root/radiance/ray/src/px/aedimage.c
Revision 2.7
Fri Nov 5 03:31:38 2004 UTC (20 years, 6 months ago) by greg
FILE REMOVED
Fri Jan 2 12:47:01 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 2.5: +10 -9 lines
Sat Feb 22 02:07:27 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.4: +3 -4 lines
Tue Oct 27 09:08:25 1998 UTC (26 years, 6 months ago) by gwlarson
Fri Oct 2 16:21:47 1992 UTC (32 years, 7 months ago) by greg
Thu Dec 19 14:51:44 1991 UTC (33 years, 4 months ago) by greg
Diff to previous 2.1
Tue Nov 12 16:05:36 1991 UTC (33 years, 5 months ago) by greg
Diff to previous 1.11
Mon Nov 11 14:38:48 1991 UTC (33 years, 5 months ago) by greg
Diff to previous 1.10
changed call to fgetresolu()
Thu Apr 18 14:35:03 1991 UTC (34 years ago) by greg
Changes since 1.9: +10 -1 lines
Diff to previous 1.9
Mon Mar 18 09:35:01 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.8
added luminance() macro to color.h
Wed Nov 7 13:10:27 1990 UTC (34 years, 6 months ago) by greg
Diff to previous 1.7
minor improvement in gamma correction
Fri Jan 26 08:17:29 1990 UTC (35 years, 3 months ago) by greg
Diff to previous 1.6
Fri Jan 5 17:52:49 1990 UTC (35 years, 4 months ago) by greg
Diff to previous 1.5
changed EXPOSURE information interface
Fri Oct 20 20:35:57 1989 UTC (35 years, 6 months ago) by greg
Changes since 1.4: +7 -26 lines
Diff to previous 1.4
change to color normalization calls
Fri Sep 15 09:10:24 1989 UTC (35 years, 7 months ago) by greg
Changes since 1.3: +10 -6 lines
Diff to previous 1.3
added call to getheader in aedimage
Tue Sep 12 13:04:16 1989 UTC (35 years, 7 months ago) by greg
Changes since 1.2: +1 -2 lines
Diff to previous 1.2
Fri Mar 10 10:20:07 1989 UTC (36 years, 2 months ago) by greg
New gamma
Thu Feb 2 10:49:04 1989 UTC (36 years, 3 months ago) by greg
