin);
| 495 |
*yp |= getc(stdin);
| 496 |
| 497 |
| 498 |
| 499 |
movecolor(offset) /* move our color table up or down */
| 500 |
int offset[3];
| 501 |
| 502 |
register int i, j, c;
| 503 |
| 504 |
disintr();
| 505 |
command(SCT);
| 506 |
byte(MINCOLOR);
| 507 |
byte(NCOLORS);
| 508 |
for (i = 0; i < NCOLORS; i++)
| 509 |
for (j = 0; j < 3; j++) {
| 510 |
c = colrtbl[j][i] + offset[j];
| 511 |
if (c < 0)
| 512 |
byte(0);
| 513 |
else if (c > 255)
| 514 |
byte(255);
| 515 |
else
| 516 |
byte(c);
| 517 |
| 518 |
shortwait(20);
| 519 |
enaintr();
| 520 |
| 521 |
| 522 |
| 523 |
picreadcm(map) /* do gamma correction */
| 524 |
colormap map;
| 525 |
| 526 |
register int i, val;
| 527 |
| 528 |
for (i = 0; i < 256; i++) {
| 529 |
val = pow((i+0.5)/256.0, 1.0/GAMMA) * 256.0;
| 530 |
map[0][i] = map[1][i] = map[2][i] = val;
| 531 |
| 532 |
| 533 |
| 534 |
| 535 |
picwritecm(map) /* write out color map */
| 536 |
colormap map;
| 537 |
| 538 |
register int i, j;
| 539 |
| 540 |
disintr();
| 541 |
command(SCT);
| 542 |
byte(MINCOLOR);
| 543 |
byte(NCOLORS);
| 544 |
| 545 |
| 546 |
byte(map[j][i]);
| 547 |
shortwait(20);
| 548 |
enaintr();
| 549 |
| 550 |
| 551 |
| 552 |
longwait(t) /* longer wait */
| 553 |
int t;
| 554 |
| 555 |
flush();
| 556 |
sleep(t);
| 557 |
| 558 |
| 559 |
| 560 |
shortwait(t) /* shorter wait */
| 561 |
int t;
| 562 |
| 563 |
register long l = t*1000;
| 564 |
| 565 |
flush();
| 566 |
while (l--)
| 567 |
| 568 |
